View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Civic/Crx si block???
- CEL then overheating
- need torque specs on b16 head, cam journals
- Need a part for rear sway bar
- need pics of rear sway bar installed.
- what header for a DOHC ZC in a 1991 Civic Si?
- Question on starter! quick question
- B16a Idles high!!
- need a quick response before leaving.. will 94+integra rear shocks fit 91 civic dx rear?
- ASAP Big Problem
- Im going cheap, Im going pacesetter! lol
- Messed up fuel pressure (gen 1 b16)
- will a 90-93 console fit in my car??
- Exedy Vs. ACT
- What will i need to use this?
- Window Roller/ door panel question
- Anyone with a Si......and a ZC intake mani laying around?????
- Another Break Problem
- need a zc distributor
- Spoiler Question
- powdercoat or not to powdercoat ??
- i need a JDM CRX front end.....
- Just bought a CRX with b16, what should i look for?
- My second project car has begun!!
- 1gen header Q?
- Y8 head on a a6 block!
- SiR conversion...
- A weird question about my tranny
- Will i now start breaking axles???? a bit concerned.
- AZ differential shims...
- front bumper and resonator removal
- 4-1 Header in a 4g civic?
- Headliner
- Dumb Question.
- d16y7 on to a 90dx
- rear sway bar question..
- over heating problem someone please help asap..
- Where do i get a b16a throtle body gasket ?
- Zdyne Gold Timming + fuel question.
- Is Atomic Performance still around?
- How to get the cig. lighter out?!?
- sohc timing issue
- need help in jersey
- Mini Me Timing - HELP!!
- Water in my headlights, how do I get it out?
- Fuel pressure should be???? Modded B16 w/ DSM 450cc Injectors
- Last call for CRXPO=Large West Coast CRX Meet
- pre-obd to obd1
- Jenny Craig
- Weapon R coilover question...
- y8 head
- EF spring rate/Ride height
- b16 cost
- What's the best reclinable Racing Seat for a CRX?
- Devin17 u ripped off the wrong chick!! AND ever one will know about it
- Help: 91 Si distributor work in a B16 Dist.???
- whoa.. check this dope ish out
- First Gen CRX getting no love?
- what is the best compression for nitrous
- i need stock exhaust piping from the cat back anyone have it?
- How hard is it to replace the starter on a 90 crx?
- Throttle cable reblacement for 90 CRX w/ JDM b16-a
- ECI & dizzy question , need help now!! mech just called....
- Where to find head gasket
- Car won`t start, no spark: most likely culprit?
- Time slip difference between stock B20 vs stock B18c1
- Tranny grinding in rev???
- axels
- front bumper warped???
- Making the interior of 91 CRX amber
- I need a new seat/ or seats, help me out
- timing won`t set right??????!!!!!!
- Any Maryland people? Baltimore/Harford?
- Stupid CRX Project
- my brake warning light stays on (on dash), what can it be?
- Is this just a bolt on?
- B16A Dyno Results
- Crx Si distributor interchangable?????
- b16 wiring??
- 87 crx si...should i buy??? (pics)
- Emissions testing
- please help......different dizzy connetions????
- si Head
- zc engine with integra ecu throwing code
- racing fuel and OCTANE
- labor cost
- FREE crx body!!!
- problem with rear disc swap...need help
- what should my Kyokugen Lugnuts be torqued to?
- si Swap regarding intake manifold
- anybody else done this before?
- lowering a 1st gen rex
- bent frame?
- mugen ecu reprogrammed
- B16a tranny???
- 4 Wire Oxygen Sensor with OBD-0 ?
- how loud????
- Muffler Question
- b16a swap into EF hb question
- Hi, I'm the new guy
- ecu
- Change to z6 manfold on a preobd sohc vtec swap
- Some questions about b18a's?!?!?!
- timing belt replacement steps
- muffler question
- where do I connect a tachometer in my civic engine compartment?
- Model of distributor
- where can i find a mount kit with shift linkage
- Where can i pull vaccum for on B16 ???
- Are HF and Si headers the same?
- Rear Suspension Questions
- mini me help!!
- CEL code 7 on PG7. TPS?
- body repair - need information on how
- Missing the point
- Sport Compact Nationals, Norwalk Raceway in Ohio
- Japanese SiR owners!!
- o2 Sensor robbing performance???
- Lookin' for that link...
- Need some pictures on how to route intercooler piping...
- suggestions on my gutted interior...
- Hydraulic Tran. Mount Pic & Rough Conv. Guide
- why cant you...
- 1st GEN Q? 2
- 1st GEN Q?
- D16z6 Swap
- Motor Decisions........
- after market intake manifold for z6 (tried searching under every combo possable?)
- Guage cluster lights
- is there a code 1 ??????????
- seatbelt recall, car running like crap and which oil filter? 3 in 1 question doozy!
- Fluctuating Idle on Stock 89 CRX Si
- how to fix radiator supporter?
- whats my car worth?
- b and d seires throttle body size...
- does anyone wanna make some money that lives in jersey?
- vss on ys1.. I'm confused about p/s lines.
- 88-89 taillights to 90-91 tail lights (tried search)
- DSM Injectors in B16A
- Need help with starting problem ASAP!!!
- 90-91 rear crx discs & pads
- B20
- Seriously scored at the junk yard 2 day!!!
- boost problem?
- brake upgrade???
- DX to Si wiring question!!!!
- how long did you wait for HCP mounts?!
- ZC = problems, help!
- 89 HF harness 89 Si ?????wiring harness
- who put a b series motor in their crx and used stock honda mounts?
- Gas tank & N20 bottle mounting ?
- doing a rear disc swap, have a queston..
- bondo fun with your crx
- AC help with B16A swap??? HELLPPPPPPP
- Rear speaker brackets
- removing speedometer cable
- Problems with my tranny or linkage?
- Anyone know a good place to buy Stainless Still Braided Hoses.
- Cruise Control
- What kinda ECU's are you guys using?
- one piece front for crx
- check out this deal i got(tell me what ya think)
- what would a 90 si with CAI and Straight Pipe axle back exhaust run in 1/4 mile?
- Can someone do me a favor ??
- short shifter hits my exhaust?
- zc or sohc
- Whats the lowest price i should take for my hatch?
- 89 crx si A/C help
- alignment..
- 1/4 mile time with ls
- anyone with a electric oil pressure gauge
- How hard is it to convert cable to hydro???
- rought starting b16a
- head package??
- 1 quick question, size of nut, ASAP
- EF CEL with no Codes
- Rust issues on a CRX
- valve adj b16a
- whats a good suspension way to go for a 91 crx si under $500.
- d16a6 in 87 crx si???
- Does anyone know how to take of a door panel?
- whats a better intake manf. a skunk2 or a itr, for a b16
- Going to look at Civic tomorrow
- is it hard at all to install a fluidyne radiator in a 91 crx si
- Weight of ITA Civic Si
- my civic
- si to dx?? question
- brake pads
- 89 Civic rotors turned, warped worse immediatly after install?
- Problem with car, but need answers on something?
- I'm betting money Trinity locked it.
- will 89 Si seats go into an 88 SE(DX)?
- zc swap in to 91 civic si need help!!!
- md people..
- Shit! More problems with b16.....
- Head Milled or thinner Gasket?
- I've got about $400 to spend on my fuel system
- 92 Si seats in my 90 CRX HF
- How do you take the rear motor mount out of a crx!???
- what 1/4 mile times should I be running?
- type r intake manifold
- New Civic Si motor, is it possible to drop in an EF?
- d16
- whats the difference?
- Need help with B16 Crx!
- anyone with an 88 hb or crx changed rear suspension?
- Serious lightweight flywheel question.
- gsr motor, what can I put on the b16?
- MAACO supreme smart pack shoud i do it ???
- zc ticking
- kazaa people we think we are fast..
- thnx
- Zc parts
- Reducing your time without adding HP?
- July Central Ohio Civic/CRX Meet
- Does everyone else's D16a6 CRX bone out at 4000+ RPM?
- modification ideas?
- can anyone help me out?
- tell me what ya think she's worth
- Hyperblack Primax 767 wheels (look like Buddy Club P1 racing)...
- Field's VTEC controller in a CRX
- What injectors in a Mini Me????
- ys1 clutch problem
- octain on a b16a?
- Koni Yellow question.
- H&R race springs?
- I need wheel alignment, good places in NYC?
- Turbo B18B dyno numbers.......
- I need a Turn signal/Wiper switch assembly 86 Civic Wagon
- some rust from exhaust????????
- SOHC V-tec Power Q
- Rims question
- code 9??
- motor mount repair????
- How to check if ECU is good?
- suspension options
- AEM Intake + Neuspeed front strut bar
- what do you think about this color on a crx...
- Would you feel safe with only 3 lugs on one of your front wheels?
- gas line leak
- zc oil cooler bolt
- code 8 need help
- looking for
- For all of the Ohio CRXers the CRX Ohio website is back up.
- good motor f/s
- Post 1/4 mile times those of you running a D16Y8
- played out question. what shocks with GC's?
- Code 43 - Fuel Supply System??????
- Question for b16 sedan owners...
- tdc sensor?
