View Full Version : Honda CRX / EF Civic (1988 - 1991)
- interesting no crank
- Clutch Problem?? Plz Help
- Cracked Sub-Frame
- Hasport Shift Linkage
- Fuel Pump Problems someone please help!!!!
- Stock Clutch Fitment Guide
- Throttle Position Sensor
- b18b1 problem (PLEASE HELP)
- OOOOPS antifreeze in washer tank
- DC rear trailing arms
- BARO Sensor (Atmospheric Pressure)????
- Check Engine Light Problems
- Will A
- FReckin mpfi!
- problem getting car to stay running need help!!!
- what clutch do i get for my crx?
- EF EURO clusters
- what suspension would you have?
- D1B7 HELLP ASAP PLEASE
- Just picked up a wagovan need help
- Chaning 89 Hatchback d15b2 5spd DX Clutch
- leaky ys1
- just a couple quick questions.
- Valve cover question.....
- Si to HF trans conversion?
- B18A1 swap into 91 civic
- 89 si ef hatchback moldings
- ZC sohc and D16a1 sohc the same?
- AWD trans question.
- Tried searching. K swap question.
- Speedo?
- where to buy an axle back peice like this?
- Tachometer Problem
- 90+ flywheel and 88 tranny, what clutch combo?
- What crank pulleys will fit a d15b8?
- My GSR is kicking out of VTEC...ECU problem???
- what do i need to do a rear disc break to my 89 hatch back
- Air conditioning problem
- Which Header B20 in CRX?
- Need suspension torque specs please!
- WTF is this bushing thing???!!!???
- 4 Door Civic
- Does OBD0.....
- Fuel smell. Replace just o-rings or seals too.
- multiground question
- white ground wire
- Gauges all out, any suggestions?(searched)
- TEXAS IS HOTT!!
- in the market for 1988-1991 EF hatch
- Has anyone tried?
- Removing Engine but not transmission?
- IACV?
- cooling fan problem
- Help with CRX Fuel Pump!!!!
- Engine bogs at 4k RPM, I'm stuck
- dohc zc pistons
- code 14 wont go away :(
- ground for starter
- sohc supercharger help please
- seatbelt warning light wiring help
- car turns off with no cel codes.....help!!
- Having Ac in ef sedan with d16z6 swap.
- Trouble after new distributor?
- ENGINE HELP
- what shift linkage do i use d16y8
- si wiring harness
- d16y8 and d16z6!
- head light help!!! Plez!
- Engine question?????
- Junkyard Fender Flares
- PLEASE HELP..
- "Strange Civic Starting Issues"
- 91 Civic Si Foglight HELP!!!!
- Help Stop a CRX Scam
- What engine is this/which thermostat to get?
- projectors
- -----> how do i identify a d16a6 cam?
- No start!
- d16a6 + spray???
- compression test today....
- rera brake lights won't turn off!
- k20 crx
- What are the differences between alternators(obd0-obd2)
- Bought a Distributor, not sure if it's what I think
- Best engine for long hauls - Power + MPG.
- ecu problemswith my jdm b16a in my 99-00 si
- NEED HELP - UNDERDASH WIRING!
- park brake light wont turn off after motor swap
- ek full coilovers on 90 ef hatch!!!!!
- D16z6
- crx si-r cluster install
- please tell me why my tire is doing this **PIC**
- fuel pump
- How do your 89 Civic corner lights come out?
- "89 Civic Sedan Starting problems"
- rotor problem
- Are civic rails different from crx rails?
- 1991 Honda Civic Wagon Seat Belt Alarm will not stop
- Trans...
- smog...... failed miserably
- Lower Tie bar
- Cooling fan always on. Help Please
- wiring problem. . . please help
- Throttle body and FITV
- rear suspension troubles
- saving up for rebuild in august. swap or stock?
- Misfire after warmed up
- Brake Prop Valve Question
- ecu problem
- EF ZC Fuel issue, please help!
- INJECTORS?
- ls swap in 91 crx harness problems
- Newb with some questions about B18A in a 90 Civic hatch
- ys1 cable tranny help
- Big Problem HELP!
- Burning MAD oil
- wiring help
- d15b
- which axles?
- Lug Conversion
- Help Choose Wheels For Project Black N Blue...???
- Oil in exhuast!
- these supposedly 89 crx si seats with grey stitching wont bolt on my 90 crx hf ???
- will a 91 civic hb dash work in a 91 4dr ef
- Please, HELP a fellow EFer
- not so impressed with new rear sway bar?
- few questions after converted to obd1
- *would like to see ef with 0 offset wheels*
- TURN SIGNAL STAYS ON
- dohc zc valve cover
- tail light differences
- 4040 valve with stock ef ed brakes
- over reved my sohc (bent or dropped valve?)
- 94 LS motor + 91 STD chassis - harness MAP sensor
- question about a friends automovehicle..
- dohc zc
- Engine won't turn after replacing timing belt
- will 89 crx si seats bolt on my 90 crx hf?
- nitrous question
- where to buy rocker panel/ rear quarter panel repair panels???....help
- Engine Wont Run
- Strange CRX starting issue...
- ADVICE PLEASE
- cable clutch bracket
- @@@ code 17. (vss) @@@
- CRX side molding removal?
- my 91 civic si sohc vtec
- si trany problems!
- Detachable Steering Wheel
- B16 Head Gasket problem (Help)
- new 89 crx spark plug help
- Inner tie rod replacement...91 Si
- b18b1 into 91hb std
- code 9 jdm crx with an obd 1 jumper
- swap wiring screwed up
- crx- this ever happen to you?
- Did I do my valve adjustment right?
- SiR hubs... moreover...
- H23A turbo CRX
- TPS help... I searched
- installing ignition lock cylinder
- sir front bearings
- can I use a Y8 intake manifold to switch my d15b2 to multi point? thinking of doing a z6 head swap.
- Will ef9 quarter panel glass fit on my 91 civic si?
- What are the symptoms of a bad oil pump
- is it worth it to trade my da integra for an ef si with b18 ?
- Aftermarket Intake, Which ECU?
- what do i do with this block?
- battery question
- B16A Engine suspension problem popping noise
- Can i switch my D15b2 4 speed tranny to any D 5 speed??????
- vtec wire?!
- can i use a 90-93 integra intake manifold for a dpfi to mpfi swap on my dx????
- 89 crx hf????? help
- question on wat to do next to my rex????
- A question about AC removal
- Why are my climate control lights always on now?
- I need to replace my wheel studs
- Let the de-ricing begin!
- How To - Remove Honda's Doorlock Safety Feature (With Pics!)
- speedometer help plz
- pulls hard to the left
- HELP!!!!!!! B20A swap in a 89 rex
- Need Help 1989 CRX
- CRX Rev Limiter?
- b20 question
- precision turbo injectors
- autometer tach problem
- Calling all gurus
- Crx Battery
- 4speed to 5 speed swap
- what are these parts?!
- obd to obd1 dizzy plug repin
- Hey El Vap133... B16 in civic?
- Anyone try putting EG side skirts on a EF Hatch??
- A/C problem after swap
- what bumper is this?! not ef9, USDM, 88-89, or bodykit
- chipping JDM P72?
- sir bumper question from a noob
- my car is breathing????
- a/c compressor
- 35/40 vs 40/40 proportion valve
- excessive oil burning
- Need some wiring help on EDM Hazard switch
- Does this look right (potential clutch issue?)
- What 2 wires did RYWIRE swap on the engine harness connector for dizzy problem?
- Need some experienced help. Clutch sticks, hard to press, and low engagement.
- New Steering Wheel!!!
- Oil in spark plug housing/hole. HELP
- 91 si seats
- EG cluster in a EF?
- EF Civic SiR Front Hubs and DA Teggy Front Hubs!!
- minie-me timing belt
- 90 Civic D15b - CEL ON - ECU Blinks 7 Times - Bad TPS?
- What would you pay for this CRX - see pics
- pic request: 88-91 civic hatch on Drag dr27's
- CEL code #44
- auto meter shift light (please help)
- b18 rear motor mount ??
- Fuel gauge stuck on F, sending unit and gauge OK
- turn signal problem! please help
- smallest steering wheel
- My New 91 HF
- Poor Throttle response after tune up HELP PLEASE!!!
- stupid master cylinder and my brake booster
- any DIY endlinks?
- EF9
- How Many EF owners know what the "Essential Mix" is?
- Almost Ready!
- Difference between pm5 and pm9
- brake problemmmmm (please help)
- Your first mod?
- EG hub coversion need insite .....
- How much brake fluid is needed? replacing lines EF8/SiR
- map sensor, tps..... help!!!
- crx ?
- bad master cylinder or brake booster?
- Jdm b16 ecu question
- What did you do to your EF today?
- Textbook for Rebuilding Honda Civic engine D15B engine
- code 20 expirianced peeps chime in plz...
- Odd temp gauge problem.
- crx rear lip
- differences between 88-89 and 90-91 mpfi dizzys?
- surging under low rpm
- car stalled and now wont start????
- HELP
- No clutch presure
- door panel question
- d15b2 to d16z6 vacuum diagram
