View Full Version : Honda CRX / EF Civic (1988 - 1991)
- which Cometic gasket are you using?
- Help! ... My Story...
- AC Help
- Car Request
- 3 month of works.. and let me entroduce..
- oil in spark plugs #3 & #4, missing, backfiring
- shaking front end? changed both axles. Don't know where to start. Any Ideas??
- JDM EK Civic Drive Side Air Vent Pocket Question?
- fuel pump
- Wheel Stud with Bigger Splines
- New CRX project for me
- A few motor Swap questions
- Pics of hatches w/ progress springs?
- Upgrading engine
- tach, temp gauge, and fuel gauge dead
- Weird Car Starting Problem
- The effect of high boost (psi) on a motor??
- Vtec won't kick and i have a rev limit at 6500 rpms
- SiR Crank Question
- Rear spoiler?!?!?What kind???
- obd0 to obd1 help
- why is my hood crooked as hell?
- Rear engine mount ripping out of crossmember
- egr ?
- what do you think i will run
- Rear didn't lower with Coilovers?
- pg7 ecu
- 92 integra b18a into 89 crx-si help
- I want to sell my CRX but I love it so much!
- compression test ?
- what intake gasket for zc??
- d15b7 into a ed questions.
- Code 7 WTF
- ecu question
- B18C easier to drop in with front crossmember and front bulkhead off?
- Tranny rebuilt something is wrong
- 91 DX CRX ECU WIRE HARENESS
- civic good price?
- Can I remove the whole map sensor from the wall?
- Mini Me head stud question
- CRX rear interior in Civic Hatch??
- vibrating issue
- Please help...
- A6 IACV Q?
- Pls help me identify.... I'm lost
- Does the Std. Civic have a differant hub from the rest?
- engine harness
- ls in crx...... wont start??????????
- Labor of love. Check out my caged heap. 89 civic hatch SCCA car.
- does anyone know a place i can just get the coil overs springs?
- obd 0 check engine light code 2 (oxygen sensor) ANY SUGGESTIONS?
- Weird code on ECU 89 Integra LS
- Turbo Crx 2.5 Inch straightpipe exhaust...holding me back??
- EF Handling wit Bseries
- South FL CRX Part Out
- Tire siping?
- Knocking/Rattling Noise from tranny
- some weird problems... ??
- b16 swap lowering springs on 91 hb.?
- Eg UCA's on a EF??
- clutch cable too short!!! using LS though?
- possible causes of running rich please
- WTB civic exhaust for EF
- Anyone know the weight of a 4g civic hatch???
- 91 EX Sedan knuckles. Q on replacement parts
- Battery being drained
- WTB REAL SSR TYPE X RIMS
- zc, d15b vtec or b16?
- SOHC ZC non-vtec camshaft in si
- Car shut down, battery sparking and smoking....NEED HELP QUICK!!!
- Need some of your guys expertice!
- tranny problems???
- Mini me clutch cable
- crx si motor with b16 ecu
- I need help with my 90 Civic dx
- The best turbo mani for a B-series in an EF
- torque converter question
- Anybody ever use lucas oil stabilizer?
- Battery/Intake quest.
- ok i have a 88 civic it should be ef right
- Center tail light
- 3rd times a charm, zc or si?
- quick question about compatibility, do crx tailights, pass side mirror, and fender fit the hatch???
- Lights not working?
- Please help me!!!
- CRX turbo charge pipe routing, relocation of windscreen washer bottle?
- will 4dr dx hubs and knuckles work on a hatch with a b16 swap?
- help me pass emissions!!!!
- Problems with my Car (W/ Mini-Me Setup)
- Block Hone and ZC domed pistons in D16a6 or B18a1 Swap ????????
- AT what Point do i get a Non NooB status ??????????
- tail light harness -91 hatch
- B16A Question
- SMOG CHECKS!!! SMOG CHECKS!!!
- ZC Motor performance in EF?
- 90-93 integra axles in a 99si trans?
- B16 AC tips\info\brackets
- destroyed my engine
- light fly question
- how bouncy was ur car when u got it?
- crx fog light mounting
- ITR LSD into cable casing
- How to wire chipped ECU 1 wire VTEC?
- 89' Civic with B16A
- high revs
- Already search..Cel 4 on B18b swap..HELP
- tanabe exhaust for crx
- whats the redline
- Modifying 87 Crx ?
- Looking to buy an 89-91 Civic Wagon / Hatch, need opinions
- Vtec question. Not sure if oil pressure thing is needed, is it?
- Need Help
- V0lv0 Lip....Pics Inside
- HELP!
- Does anyone know what number the corner and tailight bulbs are?
- NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! on guage cluster
- Civic Si clutch cable not working w/ b16a!!
- need help sunroof glass
- help need smog test only place in socal.
- FOR SALE
- need help with friend gs-r swap.
- steering wheel shaking
- i took off my pedal and brake booster thing moved now it blows air
- peakboost
- Code 5 questions, I searched...I got no answers
- Del Sol seats in an EF? please help!
- timing fixed - different cranks?
- Hesitant Start?
- 88 clutch
- EG 8valve dizzy on a d15b2 able to work?
- crx question
- temp problem in 91 crx si
- boosted on stock internals?
- Help again!!! please.
- problems with brakes. master cylinder?
- Accelerator is Broken!!
- d16y8 into 88 crx hf?
- to the guys who made the h2b adapters/ and anyone who konws how to fab
- HELP! idle air control valve?
- A clutch for my car and a mechanic to install would be 470 $
- obd 2 motor in a obd 0 89 si
- anyone ever use sea foam on the motor/car!!! HElp!!!
- mods please bring back the for sale thread!!!
- CRX rear lights
- my ef wont start
- clutch on a 89 d16a6?
- WINDSHIELD WIPER GONE NUTS
- HELP!! No spark..........
- battery relocator kit tips on crx
- JDM OEM Part Supply
- Does anybody make a top mount turbo manifold to fit the EF civics
- IN MIDDLE OF SWAP, NEED QUICK HELP
- What the hell is up with my Spoon OBD0 Vtec controller?
- EBAY SEATS, who has them/seen them in person
- Will a b18 throttle body work on a b16?
- lsvtec+pr3's=pump gas???
- need help and parts too
- Vtec Selonoid Torque Specs?
- What Kind Of Exhaust Is This?
- crx fog lights
- i need new shocks!!!!!!!
- Loss of Tach signal.
- fog lights from a prelude
- repairing worn seats
- Ef turbo intercooler install?
- WTK: Price for B18A1
- Am i getting a good deal?
- anyone running a 255 walbro fuel pump in there EF? If so, i gotta ? for you.
- Need pinout for 0bd0 pr3 or pw0. (yes i have searched: look inside)
- SOHC ZC swap gone wrong!!!!
- 2 questions: what car should i buy of 2 i found, and what engine code is the 91 SI motor?
- Crossmember Problems: Fluidampner
- parts wanted for ls/vtec 89 civic si
- how to match the blue plastic interior
- to neone who has....
- thinking about a RHD crx
- axel Q's for b-series into 90 dx hatch
- Where to get new synchros for JDM cable tranny
- strut rod bushings
- JDM Vs. USDM front end
- $800 EF Sedan, tell me what u think
- hood problem
- b18b or b20b
- First time car pics- ED9 project build
- will this pass smog? EGR headache
- what are these clear headlight are worth ?
- YOU WILL NEVER BELIEVE THIS....
- B18A1 in a 1990 Si Rex HELP, Vacuum Lines ? ? ? Pics Inside!
- HELP!!! COOLANT LEAKING FROM EACV INTO INTAKE MANIFOLD!!!!
- Hood is stuck after i changed out for a replacement one.
- is it worth buying 86 crx?
- rust solution? come in here =)
- PLz hELP crx swap
- Good sites for rims?
- b16a tranny????
- crx how to change tranny fluid
- b18 swap
- Clouds upon Clouds of white smoke!
- Where is this water coming from
- What makes EF's so great?
- jdm front end
- MPFI swap on auto CRX - where to put transmission cable?
- Spring install advice:
- MORE HELP QUICKLY!
- Are these compression numbers good?
- Bearing clearance specs needed
- How to tell which tranny you have b16???
- HELP ME FAAAASSSSTTTT!!!!
- Vtec problem
- ► The Official "Where can I buy a engine/tranny/parts for my CRX/Civic!! ►
- whats the best place to buy a tranny for my crx?
- Ecu Codes?
- Skunk2 vs Ground Control...any experiance, clicky click!
- Axle removal alternative?
- 4 wire o2??
- Aftermarket Crossmember for CRX?
- 92-95 civic radiator in a crx?? will it fit?
- rear bumper and tail light removal?
- Doing wire tuck, where to relocate map sensor?
- Q About My 1988 honda crx??????? (150 $$)
- Body work
- need suggestions on JUST a muffler
- cant go past 3000!!!!!!!!!!!!!!
- rough idle
- help me fine motors online! ..... please
- b18a swap wiring
- the yellow-eyed monster: check engine light--code 1--the saga continues
- What rear mount bracket do I need for my B20B swap into my 88 CRX??? need help!
- H22A motor swap in a crx
- Who has b18c5 swap into CRX
- CRX Suspension/chassi autoX
- carbon lip
- help with B18 swap in 89 crx dx non mpfi
- just got this civic and it makes this sound
- no spark or fuel after wheel hop at the track. itr swapped crx.????
- Low 1/4 mile trap speed
- motor question?
- mpfi questions
- gauge cluster swap
- humiliating night
- not getting any spark
- code 10 and 14
- wat size bolt to buy ?
- eacv and iat wire colors?
- Emissions Legal b18c1 REX :P
- crx with zc
- No Spark, OBD-1 Conversion
- dohc swap in crx
- difference between 89 and 90,91 crx axles?
- need help with spark
