View Full Version : Honda CRX / EF Civic (1988 - 1991)
- OK SO WHERE DO i STAND THAN ??? (((((D15 BLOCK D16 HEAD))))))
- EF Hatch side markers
- CRX models? KY KQ etc..
- $350 Civic project
- HELP!!!!! D15 block D16 head !!!
- question about d16a6 dizzy
- Mini Me Wiring Questions??
- Cant figure out problem + solutions to past problems for those who said they had same
- D15b2 vs d16a6 head
- will it fit?
- factory ef9 manual???
- Paint Color Help.
- Window giving me trouble!
- wtb-ef hatch pass door and drivers window
- bearing noise in alternator
- radio connector crimps loose
- alternator to ecu fuel saving
- crx edm hatch wing install
- is this a cable trans?
- Question.....Need An Answer
- 91 Civic wont start....any ideas
- help engine redlined at 7000 rpms instead of 8000 rpms????
- timing belt routing
- My 89 CRX Si Cranks but wont start can any one help????
- obd0 wiring question
- Seat cover: before & after pics
- i need pictures of pass word jdm 3 point strut tower bar
- _____need help rewiring bumper and corner lights___
- i need good sites
- fuse 14????
- HELP!!!!!!!!!!!!!!!!!! BROKE MY LUGS
- 91' crx tt drag build (will make 56ks wish they were fast)
- drivers side window issues
- Im Back In!!!!!
- b16 ecu what code is it?
- 1988-1991 Civic SiR "SEDAN"?
- 16 valve d15 b8
- Pic request of you stock front bumper. Cut out or no?
- weird noise coming from driver side front..
- crx fuel pump problem
- different gauge cluster in crx
- what are some good clutch and flywheels for a crx b16a??
- Cheap Fidanza Flywheels
- question about timing
- dpfi -> mpfi question
- quick ?????
- MSD / Crane ignition with Stock Spark plug wires ?
- D-Series OBX LSD. How to tell if my tranny has 40 mm bearing?
- 1990 civic ex 4dr loud knocking...HELP!
- sir climate control
- 1990 Civic LX Won't rev passed 3500
- My Front Tires
- TPS? or IACV?
- Tranny leak
- Brake lights don't turn off
- turn lights on and no tail lights ?
- Steering Rack question
- Just another B-series question for you guys.
- how to tell if your B-series came with an automatic or manual transmission originally???/
- castle nut
- jdm crx sir parts catalog and shop manual
- Finally...
- SiR Question...
- b20 swap problems
- EF D16Y7 PROBLEMS
- Will a Wire harness out of an 91 Hatch Si work for my 88CRXsi?
- This is abram_quito1 i have fs crx psrts jdm b16 b18 type r misc parts
- si cluster question
- ef door hinge swap, what else will work?
- I HAD TO SHARE MY GOOD FORTUNE. MUST READ!
- What mounts to put D15B into EF - And other Qs
- Engine Compression test?
- ====CRX TOAD==== THIS IS ABRAM_QUITO
- how to remove ecu pins
- B16 -91 civic HEADER HELP NEEDED
- ETD Traction bars???ever try them??
- Took The Beater To The Track: y7 swap times
- Introduction and question
- anybody have good reviews of sway bars?
- b16a1 ecus
- b-series rexs (others welcome)
- gsr rexs (others welcome)
- What is this piece called?
- ??After DPFI 2 MPFI Conversion??
- Main Relay continuously shorts out.
- can i change my 1.5 dual point injeciton to a multi point injection
- best tires size for crx
- ls swap in crx?
- my small amount of rice crx build.
- wiring
- part # for VW front lip? (to fit EF sedan)
- my last ounce of hope thread
- Desperately Need Emissions Help, Failed with new Cat and New O2 Sensor
- Just bought a 91 crx, WHAT MODEL IS IT?
- Bumper installation ?
- break it down for me.....
- help? bolt that holds traction bar keeps spinning wont come loose
- SOCH ZC
- Car won't start, already checked basics, HELP
- b16 in a 4 door ef question!!//
- OBD1 LS Vtec into 91 EF Hatch Si Questions
- how much gains will you get wit a vtec controller???
- b18a1 no start???
- CRX wont start
- VTec problems
- COMPLETELY Removing oil from engine?
- a/c gurus questions please read
- B16a1 starter in d-series transmission??
- question about FITV removal
- d15b swap in 88crx si w/ p28 running rich, No CEL?
- hood latch
- Just turned over 195000 miles on my rex
- will a 1.6si tranny fit on a 1.5 motor on a 89 crx
- HELP! NEED CHEAP HP
- how many fuel injectors do i have?
- performer x?
- New Member....Wago...
- No idle+unstable rpms
- Hood dampers
- Find of the year but what trans do i have
- CRX STOLEN....
- exhaust
- 88 honda crx si wont run right
- 91 Hf Bumper Support on 91 STD.
- Weird CRX starting problems
- Crx in progress, got motor. PICS!
- from rice to nice
- 91 b18a1 into 91 civic si
- any cat-back systems offered for ef sedans?
- WTB: 1988-1991 FRONT AND REAR SIR BUMPER KITS COMPLETE
- b18a1 question
- clutch ?
- car wont run anymore.
- Has anyone replaced their fender liner?
- not burning fuel
- 1991 CIVIC DX- SWAP B16A1
- fan problems
- DC spindles on my EF!!
- need delsol b16 vacuum diagram!!!!
- Billet D-Series mounts for only $299
- idle problem and overheating
- Need help with removing intake resonator box.
- Quick Question on my 1991 civic ef
- FUEL INJECTORS SPRAYING TOO MUCH
- engine code 18
- any upgrade suggestion
- bad gas mileage in a ef??
- start up problems need help
- fuel problem that i cant figure out
- transmission????
- Question about ECU jumpers and getting bar'd in cali???
- Side mount intercooler as a radiator
- IACV code after obd1 conv
- need to know a part name
- 88 crx hf......i don't know what to do!!!!
- write up on del sol seats
- no brakes. Ahhhhh!!!!
- help me
- JDM D15B head similar to....
- New EF 600hp turbo build
- What's the difference between JDM and USDM manifolds?
- tachometer wiring question
- help.. knockin sound
- D15 injectors work in a D16A6?
- exhaust
- EF9 cluster wiring.
- DC2 Front Brakes on an EF
- what makes a crx si heavier than an hf
- jdmb16a1 swap into my '89 civic
- new cat to the crx group
- whats needed to do a jdm front end?
- codes 1 & 7??
- VTEC good at 4000 rpm or not?
- wierd over heating problem!
- Squad Rear Tow Hooks...
- raptor shift light problem
- d15b transmission question
- 91 std - no start =/
- 91 STD - No start.
- ef9 jdm BODY SHOP
- Driver Side Seat Belt
- Rear stabilizer issue ??
- D15B2 crank pulley explosion
- crx 1/4 ????
- Problems with rear mount bracket in Hatch
- Anyone running 15x7 rims with a +28mm (ish) offset?
- d15b7(non vtec) swap to d15b2
- breaks
- What do you think of this roll bar...
- jdm b16a 2nd gen
- ex front spindles on 90 hatchback
- Pulsing Idle? possible brake booster?
- Does all 88-91 CRX have power steering?
- Cousin just bought a turbo crx
- RPMs not working on EF9
- CRX, Shift Linkage, B16 cable tranny.
- Jdm Climate Control???
- 1990 civic si wiring questions help please
- hey guys
- hatch support Q:
- b16a clutch
- somseone help please
- New member here saying hi.
- maniical mystery motor miss !!!
- 1988 sedan build
- What bar is this considered? I'm pretty sure its not the C piller bar.
- would a JDM Civic HB front bumper fit a CRX with a JDM front end?
- CA Bureau of Automotive Repair (BAR, State ref'd, certified, etc.)
- pass. jdm intake
- idle and dying problem... cant check the code either...???
- where is the shift interlock located? auto to manual swap
- i have a question about my b swap
- ef civic question
- !!!!! WEIRD OVERHEATING PROBLEM !!!!!
- B16A sensor?
- Will DA mounts fit a EF with b-series?
- Stuck axle nuts?
- What year rear camber kit fits 91 hatch?
- just bought a crx today an have a ???
- code 23....but vtec still engages?
- idle problem need help (searched)
- CRX Si GSR block b16a head trades in Chicago
- Heater Core ?
- making the high beams low beams
- will the this work?
- Crack in Floor , what should i do? ... Scrap it or keep it?..
- DOHC ZC swap?
- Sorry for double posting...told to try my luck here
- fuel pump problem
- Help CRX JDM whole front end conversion?
- D15b2/z6 And A6 Sputtering In High Rpm
- ls swap question
- +++++++++JDM CRX SiR need help removing engine block paint++++++++++++++++++
- Wire tucks is it illegal for smog in Cali?
- New EF products from Hasport - hydro conversion & stock replacement mounts
- d16y8 head on d16a6 block smokes
- iacv coolant lines
- i did a search no help, car bogs
- crx problem. it just dies
- SI final drive into a DX , have ???'s
- CEL, one short blink, one second, over and over.. doing something wrong?
- side markers
- Fuel pressure problem??? help!!?
- Is it posible to ZC SOHC block with 95 SOHC VTEC head
- I DONT KNOW HOW TO CLOSE THE TRUNK?!
- MPFI, what size wire?
- engine bacy wire tuck?
- Leather seat or cloth
- a few questions
- quick question on my transmission
