View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 91 CRX will not start
- wing identification
- The beginning of my Crx build...what did I get myself into?
- Is it worth taking out the mid silencer?
- ee8 what can i do?
- Random Shutdown
- D16 build question
- HELP!!! EF1 Hatch not starting_Walbro Fuel Pump does not stop Whining
- What do you get for MPG's?
- d16z6 swap in crx no spark
- Exhaust
- b16a diff noise?
- Will 98 Accord single din cassette tape player fit in 91 Civic?
- Car isn't starting
- Blox rear lca from Civic look longer than stock ones on CRX
- Start but no run, need help please!!!
- 91 Ef LS Swap Issues
- Would O2 from EF/DA fit threads of the O2 bung of b18b1 header?
- Can 15100-P7A-013 oil pump from 99 Civic d16y8 be used on 91 crx Si d16A6?
- no spark after replacing cracked dizzy cap
- EF - Looking for front bumper where fog lights are underneath bumper lights
- Is a dx engine harness 90-91 hatch the same as a 90 crx dx?
- 91 CRX HF - Smog Fail
- Is this my O2 sensor?
- any one know what a resistor assy? for a crx?
- Help Please! Wiring Guide for Electronic Ignition Module Install (Igniter)
- Crx Door trim clips(upper and lower)
- Missing transmission radiator hose
- b16 engine harness problem!!!!!
- 88 CRX - engine harness question
- Horrendous milage in 91 Civic
- Reverse lights/Corner turning on When braking.
- DPFI to MPFI conversion - Should I use a Y7 or B2 head?
- buying a 90 crx/auto - need some advice on what to do!
- Please help:Speedo not working code 17 pic included
- Seat belt retractor question, went to Honda...
- 90 Hatch Suspension Setup - Opinions/Help?
- Coolant reservoir over filling after headgasket job.
- rant about the 89 CRX Si on Ebay now
- dashpot on 1990 civic hatch
- 1991 Civic RT4WD front end vibration
- I recently bought a 91 civic sedan
- crx si d16z6 swap, cleaning up a mess
- Sloppy shifter, everything is new.
- Trunk emblems
- CRX DX/D16a6 cranks but doesn't start after mpfi conversion...
- door stopper from sedan on crx
- Low idle/Sputter
- Broke off piece of block
- need help with swap? share yur opinions
- What springs and shocks can be used on a Civic Wagon to lower it?
- aluminum drum upgrade for ef hatch
- 88 ef sedan - Is a 90 crx front bumper a direct fit?
- OBD-0 to OBD-1 Conversion Issues
- '88 Hatch seats interchangable??
- Oil Leak!! Ontop of my manifold flange...
- Moldings/ clips
- [CRX B20v JRSC Build]
- jman's 91 lx sedan
- Help I'm getting no spark
- '90 Si Rusty Mofo
- '88 civic stays on without the key?!
- Need some help - 88 civic dx/jdm b16 swap with codes 17 and 23, sporadic VTEC
- PM3 head vs PM9 head
- 1991 ED7 Rear calipers / E-Brake uneven
- Replacing the belt for 1990 Civic Lx
- First post - I've got valve problems
- CRX Dying at idle.
- B18b1 swap with hiccup and code 3
- Build Thread - 90 hatchback dx/jdm d15b swap
- 91 ef/d16y7 swap - How fit Y8 intake if fuel line goes straight to throttle body?
- 91 Civic LX 4-Dr /MT - Will Exhaust from Chevy Cobalt fit?
- b16a slight oil leaks
- Rad fan comes on WAY late, air in the system or something worse?
- Crx Si sunroof help!!!
- Dash removal 88 si now lights don't work
- Any EF D15z1 Swaps Here?
- Where to get my parts - Is autozone or oreilly better?
- Half-Size radiator in a CRX
- Nasty exhaust tone with new exhaust, HELP FIXING IT
- L3 transmission
- dx conversion to mpfi
- 88-91 Civic OEM Mats differences (pics)
- 90 civic DX/D16Y7 swap/P06 ECU - won't start and electrical problems
- CRX Si - stalled and smoking from around exhaust manifold
- obd0 or obd1?
- 1991 ef hatch, having issues, seems to be a fuel pump.
- '90 Civic Hatch runs great when it's cold but when it warms up...
- 1990 CRX Rear Disc Swap.
- What to look for when buying a CRX?
- B20vtec won't start HELP!!!
- CRX SI B18A1 Code 8
- 88-91 CRX/EF Civic Picture & Video Thread (NO COMMENTS)
- $For Sale/Want to Buy$ - 88-91 CRX/Civic Parts Only (NO COMMENTS ALLOWED)
- s1 Cable tranny Clunking Noises
- Fresh Rebuild Wont Start. Where would you start diagnosing
- 88 rt4wd wagon, need some info about lowering
- CR-X Rear Decal Measurements or File Wanted
- Tires for my 91' Hatchback...
- ef civic. injectors not spraying????? help!
- New to Honda...looking into an older CRX...:)
- Will the carbon fiber hood from an ef hatch fit an ef sedan?
- 90 Civic LX surging, misfiring, sputtering
- 91 Civic sedan owner - interior and suspension questions
- B16 Crx shuts off, wont start again
- 89-91 sir b16a ticks
- traction bar with an engine mount
- New EF Project
- Si trans vs HF trans on 91 EF's for best MPG questions
- how to go from k-series back to d-series
- CRX B18 to much fuel - OBD0 injectors with OBD1 ECU, no resistor box
- Price check on Hybrid Crx
- Clutch Pedal Plug Help
- Front bumper sedan/hb
- Removing rear bottom seat cushion from 1989 HB Civic
- Speedometer/Odometer stopped working
- Pinout for the cabin harness connection to the rear harness (91 DX)?
- Wagovan swap question
- RUST HELP Unibody Issues
- thanks for the tech help
- Trans wont go into 2-4-R. Rhd Crx, just did a single cam swap
- b16 ef bad axle?
- Hydro/Cable Conversion, need info.
- D16Z6 back from machine shop with new parts (pics!)
- B18 swap in a 88 crx si-shift linkage question
- needahelp; sedan ef 89 lx, havin a hard time to change shift...
- with regards to carbon fiber hatches.
- heater resistor dead?
- well have had my crx for about three weeks
- Starting issue
- ?crx obd0 b16 swap?
- Hi! I'm new...looking for advice on engine swap into 91 civic DX
- Spitting flames
- lower radiator hose still cold after changing thermostat
- EF Tein S-tech on EG sedan 4dr?
- Edlebrock Performer clearance on a B
- crx steering spline coupling question.
- Official EF Antique Status Thread
- Brake booster for '90 si hatch
- What's the best flywheel for EF Si?
- Constant and Switched Source for gauges, where to tap in?
- 1990 civic zc swap
- Ed6 Walk Around
- MPFI conversion, no fuel to from injectors
- problem with swap
- 91 Civic B18B1 Code 9..Running Rich&Starting Problem ..HELP
- Could not start this morning
- EF Hasport Billet engine mount kit Installation.
- Is this car worth it?
- Rear bumper is stuck. How to get it off?
- oil in exhaust runners and coolant in oil
- New key from Honda won't turn ignition
- CRX Track Project
- Knock on start up???
- Jumpy Tach when signals on
- Vaccum question
- 0bd0 to 0db1 conversion
- another 02 cel that wont go away!
- Idle surging
- b16a1 wont start got fuel and spark
- Mpfi swap auto ex engine harness into manual dx
- school me build
- main relay problems (fuel pump primes)
- fs random civic parts
- electrical issue thats got me stumped
- Feb 1991 Honda Civic GL over heating problem
- Alternator issues
- mirror compatibility
- B series in a crx ???
- FWD Shuttle Ebrake fun in the MN snow
- EF Hasport Billet engine mount kit.
- 90 crx blown engine
- 1st Gen JDM b16a vs the usdm b16a2
- b16 ef bad main relay?
- obd0 b16 chipping to disable O2 sensors
- 91 CRX SI w/D15B VTEC keeps turning off
- civic si hatchback 3rd brake light
- EG inner tie rod ens in CRX
- Random wires on Ef7 crx (HELP!!)
- EF Civic heater blower motor not working
- Head Light Combo Switch
- looking for parts
- 91 ef hatch Hood wont open :(
- CEL - Fuel cutout - 91 EF
- difficult steering
- Re-wiring b16 battery from the front to the back
- car dies a mile before i got home.
- 1991 CRX HF Odometer
- innovative motor mounts couple question
- Gauge cluster upgrades for an 88 std?
- Installing rear wiper
- obdo b16a vtec solenoid
- 89 civic si b16a2 cranks no start
- Merry christmas fellow EF'ers
- JDM Spec S1 Cable Tranny clutch pedal squeecking
- parts search help!!!!!!!!
- 1991 Honda civic not starting all the way help
- 91 EF with sunroof
- LSD Diff On a JDM s1 Cable Tranny
- *PICS* Can I delete these A/C related relays on huge wiring harness
- 0bd0 b16a vtech solenoid gasket
- Gsr intake manifold question
- Which axles for a civic wagon
- Type of Axles that's Mostly used on a b16a swap
- B16A Head, with b18block
- Head Bolt Torque?
- My 91 Civic DX With a 1st GEN 0DB0 B16A Swap
- mini me swap and y8 intake manifold, how much hp?
- Sandy Gas Tank Questions
- Rhd EF7 Distributor plug on engine harness doesnt match new dizzy plug
- 91 crx hf misfire problems.
- Various questions from a new owner.
- dpfi to mpfi also pm5 to pr4
- 91 crx si harness question please help
- newb question!
- Why does this happen? video
- Stranded at work...again with other rex this time
- Under dash wire harness connector issues
- 88 hatch idle problems
- Plz help with dropping crx si engine into crx dx shell
- 1990 stock civic dx, idles badly, won't run.
- ef/d16-y8 mini-me - need help with wiring the harness
- First Gen B16A Thermostat Housing
- 88 civic starts then dies
- Rubbing With New Rotor/Pads
- 4 hole injectors
- 91 Hatch w/ Z6 Swap: Which OEM front torque mounts to use?
- intake manifold for mpfi swap
- 1990 honda civic wagon K24-awd build...
- What are you guys using as replacements for the front hubs?
- After cabin harness swap, can't get main relay to connect to injector resistors
- Lugs on my 91 crx to short for 08 Fit sport wheels??
- d16 build in my 88 C REX
- Hydralic Tranny Mount for EF- Check It Out
- 60a Fusible Link Blown
- B16a cv shafts installed reversed??
- 1988-1991 Civic/CRX budget front hub 4x114.3 conversion [DIY]
- crx runs and then dies while driving
- 2"/50mm Test Pipe?
- Crx dash/tail lights
- need crx ignition switch diagram plz
- ef -- where are good places to find jdm parts?
- Doch ZC Oil Filter
- Leftover after sound deadening removed
- Where to find Windshield Molding for 91 CRX
- This might be dumb but please HELP! D16a6
- Trouble with H2B CRX...wont start.
- Bisimoto V2 Header concerns
- Wont start unless I rock-er back and fourth...
- 88crx si GSR swap WIRING ISSUES HELP!!!
