View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Fix it ticket for loud exhaust.
- zc tranny?
- 89 hatch vs. 90 hatch: differences
- I need help selling my CRX...
- whats the diff between a 88-89 and a 90-91 crx
- Still Leaking Taillight
- Poblem with Sk2 intake mabnifold install
- d16 turbo
- B18B Swap into 1990 Civic (EF)
- How can i make my crx exhaust sound better?
- how to wire a S-AFC2 to ur pm6 ecu for zc motors or si motor
- Crx Shocks~~~~
- A/C Bracket From Ha sport please help
- Quick answer, need color of wires on dizzy plug
- Removal of crank belt pulley with no timing belt?
- Crx (Video)
- possible starter problem...please help
- help with identifying radiator
- search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help!
- Got a question please everyone give their input please thanks!
- Its about that time..
- help!!! noise near my timing belt area...
- pr3 ecu in crx
- what timing belt do i use on a ZC
- **Need help CRX Vs. SOHC ZC and a turbo eclipse
- 2003 EP3 Civic Si wheels on CRX????
- Skunk 2 Control arms on a ef
- CODE 5 and 10 from ECU? Whats this mean?
- Did a y8 head & manifold swap on a d16a6, which are the better injectors to use.
- i'm missing the studs on the block to help hold up the header...where can i buy these?
- crx si ecu
- Caster adjustability idea with Jimfab bar
- HELP! ! 00 civic si cluster into my 88 crx
- my clutch!@.
- motor mount inserts for d series
- h22 swap wiring 92 civic
- sohc zc info needed
- throttle body
- tranny slipping out of gear in 4th...shift linage the culprit?
- 88 crxhf
- ES Steering Rack Bushings Install....
- How Do I remove This Shift Cable From An Automatic Tranny
- 89 Honda civic dx installation of a B series Question!
- Q's on B20Vtec in a 91 crx si
- how much does a stock crx wheel wiegh?
- Valve Cover bolts?
- 90 STD hatch with 89 Hf 5spd tranny? will everything bolt up
- question on tranny\clutch\flywheel combo...
- PM7 ECU NEEDED
- CRX Shifter question
- B18A1 options
- Starting Problems....PLEASE HELP
- zc problems
- hondata stage 2 for pr3?
- 87 CRX HF question
- Any got any pics of Greddy SP2...
- Name that sound...Problem..whatever you wanna call it! vidclip inside 4mb
- new member
- clutch cable??
- High Idel in my 88'CRX B16A :wtf?:
- safc2 help
- which ignitor?
- How do I get the front bumper off????
- Civic Carb Help!
- Ls in hatch !!!
- zc ecu help!!!!!!(yes i did hours of searching)
- ingalls camber kit prob with upper control arm
- b16 cali smog
- del sol seats in a crx
- ?? BEST CRUSH BEND.. for crx or hatch
- 96 GSR dash in 89 CRX Si
- fuel pressure p[roblems
- Turbo Kit for DOHC ZC
- b16 wont start, need opinion
- Zdyne Managment Option
- If you had 6k for a engine for your crx what would you do?
- Friends EK Spark Plug Wires Got Jacked, Will CRX Spark Plug Wires work?
- Whats wrong with my engine?
- b16a swap ?
- please help
- JDM SI-R CLUSTER
- Incar videos from my B20VTEC EE8
- Door visors for CRX?
- GM Synchromesh and bad mainshaft bearing
- where the heck is that thread about honda weights???
- turbo sohc
- Inside Flooded
- will 92 (eg) rear drum setup work on 91 civic (ef)?
- Fuel Line Help?
- Turn the ignition to acc and theres this hissing sound, wont start- HELP
- retarded all and still advanced
- crx oil pressure gauge install.....did a search already
- 2gen crx over 1gen
- EF Carbon Fiber fenders
- Time to do something new...
- bday's are great
- help with d-series transmission identification!
- Where to find fenders?
- argh.. more problems with b16a, probably something stupid..
- Rebuilding a block
- how long
- installed short ram intake but problem
- Hook up for Walbro 255???
- Lets play "why doesnt my gauge cluster work?"
- front end options
- What bulb for 90 hatch corner lights?
- 88-91 Cluster wiring....need info...
- Who here with a ZC has passed Md emissions?
- SURVEY: at what rpm do you launch?
- Riddle me this HT member...
- exhaust brands
- 5 Cylinder?
- Eibach Drag Springs
- Quick wiring question (already searched)
- RIM HELP
- 5 lug ef?
- B16 MOTOR PROBLEMS, PLZ HELP
- 88-91 tansmission question
- F*'n clutch switch! how do i easily remove...
- EDM to USDM
- 89 crx ignition problem
- crx/civic body parts the same?
- Need Help with D16Z6 swap!!!!
- SOS please help with wireing
- where do they sell lower control arm bushings?
- Swaping Z6 in STD civic (88) COOLENT SENSOR??
- How can I activate vtec?
- 92-95 sohc vtec harness into 89 ef hatch ????
- Poll Ended. FS/WTB Rules Updated! [Does the EF Forum's FS/WTB thread REALLY work?]
- LS vtec timing belt?
- How to drop motor from underneath safely...anyone done this before?
- How to activate vtec with Tach w/ shift light?
- taking out tranny question?
- b16a1
- Looking for exhaust kit website.
- Normal Tranny Operation?!?
- looking for Aaron Anderson... or AIM SN ilxer0il
- 3 questions
- 1st Gen CRX - Anyone else racing?
- The EF-honda.com West Michigan Honda Meet 4 @ Gingerman Raceway July 5th 2004
- anyone have 411 on DIY P&P for D-Series Non vtec??
- TPS PROBLEM??
- fuel rail wont fit on skunk2
- What Management/ECU do you run for your boosted SOHC motors?
- mini me swap problem
- What year CRX comes with factory tint?
- I fried my engine, what should i get now? $ on the way.
- will eg lower control arms fit on ef?
- one axle a little short perhaps?
- b16 motor
- Hydro conversion - Did search
- Throtle sticking???
- HELP!!!!!
- 4 Crx's and 1 Civic on the Dyno... HMT Style **video**
- Which axles to use for J1 tranny
- wiring diagram for jdm antenna?
- Turbo Edit....Ghettodyne
- Maintanace questions
- My newest Toy
- CRX HF owners LOOK!**
- Moderator.. Please Help!
- 88-89 integra clutch on DOHC ZC/dx tranny
- Transmission is acting up! please help
- Upgrading my Ef with Eg parts.!???
- Ha, 3G CRX in Gran Turismo 4
- -> Feb. 19th <- Staring at the screen right now awaiting replies...
- what year crx engine harness is this and from what car (88-91)
- help!
- my radiator exploded today!!
- code 8 TDC
- GSR cluster questions!
- Trouble getting coilovers to seat properly on stock shocks.
- traction bar on my 88 crx????????plz help.
- D16Y7 block/crank/everything besides head...same as Y8/A6/Z6???
- 89 civic hatch with D16y7 swap
- What Aftermarket intake fits the DOHC ZC?
- Installing Racing Seats
- noob question. when does my vtec hits?
- So I broke down.....
- anyway to tell if its the alt. or just the belt?
- Anyone Have A B16a2 CRX dyno?????
- What is the Engine Code for a Crx Si block?
- increased steering response
- double bend skunk2 short shifter hits crx console?
- Why doesn't my PM6 ecu have a eeprom slot
- Don't make the same mistake I did (mono-wiper)
- any referrals for a decent priced shop on just picking up a motor?
- where to buy corners for my jdm bumper
- Fuel Injectors NEED HELP
- Motor Swap Completed
- Where to buy SPC
- ???'s about parts needs to instal coilovers
- Leaking Caliper!!!
- so.cal shops to copy a lip mold?
- what are the benefits of putting an lsd tranny on my b16crx
- Anybody done a Honda Challenge car?
- Tein?
- Will this clutch fit??
- pr3 throwing a code 15
- Need part number list for CRX D16
- Question
- B16B (LS)/B18C
- see what i just got
- how do i fix a 91 crx intake air temp., ecu code 10
- car won't start, please help.... should be easy fix.... what am i missing.
- LS Vtec swap
- Swap out (non engine)
- d15 to d15 complete!
- B18 swap axle?
- Water getting in!!
- integra interior on a crx?
- Best place online to order OEM parts overnight.
- LS Vtec?
- Name of Header Gasket?
- EG skirts on EF?
- Woo Hoo Got Skunk2 Cam gears for $119 last night on Ebay
- 90' STD HB, want to install the rear cargo cover, few questions....
- Clunking & Squeeking from rear suspension...need new bushings?
- What b series cable tranny are you guys running in your crx/ef?
- 88' civic with 93' ex motor swap question
- HELP! rear suspension problem / driver side 1" lower then passenger side (Pics)
- rattling sunroof...what should i do to fix?
- Whos got Pillar Bar in thier EF9
- ES motor mount inserts in CRX... WOW
- Need mad help and info on swap
- HAsport EFB2 kit.....where to get best price.......THANKS.
- Neuspeed front strut bars
- So my car got broken into......
- Removing and replacing rear quarter glass?
- Stupid question...
- sohc zc problem
- Powercore race Cat
- ES motor mount inserts... what are the washers for?
- Need a Rear Seat for a Civic Hatchback/CRX
- DHRacing.....
- air intake
- stumped!!
- teins basics vs any other suspension for crx
- B16 Crx Questions...
- 1gen vs 2gen crx
- What tires should wrap my rims?
- Best swap with the following parts
- radius rod bushings.. any1 replaced them??
- crx dash
- lots of collectable honda ADs and sales brochures
- 88 Crx Si Tranny Compatibility??
- DX motor with Si Cam?
- wagon hood
- questions. I need answers...please
- any aftermarket front lips for EF?
