View Full Version : Honda CRX / EF Civic (1988 - 1991)
- wtb:crx
- anyone buy from these guys?
- failed inspection
- si tranny swap
- si exaust change
- help with cusco 6 point roll cage in 99 si
- 84-87 CRX questions...
- d16z6 into crx wiring
- ecu question on swap
- CRX HKS Sport Exhaust
- Box of crap?
- 90-91 crx c pillar bar install HELP
- FS: DC 421 Ceramic HEADER, CAT, PIPING EF Civic / Crx $100 SOCAL!
- input shaft bearing question
- pics of turbo set ups????????
- everything you need to know about ZC
- turbo setup is it worth it??????
- how fast have you gone????????
- suspension sh!tty help me out..
- Fuel rail going crazy on b16 swap
- fuel injectors
- No Power!!!
- mini me on my d16a6.....
- B18b
- dx to MPFI writeup?
- FS: 15" Forged Brig Mag8's JDM engraved.....700 OBO w/ 205/50/15 cooper zeon 95% tread
- Apexi World Sport exhaust sound clip request
- LCA's on crx??? gsr's
- suspension suggestions
- Should I jump on this deal?
- Struts for The REX??????
- How can I do a seat pan swap???
- d15 to b18 swap
- Important question!!!!
- Radiator question?
- yet another B16 vacuum line ?
- is this right?
- B16a vs. B18a
- love for the EF
- Cheap Crx!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Delaware and md,nj,va
- c/f hood vs stock one (weights? civic cx)
- crx center console
- two questions about my crx
- Gutting a cat converter
- crx verse del sol (what are the up and downs)
- 5 lug
- b16 rex with jdm 4-1 itr header
- what ecu should i run
- Black Hatch on 273 in De.........question on set-up?
- Wire harness?????????????? Need help now!!!!!!
- having a problem someone help?
- crx digital clock question
- LS VTEC turbo
- am I the only one???
- Indy truck bash
- Stolen CRX in Manchester CT!!!!
- Project b18c1 88 HF, started 1-29-05 :-)
- jdm ef9 civic hb sir front end & ef8 crx sir front end?????
- *SEARCHED* EF2 Cluster Install 88 Crx Q's
- ZC motor
- the honda sign is at the top!!
- Popping The Clutch?, Causes?
- Easy way too run a SS fuel line too the engine bay?
- rev limiter for PR4 ecu?
- CRX Sunroofs? Degree of difficulty
- QUICK QUESTION?? NEED TO KNOW FIRING ORDER QUICKLY!!!!!!
- Is $695 for a sohc zc too much?
- pic request ( jdm center console)
- Swapping seat pans.
- Started the body work on my CRX street/race car...
- civic price
- Oh No, I lost something......**PIC**
- Quick axle question??
- Whats wrong with my b18a swap
- Horn Switch Question, Wire Colors, Already Searched
- do crx's have disc or drum brakes??? help fastttt please
- putting my CRX back together help!!!
- ITR swap into 89 CRX......
- Breather tank hoses for B18C
- Suspension Options For Civic Wagons?
- ZC high rev start
- CRX swap d15b 3500 RPM rev limiter
- jdm gauge cluster
- Suspension
- ???? Who makes an H22 mount kit for EF's ????
- how can i hit low 14's to 13's in the zc hatch
- fan switch question
- Best way to test alternator
- HELP PLEASE!!! DAMN PEDAL ASSEMBLY!
- AEM EMS 30-1000 for sale
- 1998 Integra sedan rear seats into 1991 Ex sedan?
- FRONT LEFT RIMS VIBRATING
- Honda Techinicians, Car wont start need guidance
- whats the difference between the jdm front end and usdm?
- SI speedo?
- can u put a vtec valve cover on non vtec
- AFC 2 help for my LS..
- clutch has two engagement points??
- where can I find more information on the Falken EF drift car?
- Sunday was a good day
- just bought a 91 lx 4 door
- Different crankshaft pulleys for D15?
- putting money into my car.. is it worth it?
- pic request
- just got paid-want to do the OBd1 swap, help me make the list!
- I hate to whine, but my car did it first!
- dumb question!
- Cam gear compatibility? Y8 gear on A6 cam
- Popping Noise From Front End When Turning Steering Wheel Side to Side?
- Valve Covers
- OBD1 injectors
- Caster Adjustments? Using 86-89 Radius Rods on My 1990 STD HB?
- zc running but very poorly
- Bumper Question
- Vibration in dash at 4th gear and up, very annoying! help
- HELP!!!!!!!!
- 4wd not working as its supposed to.
- what sterring aftermarket sterring wheel hub fit crx
- crx, quick release,hub assembly Q's (i searched)
- umm awd crx pics
- hydro clutch and cable tranny?
- 88 CRX SI rear disc brakes SPECIFIC help please.
- post CRX wallpapers
- My buddys Deuce x 2 in his rex
- brakees
- anyone in socal w/ b20block/b16head crx? post here.
- WW front bumper fog lights...
- input shaft bearing cause rpms to fall slowly?
- Help with motor swap ZC
- GSR or b16 valve cover
- ls half shaft b16trans
- 91 si hesitates/bogs/sputters at low rpm
- Please help, longest motor swap of all time!!!!!
- Q on bumper...
- Do I have to...or no?
- oil presure gauge
- i need honda center caps
- high flow
- do dizzies tend to fuck up a lot?
- Help With Wiring on b18a swap in hf
- please help i dont want to make a mistake
- fuel pressure regulator
- Swap gone WAAAYYYY wrong..!! Need help very quick
- Bad crx fuel pump OEM or Aftermanket?
- whats my civic worth?
- B18a or B18b whats the difference?
- crx body kits
- B20 swap in a 89 Si CRX having problems
- looking for best deal on mount kit
- more codes then a programer!
- Struts for the REX???
- how can i wake my b16 up???
- question what would u guys do
- Fog problems with my crx
- need to know
- CEL on, No ECU light No Fuel or Spark? Pr3
- B18a or D16z6
- Crx keeps dying ( please help)
- Gen 2 CRX front lip
- fog light install?
- wiring for obd0 to obd1 harness
- pro comp shocks for lowered civic
- what switches do you have in your car??
- is a d16a6 what is listed in the box... iwanted 2 know if it is good
- A8 Vtec Sol & B19 Knock Sens. Cut wire and connect to ECU?
- CRX Si dash in a Si Hatch??
- info about a d16
- 00' GSR brakes on 90 crx dx?... thanks!
- sohc zc head on a d15b2 questions
- Where to buy top fuel bars?
- 89 hatch start but then dies...
- Brakes are locked up help!!
- pics of your gauges
- wiring q's
- The New Paint On the EF
- OBD0 TO OBD1 CONVERSION HELP.............
- shift linkage
- EBAY FLOORMATS. (search is temp. down)
- fuel relay????
- Problems with dpfi to obd1
- my hatch will not start...HELP
- Open header for the track?
- ignition system
- question
- OBD-1 b16 into CRX
- How long is the e-brake cable on the 90/91 si?
- good philly auto shop?
- Rare EF Center console
- Boosting zc in 90 Si
- CRX HF Engine
- rpm/tach needle bouces when the car is cold....help please..
- vaccume problem need help
- Using JB Weld to fix a Crankshaft?
- exhaust
- have a question about some tire fitments......
- b16b into a crx?? anyone with it?
- stock hydro system
- Pics of any gun metal black crx's????? can any one help me out?
- CRX FOR SALE MASSACHUSETTS
- tps prob
- Bad Boots
- ZC engine build up
- does your crx do this when turning?...
- PLEASE HELP WITH UPGRADING SUSPENSION WITH B-SEIRES MOTOR ANYONE KNOW!!
- Turbo NEED HELP
- Strut Bars/Tie Bars. 88 Si Different than 89 Si? Maybe my cars WRECKED
- Stock rear sway with Ominpower Coils?? installing as i write.
- no spark.....dissy good HELP!!
- Lips? Sides?
- LOOK AT WHAT I HAVE FOUND.....
- mpfi low idle
- Resistor box part#
- Electric VSS interchangeability...
- smog legal swaps
- I bought a Hatch Linkage and It dont FIT my CRX..?
- harness helpppppppppp
- any tips before i swap civic chassis?
- neptune??? like hondata
- i was cleaning out my little storage building and found pretty much good parts left over .....
- project GsR CR-X (BAR BABY)
- ZC No start
- crx w/ls swap for 800.00?
- GAS TANK??
- Y8 on a6 head
- Gummy oil residue on spark plugs
- HELP!!!!!
- good deal, vt headlights?
- motor mounts
- CenterForce Dual Friction VS. Clutch Specialties
- firing order and #1 pos on dist
- hydro tranny to cable conversion still around???
- Can I UPGRADE my power cables?
- anyone know where to get a J's racing wing?
- looking to trade masport mounts for wheels
- ** FAQ BATTERY trunk relocation THREAD **
- Car won't start Agian. Searched. weird symptoms
- CRX 1.6 16v TURBO project
- no brake pedal pressure
- Car doesnt turnover? Battery is not dead
- Ignition Wire?!?
- Need name of gasket...
- 90 -93 teg throttle cable on gsr?
- fog lights for crx
- benefits of polishing/shot peening rods
- car smells like rotten eggs??????????
- trade my crx
- Brake Set up
- were to buy rings and berings
- integra front brakes on civic???
- part # for Jap spec VIS hood?
