View Full Version : Honda CRX / EF Civic (1988 - 1991)
- crankshaft pulley removal help
- rear disc brakes
- oil pan d15: Some questions pertaining to removal / installation
- crxs.......
- traction bar arms...torque bolts while suspension is lifted or on ground?
- Poly bushings on back but not front
- Extremly weird problem... WTF MATE?!!
- b18c type r turbo conversion....
- will h4 bulb into usdm headlamp work
- civic si
- 89 crx b16 couple problems need answering!!!!!!!
- good place 2 get internals for a b16
- GSR CRX quarter mile time question
- SOHC with PM7/P29 pistons Post your setups and times
- Difference in Y8 vs A6 intake mani?
- d16a6/d16y8 mini-me timing belt issues
- SiR Brakes on 91 Si How did I do???
- da door moldings on a ef hatch ?
- if i think it, can i build it?
- need some help
- getting B16 to 200 hp all motor.
- need help locating the IACV
- So Im getting sick of my integra....
- tranny grinding noise, could be pilot bearing?
- what to paint my crx?
- eg shell looking to get rid of for parts
- can i use b16 head studs,rod bolts on lsvtec swap
- coolant temp. sensor = will cause a no start?
- FINALLY!
- Chassis question
- quick question
- Pics Of My D16 Swap In Progress (87 CRX)
- password jdm cf intake on a crx?
- power chamber intake
- 91 crx dx throwing codes 10, 16
- Dimensions of a "stock" or K&N rectangle air filter
- d15b2////d16a6
- rt4wd civic wagon rear differential fluid
- 88-89 hatch fender fit on a 91 hatch?
- d16z6 intake manifold swap
- steering colums
- D16ZC SOHC
- Swapping in a dohc zc which harness?
- d15b2 specs????
- I am finaly buildin a new motor!!!!!
- HELP!!! problem with starter turning but not starting my car
- couple 0' problems
- Misc. CRX Questions
- cam positioning sensor code 6?
- new ED8 project *56k... doubt it*
- da-6 wrecked and driving a 1991 crx dx
- exhast
- Reverse problem w/ dx tranny
- itb's on crx
- doing a b18a swap in my 89 civic si hb.
- Which would be faster?
- Is a Fuse or Circuit Breaker Required on Battery Relocation
- Removing Rear Seat on '89 Civic Si
- RSR Exmag - Does it just bolt right up?
- help pic request!!! (SEARCHED)
- HELP: Car won't start...
- done search and still need some help
- B16a1 wont start.
- replacing the radiator support
- LS/vtec help
- crx skunk 2 exhaust pics
- My EF is Happy Now Sneak Peek :)
- need alittle help with the E-brake
- CV joint prob
- ?? 92 head on 89
- will a 90-93 integra gas tank fit a 2nd gen CRX? and vice versa
- where can i buy head stud and a few other parts from
- 160 hp sohc zc???
- crx engine help!
- HHHHHEEEEELLLLPPP
- oveheating and no cabin heat problem now leads to car not starting
- another busted climate control
- where can i find a billet cam cap? (for a dohc zc)
- need advice on fuel pump swap in progress
- HELP! Mini-Me Breaking Up Bad In High Revs
- Which year EF will my 91 accord lip fit??
- pic / vid request for hks hi power on a crx
- New Hatch shocks made my car leak!
- converting
- coolant hose problem
- radiator cracked of crx HF need HELP!!!!
- need help wiring up accord climate control to 89 crx... already searched.
- My new 4 door project Need some help.
- Car wont crank over sometimes. help. no search found.
- LTB quick release install
- Court support, compatibility for a 90 crx needed.
- DOHC ZC
- what oil gauge are you running in your car
- lsvtec swap what timing belt do i use
- question on 89 hatch standard.
- Transmission???
- Overheating Issue b16 turbo solution
- CRX si 90-91 4 wheel disc - front rotors larger?
- $8000 and you get.....
- :thumbdown: stolen crx - san diego/chula vista :thumbdown:
- Those with OBD 1 Ls Motor Swaps...Quick Question
- EF9 for sale...LMK what you think is a reasonable price
- d15 block with d16 crank, will it work?
- Code 20 ELD...converting to obd1
- Turbo Mini Me
- little help?
- Driver AXLE question/problem
- Anyone have luck with this type of power window conversion?
- Pics of my new EDM cluster
- 85 crxSI DOHC swap
- TB ?????
- ??? intake manifolds
- EF b161 mounts
- other shocks other than agx that are cheap
- which one would be faster
- d15b7 into 91 HB swap questions
- WHAT BEARINGS TO USE IN MINI ME??????
- Cluster problem...need help
- WTF
- painting interior trim pieces
- Axle Seized in the Hub
- testing your booster on a crx?
- car wont start. not getting spark?
- rear bumper issues, 56k = not good
- 1/4 time for this new setup my friend got
- manuel to power window conversion?
- tach help...pictures???
- dx swap into hf
- ef HELP 88
- OMG, this swap is killing me, need help (pics)
- CRX Axle
- wheel bearings question
- Honda Engine Block
- can autometer water temp gauge be used as an oil temp gauge?
- Question about Honda Automatic Tranny Reliability - 91 Civic Dx
- Trade
- Got a 89 CRX!!!!
- Changing my headgasket
- EF SEDAN SWAP
- Cheap A/C, who has done this mod?
- ??? SSR Lug Nuts
- civic si hatch sunroof into crx moonroof
- BAD MAIN RELAY
- Diagnose my clutch problem... ( VIDEO )
- CRX overheat, strange cold idle, no heat.
- civic ex front brakes?
- Power Windows not going down.
- CRX Swappin?
- Manual window crank removal
- ZC HEadgasket/headstuds
- HID bulb size
- Wiper Stalk Switch
- Apex'i Exhaust Control Vavle Do they work and how easy is installs?!?!?
- Proarms? what are they really ?
- still cant figure out what else i need for the mini me
- CRX Toast!
- crx b16 problems
- will eg suspension fit on a crx ?
- Odd tachometer problem.
- i have a ? about my crx conversion
- Please help me decide.
- tokico 5 way setting advice
- Walbro install in CRX, issues!
- Where is the ELD on CRX????????
- d16y8 swap
- what do you guys think of this crx
- b18a1 oil pan gasket alternatives?
- time for a new exhaust
- d15b idleing at 2k
- brakes took a dump on me
- help with the build up.......
- Exhaust question. How much better is mandrel bent? Worth it or not?
- 89 civic si starting issue
- 91 CRX SI, hatch or other
- random loud beeping sound
- LS-VTEC which piston?
- My Free 88 SI Rex
- engine wont start HELP
- Wierd stuff going on!
- Fuel Cut off switch - fuel disablers how?
- 2 point and 3 point front upper strut bars anyone interested???
- Do you recognize this brand...
- short shifter??
- please help with si door panels
- converting to obd1
- where can i buy ctr pistons and ring for my lsvtec swap stock bore
- Crappy D15b2 --_help
- Idle air control valve
- will 89 crx SI doors fit on a 89 CRX HF??
- b18b1 swap guide 89 crx
- CRX ZC head shave
- conversion wire 3 bar map sensor?
- My Oil Pressure gauge line broke pics shortly
- Mini Me Motor question...
- new swap, wont turn over :(
- RHD Conversion
- motor mount ?
- 89 hf with jdm b16 obd0 need help wont get spark
- integra engine and tranny swap questions
- Interior lighting = 194/168?
- ef HELP
- b18c1 questions
- CRX Mudguards
- H.I.D. Conversion CR-X
- Help me! Vandalism hits hard...
- are d16z6 and d16a6 interchangable???
- eg front knuckles on ef?
- CRX power door lock install
- z6 into 88 crx si
- SMOG QUESTION CALIFORNIA
- Catalytic converter?
- H22 in my 91 CRX
- Got into a wreck today :(
- want to replace my OBD 0 to OBD 1 ECU conversion harness with something better
- send feedback on h22 swaps
- send write ups on h22 swaps for civics 88-89
- Send picks of h22 swaps
- Crx gas tank into Hatch
- the new project
- question about 88-91 civic rear lip
- alternator/ starter swap
- Rebuild my d16a6 or go with a d15b?
- Front End Help...
- Si moonroof installation
- wings west kit
- K in your Rex? Keep your cluster!
- lookin for a cable tranny
- Purge cutt-off solenoid valve!!
- 92 honda head
- Head Gasket?
- 48 hour CRX rebuild - just about done!
- crank questions... need help today... going to machine shop.
- CRX With Dohc ZC......PLEASE! HELP
- Review this set up
- EF gauge cluster?
- Head Gasket help
- rear seats for crx?
- sidemolding?
- What is this called??
- engine overheated and no heat
- Ever replace a rear quarter panel?
- CRX REAR HATCH
- Fuel lines
- zc head
- need help with idle surge
- Need vacume diagram for a b18a1 in a hf crx
- 91 crx si seats in a 89 hf not bolting up....
- Buzz or spinning noise right after engine started
- im looking to go to c.m.i an need to haul ass an tring to get themost bang 4 my buck
- obd 1 b18a in 91 Civic Dx... Quick Help
