View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Instructions on taking off CRX door panel?? How?
- How big are the stock brake line nuts?
- How do you flush the brake fluid?
- how do I know if I have the y1 lsd tranny????
- What are the O2 wires color on the JDM wiring harness?
- HELP W/ wiring up VTEC
- Is there a JDM 1.6L SOHC Motor that came stock in the 88-91 Civic - same as USDM?
- Just general words to all US Honda drivers
- Biggest injetors on ZC?
- Heater fan removal on 89 CRX with AC?
- Wide wheels, tires, and offset
- std axels i need the truth
- bad motor!!!
- Gauges install. Thanks
- How much of a difference will this take?
- Peak Power of a d16a6
- Best Exhaust
- resistor box question for d16y8 injectors
- nuformz block guard
- gas milage .. why so bad?
- Does the 91 civic es have a rear swaybar?
- Auto for daily driver but want swap what to get?
- installing clutch cable
- 89 to 91 guage cluster wiring changes?
- best mod ever!
- I'm looking for $2000 winter car, what should I buy?
- Dumping fuel need HELP, please read!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- jdm crx manual, anyone seen it?
- 89 fender on 90...
- where do you get the adapter for the ST sways for an 88 crx?
- quick question
- Where/What to buy.. ZC injectors?
- ATT: Dustin
- how do i post pics?
- Front strut bar, w/ B16 swap
- any suggestions for my turning problem?
- Moroso Oil Pan for b16 - Where to buy?!
- why wont my car start?!?!?
- How to test for a bad CV joint? help....
- TCRA California Speedway Sept 21-22 *Honda-Tech Special*
- 88-89 integra intake manifold on a D16Y8?
- can anyone suggest a camber kit?
- ecu location
- ****which gauge clusters will fit in place of mine, plug and play??****
- B16a1 swap question(s)
- Urgent plz help... b16 fuel cut at 3200 rpm? why?
- Rear Strut Bar Pics please
- Help!!! Bad gas mileage
- i am in wiring hell...please help
- how to test LSD
- Swapping into an automatic?!
- LSD broke need help to repair
- Putting in a SOHC in my CRX dx need some help.
- my Windshield wipers don't work help please!
- headgasket ??????
- Quick B18b Q for a friend
- Avg. swap prices
- B18A with S1 tranny, axles, etc. for sale in So. Cali. <~~~~~~~~~
- changing studs on 88 dx HELP ASAP!!
- Car Wont Start.... need help QUICK!!!
- trans oil
- tumor
- what ET can i expect
- Cams for y8 motor...
- Slammed into a Roto-Rooter Truck...
- Where to get valve adjustment tool in town?
- Where To Find Used D16A6 Parts?
- block guard for d16 all motor
- si distributor markings?
- Where do i get a turbo adaptor for the HF manifold?
- How can i lower the front of my 1st gen crx??
- Looking for radiator resivor tank and parts..
- D16Y8 Intake Air Temp Sensor???
- will a d series ignitor work on a b series distributer??
- Cams for a turbo B16
- couple of questions for you guys...
- Almost everything you need for a sweet B16....Dial ups beware!!!
- CoilOver Spring Upside Down? Matter at all?
- what are the best cams in a b16a for going all motor
- Has anyone blown up a motor attempting the MPFI swap?
- Why are LS trannies so expensive? What else should I lok 4?
- WTB: SI harness
- Something you guys might want to see>(great project)
- 90-91 LS distributor help?
- ground wires.. best solution?
- all red tail lights
- tps and zex question..
- Alignment and wheel size
- which build up? b20 or high comp ls
- Code 43 On a p4r LS motor ??
- ZC cam angle sensor adjustment?
- Went shopping today!!!
- D15B2 vacuum lines
- Distributor bad.... Will this Work????
- How to wire the DX distributor wires to the SI
- ok. i plugged an SI computer into my DX engine and it doesnt work right.. what else do i need to cha
- Nissan Spec V vs Civic I/E/H vs RSX S
- Clutch Cable
- 88-91 Rear Stabilzer Bar
- OBD2 motor into 1989-1991 civic/crx
- dohc zc head = dohc teg head?
- SOHC Race Cam - HondaSaver
- Y8 injector question
- 4thgcivicdx-gsr
- Quick ?
- What fluid for hydrolic clutch?
- in md and need help!!!!!!!
- Mugen aero kits urethane or fiberglass?
- Direct Port Nitrous
- check engine light
- need quick answer to clutch question...
- Help!!!!
- mini me question again (to jdm ef9)
- WTF LSD tranny Bullet proof i beg to differ
- 92 sohc zc need info
- Any experience with Suspension Techniques rear sway bar?
- Which USDM model is the EDM model EE9 equivalent?
- Brospeed exhaust for my 91 CRX Si? Anyones input?
- How to time ZC DOHC?
- HELP! Mixed up ignitor wires, which ones go where?
- Has this happened to anyone?....(I doubt it)
- New Project
- After Y8 head swap..Overheats = smoke coming out from rad.
- should i do this swap part II
- Does any have a "ice box" like intake setup?
- Does ITR JRSC fit on b16 EF with HCP mounts?
- ZC motor....just throw it in...or rebuild it???
- leaking vtec solonoid/no vtec
- What does it take to make a 88-89 CRX identical to a 90-91
- EF Coilovers -- Please help guys!
- spline count on axle
- Need help guys. This is an EMERGENCY
- Trade 88-89 Crx tails for 90-91 anyone ?
- I know I wasn't supposed to... Ground Control Coilover Related
- Rev limiter on a pr3?????
- FPR question?
- When I press the horn, the *door ajar* light lights up. Any ideas?
- b18a1 questions
- SENSOR WOES. Knock sensor is bad, O2 sensors are messed up--what's the best solution?
- over reving over 8k on a b16 with a chipped ecu w/ no redline...wat can happen?
- does any body have a picture of a two tone crx?
- what kinda gains to expect from a test pipe/cat bypass ??
- just curious: $3400 to spend GSR swap or D16 12sec setup
- running z6/y8 injectors with non obd ecu
- can somebody help me???
- anobody wana post some hot ass videos!!!!!!!
- anybody run an aftermarket radiator in here
- HELP!!!!! The seat belt sensor light in the dash of my 88 CRX Si won't quit flashing and beeping!
- another amber corner post
- race seats on stock sliders???
- engine swap in the twin cities
- i need a rear bumper and sideskirts asap
- d16a6 rev limiter problems
- Mileage with B18B1 in CRX Si...
- anyone using a pr3 0r pw0 on single vtec?
- new member, some questions and requests?
- glassback or bosal resonator
- my civic is starting to stuble on acceleration? why?
- Swap info
- its almost winter and my heat sucks
- Reliable Engine Swaps?
- Engine code 6 and 17 help
- what valve cover gasket for a b16a1?
- Shipping on wheels/tires
- any one with these pics!!!
- new mod
- Fixing a broken wheel stud?
- Engine parts for sale.
- 4g help!
- where to get all red crx taillights or way to make them.....
- B16 EF guys.. What air intake?
- Need specs/info on a 4G hatch
- Some easy ground-control coilover questions
- Problem with tire hop!!!!
- mini swap
- 7k rev limiter w/ b16
- ef9 jdm bumper with factory fogs or without?
- testing waters: anyone have a WW RS front for crx FS?
- 4th gear entering the traps running a y1
- Clutch cable problems?
- Tranny Q (especially for all using hasport billet mounts with b16)
- code 17...VSS....question
- Question about ECU codes....again......
- I'm looking for a JRSC for my Bseries powered CRX.....
- tough decision - which civic do i sell?
- Should PWO ECU w. B17 be chipped?
- why does my car top out at 70mph
- Stock Throttle Body -- Size??
- Info on CR-VTEC swap
- mini me swap info on d16z6 head
- B16a swap - Oil Question
- Speaker size
- Another 5 lug conversion question?
- body shop problems - need opinions
- all about the d series
- si ecu or integra ecu
- almost done!!!!
- code 20 and screwed up gauge cluster???
- any one running 8.1 compression?
- Whats the difference between ...........
- 91 crx si harness on 88 crx si for b16 swap
- will a 99 si tranny (hydro) work on a b16a (cable)
- who makes wind deflecter for 91 crx doors
- 91 jdm b16 in 88 si driver side
- jdm zc
- B18A/CRX guys : question for ya
- upper control arm bushings
- Need diagram for cv joints on 91 civic hatch, asap!!!
- tranny question
- where can i find MUGEN exhaust!?
- swaps?
- need help with lookin at possible frame damage.
- checklist for b16a swap. suggestions please
- b-series motor mounts
- windshield wipers
- Just got my hands on a Free MUGEN ecu chip. What should I do?
- 88-91 civic 4dr handles
- the highway disaster!!
- I almost killed my honda!
- Where can I find 89 Si seats?!
- should i do this swap seriously?
- B16a SIR 2 that much better than a B16a SIR 1?
- i need a b16a reciept or some helpful advice!
- my steering wheel is shaking
- Greddy SP Exhaust
- 195/60/14 Azenis and H&R on KYB's.....Will i rub alot?
- i now hear a new chattering noise under my hood.. its near the tranny it sounds like.. what is it?
- b16A 1st gen with 88-91 civic sedan
- 90 integra LS brake booster on CRX
- Monza Exaust??
- Header Heat Shield, Leave it off?
- Eibach Pro Kit & Tokico Premiums
- best sounding exhaust for ef b16?
- Oil Filter For ZC?
- neverending zc probs: plz help
- My Intake is Finished!! ( Dupli Color Anodized Blue Paint)
- suspension install pics
- F22 from a prelude, how hard to swap?
- what exhaust do i look for?
- hks exhaust installed
- will 88 si front rotors fit a 90si ?
- Anyone know a good place to buy a ZC motor
- Wait for skunk 2 or.....
- 89Crx SI Bought to be Turboed need advice! d16z6
- lack of fast idle control solenoid valve in ZC
- Will Tenzo Rally2 seats bolt on to 91 CRX Brackets (give me some picks)
- installing front bumper - need help asap before i go see body shop
- Grant SW problem
- B series cam gears and valvetrain, in a ZC head?
- help with putting a b18a in a 90 hatch
