View Full Version : Honda CRX / EF Civic (1988 - 1991)
- getting ready to buy 10.2 fast brakes drag kit....which master cylinder?
- Rebuilding a D16A6....Cost
- Will a 2001 integra cd player fit in a crx?
- yalls opinion on my 4dr
- another 4-1 header question
- HELP>..SMOG>>REFERREE...am i screwed?
- what do you ppl think about my car
- a few b16a1 issues...looking for help.
- i need an engine harness
- dose anyone know who makes motor mount for a 88 or 91 hatch with h22
- attn: Guy Who did his Gauges Needles orange and Bulbs orange
- Changing the brakes.
- Question about d15 power
- hey im new here
- Question about Master cylinder fill cup.......
- My time slip at the track..
- syncromesh for your tranny
- 1991 Civic Std Minime (D16A6/D16Z6) Questions
- amarillo racers
- Engine codes
- ZC into 4wd wagon
- Which oil pans fit a JDM B16A?
- racing harness
- pr4
- Smaller Battery
- Hondata intake manifold gasket
- 86 hf crx and 86 crx si cv joints/zxles interchangeable?
- need help selling for my friend JDM intake
- Looking for JDM Wing
- How much is hp/tq is possible? and is it worth it?
- !wow! street imports has fast shipping
- New family member
- SMSP D16 Header Testing Results
- CRX radiator options!?
- Garage Manual
- need help with electrical vss
- DIFFERENCES IN EF CIVIC
- rear disc conversion questions..
- Safe windsheild removal?
- wires, model number or brand?
- 90-93 Integra front brake system + 90 crx hf stock HF engine hub knuckless etc. will it work?
- HF brake caliper on SI knuckle
- '91 CRX evaluation
- headlights/tailights
- 98 Integra LS cluster install into 90 CRX SI
- Cold Air Intake
- Paint Job
- yes another what clutch kit do I use question (searched)
- VTEC on 88SI
- D16A6 BOTTOM END VTEC HEAD(MINI-ME?)
- CRX Wings West spoiler has water in it. Help!
- JDM wheels anyone?
- EF with b-series swap vs MINI how would they do against each other?
- ls/vtec? or crvtec
- boosting an hf ?
- Sparco seats in a 90 Civic hatch...do i need the Sparco sliders?
- p28 ecu in ED6
- 88 DX wit MPFI , Sohc Vtec Dizzy ??????
- Bearing and Seal kit (tranny)
- supercharged D16A6 or aB18C1 in a CRX 88-91 mdl.
- Crx and Hatch Bumpers are they Interchangable?
- spoon b16b stroker kit.
- Eg front and rear brakes fit CRX?
- Help me please
- Transmission Question
- Map sensor, causing bogging?
- crx weight
- first gen crx
- 89 Crx si "stock" will not start?
- BAD IAC? OBD1 Question
- Fuel Pump Relay
- si distributor plug on zc distributor?
- running on 3 cylinders
- newby here with a couple of pics....
- crx update sorry no pictures tonight
- Need some help
- Check out my new stuff!
- need to kno replacement parts for the b16a
- Crx armrest?
- hey ppl im saling a 89si civic hatchback for 5,000
- FS:JDM Y1 LSD TRANNY, B16 FLYWHEEL, EXEDY STAGE 1 CLUTCH
- 2005 CRX
- obd1 fuel injectors
- help!!! ls swap need smog...
- jdm trivia: Name these Fog lights? ef8? ef9? ef2? help!
- Question about motor mounts on 91 si hatch
- jdm crx front
- How does the OEM armrest mount? Does it have a metal base, or just screw into the console?
- Did a swap first time
- who has a 4-1 in a crx????
- b17a1 and b16a2
- CRX w/ B18C1 -- What obd & ecu are you running??
- setting up fields hyper r
- how to ID ctr cams, if they are the real deal or not.
- 89 hatch swap question
- anyone know where i can order stock 90si gauge overlays online?
- Aftermarket Brake Calipers
- B18C1 + CRX + some tuning = better ETs.
- 95CIVIC 4DOORS
- RIMS
- What do you think about that: M3 vs. CTK
- anyone selling or know of anyone selling EF T-shirts?
- $2500. need to get to a reliable low 13 sec 1/4. no nitrous. recipes?
- CYP - Cylinder Sensor and Electrical load detector
- COMPRESSION VS VALVE ADJ
- i have a d16z6 in my hatchback will 4-1 one piece dc headers fit ?
- JDM Importer horror stories?
- i am really hatin on my shitty fart can ricer shit muffler on my car !@@1
- which u guys are running nowe for a hatch ?
- a20 crx
- 89 teg ecu or stock pm6 ecu, which would work better on my d16a6 mini me?
- Clutch Switch Bypass
- OBD0 Knock sensor questions
- would be a sick decal
- What do you keep in here?
- 89 civic shock question....
- Trouble with my car
- 1991 CRX Si shell for sale!!
- What's the favorite thing about your EF?
- Which aftermarket ECU is the best for 88-91 CRX SI
- shaved gas door?
- Crx motor swap
- EF ECU Codes
- preparing to swap a z6, which distributor?
- 90 Ef to 90 integra rotor & caliper
- need brakes for daily driver, semi-metalic or ceramic also need drums
- Clutch / flywheel
- 91 DX HB BRAKE AND SUSPENSION UPGRADE SUGESTIONS
- Removing the motor but not the tranny?
- camshaft pulley adjustment
- ef9 rear seats
- Will this work? 92-95 DX internals into a 90-91 SI trans casing??
- Dash Conversion
- Hasport mount fitment issue..
- Help me with my 88' DX. I need information/suggestions.
- Prepping for my DOHC ZC swap into my 88 dx CRX - questions
- ecu code
- crx springs
- people with d16y8 in there crx's
- New Honda enthusiast!
- car wont start
- Wanted: manifold for civic 94 si turbo
- High rpms
- Help me break open my tranny casing....
- help, track on cluster melted.
- Bad lower ball joints?
- weight of doors??
- Dohc ZC Q's
- Turbo or ls/vtec in a crx
- manifold swap question
- A/C Compressor Belt removal
- streetimports.com :thumbup: or :thumbdown:
- Crx/Civic Coilovers... Show pics please.
- Crx seats- i know...
- FAQ: Fuel Filter Banjo Bolt Socket 3/8
- engine swap
- crx going 70mph + racoon =bad day
- Please help!!
- im going to crx hell :(
- d series tranny???????
- which header would fit my LSVTEC in my EF
- Torque specs on D16a6 ??
- Haha is this really an "SiR" item?
- do i have 23 or 26 spline cv joints for a 89 Civic HB Si
- 1988 Civic Wagon weight?
- my car wont start?
- HKS BIOTCH
- d15
- need advice on tires/rims
- need to quiet my exhaust--2nd resonator or stock muffler?
- Are std's really this slow ?
- b16A
- crx hf
- what do u think of this crx
- d16a1
- jdm d15b sohc vtec timing?
- b16 crx pistons?
- need help with dpfi to mpfi
- What is EDFC?
- need help now!! mount problem?
- Driver side axle seal part no.
- si interior?
- WHAT IS MY MOTOR?!
- LSD BURNOUT GONE WRONG..i'm scared.
- REBUILT MY MOTOR NOW ONLY RUNNING ON TWO(2) CYLINDERS. :(
- Lets get a SO CAL EF meet going!..
- hf to si crx conversion
- crx problem????
- Odd MPFI Question (searched)
- b16 s1 tranny grind
- b16 runs, goes into vtec, throws no codes, but doesn't pull
- sir hood
- Crx weight strip down! BUMPERS!!
- car starter starting issues.
- Polybauer WideBody kit?
- just couldn't resist the EF world callin my name...
- What springs or coilovers will fit my crx?
- Tuning potential B16 OBD0 VS OBD1
- Dumb questions but need old h-t people to read
- Help me find a detachable steering wheel....
- In your opinion which is better??
- rawr
- Ecu Code 1. Engine Light on after a few minutes of driving
- 92' civic hatch manifold swap problems
- 00 ITR cluster install in 88 crx.
- Exactely what is a mini me?
- HELP fuel rail, fpr, and fuel pressure gauge install
- Manuals
- HELP with Obd1 code Please
- wieght
- Thoes of you who have done poly bushings....????
- Dont know which sensor.
- Car runs alot faster when cold?
- Wiring autometer 5" tach.
- mpfi swap problem...consuming gas?
- *SEARCHED---Please help!!!!*
- which 93 delsol si parts will swap on my 88 crx dx?
- crx owners check this out
- first time at the track. howd I do?
- Skunk2
- Control Arms? Replace or new bushings?
- you aint a baller...
- boring a zc block......
- leaking MAD tranny fluid YO!
- ??premade roll cage??
- crx rollcage, you might need it
- 5th gen seats in a 4th gen hatch
- finally painted my car
- b18c1 with DSM turbo parts ???
- 88 civic, add jdm 10k tachometer
- Ran at Atco, NJ Tonite, NO Back Pressure=BAD???
- How to wire EF so Front Signal Blinker light is constant
- problem with 88hatch need help
- **Honda ECU pin tool for hasport subharness**
- what 91 civic ex parts can go on a 91 civic standard hatchback? engine and tranny wise?
- 1990 CRX Si Suspension
- New book on the shelves everyone here should read...
- B series intake manifolds
- steering wheel hub bolt.
- everything needed for an engine swap?
- ZC Cams?? What can I use for turbo...
- ed parts for sale
- crx confusion subs headlights idle ignition?
- Where does this plug go?
- easiest engine swap?
- JDM Front Conv. CRX anyone have *IN STOCK* ?
- jdm cluster
- wich ctr pistons??
- b16 search
- Newb wants to do work on car/s, wants info/guide
