View Full Version : Honda CRX / EF Civic (1988 - 1991)
- i need a zc motor for my rex does anyone have one?
- Seat Belt Mounting Points HELP!
- Opinions on if this Civic is a good deal.
- I might buy a 1991 dx sedan but i have some quetions first...
- Skid plate
- help
- How to install an external fuel level gauge on a civic 89???
- d16y8 Swap question
- Im stuck...
- any one looking for a j1 tranny
- Can someone run this VIN for me please?
- Air fuel for 90 civic si
- what motor?
- 16 Long VS. Short
- Power windows on STD hatch?
- Brake problems (pedal going to floor)
- Custom OEM/SPA Gauge Cluster from King Motorsports
- swap parts question need help asap
- d15b1 manual tranny on a b18a motor
- show me your intercooler piping!
- Wanna TURBO, need HELP.
- Sunroof, need HELP..
- code 16
- Does this look like a good dea? b-series mount for 225.00 +S/H
- jdm climate controls
- Tan interior
- Exhaust question for supercharged CRX
- have anyone change the water pump on a crx dx??? pics please
- Need civic nouva headlamp
- $15 forged stainless shifter
- b16 in an hf...
- CRX-EF civic Hatch.
- shop manual that specializes in transmissions
- cv axles
- Putting a Vtec in a CRX
- civic differences....
- zc or d15b vtec? Pros & Cons
- Corner weight for 90 EF Si.
- EF9Sir: Which calipers to use?
- DOHC ZC unused plug
- Charging system woes!!! (any super-techs out there?)
- need intake diagram for 1990 civic swapped to a 1992 manifold
- BAD DAY...Timing cover removal?????
- o2 sensor problem (obd1 4 wire)
- Anyone got a copy of the Ground Control Instruction sheet for a crx without Koni shocks
- Ordered a B16A1 from Osaka ( canada )
- Parting out 1991 CRX Si RED
- Help with my doors please
- 90 4dr bumper on 90 hatch? (searched got mixed answers)
- Ebay CRX for sale
- I need to find some hard to find parts. Will you help me?
- accessory power source?
- Quick Question
- zc timing question:
- what size piping and what cat?
- will a 88-89 integra ecu work with my stock si enigne
- post your FMIC with your wings west frotn end....
- Striped Threads in Block
- Will this motor work?
- Wiring Help, needed fast
- DIY Home Depot Lip (56k be warned)
- car trouble
- 92-95 civic cluster
- h22 in rex questions?
- CRX chassis code in Vin should it always be ED8?
- How much have you spent on your CRX so far?
- HELP HELP HELP
- can"you"help me decide??
- Any difference in 89-91 JDM civic/crx si tranny and usdm one?
- hybid axels Qs
- DOHC ZC Height
- 2nd oil change on b16 still smells like gas.
- Using a p28 do i need a knock sensor?
- boosted crx project
- Help a swap noob out with a quick question...
- What does the 2000 GsR Valve cover look like?
- tranny install
- Anyone build a new radiator support ?
- coilovers
- Differential bearing scrap
- Which sway bar?
- will a 89 crx si radiator support and radiator fit on my 88 si
- I need help biulding my engine
- Didnt pass smog even cheating....
- SAME MOTOR????
- Spark plug wires
- can anyone help me find this
- Do your pistons need replaced when doing an ls vtec?
- Anybody running a 90-91 style crx cluster in an 88-89?
- Brake/Axel/16 Swap question...?
- Yahoo!! I just got my Calif. Cert for my 89 with B18C!!!
- Oil breather hoses?..DX to SI help
- doing an exhaust on a Ef... whats the story on ES mufflers?
- Engine noise please help
- No start after swap....Power Problem.. PLEASE??!?!
- Wire Help
- Rust Prevention
- JDM sniffer comments
- a good place to buy brand new interior
- CRX hickups on the freeway
- Want to see any hatches w/...
- Around here?
- Electrical Problems, HELP!
- new to honda seen so bear with me and answer my question please
- quarter panels
- CRX wanting to get a custom exhaust but have questions...
- Cant SLeep
- Spark plug wires - is bigger better?
- best sound and performance exhaust
- spark plugs are black
- please help
- horsepower questions
- ZC in 88 hatch
- What does a obd0-obd1 wiring harness do?
- jdm crx floor mats... what do they look like?
- anybody else have a roboshifter?
- square yellow fogs
- clutch questions
- throttle body question.. ????
- A Couple of Questions
- Non honda - torque converter removal
- anyone need a cluster with tach? (90-91)
- Maybe its just my CRX but.....
- jdm 5zigen muffler
- Need HELP BAD!!! B16 Question!
- 90 Si Civic, no e-brake (?'s)
- cf has crack. repair / prevent from worsening?
- Odd TPS voltage problem
- Any exhausts that fit a ww rear bumper?
- syncros? where to buy
- autopower rollbar
- Help me and my CRX
- cleaning dirty car seats
- Price for JDM conversion
- headers???
- What's the going rate?
- B18A Allmotor in an 89 Civic hatch?
- tennessee EF REPRESENT
- anyone have a dc sports catback on there crx?
- ALL JDM wanna be CRX/hatchs enter..or people whop want amber bumper lights
- A/C compressor question
- TOTALED MY CRX!!!!
- 88 crx si idle problem!
- 94-01 teg center console and armrest in my ef?
- CRX Swap Shortshifter/Shift Linkage question?
- Engine turns over but will not start.
- Car starts and shuts off immediately
- Fender Fitment
- PRICE MY REX
- 1.5 ek civic
- Sunroof advice
- filling DX tranny MTF.... which hole?
- dry cell battery help?
- type r IM ??????
- 94 teg seats into ef?
- Switching VIN plates?
- Full-race crossmember won't bolt up.. ideas?!?
- Need a custom harness for your swap? Lemme know... dpfi, obd0-1, B18c, z6...
- Motor problems
- rear bumper question
- Help me pick a direction for my project!
- headlight assembly
- F*#K Theives...Help Me
- F/S 91 Civic HB SI shell $1000 obo
- Fuel pump relay?....
- will this motor bolt right up to this tranny??
- Good trade or not?
- distributor problems on my ef HELP!!!
- throotle response?
- 89 hatchback gear shift replacement
- JDM D15b vs. DOHC ZC?
- not pic whoring...need to make my jdm ef seats go back further!
- Anyone have pics of a 88-91 Civic HB with Rota Slipsteams?
- z6 rods in a d15b2 motor
- HF bumper support or STD bumper support
- 92-95 Civic Radiator in 89 civic Hb
- obd 1 harness in a 90 hatch
- in need of some help guys...:\
- 91 civic hatch si for sell w/new hasport mount kit.
- b17a1
- Cost for etest.
- Knocking/Pinging from what sounds like the top end.
- 90 crx dash in 89 civic?
- clutch cable adjustment - catching high... plz help
- 99 Si Wheels or Black Rota Slipstreams
- WW sideskirts?
- SOHC ZC probs, possible fuel system
- I cant figure out why my car will not start.
- 1990Crx Dx 4sale or TRADE
- crx with what in it?
- could someone post the differnce between auto and manual 5 speed rear mount bracket
- b16
- d16a6 fuel pressure
- hydro tranny conversion
- 88 CRX with Hydro tranny.....how?
- Purge control solenoid hooked up improperly, Increase Hydrocarbon emissions? HELP!!
- what catback scould i buy for my crx?
- PVC intake Bad?
- 88-89 integra gauge cluster
- check this out. pretty sweet coils for EF
- b17 got the dyno results...
- can i use my dual point intake on an si motor till i get .......
- b16 pistons in a LS block is it possible
- The TODA Sports Injection Kit on ZC.. Any body see them or hear about it?
- driver door
- AWD civic waggin question
- question about momo and isotta steeringwheel bolt patterns
- Mini Me Swap?
- Weird experience today...can anyone comment?
- Dash tach and Temp gauge not working ;/
- Which cilinder block on ZC?
- j's racing intake for a crx?
- weird sound
- Is the b16a2 head the same as the CTR one?
- DOHC ZC TUNING
- Does power steering pump fit B16 conversion in CRX???
- Next Step to Finish Line
- what series motor do i have????
- ZC head options.
- Video of my crx... 12.6 @ 110 Turbo/Nitrous D Series
- New a/c compressor
- Engine Swap Help for a '87 Civic
- My vtec controller mounted in the clock
- Engine Identification\Specifications
- sir 1 for sale b16a
- D series turbo downpipe?
- weird problem
- pic request - invidia cat back on 88-91 hatch
- mini me question,, Need help
- turbo kit???
- popping noise
- DOHC ZC torque specs
- Have to replace thermo switch. Does it tap into the water jacket?
- RADAR DETECTOR !!!!!! HELP~!!!!!
- where is the service conector???
- 91 Honda civi si
- MY pressure plate is dead i think??!?
- NEED HELP!!!
- drive axle vibration
- crx si dohc zc swap codes 1 8 and 9
- Spot welds on front of crx rad. support
- bay area owners!
- nitrous spark plugs...
- water reservoir lid wants to pop out!!!!! need your experience thanks
- Lowering an 87, CIVIC, DX, HB?
- Transmission Problems
- what axels do i need for the b16
- New with Hondas... Need Help.
- ZC in crx....what ecu?
- 1988 JDM L3 Cable tranny What clutch? d16z6?
