View Full Version : Honda CRX / EF Civic (1988 - 1991)
- front end conversions
- Looking for Aftermarket bumper covers for a 91 civic SI
- 90 Civic Ex 4-dr Master cylinder swap
- How much did you pay for your ride?
- what is odbo, and 0db1? what does this refer too?
- carbon fiber mirrors.. I can't tell if these are crap or not.
- CEL Code Error, 1 Blink. Oxygen Content
- shouldn't my car be faster?
- what free/cheap mods are out there
- Civic Hatchback DX engine died on hwy!
- just finished zc install, some questions...
- weird hiccup after tune up??
- my car wont run code 7... i measured some voltages now anyone got ideas?
- HELP!!! Zc into a HF problems
- ECU Question
- FS or FT: complete b18c GSR swap for 88-91 Civic/CRX
- TPS? car diles wont rev tho ?
- New tranny blew last night...differential pin?
- ignition switch question
- Thermal Catback on CRX HF
- d16y5
- rev limiter
- D16 or B16 What motor do I go with??????
- Why is my clutch pedal so stiff???
- b18c5 vs. built b16a
- spindle questions
- ef - h23 swap.. is it worth it~?
- How hard to do this?
- tranny bearing question...WHICH ONE
- sohc zc into 91crx si swap questions
- What time's you think my ls turbo crx will run?
- crx si
- JDM B16a Pricing...
- 90-93 integra front on CRX??
- Has anyone removed VSS from 4th gen hatch tranny?
- What should i run?
- Anybody in Orange County, CA who can help?
- integra gsr cat converter fit on a crx?
- Which ECU for an MPFI swap?
- grinding on third gear after 5000 rpms
- question about a code
- b20vtec... in 1991 HF
- did your new muffler get louder??
- stock sir mounts and linkage?
- can you put 4dr fenders on crx?
- anyone use a fiberglass hood WITHOUT hood pins?
- Will 90-91 crx cluster cover fit a 88-89 dash?
- Car is slammed
- New clutch is in, what is the break in period?
- Fuel Filter change
- STripping out a CRX 1988 SI
- b16a of death
- JDM Question!
- Free Crx ECU
- 90-91 Civic/CRX hood interchangeable?
- need help asap real quick question
- **how the H&LL do i get the FLYWHEEL BOLTS OUT?**
- Clutch pedal/ transmission problem
- cv axle installation?
- five lug convertion?
- B16A Code 1, I know what it is but hear me out...
- More wiring questions for the b16a?
- Question about oversized pistons
- Does anyone have GSR cams in there b16a?????????
- Thoughts on Centerforce clutch kits
- Help with launching!!
- What Half Shaft for B-Series
- Just picked up some coilovers, what are these things that came with it???
- SIR b16 cams forsale.....
- 92-93 integra xsi b16
- Will a CODE 6 cause a high idle?
- When lowering the car,,do I need any other things
- My 90 DX CRX got crushed by a ford explorer
- Dyno shops in Illinois ?
- Oil in the muffler...
- your ultimate crx?
- has anyone replaced a crx rear x-member???
- hood cable size...
- innner fender trim
- how much potential does a DOHC ZC have?
- how much for re-uphostlery?
- What is Code 21 on the b16a????
- b16 ef track guys ...
- Best place to purchase Oil drain plug?
- What CV Boot for a B series swap
- 87 crx d15a3, What can I do?
- Sunroof problems
- Crx owners why did you like your crx?
- 91 Civic hatchback (std or DX ?)
- Anyone else have these yet?
- SOHC ZC and D16a6..cousins or brothers?
- suspension swap between ef8, eg6 and ek9
- Lighting problem...
- 91 crx si for 1100? goood price?
- Roll Bar please HELP!!!!
- integra spindles...a couple questions
- Help!
- E-Brake Cables?
- Rust on the floor, bad?
- Painting Wires
- Car can't hold voltage, help ASAP!!
- Si seats into a 88 DX ????
- This sound fair?
- 4-1 Header
- Slightly OT: Drag racing techniques for the ZC...
- Guys w/ B-series HF's, got HF axles kicking around?
- i just swapped out a 88 d16a6 from my 88 crx si to i think a 92 da16a6 1.6
- Wheel wobbles a lot!!!
- is this summit battery relocation kit OK for us CRX owners?
- quick question: mpfi gasket
- CRX HF Color Q
- hf motor in a dx?
- Do I have a Limited Slip Differential?
- will dx axles work with a si tranny?
- quick question
- 2 buy an si or not to buy?
- Wire color for Civic/CRX resistor box different from Integra one, what colors are the same?
- 89 integra 1.6 good motor?
- 93 civic IAT where is it?
- crx ball joint prob
- CRX dx intake manifold opening????
- does anyone know what diameter the lower radiator hose is?
- Opinions needed on a Custom Exhaust
- Where can I get a clutch alignment tool?
- jdm b20
- auto crx options
- 4 spd to 5 spd tranny swap
- Si cluster.
- 90 CRX Si tranny... Noises - What could be the problem??
- are the B16A o2 sensors identical?
- What mods do i need to do a jdm front end swap?
- Arp d16z6 head stud question
- 1988 integra ls front on an EF
- What I did last night...
- J's sausage is in, it is so damn big
- Pic,s projector headlights on a crx?
- Mid Pipes worth it?
- CRX paint questoin????
- Did I make the right clutch choice?
- Just changed fuel filter and engine doesnt want to stay on. (HELP)
- Pr3 ECU needs 2 o2 sensors?
- Need some tranny info
- what's the difference between the CRX 88-89 headlights and the 90-91 headlights?
- just a bodykit painted or the whole car???
- why buy a zdyne ecu vs. hyperducktuning mugen prog
- tie rod help
- new car just bought for 700
- I think I've been scammed! How long to wait?
- Do Acura Emblems fit?
- Ecu Codes on the b16a???
- Went to the track last night
- 89 civic std to si conversion help...
- D series block question...
- Donor vehicle for 15" rims?
- Will a EX gauge cluster w\ tach, plug str8 into a 98 DX
- HELP!!! I keep breaking axles!!!
- car smoking
- best cable tranny for b16 lsd or s1 for 1/4 mile
- Help! ZC Tranny emergency!
- What are some options for more stopping power?
- Which fuse is the "hazard" fuse?
- what car to buy with 8k
- B16A problems starting, think may be dist.
- snapping axles
- Parts list for skunk2 intake manifold in a B16
- Good Mini Me mods?
- CRX si cam in turbo D15B7? Will this work?
- SOHC Guys - .020 Off A6 Head or Z6 Head For D16A6 with P29 Pistons?
- Anybody with a single cam turbo ef?
- Taking the D16a6 to 9k?
- S1 tranny question..
- Installed V-AFC need help on a few things..
- B16A2 into 88 HF
- Jap Crx Stock B16
- how do you check IACV
- start up / idle / power of cold engine
- Tool for setting valve lash
- dist problem
- delsol vtec block, replacement for 1st gen b16a?
- need help with greddy turbo kit on zc crx and some suggestions
- b16 final gear options
- Removing my mirrors for paint
- why is my turn signal or hazard works and then not work!!!????help please!!!
- 1/4 times
- Need help setting rev limiter (Hondata)
- High mileage; what to look out for?
- Ls/vtec question? S1 tranny question?
- O2 sensor in the b16a?? Vtec Question?
- crx b18c1 swap wont start no spark
- Swapped steels for alloys....probs erased.
- Higher compression......how much to mill off????
- d16z6 into a 88 hatch??
- Clutch Pedal Broke!!
- b16b swap?
- what does the original battery look like?
- Fuel hose not the same on DX engine as on the ZC? Help...
- need help, car dies periodically and i don't know why
- auto tanny to 5 spd 88crx
- CRX fuel filter
- which intake manifold to use for dpfi to mpfi?
- b16 crx that wont ever stop breaking down
- Big Brake Swap - Fronts
- Battery light on dash came on???
- knocking or ticking noise from B16..... =(
- what to do to my 84 crx
- D16 pistons
- z10 vs. place racing vs. jimfab
- how to get first gen b16a up to par with 2nd gen b16
- Loss of horse when ITR intake manifold was added on???
- Check Engine Light???
- zc transmission
- help building an na d16a6
- not sure whats wrong
- New guy
- How do you de-pin the ECU???
- What do you think would be a good price for a a6?
- Pics of bolt-in Autopower rollbar for Mr. Saturn
- will 89 bumper work on a 88?
- 91 hatch fs/trade modded
- EAVC cleaning question
- MPFI Wiring?
- What can I do to make my B16 CRX faster?
- check engin light problesm...help!!
- aem v2 intake b16 crx
- Si and HF springs the same?
- CRX Si motor into 89hatch?
- gauge hookup
- jdm parts
- Brake pedal soft on hot days
- Strut Bars????
- Picked up two CRX's today....
- How do I prevent fuel from coming out of the lines when I pull my engine?
- need help with GSR timing and help?
- How do you fill up the tranny with fluid? And how much does it take?
- New floorboards, a concern, or a go?
- are these mount inserts any good?
- new honda ad.
- intake options for b16
- 86 CRX Si, broken tranny mount
- Help please...suspension experts needed.
- grinding gear
- CRX - what are the yrs with the see thru plexiglass rear ?
- obd1
- a few quick timing questions
- is it illegal to drive a rhd in u.s.??
- 14" rims, are there any out there?
- how to get the shift linkage off the tranny???
- My new ehaust
- crx hatch not closing.... help me please!
- b18b in EF - headers anyone???
