View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what hood is best
- Check engine light
- how can i TEST my Ignition Control Module... ICM??? 88-91 dx
- getto motor mounts?
- b18a obd
- B16A, Z6, ZC, D15B2 or keep the A6 in my 88' hatch, gimme your opinion
- Mini-Me don't worry i Searched
- no brake pedal, help!?!
- alright fellas i just wanted to know how high can a d16a6 cam and piston have ?
- will aem itr cai from eg fit an ef
- No Start "No power" only E-flashers
- civic wagon body kits and accessories and performance suggestion
- opinion
- my new wings west wing on the civic
- fixing a totaled hatch....need a question answered.
- crx or hatch
- Coolant leak, check engine light
- CRX Service Manual
- car still wont start
- And the score is: MPFI 1, SiMateoAko 0
- CRX interior pieces seats backward
- Just put on my Innovative Mounts Front Cross Member
- Crank pulley bolt too tight!
- What headgasket??????
- ecu ???????
- Where can i find a B16 wiring harness???????????help please
- ARP studs for the d16a6
- swapping from b18a1 to b16a2
- Is the JDM EF6 (1.5x) the same as a USDM CRX
- Zc trany mount?
- 98 integ susp into a 91 hatch std?
- Video burnout Civic EE9 B18C-R
- Short shifter just installed...to stiff between shifting?
- AC HELP
- upper control arm help
- How to test PCV system?
- chipped ecu suggestions
- 56K KILLER ... my semi finished race ef hatch
- what to do about throttle pos. sensor??
- '85 Civic hatch wiring issues
- Flamers
- Question about the hmotors b16 full swap
- Ebay find: cheap B16 parts car in the North West. with many extras!
- my time..first time at the track
- CRX GREDDY SP2 QUESTION..........
- NEED HELP!!!!!
- CRX vs hatch: info for junkyard purposes...
- went to the track....pretty unhappy so far
- J1 WILL NOT SHIFT WHEN MOTOR RUNNING
- Blown Rex
- sohc vtec
- crx bumper on a civic hatchback???żżż
- Oil pressure swith
- cleaning cat with solvent?
- finally got pics of my car and swap
- IM WORKING ON MY CAR RIGHT NOW NEED HELP!
- ECT Sensor code showing up what do i do!?!
- b16 bouncy
- something electrical ??
- which is stronger d16z6 or minime y8/a6 and why
- why are my times so high? (searched)
- eg axels on an ef?
- Need help with B16A Swap and Ignition Upgrade/Maintenance
- turbo b16 t3/t04e need to fit a 92-95 civic radiator in how
- problem - injectors arnt gettin and impulse
- having problems with ram intake
- CRX Battery Trays & Brackets
- need help with my zc
- ADJUSTABLE UPPER BALL JOINT vison negative a-arm
- Dual A/C Pressure Switch Removal
- Custom Speaker box......floor reconstruction
- wut exhaust is good?
- Aftermarket mirrors???
- ls-vtec crx dx
- need help: sohc zx into 89 crx hf, not firing on all 4
- 4-1 header O2 extension wire?
- 1988 sir front end
- cheapest place to buy power chamber intake
- Brake question need help??
- Axle Question: Intermediate shaft Purpose.
- Finally time for my swap!! SO HELP ME PLEASE
- Help diagnose whine / drag / miss.
- Passenger drive axle problems>
- I have $2,000 to spend on swap, PLEASE HELP !!!
- Quarter Panel Pictures.
- Suspension for a 90 civic h/b
- hrmph...
- gapping
- Which engine for 91 civic hatchback dx
- No power after i changed alt
- CRX Flywheel Spline count ( diffrence in DX & SI )
- Axle Swap Quetion??
- i need help wiring 95gsr into 90 civic dx
- crx security box..question
- How to tell JDM from US trans
- Single cam Turbo for sale (Greddy)
- A longshot but...I need help with my MUGEN rear wing for my CRX
- sunroof stuck open! rain is coming!
- 88-91 Civic DX Problems.... need some imput
- Front main seal replacement with b18aCrx
- 1985 GT-S Corolla with S2000 engine swap for sale
- anybody know's how much the vis mugen replicas cost?
- will integra midpipe fit on a crx?
- sparco seat
- Next Crx ? (pic)
- 91 Civic Std. D15B1. What should spark plug gap be?
- Engine fire *sigh*
- Engine Noise - Flapping Sound?! WTF Mate?!
- Im thinking ZC in my 88' dx, can i get parts for it?
- crx backseat
- ok question about headers b16
- Need Help with Springs on a CRX???
- new tires and a new drop
- Hatch won't close
- 90-91 crx si inside harness
- need some help my car cranks but it dont turn over n start
- 87 civic what d series motor can i upgrade too?
- Car won't start! help already searched and found no answers. help a brother out!
- OBX Throttle Body Spacer
- Won't Start...
- EA Build (56K no way...i mean it)
- 1990 crx harness fit in 1989 hatch???
- car wont start. need quick reply . please help!!!
- crx lips..
- Axle removal question
- Glass sunroof on a crx?
- what intake do i get???
- header paint
- 90-91 distributor plug wires on a crx, and the harness on the ecu plugs abc
- why won't the USDM carbon fiber hoods fit on a jdm front end?
- 1990 teg cluster into 91 crx
- weird charging problem
- overheating ZC - changed thermo
- Can 02 sensor make car smoke??
- VTEC Solenoid short!
- Phillips Disk brake screws?
- Does any one know where I could find a dart block
- want to trade? 1985 Nissan lowrider pickup with hydros!
- code 22 vtec oil pressure switch defective.....
- one wire o2 sensors
- sparks header clearance
- h23 mounts in civic
- need some advice.
- JDMSH!T products
- NEED HELP!!! OBD0 CARBURATOR NEEDS TO BE REWIRED TO AN OBD2 MOTOR...
- sputtery and probs please help me guys :-(
- why does my rpm's increase when im in neutral
- Omni coilovers or ground control?
- .mov file of my idle issue. Has anyone ever had idle like this?
- Intakes that will fit with battery removed
- Weird swap problem, help
- skunk 2 camshaft and adj. cam gear
- Is there a difference in a 88-91 flywheels?
- anybody know where i can buy a mugen front end?
- painting lightbulbs
- Grinding noise on the front pass.
- FS D16Z6 Long Block HKS T25/T28 D15/D16 Manifold
- Seat question, need help please
- Key won't turn
- cherry bomb as a resinator?
- i need help , injector questions
- jdm crx clock
- Broken radiator peice??
- Need 90-91 Si Gauge cluster
- anyone whant to trade for my wreked s2000 for a ek hatch!
- b16a not accelerating when foot is on the gas
- CRX Fan
- wheel stud broke today need help!!!!!!!1
- b20 cams
- mpfi swap to an LX?
- Someone with a DX, plz tell me where this plug goes
- 320mm Steering Wheel. Recommendations?
- axleback?
- Neuspeed race springs and Koni yellows
- DOHC ZC
- suspension making squeak ass noise
- anyone wanna trade the bodykit for my stock stuff
- b16 won't start
- fuel injectors and resistor box?
- sir bumper blues
- Full Race 88-91 CRX Traction Bar Owners!
- NEED HELP!!! zc pass smog Q"s?
- Ignition stuck???? what to replace???
- a6 top end question?
- HELP QUICK PLEASE!!!!!!! CHECK THIS OUT
- window regulator from 90 hatch to 91 crx?
- NNNNEEEEEEEEEEDDDD some HELPP
- quick ques??
- Where did you put/mount your tweeters?
- Need Help on part's NAME or part number
- exhaust?
- NEED HELP FAST PLZ
- ECU wiring
- Does your B-series swap mounts make bone grinding vibration?
- Help cant find kyb gr2 front struts for 88 crx.
- HAVING A HARD TIME trying to find the following items for my 1989 civic hatch
- Code 9 issues, searched.
- boosted, now brakes feel weird?
- questions about DOHC swap into a 91 crx hf
- Keeping automatic oem seatbelts with aftermarket seats - belt buckle mod
- ignition problems?
- question and parts sale!
- fuse box
- Y8 Intake Manifold
- 0bd1 Intake Mani on HF ???
- Which pistons for ls/vtec
- tie bars
- EF smoking and lost compression!
- SWAY BARS SI IN DX (CRX)
- need help ASAP!, A/C related...
- DPFI-MPFI\DOHC VTEC Wiring Questions
- Cusco roll cage for 88 crx!?
- searching for a CUSCO DEALER
- I NEED TWO COIL-OVERS FOR CRX SI
- AC system install.
- VSS where is it???
- Project switch-a-roo number two
- longer gearing
- Forged internals D16a9
- b16 swap radiator problem
- Quick Question PLEASE READ
- front bumper bar (impact beam) removal?
- B16A2 swap: vss to cable questions
- Crx DX(MPFI) into D16A6 Running Rich and not getting spark!!!
- Coolant leaking behind my intake manifold!!!!!!!!!!!!!!!!!1
- JDM b16a crx, NEEDS MORE POWER!!! Stage 2 cams require compression boost?
- Rear speakers in a base model 90 civic h/b
- Ok, Axle seal confusion... PLEASE HELP!!
- ECU CODES
- mounting 6x9s speakers in the rear stock location in a CRX...........
- Which d16 tranny?
- Control Arm Problem
- how can u tell what model crx u have between dx and hf
- Wiring???
- Removing evaporator, will heat still work?
- quick e-brake question.....
- mechanics?
- i got a rookie front end question.
- Spark Plugs???
- need a body part #
- wut kind of struts should i get?
- 4 lug conversion?
- 91 crx
- Need help
- climate control light bulbs
- how much is my car worth??
- b16 motor mounts
- Brake kits for Civic/CRX
- BUDDY CLUB WHEELS
- 4.7 & 4.9 Final Drives for ZC/D16 Cable Trans
