View Full Version : Honda CRX / EF Civic (1988 - 1991)
- JDM Valve Stems.
- headlights turning off or dimming then goes back on?
- how to get max horse power out of a 89 dx engine
- Vaccum Diagram
- question about nos?
- ctr pistons req 100 gas and itr doesnt? i need to know thx!
- coilover springs question
- Which HID kit?
- Looking to buy a CRX
- what radiator hoses for b18c engine?
- d15 into a 96 ex
- i just got a crx and i wanted to know what mods would be good to start off with ?
- New traction bars for EF's
- Spherical bushings?
- What kind of rims???
- need info on lower control arm for ef...plz help
- EF hatch Stolen just now, WAUKESHA WISCONSIN
- Stock CRX Si Yellow Paint Code
- Best Lookin Muffler For EF!!!
- D15B Engine swap wont start...HELP
- Tower bar on EF
- ef hatchback
- ls turbo) how much power/?
- sourcing for a B20B in 89 CRX
- Vacuum line diagrams???
- wtb civic si or type-r 88-91
- how much would it cost? #3 Cylinder Valve guide and seat.
- crx d16 si swap into a 88 civic HB with a d15 auto matic
- IACV screen
- best cheap crx jdm parts and b16 1st gen motor website or company?
- Questions on the 4wd 5-door models...
- my 90 civic hb dx is really out of time i need help to fix or someone who will sell me an si motor
- What would you do
- Engine Swap Horror
- Just converted to obd1, throwing codes 9 & 20. any ideas?
- where can i buy a act or exedy clutch for not to much money
- No fuel, im stumped
- another my car got owned post :P
- Ne 1 interested in TiTaNiuM Custom Strut Tower Bars?
- cable to hydro help
- 91 crx front end shaking
- mini me vs. auto to manual z6?
- wiring question?
- What's the best size rim to go with on an EF?
- gsr cluster swap gas guage problem!!!!!!!!
- rpm jumping
- HELP WITH B16 PROBLEM!
- Battery Draining Rapidly While Car Off. How Do I Trace? Daily Driver
- My cars going threw alternators...
- Traction Bars
- does 88-89 headlights and corners fit on 90-91 crx
- d16z2 what fits.
- removing interior vinyl top?
- Is there carbon fiber doors for crx?
- CF Company Question / VIS and Siebon
- stiff springs
- Idle Prob. 1300-1600 bouncing. Can cover single hole partial and get steady 750
- Help with 01 GSR in 89 Si (searched)
- 88-89 CRX under car coating
- Main relay, click buzz, no start, I know I know search(I did)e
- Is my CRX OBD 1? So does that mean so is my SiR-I B16A1?
- Problems with H-beam rods and Speed Pro pistons...
- removing buzzer from 95 GSR?
- Short Ram air intake whistling noise
- a deer own3d my car
- Sparco Steering Wheel
- Just wanted to say hi!
- how are crx's classed? ie, are they gen 2, series 2 etc?
- external coil question
- can a full length adjustable coilover suspension for a integra type r be customized to fit a crx???
- 99-00si oem foglights on a crx
- need help!!!
- Fuel inj. resistor box?? how to test... Injectors not spraying..
- what stock intake will fit in my ef hatch
- integra lca's
- How do I remove my dash?
- Feilds VAFC install in CRX
- swap question
- How much should it cost to get this done at a shop?
- a honda pro would know this
- b18c turbo
- can i fill tranny thru backup light switch hole?
- D16Z6 heads
- spring problem
- Swap
- B16 with ITR internals
- What does the Canadian SE Hatch trim level compare to?
- why the hell all my 4 wheel brakes locked up when i...
- shift fork
- CRX Vtec head swap
- went to the track today w/ my new b18 crx
- how much does a 89 civic dash weigh?
- where to get good parts?
- burping/backfireing sound when trying to start engine
- B-series Dizzy questions
- OEM Part number for tie rod ends
- This Muffler...
- B series motor mounts...
- My car truly hates me..
- Coolant problem and overheating problem
- Valve timing off - Car feels like stock Si.
- Angel Eyes not working completely, whats wrong! NIGHT PICS!
- Checking Ecu Codes.
- g~dam sh!t
- how do you take this out? window outer molding
- removing wiring harness
- help changing locks
- THEFT! I NEED INTERIOR!
- Manual ecu for jdm D15B SOHC NON VTEC honda civic
- Rear alignment issues...what will work...?
- Calling EF squad INFO
- will a d16z6 head fit on a d15a3 block
- Whats a good exhaust for my 90 civic?
- Help: Crx Manual Book
- where to aquire a vss?
- Is this normal on a 90 crx?
- aftermarket crx control arms
- Ebrake Warning Light..
- Need some valve adjustment help
- will a d16a1 sohc head bolt up to a d15a3 block let me know
- rex prob
- 91 Civic SI rear seat issues, help me out please...
- B18C JRSC possible?
- b series swap on crx!
- ZC into CRX
- Wheel paint on Valve Cover?
- ZC in 88 Civic axles
- will a d16y8 intake manfold fit on a zc motor?
- Can I run High Impedance injectors in my CRX
- 96 civic LX center console?
- lowering with stock springs
- hasport hydro tranny in a cable equipped car - clutch pedal is sticking down.....?
- will a jdm throttle body fit on a sohc zc?
- Has has a b-35m colored 4th gen?
- ef b16 to obd 1 single vtec
- Brake Light/Rear Wiper Problem
- exaust
- Fields and MAP code!?!?!?
- HID kit question...
- Thinkin bout goin import!?!?
- Carbon Fiber lip for a 91 EF?
- weird instrument cluster question
- Would LS tranny be a bad choice for b16?
- Can I use OBD0 distributor with OBD1 ECU?
- proportatian valve?...
- Help with Turbo Installation for b16a
- Where can I get power folding mirrors for my crx?
- Identifying a bad injector
- which mark is advance on the crank pulley, i forgot
- cold weather
- Exterior Driver side panel on door..
- Type R Flywheel and B16 Cable Tranny?
- cam gears on, but crazy weird alignment
- How to Mini-me?
- Installing cam gears.
- Anyone heard of them?
- Where did my wheel come from
- I NEED HELP!!!
- ZC sohc Head or the D16Z6 vetc head
- I NEED HELP FINDING THE SPEED SENSOR WIRE
- transtop
- removing cam gears urgent help
- Looking for some suggestions for an engine swap/body repair
- Anyone put DA (90-92 integ) struts on an 89 ef?
- engine swaps-vtec head 4 d series
- Need help with B16A wiring into a CRX Si...
- Where should i mount my SAFC II
- squeaky alt belt.
- xm radio gurus...help needed
- rare rims
- Just got me a '91 CRX Si!
- Tips on Axle Seal Replacement?
- JDM B20B swap into a '88 CRX Si...info??
- do 89 crxs' have inner bumpers?
- dumb question but....(4doors)
- JDM B20B into a '88 CRX Si Swap Info.
- b-series cable clutch does not fit, help
- wheel spacers
- Where can I get a jdm wing?
- car turns over funny.
- 1990 honda crx what engine to put in it
- H4H worth the buy?
- 1.9 liter d series???? wtf
- VTEC spool valve part no. , searched but no answer
- civic turbo pressure
- New car
- should i buy
- HONDA D15B VTEC ENGINE
- EDM/UKDM Guage cluster into a 89 civic dx question ?
- Civic CRX B16 B16A ENGINE
- Slipping tranny
- coolant needle staying low
- jw..
- Gauge cluster
- p28 chip
- oil leaking from my diff out the drive shaft
- ok seriously need some help, car bogs when you hit the gas, but fuel gauge is reading 70 psi, which
- PM5 VS PM9 whats the diffrence?
- Fan Relay: where is it?
- Circle of Earth
- new tps sensor with b16 swap.
- how much do u think this rex worth
- milling d15b head
- Purchasing a CRX(maybe)
- iacv code on ecu HELP
- rare rims?
- header help...
- d16z6 swap problem help!!!
- JDM power folding mirrors... how can i tell if they are power folding?
- Koni's + Ground Controls...how?
- leeks from the diff out the drive shaft
- Help. Clutches in cable b16's. What the hell fits.
- 90 civic hatch wont start
- smoke problem
- SEARCHED: 90-91 HB Seat Install in 88-89 HB
- Strut Bar
- NEED HELP PLEASE !!!!!!!!!!!!!!!
- Sidemarker Wiring on a Crx. What colours? Angel Eye the same?
- b16 im on ls head
- Who wants to be a hero? (must have a camera lol)
- Need Help
- 89 crx front bumper question
- Removing Headlight w/ Bracket Assembly. WTF!! *PICS*
- rotary button constantly going bad...need help please
- msd 6a ignition?
- Air conditioner only works on speeds 3 & 4, why?
- D15b vs Mini Me, which is best under boost?
- Sticking throttle body
- centerforce dual friction clutch
- b18a1 which color wire is the tps voltage wire
- B16a1 or B16a2?
- rear plastic swap from 87-89 crx
- how much are the price of these rims?
- Will my 90 DX alternator work on my 95 JDM d15b??
- Time for Rebuild?
- ED7 not starting
- Looking for a JDM frontend for EF9
- I finished my swap today!
- Exospeed = bad experiance
- Clutch problem, this is that same car im always asking questions about.
- rough idle
- How To? Automatic to manual swap in 91 CRX???????
- push button start how to?
- upgrading 89 clutch/flywheel?
- where can i get jdm and edm rear bumpers/moldings
- headlight positioning, please help!!
- what are thoughs bolts that go into the side of the passenger side of the head called?Where the cool
- [review] hasport header fitment yeah i finally got pics installed
- OBD0-OBD1 Conversion!!!
- gsr dash in a crx
