View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Need Help
- CRX 16i 16v
- 89 Si HB Sunroof replacement
- crx help please - best rim offset size
- is this worth it?......
- Anyone have a rusted out hole in your floor?
- Chipping ECU Question
- gsr into 91 hatch
- Got my first Honda, searching for some power
- 88 CRX sunroof question
- What windshield will fit?
- Suspension Question
- Would a DC2 Short Shifter work with a B16 in a EF?
- Question on A/C with B16 Swap..
- will stock CRX SI o2 sensor fit on B18C1 ?
- TEIN Basic Vs. TEIN SS
- d15b swap to d15z1 vtech
- Full fiberglass front end?
- looking for a crx shell...
- DPFI--->MPFI (b16)
- Need some info on OEM foglights
- look..
- CRX - bigger front discs
- can you interchange parts for 1988-1991 honda crx?
- 91 hatch used for how much usually?
- CRX pics pt5. 56k go enter the iron man
- Which is better for racing, Auto or Manual?
- VTEC HEADs
- cat or resonator
- 1988 CRX si shell for sale
- thermal 3" pics/ st sway bar
- 1st gen crx b16 Question
- not getting past 3500Krpm ??
- what the hell is this noise going on in my hood?
- honda crx parts, will 88 parts fit 91's??
- Body Kits
- 8valve to 16 valve hybrid worked just fine!
- Car wont spark.. ANYONE HELP ME???
- *let off the gas car shakes, push i clutch goes away?**HELP*
- 89 crx hf stock getting codes 4 9 10 and 15 help!
- which wire is the rpm wire?
- TUNER LUGS??????
- tranny oil
- b16a swap in 91 hb intake??
- HAVE QUESTiON WHAT COMPRESSION SHOULD BE FOR A B18c TYPE-R or B18c5?????:?
- Will EK 96-00 Civic Springs work on a CRX?
- skunk2?
- D15 SOHC Vtec ???
- B16A question
- changing clutch
- 87 crx si intake
- Can't Search for ZC
- Sorry if inappropriate: Does anybody need EX Knuckles? Have two pair.
- Is there any way to get more torque out of honda engines
- To sell or not to sell
- Front hub problem removing
- 88 Wagon AWD Doing D16z Swap. WHAT ECU to use?????????
- For all the Mini-Me guys!
- Marshall FP Gauge Install..?..
- timing issue
- Few Questions from a n00b CRX driver.. :P
- someone please help!!!!
- obtaining a zc
- CRX glovebox broken. can i fix it?
- what to do turbo or b16
- Preformance mods for D15B2
- check this guy's site out,so much info
- 90 crx front lip?
- HOW CAN I HOTWIRE MY FUEL PUMP
- how much was shipping on motor from hmotorsonline??
- brake question
- Ques. about transmissions.....
- How to wire vtec to shift light??
- trip to the strip
- hypothetical h22 into a 88 crx w/ passive rear steering can it handle
- Auto w/ multiport
- Help with exhaust!!!
- CRX Radiator Fan and AC Fan... NEED HELP!
- Cheap/Free power upgrades on D15B2
- For all those Who Love BUTT connectors, Getto FabulOus!
- mounting brackets for EG radiator???
- track times.
- Looking for CRX stuff
- Did 88-91 Si's come in Auto?
- low rev help
- CRX B18C1 fuel injectors?
- Question on b16 in CRX HF..
- At crossroads and need some advice
- Specs on ZC?
- Exhaust question
- 1988 crx Si cluster
- 91 civic hatchy, dx or std?
- Dizzy gone bad?
- crx w/ 300k miles worth $700?
- Will a PG7 ..
- Is your hood level with the driver's side fender?
- swaping my new b16a(second gen) help please
- hf/vx exhaust manifold
- do the dohc zc valve covers, fit on a b16a head?
- HELP...
- Questions about Membership...
- I swapped a 93 Si D16Z6 into my 89 hatch everything is done it starts but it.....
- Steering Wheel Shaft Size...
- Pics of sedans
- engine model #s
- 89 crx hf axle
- having trouble with axels going into hubs
- heater hose diameter
- Shock/Spring Removal, CUSTOM work may have screwed us
- Bumper Cover ?
- b18 mount kit
- HELP!!!!! need vacuum line diagram for second gen b16a
- 99 si lower motor mount???
- Need some help with engine swap
- Good bike rack for the Hatch?
- b16 EF overheating please help
- D Series Perfromance!!!! U Make The Prices
- delta 262 or 272?
- difference between 88-89 and 90-91 front and rear bumpers?
- can i run to rich?
- rotating tires?
- Very Good Lowering Kits
- for wetness out of my exhaust??WTF
- carbon fiber hoodS?
- I thought all D16A6's were MPFI???
- wiring
- 90 Si STILL HAS NO SPARK! Help !!
- OBD 0 to 2
- flywheel /clutch appl.??
- obd1 to obd0, please help
- dx distributor with vtec head
- Radiator Hose ? Please Help...
- will lude seats fit in a 01 civic?
- Brake Master Cylinder Upgrade?
- Map sensor diagram, searched.
- swap guide
- Front crossmember
- I couldnt post on the fource induction
- Cam Gear install, very rough Idle!! Help Please!!!
- What is Handata
- turbo for a '93 d16zc vtech
- Bad Wobble After Swap, Tried everything....need some Ideas
- ACT extreeme 4 puck clutch...dead after 3 months?????
- what mods should i do next
- CRX/EF civic owners need HELP!!!!! on what to do with LS/VTEC fully built TURBO beast!
- ZC into 87- hatch?
- Where can I get a Crank Angle sensor for DOHC ZC?
- Does a 90 civic hatch hood fit a CRX 91
- CVCC help!
- Best Muffler for Clearance/Sound
- b16a1 vtec engagement?
- jdm rear seats for ef
- OK...now I'm confused. Valve cover breather, and PCV
- HASPORT/HCP MOUNTS?
- A slightly different header question...?
- More pics of this Crx ????
- cv axle spines
- Vtec head with dpfi setup... for now
- d15 all motor
- Gsport Beast swap in 91 CRX HF
- need help zc motor...
- Specs on B16 on CRX
- Preformance mods for D16Z6?
- NEED HELP PICKING RED PAINT
- stripping fiberglass :HELP:
- Wat distibuter for ZC DOHC?
- What Engine To Get.....
- what the hell.....
- cap and rotor question...
- how much would you pay
- Crank question
- Need help! Testing the Ignitor(Icm)????
- overheating help
- I forgot the bolt pattern for head tightening... anyone know?
- tranny rebuild?
- So I watch the tail lights of my own ride
- I don't know if this is a 91 Civc or Turbo problem... Car has no power once it gets hot.
- b16a1 running rich?
- black spray paint...
- good clutch for b18b turbo....?
- No spark .. HElp!!!!
- di6a6 rebuild ?
- compression test....
- Really Stupid Newbie Question
- Does anyone have 90-91 Si Gauges for my car
- _-= rex w/ h22 questions =-_
- Suspension Help!!!!
- Couple CRX questions...
- Coolant leak problems
- Samco radiator hoses for Civic/CRX ???
- anyone selling a carbon fiber hood???
- kind of turbo for 93 ls engine...
- 88 - 89 and 89 - 91 seats lets get this info straight
- Block and head assembly
- STOLEN CRX STUFF! AHHHHHHHH MARYLAND, DC NOVA
- cant decide what motor b20 or b18
- Lip Kits for a Crx??? Where AT!!!!????
- sk7 or Y1 intermidiate shaft???
- Question about crx si stock wiring
- where can i buy an b16 first gen complete for my 91 civic si
- write-up 88 cluster (no tach) swap to 90-91 cluster (with tach) wiring
- what do you guys think(flame on)
- Zc transmission problems
- broken crank pulley on b16....what to do?
- Engalls in Front, Ghetto Rig in rear - just did tonight, got questions
- replacing head
- EF bumpers
- Will 88 Civic HB DX front lip fit my 88 CRX SI? (Searched)
- pic request: engine bay shots of waynes crx from teamrice.org
- harness,odb0>odb1 what the HELL
- which oil pan for dohc zc???
- need help-cv boot
- hf b16 swap...what plugs left over? axles not going in easy?
- racing seats
- Restricted exhaust causing bogging.
- Are D Series Crank Pulleys the same?
- exhaust?
- Pictures of my new and improved turbo setup...
- Where do these vacume/coolant lines go?
- Advice on wheel alighnment please...
- jdm d15b swap into an 89 civic dx. need help with wiring and ecu
- fs/ 88-91 crx clear corner lights
- First gen B16 intermediate shaft ?
- Thermal 3" + ST sway bar = ???
- Check engine light flowcharts *inside*
- high pitch noise coming from throttle body
- how to tell which wheelbareing is messed up
- 4 wire plug for ciggerate lighter what do they do?
- Bad to start engine with no axles?
- Please read if you own a B&M short shifter
- Rev limiter b16a problem .....
- question about main relay
- Look at my rack...
- should i even try
- Any pics of EFs with EG sideskirts?
- engine wont rev
- PLEASE, PLEASE, PLEASE help star this car..
- Dizzy and swap question...
- Mugen CR-X Logo
- ls wirng harness work for b18a swap into dx
- b18a into dx can i use a ls wirng harness??
- Oil Pan Dent...bad?
- crx convertable spotted on freeway...pics
- What year is my ecu?
- code 16 - ELD - car wont start sometimes......
- Question for CRX HF w/ B16A owners...
- WTB-CRX 88-91
- CRX Access Fog Lights.
- No thermostat
- Loud Exhaust For a 88 HB???
