View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Torque Specs Needed.....ASAP.....(?HELP?)
- Help: EF9 Bumper Pole and Fog Lights
- ef front brakes
- motor swaps for 91 crx (flame suit on)
- can omni 92-00 drag coilovers work on a crx?
- Weird starting problem
- Good steering wheel that won't burn !
- New to this Site and Hondas
- 1988 b18a1 crx?
- 91 Si Hatch that i am going to part...most valuable pieces?
- D series Questions
- <b>Ef w/ Y8 help!!!
- crazy temp gauge
- Battery light flickering on; 88 STD
- will a 88-91 crx si tranny work on a 90 crx dx motor
- throw out bearing
- 89 hatch rim fitment
- LS fuel pump in my CRX???
- Yet another clutch adjustment question....
- Choosing which wheels to paint the lip
- anybody ever impact the crank pulley nut off?
- b16 to b18b
- Error code
- Brake line thread on ITR caliper stripped.....
- brake light problems
- crank pully
- problems with my d16z6 in my rex.
- do the 88 and 91 SI distributors plug in same?
- rough idle--vacumme??
- 88 hf crx cluster
- Will a ZC motor fit in my car?
- what is a good oil for a turbo setup?
- ATE Super Blue... is it okay?
- CRX rain gutter moldings Question
- putting in a dohc zc this weekend
- crossmember messing with oil return, notch it?
- am i running rich? (b16)
- z6head/y8block
- wobbly Speedo needle! how to fix?
- Climate control fitment
- Innovative Mounts : Good Solution for AC Compressor Clearance ?
- EF : Civic Si Air Box Same Size as Civic DX
- d16z6 Valve Adjustment specs
- B16 problem, throttle hesitation
- B20 in CRX... Couple of ?'s...
- b18 ls motor smokes.
- I had a tiny under dash fire (wiring related)
- .d16a6 distributor work for obd0 sohc zc?
- where can i find freeze plugs for the sohc zc/d16a6?
- Can't align marks on camgears
- wiring for coolant temp sensor
- Can't find TDC mark on Crankshaft pouly
- Can I use a Toyota SC 12 super charger in b16a
- to all my louisiana boys
- OBD0 vs OBD1 B16a Distributors (Searched)
- Who has a Rsr Ex Mag Catback on their crx?
- robbery attempt!! milwaukee,wi!!
- Building a D16 for Nitrous. Weakest link?
- Fuel rail help
- EF with Si Rims...size of tire
- shift linkage? axles?
- Where exactly do you buy a B20Z Vtec model engine.
- JDM HOOD WON'T CLOSE PROPERLY ON EF HATCH!!!!!!
- exhaust sound question????
- what car did my engine come out of
- pump brakes and motor revs up?
- Boosted Project Thread.... Crx + B18 + Boost = Hottness! Lots-O-Pictures
- Questions about Building SOHC vtec
- Can I run 9psi on Stock B18?!?!?
- How much should I ask for this?
- how to check codes on a 89 dx crx with si harness
- need help,after swap no power at temp./fuel nor tach guages
- i need help with crx.
- K and N filter?
- JDM bumper on usdm front anyone have problem with fitment?
- A/c with efb1 swap
- 4 ECU codes need some help
- need some help or advice from the honda guru's
- Code 13 NEED HELP
- Those little annoying things...
- car will not run...(searched)
- 91 ls motor into 91 crx
- i was jus wonderin???
- zc front...
- 89 Civic- Won't start sometimes, turns for long time before starting..
- ???? about lower rear lower contol arm.
- sohc ZC/A6 going to dohc ZC................worth it?
- bumpy ride=gauge giggle??
- 2nd gear grind
- Can 5th Gen Prelude seats be installed a 1991 CRX HF by seat pan swap alone?
- e-brake cables
- everyones b-series stock engine 1/4 mile time in ef's trying to get a estimate to kno which one is
- Stock gauge cluster?
- B18a1 into a Civic EF
- converison harness ?
- I broke the head on this bolt ... how do i remove it now
- How do I disable the seatbelt beeper in a 91 civic???
- "Main Relay"
- Some help for those dealing with rust
- ***AXLES***
- swap ?
- exhaust hitting swaybar
- 1991 Honda Civic Si
- Diff b/w 91 CRX si front/rear Rotors??
- HELP! Car wont let off gas!
- sohc zc and d16a6 is the same...right?
- problem white smoke, many different symptoms
- wierd altrnator problem?
- Help me please
- D16A swap into 90 EF wont start!! HELP!
- tune up questions
- Aftermarket Hood.
- **Searched** Engine just stops abruptly..
- Grant Steering Wheel - Horn Button Wiring & Screws ???
- Running really rich after Swap SOHC ZC
- which header is better??
- Body work question LOOK! COMMENT! ENJOY!
- how many PSI can i run
- d16z6 manifold with obd0 harness.
- overheating... and i searched
- b16a Fuel avarage?
- Pics of EF Hatchs >????
- EK front end on a EF possible ?
- d16z6 rebuild
- Altenator problems!!!!!!!!!!!!
- whats the best motor for a EF hatch
- 89 EF hatch >?
- seats for a 4dr ef
- what head gasket for mini me swap?
- anyone have a lead on dpfi to mpfi swap?
- obd1 pr4
- anyone actually use those dashboard covers
- balljoints
- Walbro users electrical question?
- Chip burning/programming
- d16y7/8 swap driver side motor mount
- Fuel pump change, with motor swap .....did anyone have to swap a bigger pump for the motor swap
- how many o2 sensors do i need?
- all the black crx's out there
- B16A ecu number?
- crx-civic rear disc brakes
- where do you guys buy your seats?
- Temp gauge help
- Timing belt Help
- NOISE
- need help finding a clutch
- Noise when slightly turning the wheel left or right?
- obd 0 to obd1 short cut
- wondering how much
- would a ctr ecu work on my b16
- 1989 crx dx si conversion
- brakes making a hissing sound???
- Are these rear-view mirrors worth it?
- Eagle talon turbo?
- Help with a/c demons
- What do you guys think?
- B16A swap in ED7/EF9 : Header with the Best Clearance from ground?
- B16A Swap in ED7 Which OEM Air Intake Box and elbow is compatible?
- Stock Front Brakes with Rear DA Discs 1725 or 2040 Prop Valve ?
- weird post about for crx's w/o a/c?
- swapping in a obd1- manifold obed2 motor in obd0 car left over plugs?
- avid racing chromoly traction bar.. anyone using one
- what causes a fuel tank to rust?
- Ef power windows?
- 88 CRX seat rails
- d15b2 Which pistons/rods will work?
- honda CRX spyder??? LOOK!
- SOHC ZC value?
- is $2500 too much for a clean 91 si with mods?
- 88 lx start up problems
- HELPPPPPPPPPPPPP!!!!!!!!!!!! WIRE TUCK!!!!!!!!!!!!!!!!!
- 1988 crx dx for sale
- quick question about mufflers
- water in taillights ef sedan
- Chipped pm6 I know we got some smart people here so help me out
- Integra seats in EF
- woun't start after overheating
- crx overheat removing thermo
- sk7...sh3...intermediate shaft? how to tell which one I have?
- D15B2/D16Z6
- What is this b18a motor and trannsmisson worth
- b16 into 91 crx si
- air conditioning harness removal??
- Any body guys wanna give an estimate on my damage?
- DOES ANYONE HAVE A PAIR OF HX RIMS
- Need help
- Thoughts on this? 88 crx si w/ only 30k
- Good or bad
- Mugen mud flaps
- i have a quick crx wheel bearing question
- 1989 crx brake conversion please help??????
- Alternator pulley clearance?????
- ****WIRING HARNESS****
- best NA setup for b series vtec 20000$ budget
- Just picked up for $500, body work questions!
- what is the best motor oil for a HMT setup??
- need help with 90 hatch b16a tuning etc
- ZC Swap Exhaust Question
- Need a stock axleback
- having problems with putting new axle in, need help asap
- installed header, now a clicking and very low rev limiter
- what's the problem??! my braking light stays on!!!!!!!!!!!!
- EG/EK Front Knuckles
- help with headers
- d16a6 tranny
- seat bracket question
- What axel to use on drivers side with Y1 tranny if using the Y1 Intermediate Shaft?
- Are 90-91 bumper signals the same as 88-89?
- Start Problem Please Advise!
- Unchipping a PR3 ECU
- harmonic balancer
- installed new chip, check enigne light on now?????? code 6 (ect) HELP!!
- Hasport Axels for Y1 tranny..or where can I buy new/reman integ intermed shaft?
- Looking for the CRX Forum song
- F23A4 in a CRX?
- D-series, a6 or Z6
- does anyone kno....
- is it safe to run with no front mount on swap?
- wiring a dpfi to mpfi help.
- so i wrecked my car.. and now the engine is running like shit
- Problems after clutch install
- header question
- dirty coolant, dead battery and a leaking power steering. help!
- Wondering If anybodys Rockin the No power steering
- New pics of my Crx
- Short shifter aplication
- alittle green plug b18a1
- Crx windshield cracked
- 75 shot
- 98 center in my 91 hatch
- what is the difference between ef8 and ef9
- 91 SI CRX with B16a1 LSD swap BIG problems im pissed as hell
- axle ?? for b18a1 sawp
- What's the difference between PG7 and PM6 ECUs
- VAFC 2 on STD?!?
- header's bolts torque spec?
- HELP!!!!!
- Who sells Intermediate shafts for b16a(90-91 Integra) is what I need
- good price or not
- SRE Front & Rear Camber Kit Anyone experience with them?
- CRX si/ GSR rotor weight??
- Anybody with Skunk2 lowering springs please chime in
- cluster lights
- Dual bend skunk2 short shifter pictures?
- Really quick question
- How To: JDM EDM Backseat Installation
- Wire Tuck
- why is my crx still burning oil?!?!??
- My D16y8 with P72
- need help on my choice
