View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Which Exhaust To Get ?????
- Clutch doing really weird things.
- Sway bar not lineing up..
- Exhaust for my CRX?
- Anyone have GReddy SP2 on a crx? got pix?
- 4-point harness
- proper way of tensioning timing belt
- Looking for PS9 ECU pinout *searched*
- Willing To Tade!!!
- obx camber kit?
- boot torn on stage 2 axles
- THE Zc hose diagram
- I have a b16a1 question about my idle
- are springs the same?
- engine deals
- need wiring schematic for an 89 crx si
- Another Noob question. d16z6 + 89 Si tranny = which clutch and flywheel?
- Need help... car not starting
- help
- MPFI swap all most done, Some help please?
- zc tech question
- weight if d16 vs b16
- Speed sensor for YS1 ?
- newbie to the H badge
- kteller exhaust
- 18a1 motor mounts? cheap but good
- Problem with EDM door cards! Help...
- MPFI SWAP DONE !!! :D
- Bitchen Cheap Civic
- crx with b16 swap
- almost bought a lemon
- My Setup, 200whp quest into the 12's NA
- Brake pads for my CRX EE8
- need help quick fast and in a hury..b2 to b7!!
- need help asap engine cuts under strain HELP
- Who owns a 88 hatch or crx? - please help/participate :)
- Engine swap help. Almost finished-little problems
- Fiberimages hood+full-race+stock radiator = ????
- ZC
- I'm an IDIOT.... big F up inside.
- fuel pressure problem...
- clean engine bay
- How long do i have to be a member untill i could post in the classifies?
- ( FS: 90-91 Civic 4 door EX KNUCKLES + CALIPERS 10.3" Big Brakes Rotor for CRX )EX axles ??
- 91 CRX HF Misses
- performance i need help
- Drum brakes?
- i searched . i need a write up for head rebuild
- guages, oil water, electric
- complete b18 .... $250... broken mount bolts on block -- fixable?
- Parts from DA into EF? Possible?
- Hood and bumper interchangeable?
- zc question
- 1990 HB Sunroof Issue
- CRX DX B18B Swap
- Octane boost and CEL?
- HELP PLEASE!!!! URGENT 9/8/05
- how do u wire up the crank sersor for a zc motor in a crx 89 si
- b18a parts
- CV Joints
- hood clearance
- How long can I let an engine sit before installing it?
- Fixing redline on tach
- i need advice on a purchase!!!!! unfinished crx obd1?
- will oem 96-00 civic springs fit my 91 ef?
- If the cars a rocking and you hear a knocking (balljoints)
- OBD-I converted CRX, solid CEL problem..
- Engine code check
- 89+ Suspension
- B16 Swap question
- crx cruise control
- B16 Loss Motion Assemblies
- OBD0 ECU reprogramming
- What motors can be put into a 90 civic si
- Air/Fuel Gauge...Wire to ...02 signal...02 heater 1 ..o2 heater 2....wire 4
- Just saw a 1990 Civic EX WITHOUT rear disc brakes.
- crossmember labor
- Turbo'n my D15B7.......e-bay???
- b16a owners check in!!!!!!!!!!1
- someone wth a spare climate controls
- Starter Problem
- weird coil over height
- need help with an axle
- WTB 91 civic si (or compatible) OEM springs for cheap
- how can i clear these two codes
- Some More DPFI to MPFI questions......
- turbo zc?
- are all b series timing belt covers the same
- Stripped bolt......CRX......on shock tower help!!!!!
- Bushings...Shooting brother
- rally crx ? anyone
- check out my situation.
- 97 DX motor into 90 DX
- is this a good idea for a clutch?
- MORE BANG FOR YOUR BUCK?
- massive compression drop after few months
- Crank Girdle Torque Specs
- 90 Ef Hatch CHEAP
- floor braces
- MSD Dizzy Cap question??????
- Any Help...getting a sohc zc vtec.....help on install
- JDM ENGINEs CORP
- running poorly after sohc vtec head swap
- running poorly after soch vtec head swap
- vtec head conversion
- trunk latch problem....
- what year were pop up headlights???
- burning oil
- y8 swap done, now CEL's
- Car wont start sometimes....
- 92-95 springs work on a crx HF?
- going to build a hatch
- radiator cap
- where to get bumper lights
- del sol transtop roof broke
- clutch install checklist
- Wiring question, Using single wire 02 sensor, D15b in a 90 dx hatch.
- how can you tell if the clutch cable is going bad?
- looking for a CRX mechanic in WI
- CAR DIED WHILE DRIVING!!!! HELP?
- Overheating
- just wondering if anyone has these rims
- Are 88-91 Civic Fenders interchangeable? Need to know asap!!!
- Header 'Q'
- open header
- cv axels and transaxel gear?
- D15 block same as D16 block?
- d15b vtec tuning advices needed
- 91 honda civic swap
- B16A STUCK!!!
- what should i do wit my slow ass 4dr auto 97civic
- valve cover ?
- Anyone deal with crx_si6 aka Ryan from Iowa?
- front shocks
- 88 rear strut bushing
- RESTORATION!!!
- Question about SOHC ZC Motor????
- 91 Si crx FRONT CAMBER KITS
- ek d16 into a ef?
- question about swap
- b18a1 parts
- 1987 Civic HB Questions
- 88-91 civic si engine of tbi engine???
- d15b7 into a 89 si wiring help.
- Has anyone purchased from Nippon Motors?
- Omni Camber kit package.
- lets take sides here K vs. H
- now theres a kick in the nuts!
- 1987 honda crx si
- what is best for 91 civic si lstec/b20vtec
- engine cuts out
- ooooops, i broke the lights/turn signal switch
- ECU ????????
- reverse lights wont come one
- crx w/civic hood
- quick painless question (searched)
- Right-hand drive?
- Aimco clutches? are they really OEM?
- another wiring question
- rear wheel drive??
- built d-series runs but won't rev
- ex cluster in std
- crx with 92 95 civic front end for sale
- street/strip car challenge $5,000 budget
- 1989 CRX SI & 1999 Civic si Coupe
- CLEAN TITLE - CUSTOM TURBO D16y7 CIVIC HATCH-BACK
- GSR swap
- re: secondary 02 sensor for 1st gen b16a swaps
- only 3 cylinders firing HELP !!!!!!!!!!!!!!!!
- Just wondering
- quality CF hoods?
- tie rod/steering problem, need help pinpointing what to replace?
- 90 Civic Hatch is having problems.
- ef8 invidia exhaust
- eg knuckles?
- D16y7 swap in '89 crx hf...what ecu?
- EF hatch with b16a obd 0 swap vtec problem
- gas milage on a b16 rex
- Question about 90 Civic DX
- my chance at another CRX!! should i do it?
- Total noob question.....
- Front Passenger Brakes keep losing pressure..
- can anybody help me with my fuel consumption?
- running axles WITHOUT the c clamp locks??
- Best suspension for dd crx/hatch
- CRX restoration project, give me your advice, (with pics)
- code for a check engine light
- Header issue. . .
- hello boy
- 5 lug conversion on a ef
- Fuck thiefs!!!!!!
- HELP!!!ON SHIFT LINKAGE!!
- Who are running these?
- Looking to trade for a CRX Si
- Will rear disc brakes from a 94 gsr fit a 88-91 crx si?
- zc transmission
- engine coolant sensor
- electrical problem? everything turns off when i brake ..
- How Many Versions Of SOHC ZC?
- will smaller tires yield etter acceleration?
- how many mpg does a crx 89 si get 5 speed
- can you use 89 crx si motor mounts on a zc motor
- What kind of hp/trq to expect?
- Stolen hatch story
- Check out my REX
- GEAR RATIO
- help please
- Need to make room for a large FMIC
- need advice on what to do
- difference in d series and b series motor mounts
- post i read about adding terpentine? to fuel or something like it..
- parking lights/cornering housing wont pop out! HELP!
- REAR DISC CONVERSION
- car wont start hellp
- AN-R motor mounts
- do i have to switch em???
- B16 Axle question
- WTF, step up and vote.
- installing zc cam on d16a6 engine
- Found a pin removal tool for wiring connectors.
- Problem with Sir cluster in 88 rex si
- Boosted b series, trying to get it started
- Stock ecu "name"
- car wont start, then it will?
- vss problems
- My buddy's swap, pics and questions.
- need help with brake swap
- help dash removal
- Crank Pulley Clearance w/ Full-race Xmember
- Will a 91 crx si cluster bezel fit in a 91 hatch?
- B18A1 CRX HF brake caliper steering knuckle hub mix and match
- 89 crx brake question pls help
- TX: DOHC ZC wont pass emissions HELP
- how are azrace mounts?
- Can I run 5w-20 in my 91 CRX?
- top speed for 89 si tranny in 2nd
- free 88 hatch shell
- CODE 5 HELP, for the Love of God
- PR3 (obd0) chipping help (pic inside)
- after many weeks, its finally done, almost
- Heater Problem.....
- CRX with lips
- finally my hach is lowerd
- EG knucles
- fuel pressure reg.
- finally got my car going
- my 91 HB
- are sedan seat rails the same as hatch?
- crx problem please help
