View Full Version : Honda CRX / EF Civic (1988 - 1991)
- HEAD AND BLOCK COMBO (question)
- mpfi swap done but dumping to much fuel
- K24 swap - hidden costs?
- 2 main relays dead in 2 months time and now....
- No2Pencil build thread!!! (a good summer)
- anyone know how to install an s2000 engine start button in a ef?
- Proper "test-pipe" length for '89 CRX Dx w/ JDM OBD 0 header and OEM length Cat-back???
- help i need synchros ef with b16a1
- Identify those wheels, please!
- speed sensor cable problem?
- Transmissions Transmissions Transmissions!
- mini me??!?!?!?!
- EF Distributor wiring
- need help asap!
- jdm headlight conversion
- EK Si brake parts?
- Lower control arms
- HELP!!!! Car is reving at full throttle and wont stop!
- need to know if i have a bad injector or wiring ?
- y0 Vap..........
- Take a look at this CRX
- HELP PLEASE: ECU code 8 and 16
- i need MY PASSWORD TO BE SENT VIA EMAIL it says it will happen but wont
- what is this SI with b20 worth?
- for all with a S1/J1 B16 cable trans... want FD options?
- Track ready CRX !!
- stereo harness wire colors
- torq specs
- Exhaust manifold question?
- checking CEL on obd0-obd1 conversion
- DIY HOME DEPOT LIP
- need help car wont start
- 1985 SI HEADLIGHTS
- A friend needs help!!!!!!!!!!!!!!!!!!!!!!
- Fiberglass?? Metal??
- rex cutting up
- SOHC transmission question.
- Please help OEM Wheel ID
- new motor to start over on
- fuel system for d16y5 swap
- Problem with idle
- Melbourne JDM EF meet video
- rear disk on a ef
- stock shocks....
- gutted ef
- New to forum..
- Found quite an interesting hatch for a CRX, *pic*
- pic request: del sol si wheels on ef hatch
- D16 Mini Me Swap
- Automatic '90 DX shifts hard
- B20b swap 91 civic si
- altenator pulley
- Is there a spray paint that is similar to Rio Red???
- another almost finished a6 w/ z6 simple mild build!!!
- how much room needed to remove tranny?
- fuel cut off when it hits vtec help!!!!!!
- clutch help
- 94 DX (D15B7) going into an 89 civic LX(d15b2)
- DX tranny bolt up to ZC SOHC?
- about 2 give up on my crx project ! need opinion on rust issues.HELP!
- spindle (axle) nut help
- how to remove the door/window trim peice?
- importing a crx sir
- 90 civic hatch 4 speed problems
- 88 crx hydro conversion
- CEL Code help
- Here Is Another Of My Noob Question
- What Engine is this?
- Si Cluster Tach question?
- Changing the fuel lines (not a parts question)
- Is it safe to use spacer to gain hub clerance?
- axle removal
- WHAT IN THE HELL IS THIS????
- body moldingg/trim... what the best way to take it off?
- need help fan running while car off
- B18C Type R into Hatch will a Teg Radiator fit?
- Noise in transmission can anyone Identify this noise
- 91 civic whats the lowest suspension
- tokico whites with skunkworks coilovers
- EF HB si rear seats
- Another engine stand advice in relation to remoer's thread.
- crx and hatch windshields... the same?
- PVC Hose Size.
- CRX Hid / retrofit
- bad trans? bad clutch?
- My Experience with KSports
- for sale
- wtb:ef hacth door and fender
- JDM b16 fuel problems.
- overheating problem EXPERTS HELP!!
- best place to install extended wheel studs??
- awd sedan?
- alternator!?!?!?!?
- Entry-Level Suspension Suggestions?
- To the Fucking Assholes who like to treat me like a moron
- Fender flares
- HF is burnin' oil, what swap may be the easiest??
- Supercharged B18c Sir
- Does anyone know for sure?????
- oil pan leak??
- car has been sitting for 3 years, what to do?
- my 89 si, has 90-91 parts stock on it??
- wrong supercharger
- what the d-series tq specifications and tightening sequence?
- my ef build thread check it out
- MORE DOHC ZC HELP
- s2 pro2 or bc3
- Doing a D15B swap, need help!
- which valve cover to use for a zc?
- B16 PROBLEMS, HELP.
- Need help identifying a CODE
- Stock CRX paint suggestions..
- Stuttering - Wants To Die When Cold B16a OBD0 - Need Help
- HELP b16 obdo in to 91 dx
- 90 Civic Hatchback 4th gen. What seats can be made to fit- What "AfterMarket" seats are good?
- type r suspension on ef hatch ??
- how hard to add ac to 91 EF DX
- Brake warped..
- does 92-95 civic seat mounts fit on the floor pan of 88-91?
- got my jdm rail lights today
- QUESTIONS...HONDA MTF? and CLEANING MY BLOCK..DSERIES BUILD
- USDM B16 & JDM B16
- VSS, for jdm cluster....help
- ETD traction bars "Gen 3" - anyone use them yet?
- sir headlight question
- Locating Short to Ground
- d16a6 tranny synchros
- Revamping my EF (MPG guys check it out)
- Anyone using Eiback Pro-kit springs here on there crx ?
- Thinking about removing heat from my car.
- 91 dx problem
- car idles a little too rough. please help
- gsr with type R hydro tranny into crx, what mounts?
- 93 ex auto tranny in a 91 lx sdn auto.?
- wat color is the fan switch wiring for obd1
- Shopping list for JDM B18C Type R swap
- Crx ZC DOHC problem with ECU
- another rear disc question
- tranny
- do stock zc like turbos?
- Cam gear question
- B16 SWAP ON 87 CIVIC HATCH?
- Swapping a D15B Japan motor into a 91 civic...NEED HELP
- Power loss running way too rich
- ZC trannys use different axles?
- 88 crx si ( gas and temp gauges stopped working)
- code 28???? what is it?
- Check Engine Help. Plz! Kthnxxxx
- mis aligned crank pully?
- EFMashPlz' Build Thread....
- need ''HELP'' on my B16 only running 3 cylinders
- pilot bearing?
- Lower Shock Mount Bolt
- A6 head or SOHC VTEC head?
- Been Searching for Days!! How to Mount my Intercooler?
- nobody has a forum for 1st Gen Civic/CRX?
- Cross drilled rotors
- Very cheap alternative to aftermarket pedals
- Crank Angle Code?
- small belt for clearence
- clutch cable help on b16a
- Got My Motor Running!!!
- new setup.. possibly out of time?
- Im sorry but this is anther bogging thread...
- what parts need replaced for the jdm crxc conversion?
- Transmission Mount
- track times
- rywire harness
- cable 2 hydro conversion
- Strut bars
- Rear window weather stripping.
- intake air temp sensor
- oil in my dohc zc
- wiring for single bulb corner lights
- B16 no Reverse light !! help!
- jdm parts ?
- Y1 Intermediate shaft - Rebuild / Replacement
- exhaust (baffel?)
- ZC: Broken timing belt
- zc dohc with a d15b2 dpfi will work
- crx si help!
- anyone have the sunflower wheels on their ef??
- RSX seats in CRX?
- Why you should check your cap and rotors regularly.
- Questions about hatchbacks.
- need help on oilpump issue
- Alternator helms manual DIY
- A good clutch to use with a ZC motor? (brands, not Diameter/splines)
- Suspension Question
- replacement engines?
- Suspension Issues
- anyway to fit 225/50-16s on ed/ef?
- Are these Springs any good...
- Ef bseries A/C Question???/
- d16a6 cam in stock d15b2?
- 89 crx converter to 92-95
- should i sell my ride?
- Car takes several cranks before it starts, Anyone else have this problem?
- Loose flywheel?
- any diff between crx dx and si heads?
- A/F Gauge question
- Transmission question
- obd-1 injectors rc 440
- Hesitation in Warm Weather, but NOT When It's Cold
- bumper lights
- bre ?
- Mini-me swap parts list check, help please
- lip for my 4door?
- This or that? Engine suggestions please
- Lip for EF-9
- looking 4 a traction bar 4 my 87 crx please help me thanks
- anyone have the drag turbo kit?
- Red striped siR molding
- My single cam vtec turbo build
- Which tranny do I have?
- h2b crx
- crx sputtering
- Searched! Car won't start after rebuild. No fuel No CEL
- starting issue
- D15 head on a D16 VTEC?
- help??? i have an 88 crx si engine harness and a 91 crx and one plug that is differnt ?
- OBDO Distributor question
- CRX d15 Tranny issues
- couldnt convert dpfi to mpfi NEED HELP!!!!!!
- h22 in a crx 89
- Any Honda or Crx groups around clearwater Florida?
- Please help with my unknown problem.
- CRX Type-R
- 91 civic with B16a not running right
- prelude master cylinder with stock resivoir
- gauge cluster lights not working?
- Leak in the driver side door. Has anyone else had to fix this?
- 99 b18b
- Does a 1990 Civic AWD wagon have any redeeming performance value?
- JHP USA conversion harness and Bosch universal 4 wire o2
- V-tec kicks on and then off AND THEN ON AGAIN...SOME FREAKING HELP WOULD BE NICE! THIS IS A TECH QUE
- is this a good price for a ef8 bumper ?
- Various Bits
- saved another from the junk yard
- Thermostat/water temp gauge problem $@^!#& get your attention?? :)
- crx issues please help!
- ECU CODES HELP??
- water temp and oil pressure gauge install
- Eeeep!
- need help on a vac leak on a z6
- Anyone have Ksports on there crx or civic?
- Vacume hose (pics) B18a unrouted hose
- ~FRONT CROSS MEMBER TROUBLE~
- crx si to Vt headlight wiring help
- I did it. Finally
