View Full Version : Honda CRX / EF Civic (1988 - 1991)
- bhp?
- ZC distributor seized, Si distributor work?
- I need the size of EF Fogs PLEASE!
- suspension help
- Not the main realy, what now
- multi swap help.
- which struts?
- Radio Trouble
- cutting the prokit
- Buring Gas Faster then normal. What could be the problem?
- Has anyone (company or individual) had any success with making a b-pillar (or hatch strut location)
- rear brakes?
- rsx-s seats into a 95 civic....can this be done easily?
- Hmotorsonline.com or other?
- Alternator removal question
- compression tester should be how many psi on ZC engine??
- Can Offer JDM/EDM CRX 88-92 Backseat.
- 3000k...bog out
- D16A6 stock Pistons
- Check Out the New Wheel Color! JdM Braahh!
- b16 or b18 in a crx
- Found a CRX for $500, BUT...
- speedo
- DEF. STUCK
- Where can i get those window visor things?
- jdm cluster...s1 tranny...speed sensor
- Car wont start
- what is a dizzy
- mid pipes moven the fumes
- zc problems please help
- Electrical gauge ?. (one wire gauge/two wire sending unit)
- *** Lower or Faster? *****
- D16z6 swap in 88 CRX power issue
- Doing a y8 head, mani, ant tb swap, anyone know if the plugs will line up and work, or do they need
- major problems
- 92-93 gsr tranny need help
- overheating issues
- 83 fo door civic
- need suspension and braking components
- best parts to use?
- Help...clunking noise in my front end.
- D16A6?
- Stock CRX si wheels (88)
- ***not happy at all with h-t prefered seller **ITSTOCK**
- not too happy with my pro-kit !
- Stock CRX Spring rates?
- waht should numbers be on ZC engine?
- Apexi N1 turbo muffler rusted out!
- Whats the biggest rotors i can use?
- D16A6 swap...but only 3 mounts...can i do this?
- Axles question!!!!!!!!
- '89 Hatch w/95 teg rear brakes and Sir front brakes what S/S brake line kit?
- What are the differences between front and rear springs?
- b16 crx carbon fiber hood.
- FAILED EMISSIONS ... what to do?
- who makes springs/coilovers for first gen rexs?
- B16A's with ITR Manifold...What TB?
- factory paint colors for the ef???
- heater from hell...well not really, hell is hot
- List your personal EF web sites here
- just won jdm cluster. hehehehe
- Question about Type R intake on B16A1 head (PR3)
- CEL! Can you give me a list of all?
- :FAQ: How to Remove CRX Door Sill (56K Death)
- :FAQ: How to Remove CRX Door Panel (56K Problem)
- :FAQ: How to Remove CRX / Civic Steering Wheel
- :FAQ: How to Remove / Rebuild / Test CRX Alternators (56K Sorry 2MB in Pics)
- American vs Europe
- ITR suspension with Mugen Coilovers?
- problems
- anyone running the stock ITR airbox assembly on their EF's?
- jdm front end clearance problem
- Sunroof on an HF?
- HELP with wiring stuff
- Another suspension Question
- Ignition Coil question
- ITR sway on a 89 CRX Si. Maybe.
- someone tell me if this is broken
- anybody took out their climate control on their crx?
- 89 Si Seats in an 88 SI
- CRX bogging below 3,500 rpm after 1 min of drving untill warm.
- 92-00 Neuspeed Race springs fit CRX?
- JDM EF front end conversion
- H&R race springs with KYB agx's?
- rear brakes stick CRX
- Can you get frosted tails?
- any one have any directions on taking off the alt. pulley
- quick help! compression values
- *questions about zc swap*
- DOHC ZC
- 1990 honda civic dx wiring ?
- ** Basics on Dropping my car?? **
- ECU ?
- Strange Problem... Need Help...
- Which sway bars to buy? Neuspeed, Eibach, ST
- Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
- Alternator whine ?
- B18C5 Review
- 88 crx si tranny different from 89-91???
- anyone have pics of a stripped/caged EF hatch interior. BARE?
- New Poll: Quaife Differential - How Interested R U in....
- intake questions for 91 CRX/B16...yes i searched
- automatic obd1 ecu on 5 speed tranny
- Wanna paint 89 CRX Si sawblade rims... need part #
- Dyno Day.......Free Dyno Pull
- going carbed
- 90 civic ex knuckles or 92 teg knuckles???
- ZC with a 14B.......update
- is it true???
- SCAMMER ALLERT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
- is there a ring difference?
- b16 upgrade path.
- aftermarket LCA's
- OEM Head Bolts: Do I have to re-torque then?
- hey peep this my peeps
- calling all tranny tech heads !!!!!!!!!!!
- F/S 91 civic hatch dx w/ b16a sir II, SD, california
- Help.... not that this ever happened to anyone but.............................
- Anyone have their clutch pedal break?
- Auto Meter GP's
- Carbon Tuner looking for 88-91 CRX Sponsor car!
- HELP code 8
- CRX or Corolla (86)
- free black 86 crx si
- Need a pic of rear JDM seat cover?
- Need help choosing a steering wheel
- annoying noise and vibration..?
- VIS CF hood.... where to buy?
- zc, si tranny, adn si axels?
- what do i need....please help quick
- good intake manifold for b16a
- I found my CRX!! How much should I offer?
- 1 crx wasnt enough for me!
- May pick up 1990 DX Hatch
- need motor
- b16a with gsr head that has broken valves for 600 good price?
- CIVIC SHOCKS! which ones are best for you?
- sohc turbo question
- I need an oil pan for a brown-top ZC, anyone know if the US Integra counterpart will fit?
- I need help with my ZC SOHC
- made my own car camera mount
- Flowmaster Exhaust
- pour one out for this fallen CRX...
- my RHD civic EF9 project... pics...
- What is the deck height of the B16 and D16?
- website
- b18c1 into 88 dx with hydro conv. questions????
- my car bounce all over
- let me know if i have everything covered
- Ignition Switch Help
- F/S 91 civic hatch w/ b16a sir II, SD, california
- please help with electrical draw problem
- my lights suck
- Looking for ECU
- right way to install GSR seats
- pic request: civic interior
- JDM S1 4.40 final Drive swapped into USDM S1
- Adding vtec to a B18A1
- ignition problems in 88 hatch
- v-tec pin outs?
- EF trailing arm bushing the same as a DA?
- Engine Swappers, PLEASE check this over...
- What kind of TURBO should I get in my 1991 CR-X SI?
- A crazy idea
- How long do copper NGK plugs last?
- What kind of engine should I get in my 1991 CR-X SI?
- LOOKING TO TRADE MY 90 YELLOW CRX SI 4 90-93 TEG IN THE NYC AREA!!
- What's this noise sound like ?
- For those wanting the ls 5th swap some news...
- what seats for my 87si?
- 89 4dr
- STARTER which one to use
- does EF SQUAD have a website......
- propr valve
- need some info on 99si cluster into a 90cr-x si , please help me........
- Front a rear strut bars?
- help! d15z6 with v-afc
- What Brands offer the civic hatches the stock looking exhaust
- quick ef noob qeustion for axles(help)
- lowering
- part # for K&N CAI intake filter
- searched * wide band o2. what are you all using?
- 1990 CIVIC SI REAR INTERIOR SIDE PANELS???
- need help...valve noise??
- looking for a spal radiator fan...
- Taking off Body kit
- How to distinguish 90-91 EX knuckles from Si(s)?
- are these really needed for drag racing?
- What can be swapped into my EF from a 2g teg?
- List all 88-91 STOCK CRX colors, please.
- search didn't help what seats fit
- I need 90-91 Ex knuckles and hubs....together or seperatly
- CRX carbon fibre, powered spoon style mirrors!
- Mechanic in Atlanta?
- OBX intake manifold
- Buddy Club P1 G-M 15" wheels
- Pics of my car.
- 91 integra ls motor f/s
- 88 CRX
- DUDE, WHERE'S MY REX?
- supposily rare piece for the crx!!!
- SELLING MY DOHC ZC MOTOR /TRANNY/ECU
- MSD RPM ACTIVATED SWITCH WIRING HELP FOR MY CIVIC
- 88 si intake manifold on 90 Short Block?
- Clutch for ZC?
- building engine
- weird tail light problem, someone PLEASE help!!!!
- jdm crx front bumper question
- neuspeed race springs on a 88 crx problem
- want to know what that site was 2 install 99 si cluster in 90crx
- getting code 1 and 7 only while driving
- t-3 exhaust flange PLEASE HELP
- b16 clutch options eCLUTCHMASTER ?
- Wierd Noise Up Front.......
- lil cam problem, need some info
- Those who bought summit racing mandrel tubing for your exhaust...
- Code 6 and battery not charging on 88 dx crx
- Integra Rear Discs
- Any B16A owners using DA front Knuckles?!
- what swap to do?
- Paint black exterior pieces on crx?
- weird charging problem
- D16Z6 Boost and Build
- To those of you building your own air dams, splitters, or brake ducts (56K can EAD)
- D15B2....o2 sensor code
- High speed vibration problem, PLEASE HELP!!!
- question on tail lights
- good place to have my crx painted in nyc area?
- gold top zc w/ vacuum advance dizzy
- tell me whats wrong?iam trying to make sure iam right
- is it worth it?
- How can i tell if i have an si tranny???
- Civic CRX Questions
- Newbie w/ question about vacuum lines on a6
- Will a CRX rear bumper fit a HB
- Check out my gauge pod
- zc injectors
- Electronic windows...
- cars about to die when i turn on my lights
- Wiring woes
- rear window squirter removal.. need help
- I got my new car!
- tein suspension
- DOHC ZC Vacuum issues
- Are 88 DX hubs the same as 90 Si's?
- Exospeed Vs. Zex cam
- Help! brake lights wont turn on and the bulbs arent burnt out
- B18C1 CRX Si, need help with a few things
- Rare seats
- what code is type r white??
