View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Swap Question? Hf to Dx with MPFI conversion:Whats needed.
- b series swap need help asap!!!!!!!!!11
- Help with Tach Install
- code 4
- decent engine find?
- 88 crx harness!
- Blown D16a6
- CRX rear DA disc swap. MC????
- Checking electrical draw from rad fan on 91 std hatch?
- car idles at 2000 rpm when first started
- crx with roll bar.
- i have a problem with my rex doing the mexican hat dance !!!!!
- new problems. help please.
- vibrate
- Ecu Pinout and Wiring Diagram
- New headgasket... engine wont rev past 3k and dies at idel
- help!!! crx wont start!
- Need Help
- Damn those CRX seats !!!!!
- seat question
- ep3 seats in an EF hatch
- Another "Bitch Pin" question
- i need help about moonroof motor
- auto trannies..what will work?
- pr3 chipped
- Any good LMA write ups?
- swap!!!
- Intake making whistling sound.
- what clutch to use
- my rex is acting up, help me solve this problem
- Flywheel inspection plate
- Possible to add ABS to 2nd Gen CRX?
- opinion on brake master cylinder for an ED6
- dx/si hatch speaker pods/cargo lid fit std civic?
- compression + timing = octane?
- poor mans r buildup
- Quick write up on air condition removal under dash.
- HELP!!!!!
- trottle angle
- Thinking about building a d series head, need some advice.
- 91 civic b16a build
- Bad ball joints?
- Hydro tranny into EF using Innovative Mounts cable/hdro conversion
- edelbrock manifold/ fitment
- what can i get a tranny from
- Expertise needed for my crx si mysterious problem
- ECU question!
- intake fitment question.
- B16 questions
- climate control lights
- HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!
- B16 cold air intake in Crx?
- Hawk HP+ Pads,what rotors ?
- The Best Way to Remove Rust
- switching from cable to electric speedometer
- help finding part
- CRX4 sale SI yellow
- any single cam ZC VTEC info appreciated....
- removing wiring from 88 civic four door drag car?
- Legal Smog?
- Honda Newbie, need help
- code 7
- Will JDM Headlights fit on my USDM front end?
- rustie fuel lines
- Quick Question
- What car would win
- Brake Booster
- 91 CRX SI Problems.
- A/C switch to arm nitrous?
- big help please
- diff exploded on turbo b16
- how much?
- shock problem
- AXLES don't fit!!!!
- will ODB-0 run in limp mode with no code showing?
- electrical speed sensor and guage cluster from EG in my CRX
- Sorry I am a Newb. How to do you post pics?
- photoshop 5zigens on 89 Si
- engine swap for 87 civic
- CRX Si, B18B1 swap, Cranks, Doesn't run? Fireballs. =D
- ef9 front clip
- How to fix Rear Defroster Wires in Rear Window?
- Issue with brake lights...
- Rims
- Pic of my new HB....this is gonna make for a good "sleeper" project
- 88-89 Fog Install?
- Interlock Control Unit??
- b16 CRX cutting out intermittantly
- How do you re-solder the main relay?
- Car completely STOPS on the freeway ????D15b2
- skunk2 manifold versus ported stock manifold
- Car will not start
- auto throttle cable on a GSR
- usdm p30..
- tps sensor HELP ASAP!!!
- b16 knock sensor clarification???
- burned 2 starters what can cause this problem?
- How Much Do You Think My EF8 is Worth?
- Car dies wile driving, searched
- Best Dyno Tuners???
- koni's from ek
- power door locks in ef hatch
- shift linkage question?
- I got rid of my EG..now got a 88HB..few questions
- Project: Black 1990 CRX Si
- Eliminate Alternator?
- headlight fuse
- Any one running these Kosei K1 TS
- connector
- intake mani q's
- B16 surging and power loss
- Radiator Fan Help (searched, oh god did I search!)
- Need to raise CRX, I have coilovers (have pics)
- smog help!! (searched)
- Swap O2 sensor placment? B18C1/CRX/ITR Manifold
- tranny problem
- need to know my trans year by tomorro
- Civic Special Edition
- EF calipers ?
- 91 integ rotors
- Help!
- <<<<<<helping out a friend>>>>>
- help with 89 crx
- surging
- Speedo Lube
- D15 CEL Code 10 and 15 Searched! Help please! Other problems!!
- Need Help With Lowered Civic 91HB EF
- D15 dist. order
- CRX Fuel Tank Installation
- B18A in a 88 crx HF , got some problems. please help
- CRX Weather Stripping.
- I need a new suspension
- bumper filler removal
- "SL" Gear on 4WD EF's
- 91 hatch dx hubs??
- tranny oil
- does anyone own a AWD 88-90 civic wagon?
- JDM Non-Facelift Fog Light Bulb
- 88 crx si mini me won't start
- dizzy issue
- Headlights flickering on my 91 hatch
- sir pr3-2 question
- bad igniter or fuel pressure regulator?('91 sedan)
- SiR Conversion
- I just got my buddyclub exhaust in and ...
- Project EF, B20B Turbo, 89 Civic Si HB....56k go away
- Need a little help
- possible new CRX build? turbo owners check in.
- what gaguge cable should i use to but my battery in the trunk of my car ?
- clanking noise when accelerating from a stop
- distributor
- Seized but I can wrench it into working again?
- HELP
- $350 to spend on what?
- rear discs
- Car sputters when starting off the line with <4 gallons in the tank.
- sandwich plate on a6?
- CRX DRLs?
- 90 Doors on a 88?
- anyone know the part number?
- what ecu is this
- need help choosing a tranny!
- Anybody done a cruise control swap into 89 Civic Si HB?
- are universal O2 sensors fine for use?
- I am NOT ready to retest....grrrrr
- Trouble Codes Please!
- i need help on my fuel sending unit
- Favorite CRX!
- am ready to retest?
- how much should i boost in my ex
- Need Help JDM Seats
- wheel bearing Q?
- Tokico springs(part 5046)
- umm...guys am i missing the dizzy spring?
- replaced head with 98 civic head car turns over but wont start
- what quick release steering wheel do you use?
- How much $ to get a crx into the 13's?
- amber corners
- 88 si brakes on a 91 dx
- How much power realistically is too much power in an EF.
- window visors
- what body kit is this set up
- OMG... another turbo EF hatch
- full race traction bar question
- EK seats in CRX
- LSD crx
- 1-layer head gasket???
- ID DA KnuCkLeS
- sidemakers
- heatercore help
- Revo technica camber kit
- B16A distributor problems
- CRX suspension similarities(hf,dx,si)
- i need help with my v-tec
- Steam coming from the hood
- b18a1 trouble!!!
- fuse box
- 91 CRX Si rear disc
- 90 hatch fog lights
- please help me
- carbon lips
- lexan hatch
- 91 HF rex, MFR location-Need help asap. Thanks
- QUESTION About V-AFC II
- i need help.
- SI COMPLETE
- pston setup for my B16A
- traction bar question
- need some help on wiring
- mpfi worth all the headaches ?
- 1/4 mile times
- FAQ 2.0 link NoT WorKinG For ME DA MC question
- new teg interior in my crx
- crx hf with b18c1 and gsr block! = 2.0 liter
- CRX WONT START!
- going to get some rota slipstreams need some advice
- megan or obx headers
- i hate the rainy season - water leak
- F22 (i think--90 accord) into 4G (89 3 door civic) axles, et cetera
- brakes and maybe tranny????
- Subframe question
- timing belt
- question
- Elf's 91 hatch build thread. (LONG over due...)
- Timing Belt Noise !?
- dual point question
- Shift linkage question: Can I use my slush 4 speed linkage for my Si transmission??
- CRX window seal for door... price?
- 90 hatch STD b18a swap knuckle question **already searched**
- Weird Overheating issue
- Alternator questions about wiring
- I need Help
- Do they exist and where can i get one??????
- ok
- searched. how to remove side moldings from door?
- EL Vap133
- quick question
- NEW! Ef picture thread ( just random pictures of your EF )
- vibration problem
- CRX with Turbo/FMIC...post them up!
- crx coil overs
- i want to build a d series track car
- code 9..
- crx tranny
- Hey guys, Im new here.Mini-Me problems.
- car shuts off while driving, HELP!!!
- no spark...
- What Intake Manifold is this?
- ef sedan help quick
- B16 CAMSHAFTS
