View Full Version : Honda CRX / EF Civic (1988 - 1991)
- power windows in a ef
- Mini me swap, buring coolant! why!
- Overheating issue
- wtf is a knee?
- is this head blown!?
- Will i ever find that Mugen exhaust?
- reoccuring O2 sensor code
- Wheel size
- help
- radiator hoses b-series 91 civic hatchback
- name this armrest..
- crx leaking bad up front
- wtf!? im stumped. anyone else have this problem?
- Battery Relocation in Sedan
- Intermittent gas smoke
- automatic transmission jerks on downshift
- AC system install on non ac car
- Where can I find this car?
- B-Day Money = First Swap
- obd0 or obd1
- Rear sway bar question
- No power to wheels, but engine runs fine
- boosted crx problems
- Help low oil light comes on only at 1K rpm. WTF!!!
- CEL Code 16, unusual sysmptons
- smokes like a freight train
- Old school, issues
- Sticky Throttle Body?
- Little, Sputter...
- how low can u go
- tein s tech springs installed, front looks higher?
- HELP!!!!
- Check engine light!!
- Seat Setup?
- lets see your bays
- Does anyone think a Honda CRX will soon become a classic?
- Best site to buy your swap(Confessions)
- HELP!!! D16a6 non vtec
- 91 civic guage cluster question
- EF Civic doors on a 91 CR-X si
- b16 wiring questions
- Measurements for e-brake cables?
- 91 not passing smog
- tempature guage problems?
- DA Integra exhaust on an EF four door
- Anyone know of bolts that require a special tool for removal?
- Needed ASAP: Misc Part?
- anyon got hasport mounts laying around?
- best tool to use to cut plastic
- Clutch Question 91 EX
- i got a sedan
- B18C type R drivetrain problems!!!
- need some help with my crx
- obd0 b16 dizzy question
- EF B16A throttle cable help needed
- 500hp 1.6L f1 CRX?
- help again
- Best B series engine swap? B20 b18 or b16??
- a6, y8, z6, or another block?
- car died on the way home.....
- Mechanical Speed Sensor Conversion?
- **** honda tech!!
- To Mini-Me or Not?
- ZC swap??
- No brake pedal pressure when engine on.
- Recently purchased! 1988 CR-X dx
- car missing a little?
- Do i need a AC tension pulley to have ac?
- oil pan for b16a?
- car died now wont start
- Pressure plate???
- what are these?
- LS VTEC HELP
- 1991 Stock CRX Compression test results
- clutch question?
- Mini Me Swap, 3.5k idle and blueish smoke??
- P8R Cams Vs LS cams?
- ebay headers, Questionable?
- Wiring Problem
- question about the fumes hard line.
- si vs dx engine and dash harness
- How to Reupholster Door Panels
- Need advice with my b16a crx
- bogging problem after mpfi
- Road To Redline Build
- Ultimate Honda Engine Swap Guide
- Opening Up TB on Dual Point
- EK Mirrors on ED?
- Dual Point d15 to Dual Point d16
- Mini me Swap, 4,000rpm idle? help
- how to tell if its a dx or hf
- lsv oil leak
- pedal assembly options
- have a hesitation question
- weber side draft tuning
- quick spark plug gap q.....
- mini me head job
- Just turned my car on yesterday... with a problem...
- windshield removal
- overheating
- Spongy Brakes when vehicle is running Help
- d16 head on a 88' d15?
- Wood grain wheel help?
- mi hatch was gargling
- Removing the Alternator
- !Help! Turboing D15B2 !Stuck!
- STD Calipers on SI Knuckles..?
- another "what should i swap?" thread
- okay i need a little help
- Car chooses not to start sometimes. Starter Going bad?
- need help wires heating up
- A/C o-ring from Autozone question
- crx b16 issues
- CRX has a jumpy tach, car is running fine
- My Northwest EF Build
- ok.... now what???
- speed odometer isnt working
- camber kit question?? help!
- Alternator Question
- my little problem
- 91 ef lost power while driving and died and now wont crank over
- 89 civic lx acceleration hesitation and tach jumps! help!
- Swap OBD0 dizzy sensors into OBD1 diz??
- Cluster swap, dimmer switch and rear defog wiring
- What happens when a ball joint falls out?
- d15b2 crank pulley
- K20 swap 91 HB Civic
- b16a wiring question
- OBD0 Code 15?
- where do you put in the transmission oil?
- Horrible MPG Solutions
- iat sensor
- new clutch question
- "Project Cheapass" 1990 white civic si
- b18 coolant boiling in reservoir
- motor swap
- DOHC ZC running hot
- hit a curb, bent subframe
- post pics of your seats
- intermediate shaft bearing
- whole gauge cluster not working!
- Interior Help
- need help with b16a swap info
- TDC and CYP help
- wheel hop?
- problem starting
- ok b18a1 swap quesiton
- do EF's have a flasher??
- Bi-stage 91 std hb build. d15b2>turbo kit>tune>d16a6 engine build>re-tune
- horse power
- Anyone one on the east coast have an LS for sale?
- Oil in spark chamber 4
- Why is my dyno graph spikey from 6k-8k?
- quick crx ? (front end swaps)
- MY Build (alot of pictures)
- Need info on a complete B16 Swap
- CRX 89' complete brake conversion...
- shift linkage slop
- HELP!!! D15B2 Stock Auto Tranny
- wtb crx si harness
- how to :starter ?
- 90 crx si cluster in 89 crx si help.
- Electrical problem with Door!!
- calling all who have done a b series swap
- crx center console
- EF obd0 b swap w/ hydro GSR trans questions
- AC line question B series swap.
- no tach, interior lights, fuel gauge, clock, water temp gauge, turn signals or backup
- ZC Swap Help
- OBD2 JDM D15B Stage 2 Vtec In EF
- TORQUE SPECS d15 b7
- OBD1 EF have fuel problem
- crx b18 swap harness problems
- Motor mounts please help
- shifter question
- Not getting Fuel?
- Starter question. help please.
- disc to hub screw replacements?
- which is which? inner tie rod question
- how to fit stock crx mouns on a hydro d series trany
- Barcode's 1988 Honda CRX Si Build
- Stock radiator swap
- My new 88 hatch
- How To Mount 90-91 Civic SI Seats Into CRX
- How do I make a d15 sohc vtec and fast.
- 1991 Civic DX Sedan Can't Reverse?
- Replica Spoiler for hatchback
- JDM TEST FIT *ON CAR*
- Help with fuel cell and in tank pump installation
- suspension on a 88 ef
- EF rear disc - toe arm question
- HELP!!EF8 RIM PAINT DECISION BLACK/WHITE
- 90 crx cluster problem
- 90 CRX, rebuilt engine whine
- 90 civic not going into 5th
- hood latch ?
- should i remove my abs?
- 1988 Honda CRX Si B16a2 OBD1 Ecu error
- Speaker wire??? please help
- blower question... ef problem?
- THE SIMPLEST HYDRO CONVERSION EVAR
- 89 CRX Auto to 5spd ????
- 1.5l water pump replace question
- fuel injection troubles
- d15b1
- what parts can i use off of my ek civic?
- tranny questions
- 88 Crx dx stuck on removing Clutch assembly under the dash *I SEARCHED*
- CRX D15B VTEC SMOG RESULTS
- ek to ef suspension
- a/c problems
- crx to ek suspension.
- what tranny is this?
- need a new map sensor
- another fuel issue.
- ball joints ?
- Aftermarket PWR Windows or Not?
- B16 CRX Suspension Problems x2 Help me out
- Rust Issues, help needed
- starter question(s)???
- hmm..should i pick this up guys?? ONLY IN MONTREAL!!
- OEM japan. kinda dumb question i think.
- I know this has been answered for DOHC but can't find SOHC
- fuel injection problems, prolly an easy fix lol
- What the heck? Turn signal trouble?
- Ac compressor (90 std hatch)
- Running Rich, O2 sensor reads lean
- Help with seats
- CEL code 4
- d15b2 with Z6 head mini me issues
- Widow regulator
- Best Bang for the buck...
- Update on my project car.
- crx si wiring help please
- Fuel Problem.. ?
- Who can tell me how to remove a Lower Ball Joint?
- 88 CRX Walbro fuel pump problem
- Swapping a B18A1 in, have questions
- B18A cable ef trannsmission problem. Please HELP
- Does anyone know who makes EF civic fiberglass or carbon fiber doors
- coming soon: JRSC ITR EF!!
- Trick to slide spline all the way into spindle - HELP
- 88 HATCH HELP PLEASE.
- 1990 crx b16a swap question?
- b1 and b2 Intake Manifold differents ?
- F22a1 swap into ef GOOD or BAD?
- Im changing my tie rods right now. NEED QUICK HELP!
- Intake Manifold Suggestions?
- car slowly died, then started after awhile, then repeated
