View Full Version : Honda CRX / EF Civic (1988 - 1991)
- need help putting 1 pc headlight on the ef
- MUGEN stripe?
- 1990-1991 Honda CRX Si seats fit 1989 HB????
- D16a6 idle control valve Question
- air intake tempature sensor?
- horn, interior lights, brake light wiring
- gsr cam question
- Skunk2 Coilover owners - I have questions for you.
- crx door pillar? Not sure what its called.. how do you put it on!
- What u guys think about this combo.
- Radio blockoff plate and Antenna blockoff plate
- shift linkage
- transmission or clutch?
- Replacing weather strip rear CRX windows? How to?
- My car shuts down and wont start back up... i move ecu around and its good.
- Anyone running the Addco 88-91 Swaybar?
- Honda tech EF old school?
- PLEASE HELP Fuel injectors
- neon radiator
- y1, ys1, whats the diff?
- thoughts on JG 301X cam
- 89 civic std brake upgrade question
- Ride is off to the paint booth!!!
- little piece=big problem?
- some one in CA help me out . i need a motor asap
- Is it possible to buy jdm wrap around turn signals?
- Someone that knows ALOT about ZC's NEED HELP!!!!!!!
- MPFI swap on 91 CRX DX
- What problems do you run into........
- My tranny exploded!!!!
- Electrical Problems
- crx question.
- ... exhaust fumes during deceleration (espcially after highway speeds)
- New Civic
- 88-91 civic sedan front/rear spoiler
- quick exhaust Q
- Good ol' days.....
- tranmission help
- what lateral G's can a crx si with mild suspension work get?
- ZC or D16a6 all motor bulid up??
- Integra MC into Civic: Is it ok to use the Civic Booster?
- alternator probs
- Will 88-89 CRX bumper fit on 90-91 CRX
- NEED ZDYNE WIN98 BINHACKER!!!!!!!
- What would you pay for this CRX DX?
- i need to remove the crank pulley bolt while the engine is in the car
- 91 Hb SI
- When wiring the door triggers for an alarm.
- will a 89/91 crx si rear sway bar fit on a 88 crx DX?
- Look at this..
- Basic tech question: Crank bolt reverse thread?!
- trans. swap
- B seriestranny mounts........all the same???
- b series in EF crankshaft pulley rubbing tie rod end
- Found J's Racing Intakes!!
- Production Numbers?
- EF question
- Hood wont pop...any ideas?
- 3k rev limit WTF? Help!
- WANTED:STOCK BODY PARTS
- IAT sensor
- Why cant i post
- WTB: 89 crx
- dual tip si exhaust or single tip?
- itr intake manifold
- customs 4 door 1.5 civ ran a 16.4
- mpfi swap problems...
- my car is overheating..... help..
- damn check engine light at highway speeds
- honda ads?
- Good shops to get dyno'd and tuned in Atlanta?
- d16y8 swap ??? (throttlebody + crank gear)
- Need help with Intake Manifold vacuum hoses
- APexi world sport on a EF
- Wiring help needed- b20b into 89 DX CRX
- Turbo crx ppl what radiators you use and cooling set ups let me know!
- 89 crx HF cluster in 89crx SI will it work or wiring needed???
- Help review this price quote for me plz.
- b20 crx times
- Broken ITR TPS
- Change odometer mileage
- ek sus on an 88 std hatch?
- having problem with clutch
- V-afc wirring diagram
- whats a good 4pc strut bar for 89 crx?
- ran my b16 at the track 2nite
- All my San Diego Honda-tech bros...
- help with exhaust and coolant sensor
- 89 Accord Strut ?
- gsr dash in 90 civic dx
- Will crx stock springs fit in my friends 91 civic?
- HELP! Code 8 and 14! B18A in CRX DX
- B18c1/GSR.....okay with PR3 and FPR?
- Anyone ever seen a Mines tuned ECU?
- 92-95 civic harness into crx?
- Exhaust Set-Up . . 2.25 or 2.50???
- FS-EG6 PARTS
- zc swap question
- Model kits
- how to take off rear bumper from 90-91 hatchback?
- skunk2
- D16Z6 rebuild list, am i missing anything?
- wut do u guys think of rite hand drive GS-R 90' CRX???
- i think im going to use si wiring
- EF D16Z6 JRSC
- 91 crx SI... $200?
- Anyone wanna trade for a SHOGUN front end
- Code 15 Problem ?
- 88-89 corners fit on a 90-91
- ebay auction yet again
- tips on removing the bitch pin?>?( 88 REX)
- 96 ls motor , no pcv valve or box under intake. why?
- main relay problem
- Those who have installed an alarm in an ef.
- Ghettodyne rom
- LSVTEC or B16
- pr3 piston in b18
- whats wrong with my car..
- warped head
- GSR shifter in 89 EF hatch?
- anyone with clear bumper lights, what bulb did you use?
- CRX DX = No AC?
- JDM SiR Gauge Cluster Install into a USDM 4th Gen Hatchback?? Help Please!
- b16 block + gsr head = ?
- anyone selling a D15B2
- sohc VTEC swap in 87 Si questions.. . .
- how do you remove pins from ecu plugs?
- anyone else's ignition switch ever go bad?
- subframe bent
- Anyone ever put lexan in place of hatch glass on CRX? I have questions.
- is going from dx to si trans worth it ???
- why are the gears grinding going into 3rd?
- Auto-reseting fuel cut idea
- Steering wheel vibration...
- b16 set up in 88-91
- can somebody do a carfax please?
- oil pan leaking (help)
- Is the si thermostat same as b16 thermostat?
- Please help! 93 cx 16 valev upgrade
- anyone have a 4DR painted black?
- Value of hydro d series tranny
- removal of cable VSS in CRX D series tranny...
- Racing seat bolting points for Mr. Saturn on 90 crx
- stupid coolant temp. sensor / plug question...
- B18A1 swap completed (pics)
- PROBLEM.. ANY IDEAS?
- locked out
- walbro 255 fuel pump fit?
- Here is my How-To on MPFI
- Engine Hydro Lock
- OT: crx related
- Throttle cable
- dpi to MPFI swap... quick ?
- cylinder #1 is next to the dist. right?
- I have coilovers, which way is higher and which is lower???
- Do I need a 90-93 teg clutch cable for my B series?
- Z6 or Y8 for minime
- how much does a crx weight?
- Problem after MPFI swap
- NEED HELP: ele. lighting.
- do i have to drain the radiator fluid to remove the transmission???
- all turbocharged zc crx/civics post pics of your engine here
- Having probs taking off tranny fill plug bolt - Blocked (B16A)
- Wanted 88 CRX Door panels
- adjustable steering column questions
- Shipping CRX SI SEATS
- Newbie. . . Need help w/CRX
- Roof Gutter Replacement
- strange high idle..can anyone help?
- "Check engine" popping up..engine is stopping, then runs fine again?
- H&R Race on a 4th gen
- 91 civic throttle sticks
- What happened to the crx resource?
- car wont start...???
- How much power can be had with a chipped ECU?
- gauge help
- what are the positives of putting accord struts in the front
- 97 HX wheels
- Swaping Headlights on an 90 civic Si???? ASAP!!!
- Help-Speed&Odometer not working+"check engine"
- mpfi help
- need advice on bumper repair
- Alternator bad or something else?
- distributor question
- Tanabe
- Need Sohc ZC vacuum line HELP!!!!
- Anyone Ever has this problem
- Power Windows
- how much should i pay for a complete used a/c system from a crx?
- LS Swap into auto 91 DX
- Help me get my CRX Back together (Part 1)
- Cars (Civics/CRX) in my area... anyone out here at H-T?
- distributor experts!
- 15.26@90.36MPH
- Dohc ZC Swap help- concerning hoses/vacuum lines
- What intake tube (CAI) for 88 Civic hatch
- PITA spark plug boots
- main relay symptoms? Fuel pump not activating
- 15.59@90.035 mph
- air conditioner compressor help?
- Jet powered CRX
- rear shocks??? any OEM are shorter??
- Paint Code?
- ford explorer tried to run me over!
- Lowering 91 Crx si w/b16 (did search)
- crx suspension....need suggestions on coilovers
- Apexi RSM. Two speed digits... ?!
- CRX sunroof rust prevention, searched
- can i use an HF distributor for a d16a6??
- B16 or LS B18 into CRX
- what springs did you get/have with your ground controls?
- gethighonsi saying thanks for your suport
- Door Trim
- How do you know if you have a blown koni yellow shock?
- electrical help please!!!!!!!!!!
- will z6 oil pan fit on y8?
- Door Handles
- CRX or Del Sol
- CA smog laws
- Crx side moldings
- Help with the B20 Swap, Very Discouraged~!
- smoke from tail pipe?
- Need help! trying to ID si tranny.....
- Brake problem, got me stumped...
- engine switch how to keep air conditioning????
- 13.82 4 door civic
- intake question 90hb
- fuel pressure regulator....
- overheating problem
- zc distributor code 9 problem Knowledgeable help needed
- 88 crx si seat belts
- all zc ppl
- ac question
- what the hell is this noise? i need major help!!
- Online helms manual for crx, anyone have a link for this
- finding oil down spark plug tubes; d16a6
- blowing flames from tail pipe
- Where the Hell is the chime for the seatbelt and door?
- 88 hood on 87 crx si
- ZC Turbo Manifold??
- need motor swap help
- Look what I got today!!! Woohoo!!!
- might be a stupid question but
- question for EF's with the EX master cylinder
- Thinkin' about doing One Lap of America in CRX
- CRX backfires... dies on highway. No CEL. Please help.
- FS: '88 - '91 Civic sedan 4-door body parts!
- code 15
- Removing seatbelt?? not against the law
- dx distributor on an mpfi swap??
