View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 88 Crx Si Suspension Help
- Whats wrong!!! Help me!! Motor techs!!
- CRX OBD0 to 0BD1
- Civic/CRX heater control swap
- crx HF not getting over 35 mpg :(
- Sedan with benen tow hooks.nees info.
- 3K rpm High Idle only in summer?
- Need Wiring Help 91 CRX
- please help: replacing radiator on 90 crx si
- ls swap info
- 88-91 jdm b16 will parts fit off of a 94-97 b16
- starting issues???
- Distributor
- Is a D15B motor a VTEC or non VTEC????
- vtec problem
- Codes for Cylinder heads???
- Starting problem with newly purchased eg2 crx
- my lowered crx hit a pothole...check it out
- caster adjustment on ef
- rear bumper holes?
- Innovative mounts or OEM?
- New Shocks and Springs Install
- B18A1 thermostat compatibility
- help me plz guys rear bumper
- will a wiper switch from a 91 fit an 87?
- DC2 ITR brakes on ED/EF
- First swap need help
- EF Rear garnish tabs!!!!!
- motor swap
- Door question?
- EE wagon and Ef
- timing belt tensioner
- Which do you prefer...........
- OEM Wheel Stud Size?
- New Guy with a couple questions
- dx wireing harness
- Code 19 - lock up control solenoid valve????
- electrical poblem
- si and dx mounts
- 2 quick questions
- Help with replacing my fuel guage
- dohc zc tranny?
- EFs??? UGH!!!
- Ef REAR Lower tie bar, who makes them??
- EGR Valve Location? on1990 HB+High NOX
- 88 crx hf starting problems no power the the main componets
- crx miracle x bar
- codes
- Head swap info
- progress b series springs 2" w/ tokico hp's?
- NEED HELP.Password jdm sidemarkers
- b16 with ls tranny?
- Mounting rear sway on a 88 Std.
- Civic si Rear Garnish Tabs
- Shortening Brake Pedal Throw
- d16a6/Mini me or d16z6
- ECU Code 43 for 1990LS
- HELP!!! crx with brand new walbro 255 keeps dying out..
- ???rear shock 4 the back hatch
- amber corners 4/s 88-89 cxor civic
- SneakPreview: EF Concepts'
- lowering springs question
- Obdo to obd2 harness
- 1 blown hd gasket=reasons for speed parts
- RPMs drop when cold?
- vtec selonoid stays lock
- Has any one swaped a d16a1?
- Lets see what you've done to your ef???
- is this possible?
- 89 sedan back doors..
- b series clutch question?
- Tried to start car in -30 temps, now backfires.
- main relay???
- alright Honda-Heads
- Fuel Level gaug
- Swaping B16 from Crx to Hatch
- about to
- Fast Idle?
- emissions on my civic ef
- got a question guys tryin to buy help me out!!!!!
- Guide for H22 in a EF civic
- Little needed for my B18C swap
- 2 cut hoses on JDM B16 Tranny?
- crx fuel problem.
- I need Help badly
- blue/yellow and blue/green left over???
- d16a9 piston rings
- sohc zc w/ y8 head
- sedan 88-89/90-91
- Grinding gears
- hatcback exhuast pics
- Where can I get cheap motor mounts for my ef9?
- civic sedan problem
- help build a jdm d15b
- Mount kits, cable vs hydro
- oil leak
- What would you reccomend for a 88 CRX si
- super afc
- crx b16 vs b18
- CRX seat brackets
- My new project!
- CRX seat brackets
- DOHC or SOHC
- '91 Civic - blower fan not working
- Transmission - Can you mix Honda MTF and 10w-30?
- lsv
- How To replace the throttle cable
- What controls the fast idle on DPFI?
- Crx Glasstop
- B16A1 oxygen sensors
- crx rust.
- Si 90 EF HB Bosal Exhaust fitment??
- Crank Seal
- 89 civic hatch si(d16y8,obd2 wiring, and computer)!!!
- putting a GSR cluster in my 90 crx will this VSS work?
- Need help with my intake manifold
- What would you replace on a
- code 6 and 10 w/tps plugged in
- Autometer Tach Wiring Help! (Already Searched)
- Steering rack crossmember differences.
- PM6 v P28 for V-TEC
- Question: 1990 EF Civic Parking/Flasher
- ef parts price guide
- Witch Steering Wheel Do You Think looks best in EF'S?
- suspension???
- sticky clutch pedal
- Ignition switch problem
- b20 vtec help
- Ls vtec won't stay running.....
- turn signal issue
- understanding motors
- extended o2 sensor
- Fuel cutoff switch w/ relay diagram.
- need some fog light help
- Rear wiper in 88 STD hatch
- clutch cable
- SMOG! High NOX Gross Polluter (thesmogman)
- Bought new Gas Tank take a look
- The Best Control Arms for daily driving?
- chopping suspension help
- valve tick
- b20vtec trouble....
- Window trim
- heater knob snapped
- tach intallation
- Obd2 motor in obd0 car dizzy help?
- New guy from NC
- jdm h22 wont start
- advice on a new project crx
- 91 LX Sedan Rear Disc?
- Speedometer shaking
- pic request
- # 1 number one fuse blowing popping ???
- why are my springs compressing?
- NeedA quick answer please. what mirrors fit?
- Crx seats
- B18a obd0 swap in 88 Crx dx, actually started...
- Brakes on a 90' civic dx
- Jdm CRX crossmember
- B Series Mounts(ZC)
- transmission case idenification/swaped
- cylinder head pressure testing
- jdm ef sedan seats
- Pm5 ecu
- how to adjust cam gears???
- zc or d16z6
- Is this the ect sensor?
- CRX Civic Question
- want to make my crx obd1
- Piston installation?
- Current real-world pricing for a clean running EF
- h22 crx shifter assembly
- smog ?
- h23a in my 89 crx
- Adding 5th gear to 4spd Tranny
- Cable Assembly for H Series swap into EF. Photo request.
- LS Vtec swap won't run....need help!!!
- obd0 jdm d15b problem
- B18 sitting funny in mounts....
- starter not turning over
- D15B2 power steering crank pulley?
- Crank Pulley
- D15 tranny to ZC engine?
- JDM CRX front end on 91 Civic Hatchback?
- D15b2 timing????
- Side project while i wait for my turbo parts...
- Help me read my plugs (pics)...
- front crossmember help
- D15b transmission question
- Built b16a Numbers?
- B16a coolant temp sensor
- Best lowering springs/shocks
- Reliable Engine Site?
- are they the same
- Sidemarkers
- Sedan brake Lights
- engine splash shield
- stock engine swap
- what do guys think about this
- Mystery coolant leak
- rear seats in the crx?
- S1 tranny help
- pinouts/colors obd0
- Alternator for OBD1 B16A EF
- oil in spark plug hole question
- Quick TPS Question...
- anyone in oregon/washington
- cel on/relay chatters
- D15 SOHC intake on D16A1 Head
- ID this bumper and turns needed to fit it...
- 89crx smog ?
- Faulty Coolant Temp sensor= hard starting?
- spark plug question
- Ebay OEM Engine Rebuild Kits??
- ls/v-tech vs. b16a
- crx fenders.....
- B20b + 95 teg LS wiring harness + P75 = halp!
- more head swap questiions
- Help!!!!!!!!!
- front lips???
- obd0, two heated oxygen sensors, one wideband, any thoughts?
- What e-brake cables for 88' HF rear disc conversion?
- B16 ECU Chip Suggestions
- Rear Garnish replacement clips.
- Stock tach off by 500 RPM.
- Trying to slam my 88 crx!!! HELP!
- have you borred out your A6?
- what kind of obd1 ecu is this?
- 'Built' Mini-Me (need advise, please)
- Buyers confusion.
- Fitv or no?
- what is relays near passenger headlight?
- b20 civic si wont start :(
- obd2 gsr motor into 91 CRX dx
- ef air conditioners
- ABS fir crx si
- does a 99-00 dx oil pan fit on my 91 crx?
- Oxygen Sensor Wiring
- So many questions...
- colid clear taillights for 90 hatch?
- Door defroster vents.
- everyones thoughts on my build
- EF b16 starting issue...Yes I'm stumped.
- Where to buy pins?
- y8 wont start
- I need swap HELP!!!!! BADLY
- AC/Heater fan switch
- Type r swap
