View Full Version : Honda CRX / EF Civic (1988 - 1991)
- clicking noise on my main relay
- Power Steering 1990 Crx si with b16a1
- Will a Walbro255 cause RICH motor.?
- D15b TB and Fuel rail will it fit a y8?????
- wtb running moving honda in de
- wheel bearing part # ( already Searched)
- What engine for a sedan?
- Hatchback Gas tank on sedan?
- Headers for a b16 swapped 90 hatch
- JRSC GUYS....new track times for my crx
- EFI Swap Code 43 Help
- Installing JDM EF8 doors in 1990 CRX Si problem with seatbelts -4 Point Harness?
- Where can i find injectors for a d15b2?
- code 17 (VSS) still after new sensor...?
- Where to find ef-8 crx interior/exterior...?
- Looking for ef-8 crx interior/exterior...?
- DOHC ZC valve adjustment write up
- zc timing belt
- 90-91 cluster into 88 help please
- Where did u buy your rsr exhaust and how much??
- rear speaker baskets for 1990 Honda CRX si
- flywheel question
- Distributor for b16a1 engine What can I substitue?
- 1990 crx hf
- Crx Pulsating, Vibration !!!!
- just to clear up a foglight question
- Help with a gauge cluster
- D series guru's....in the middle of ZC/Si hybrid trans build...couple of Q's
- Colorado people...need some help!
- 91 civic hatch
- What should i do, keep the eg or get another ef
- crx with b18a what suspension? crx or integra's?
- HID IN A EF? PICS PLEASE?
- MY CRX PROJECT
- hate to do this but...
- need a si tranny SOHC
- d16y8 in a 91 si hb...WIRING??
- Modifying clutch pedal? *too long of a push*
- need info on dp 2 mp injection
- My EF9 Project.
- RSR Exmag or Greddy SP2
- GSR seats in a crx?
- Arm Rest and Cup holder in 88-91 crx
- question about main relay
- eg coilovers on ef
- ef brake question
- Which intake for dx90 w/ d15b swap
- need help need centers
- over heating ???
- b20/vtec eg vs k20 crx video?
- OBD1 TB on OBD0 (pm6) IM
- ZEX cams
- ef9 amber bumber lights???
- Body Mods
- aem pulley question
- possible ignition switch?
- 1989 CRX SI rear disc brake swap
- B20a5 computer for sale
- 90 civic Si - Exhaust Question
- B20 swap in progress
- i have a delemma......need opinions
- balljoint question
- clutch question
- Ac Lines touching header B16a in 1990 Honda civic, yes im keeping the ac
- Fuel Pump Specs B16a1? Factory CRX si fuel Pump or Change Pump from dohc engine
- Alternator Belt Install!!!
- 86 si swap?
- d16 motor with dpfi . what fuel injector will work
- Weird idle after highway driving
- help?
- d16z6 parts list questions
- need help wiring a 99 obd2 gsr motor in my 88 honda civc hatch
- ZC throttle body
- Hasport AC Bracket
- CRX exhaust on 90 civic dx?
- Quick timing question?
- Bench Racing
- what the weight of a 89 crx si
- Just a few questions.
- build questions
- how much do you think this car is worth?
- 89 civic SI no reverse
- O2 Sensor Replacement for Pre obd b16a
- A/C , does'nt blow cold air anymore, does that mean i need to charge w/ refrigerant?
- Just Got a Hf
- should i get rebuilt or new steering rack?
- NEED HELP READING THE CODES
- what do i need for the ef9 conversion
- My new civic porject.
- how do i put a dohc zc in to a si ef(90)
- where can i buy some 13" slicks for my rims
- Best b16 parts
- High Rev D16z6??
- what is the weight of a 89 civic dx hatch?
- CRX front bumper!!!
- What kinda hood is this?!?!?
- Supertrapp exhaust systems?
- IACV question???
- largest tire size???
- B16A1 problems
- exhaust manifold removal?????Help!!!!!!!
- Suspension Issue
- v tec controller question
- I Test Drove a 2006 Civic LX Sedan today
- tranny questions...
- sticking clutch
- I NEED PARTS!!!!!!!!!!!!!!!!!!
- search feature is down looking for an old post
- OT: Distributor bolt size/pitch
- cel code question
- ok help me out....gauges
- vin #
- How can i identify this 88 CRX trans i just bougth? Guy claims its Si
- Will A Carbon Fiber Hood Fit On My...
- My 90 crx SI
- alarms!
- Slightly OT: CRX destroyed by katrina
- B16 SWAP ISSUES: clutch cable! not enough play?
- quick AEM pulley question???
- Headers and exhaust help.
- b16 rod bearing remove and replace
- What bumper lights to use for Wings West front bumper??
- 91 CRX SEATS
- 88 civic hatch with 94 motor not gettin power to ECU
- Search is down, quick transmission question
- No rear seats, need ideas for custom HB
- Tranny fit?
- how many of you guys have rips in ur si seats?
- can this be done
- Greddy Exhaust: I got it! Now, what'll i do with it?
- HELP! dashboard harness
- 91 dx info on swaps and installtion info
- rear seat removal (HB)....need help.
- Does a MPFI swap getting better gas mileage then a DPFI?
- bad gas milage ??
- valve adjustment
- Erratic Idle woes...please take a look.
- chassis harness
- ? About MPFI. Real quick.
- Some d15a help please.
- Car will not start
- Z-dyne
- timing belt...
- need honda help, buying a crx
- crx obd0 to obd1 conversion help!!
- Y8 vs Z6 Camshaft
- Carbon Fiber trunk for EF sedan?
- my heat dont work in my 89 crx si. what do u think is wrong??
- I must know what bumper is this?
- need a zc in cali
- Motor bogging running out of ideas.
- Know A Lot about EF's? Need Your Help.
- clutch has no presure! Help?
- level 5 racing video
- how do you tell what intake man. you have??
- Vafc On Boosted Crx with Uberdata????? (for tach only.. will it mess up tune)
- looking into a swap on a 91 hf
- Is this the throwout bearing or input shaft...?
- quick question....on ecus
- want to do a mild build on my z6 help!!
- D16b ECU
- sir gagues in a 91 crx dx
- Gauge cluster
- D16Z6 Question...
- vacuum masters plz help.
- should i run my 13 inch hx or my 15 inch gsr hammer on the track
- what should i build for my 91 civic si
- Dropped gas tank for Walboro Fuel Pump today!
- Brighter Headlights
- rs*r exhaust on crx
- Which AC compressor
- d16z6 help
- need help connecting all the vacuum hoses to p08/p28 head...
- my engine setup almost finished. Shooting for 10s very soon.
- cliamte control unit
- CLIMATE CONTROL FIX
- Brake booster exstall question
- I Need help With a IAC VALVE!!!
- HELP PLEASE....ASAP....CRX fan
- ECU?
- rough idle, high temp, poor response...Any Guesses?
- DPFI -> MPFI (swap parts list) help
- CHECK OUT THIS CRX
- starts but stops immediately
- Energy suspension bushings and Trailing arms
- Axle making a popping noise..
- voltage reg
- ls swap and keep a/c ?
- Problem with the L-con bar solved, maybe?
- d15b7 intake manifold
- crx pulls to the right side when i hit a bump
- H22 in wagon
- cuttin weight
- Y8 manifold install on Z6...idle problem
- My brake booster crapped out on me
- bad compression prevent vtec?
- Need help with my friends car
- Camber kit for CRX??
- GSR breaks on CRX
- help Headlight Wiring Diagram
- Help me chose an engine
- need listing of engine codes
- if money wasn't an issue, What would you build?
- Need adivce Quick
- push button start in a crx
- bogs and fells like it's missing (but it's not)
- My LiL CRX Video
- 3 distributors later and still a code 9 CYP....
- im curious...
- Dohc zc with pg7 ecu. Is this combination known to run a little rich?
- THIN SIDE MOLDINGS
- b16 cams on D16A8?
- timing belt cover --- is it needed?
- starting problems
- VSS?
- del sol radiator in a crx
- Engine swap ideas please
- yay! got my p's other day...need help!
- ZC or D16A8?
- would a Faulty injector cause the car not to crank??
- my baby is back!!!
- Building B-16...Need help
- Turbo LSvtec thoughts
- mpfi swap done now what?
- Question about suspension.
- ef headlights
- Classic Car
- ef hatch bumper onto crx?
- Weight????
- Crx dx swapping an LS and converting to obd1
- Idle Problems ? Please Help Befor I Buy A CRX
- c-pillar ?
- ZC For SALE!!! RSR Header.
- side skirts
- just filled my mounts today and..
- CRX Exterior Bulb Sizes.
- timing belt damage... anybody ever heard of this?
- TPS Sensor problems......(searched)
- what code for 88 crx si tranny?
- enige swap
- My brakes half stopped working this afternoon
- Starting problems
- RSR EXHAUST OWNERS, WHY DID U GO WITH RSR????
- new guy here. having CRX throttle issues
- wiring d15z1 turbo
- Trading for EF?
- hydro to cable conversion
- pulling motor and need help
- n2o jet size
- Ef sir motor mounts
