View Full Version : Honda CRX / EF Civic (1988 - 1991)
- WTB 2 CRX SI seats, and 1.5 si complete head
- backfire from intake
- Very Nice EF
- looking for a jdm ef9 frontend, any ideas!!!!!!!!
- quick question. 94 gsr swap what axles ?
- my crx has no power
- tach install help please
- ZC F what the expletive
- JRSC in CRX..
- My Car Smokes White :S Some 1 help
- super charge
- No fuel?
- I need a wire harness for my 1989 dx crx
- d15b hydro tranny
- reverse light switch......interchangeable between b and d series tranny's??????
- Who Makes EF9 lips???
- chipping a pr3
- Injector question
- JDM rear crossmember vs USDM rear crossmember ???
- Hey
- I NEED HELP with: '91 Civic Si Headlight Replacing!
- Air conditioning? To much pressure leaking fron back of compressor.
- anything such as obd-0 p30 ecu.
- Brake lines for my hatch
- SOHC ZC SMOG QUESTION
- jdm front bumper filler piece/ fustrated!!
- Got some new kicks! PICS
- Car starts, then turns itself off...
- Vtec controller
- d series oil change
- racing seats?
- Swapping d16a6 in 89 crx dx (pulling my hair out)
- engine question
- B16a speedo cable question..
- Hey everyone
- ZC pinging; code 9
- tranny/ syncro question
- Ef Hatch Turbo Video Edelbrock Contest
- crx manifold help
- new and need help
- A little update on my RHD CRX
- k or b series?
- Engine upgrade for 1990 honda civic dx 4dr
- b series questions
- Obd0 to Obd1 conversion, now fuel pump problems!!?!
- need a honest opinion
- Hey which crankshaft has a longer stroke. Dohc Zc or D16z6???
- strut bar question..
- can a sohc zc pass smog??
- ef9 4speed to a 5speed
- WMHM.8 / 20th anniversary EF celebration / gingerman raceway July 19-20th 2008
- cel light on in all gears? wtf..listen to story...
- rc auto works manifold
- type r tranny questions
- so i ve tried everything
- Anyone in norcal have...
- HELP JDM HOOD ON USDM CRX!!!
- which coilovers?...
- Gauge cluster needs a few new light bulbs...
- 89 Civic DX BackFire? ? ?
- Ef Civic conversion
- 1/2 shaft issuses...
- 1989 Civic LX Sedan Cluster into a 1990 DX Hatch?
- 91 Civic DX - A Love/Hate relationship.
- Still havent got to enjoy my 89 SI drove it 40 miles before it died part II Tech help needed
- CRX engine harness
- 14" wheel combos on EF (CRX pref) pix - please post
- 89 HF cluster to 90 si
- What ground wires to use on my b16?
- CRX /Civic EF RULES
- Idle adjusting screw
- ok
- JDM mouldings
- Lsvtec ECU question
- crx no start
- jdm B16A timing belt
- Battery light!! why is this on?
- CRX noob that needs help
- 88 JDM B16A CRX SiR ?'s
- wat radiator?????
- I Need some help with a build
- swapping my 91 ef civic
- dohc zc ac question
- cable clutch tool
- b16 turbo no fuel pressure
- What exactly is this..?
- searched and searched and still nothing!
- V-tec engage but power drop off
- Dash Wiring Diagram
- main oil seal
- d16 tranny(ef)
- My cooling fan wont turn on unless....
- 86' civic si motor in 89' civic???
- Specs for jdm b16a?
- lights on!
- Anybody help me with cluster 89 HB Civic SI(tach signal wire)
- EF MEET AT CHALLENGER 7 MEMORIAL PARK SEPT 29
- quick question, would a zc hood fit the sir front bumper?
- AEM Power pulley belt size
- Antenna for 91 Civic
- Can you figure it out? DOHC ZC + high rpm vibration.
- ASR rear brace on a CRX?
- need help with power folding mirrors!!!
- huge tranny problem
- any reviews on...
- No spark, no start, code 15 after d16a6 swap?
- failed clutch
- what do i need to reff a jdm b18b???
- 0BD0--->OBD1
- y8 in ef hatch??
- Engine bay fuse box battery fuse.
- i know you guys like the stock look...
- looking for help with COMP ratio...
- ef 4door
- 92 v-tec head on d16a6?
- 1/2 length CRX condenser?
- NO START!!! y7 in Si
- My setup for my everyday driver
- Scary stuff DOHC ZC whats the problem?
- obd0 to obd1 problem cel with toggle switch
- Major timing issue
- Lighting Relay?
- check engine light ( vtec control solenoid)
- crx battery goes dead
- re-wiring my 91 std with harness from 89 si
- Header Question?
- smoke at 5000 rpm?
- ac switch
- EE9 from Europe
- i have both gsr hatch and turbo ls-t teg what should i do???
- k20 swap? ups... downs?
- Chicago honda mechanic
- SWAP Axel Question!! PLS HELP IF YOU CAN!!
- One way to fix cruise control...
- got my h22 going in my sedan
- CRX brake options?
- '90 CRX Si (1.6L) Error code...
- check engine light....please help
- pics of my babyyy...
- EF Exhaust interchangeable?
- 90 dx with b16 need help with smog please help !!!!!
- My new ride...
- car problems
- How does the stick shift angle?
- Intake idea
- How long should fuel pressure hold when checking for leaking injectors?
- fuse go snap crackle pop
- injector question
- How to: 4-1 header install (ITR "style") on 88-91 OBD 1 B16 crx w/ stock crossmember, lots of pics
- Question on OBD0 B16A ecu's [ Mine's Motorsports and Spoon Sports ]
- Quick eheels question...
- high rpm misfire
- type r header in ef
- ultra mega squeaking when car is moving
- early v-tec activation
- civic runs when it wants!!
- Should i run rebuilt engine with old motors turbo set up?
- Ksport Problem
- *** CRX/EF CIVIC TECHNICAL FORUM RULES | TRIAL USER INFO ***
- what do i do
- FLP Road Race Performance Shifter: Great!
- Gauge cluster swap
- jdm front end question
- vented hood
- weird starting problem- searched well, need troubleshooters
- need help with obd1 b16a. ive searched
- windshields interchangable???? need answer asap
- car wont start
- help: burping idle, overheating in traffic, and IAT
- Starter stays engaged
- Turns over, no start...
- JDM OBD0 B16 and JDM OBD1 B16
- OBD-0 B16a have egr valve?
- PR3 ac bracket from a jdm b16 for ef9
- crx with integra engine fuel pump problem
- Will a d16 Motor Work with a 90 Hatch DX Transmission?
- oil filter relocation problems?
- new project: SINGLE SECOND EF
- crome and uberdata standalone
- z6 into AWD wagon questions
- obd0 pr3 + B20v = no vtec
- tranny swap problems(is my used tranny junk?)
- Tag light went out .
- v-tech engage but power drops off
- obd 0 distributor cap
- another my fuel rail wont fit my d16 question
- OEM fender replacements?...
- what can i do with a SOHC zc block with a A6 head on it? what gasket? CR?
- How good are ksport.
- OBD1 Single cam dizzy on a crx
- 90 EF Sedan
- yes!
- b18c Throttle Cable Swap Question
- LS block ---> c5 block clutch question
- MUD FLAPS QUESTION
- spark plug gap
- changing CRX muffler, right side conversation (help needed)
- JDM B16A vtec solenoid gasket part # - searched
- civic/crx seat bracket
- suzuka blue EF?
- b16 / b18 lower timing cover the same
- car wont start... no power to the starter. HELP?????????
- Failed smog CA :(...
- So I get a new car and the thing dies on me
- mad problems..
- fuel line bleed Questions
- CRX engine swap carried over same problem HELP!
- d16y7 in 91 Si!!
- Routing speedo cable
- Is it possible to still have A/C with a b16 or b18 swap???
- ef aluminum radiator
- I don't hear fuel pump
- B16 troubles - code 6 - constant
- HELP!!!!!!! auto gas pedal spring
- my 89 ef with ls i need help
- good front lip fopr ef hatch(91)
- my first EF build
- 88 hf suspension technique sway bar install
- need help
- is it worth it
- Kinda of random.....about Toyota 4runner...
- is it possible to install 98 gsr motor into crx???
- dizzy quest
- I live in Cali what do i need to BAR a b16a????
- why overheat when car is stopped for a long time?
- what axles do i buy for a b16a
- EF with obd1 conversion not running correctly
- Looking for thread on full a/c underdash removal can't find .HELP!!!
- valve adjustment went wrong HELP!
- please help with oil/ coolant leak...
- Gas leak on a 84' CRX (carb)
- has anyone seen/used this intake?
- jdz zc bumper lip
- Which is better?
- 4th Gen CRX?
- do hydro clutches work for cable tranny?
- help me on flywheel
- Help with swap!.. injectors not spraying
- Cheap alternative to the small battery alot of us use.
- !!!HELP!!!ENGINE BOGGING @ 35OORPM
- Another attempt of a d16a6 to y8 conversion
- springs or shocks
- i need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- *** Strange CEL issue ***
- Another EF Build Thread
- radiator / headers help!!!
- *Warning this hurts*
- running on 2 cylinders
- 4x114 conversion
