View Full Version : Honda CRX / EF Civic (1988 - 1991)
- NW Car Club****Honda-tech meet***
- What color/brand lugs will look good?
- DOHC ZC Tranny compatible with?
- Car wont start
- engine rebuild question
- 88 crx dx need some suggestions
- Performer X intake on my 91 hatch?
- About to buy a 88 CRX DX but...
- What bolts to use on a d16a6 on an engine stand?
- alt question
- honda crx overheating problem
- What crank pulleys can I sue on my d16a6
- EAST COAST CRX wanted 2k
- inegra seats in an ef hatch????
- just got me my first ef
- ok. ive ran into a dilema. obd0 throwing 15
- Quick question on Clutch and flywheel combo.
- need help!
- ZC MOTOR....weird timing
- my RT4WD wagon
- build thread? why not
- Major Problems... Crx d16a6
- d15b7 pistons in a d16a6???
- AC removal
- custom or aftermarket headlights?
- car won't start help helpppp
- Walbro 255lp
- custom seat brackets
- CEL code 16 help
- ek lower console in ef
- EF Fender Braces.............anyone interested???
- pr4 vtec......(obdo)
- CRX tune up
- honda o2 ???
- correct O2 sensor
- b16 into 90 hatch
- Rywire H22 Harness
- Anyone has a pin out for Pm5 ecu?
- 91 ef idle/ vacuum problems
- exhaust...
- crx suspension questions
- gearbox noise d16a9
- Looking for H22 into EF Write Up Thread!
- Question about replacement pins
- Rear Bumper Support
- How To Determine A Genuine Si
- Need help with my timing
- 1990 Civic STD questions
- clutch feels loose after flywheel resurfaced
- z6 mini me quick qustion.. please help
- Wiring Job
- oil burning problem
- Hello everyone!
- rear disc toe problem
- Crx 88 hf ??
- downgrading from b16a to d15b2 (no start)
- 90 DX Hatch suspension suggestions
- Ex tranny swap
- Help - need code 4 troubleshooting flowchart
- Energy Suspensions trailing arm bushing install
- jdm b16 soleniod gasket
- motor question need help!!!!!!!
- 99-00 EX front brakes? help
- distibutor problem...
- Back Seats
- 90 crx aftrmrkt seats on my 90 hatch?
- crx k20 hood????
- Jdm windshield same as usdm?
- D16A6 head, port and polish, mill, tune questions.
- who has original paperwork?
- 1990 DX D15B2 NO POWER AT LOW RPMS
- Fuel pump 91 civic
- dohc zc wont start
- new cluster, problems with fuel gauge
- ef crank no start
- SOHC ZC won't start
- Which Alternator to buy for?
- wheel issues
- crx b16 problem
- removing rubber moldings?
- NRG QR + 1 wire horn button = HELP!
- Lowering A 90 CRX
- CRX Body Trim
- car wont start! help!
- Wrenching Your EF
- Wrenching your EF
- what kinda engine swap should i do??
- wheres the best place to buy the ef2 front end conversion?
- New to H-T, 1991 Civic Wagovan- Indiana
- 91 CRX Si. WTT Head/back SST exhaust for Stock System and Header.
- pg7 ecu- timing for engine?
- New to HT
- Are the Si and Hf harness interchangable? (crx)
- d16a6 block with d16y8 head and zc pistons?
- Chargespeed Spoiler
- obd0 to obd1 jumper harness question?
- Stupid wagon door question
- who has a shell for sale
- clutch catches really early 91ef
- one piece front end
- too low c/r?
- can someone explane to me the E.A.C.V
- Ok lets try this again...ed builds
- rice or not rice u decide
- diff between engine harness 88-89 and 90-91 ed dpfi
- need downloadable service manual!!
- What's up with this rear trans bracket?
- 88 rear bumper cover with 91 bumper support?
- how do i tell if my ecu is bad?
- Please help....
- i need help finding out what kind of rear seats i have
- gsr cluster into 88-89
- What exactly will i need to change to a obd1 from obd2
- still problems with my crx si gsr swap
- obd1 swap
- help with ed6 dx b18a1 obd1..wiring
- sputter at constant rpms obd1 b16
- Looking for 88 civic sedan exhaust
- rear disc brake calipers
- Crank pulley pin
- Need help Identifying valvesprings Help!!
- HELP!!!!!!
- can i put a d16z6 ditributer on a zc sohc non vtech?
- N1 EF, my favorite ef of all time! let me know what u guys think.
- 1988 civic hatch CEL
- B18c OBD 1 or 2 ?
- Are b series auto and manual flywheels same?
- Seat belt Buzzer WONT STOP !! Help.
- Stock struts bottoming out
- Better Breaking at Higher RPM???
- type r tranny in ef
- 88crx si Runs but wont rev
- Aftermarket Parts ID *Not My Pic*
- A/C question
- eg radiator on ef
- new member with a swap question
- blower motor question
- Radiator and Battery problem????
- high beam icon on gauge cluster stays on
- k24a1 in a crx? good or no?
- CRX accident
- STD/DX/LX Gauge Cluster Swap to Si Cluster
- Cluster ?'s
- Front hub discontinued, no aftermarket suppliers either
- stock d15 not starting
- car wont rev passed 3000rpm. help anyone!?!?
- the $500 start to a tribute build
- Ecu question, possibly a problem
- b16 thermostat question
- Energy Suspension
- NEED HELP! TRYING TO SWAP OUT MY 88 CRX TWO POINT FOR A 92 CIVIC FOUR POINT
- Steering wheel shaking a lot when braking at high speeds
- TD code on Si dizzy..?
- to cam or not to cam??
- 88 doors on a 90
- swap woes
- Will H&R lowering springs for an EK fit an EF?
- hydro clutch in ef??
- water spueing from back of block
- NEED HELP WITH 88 CRX INTAKE SWAP
- weird problem almost like miss-firing
- eBay Exhaust - took a risk
- someone help me! '90 crx si troubles
- whats the difference?
- Cold start switch/Fast Idle Switch...B18
- I NEED ALL SIDE MOLDING FOR CIVIC EF 91 SEDAN
- keeping a/c with a b swap?
- broken into blowm motor 91 crx hf
- CRX B16A XSI axles and rotors?
- spark and fuel but still nothing
- Car wont start after DPFI to MPFI swap..! Help please...!
- Brand new alternator and Brand new Yellow top Battery
- 1990 DX D15B2 IDLING
- issues...
- On the hunt for a 91 hatchback roof
- D16A6 wont start plz help
- 1989 civic dx keeps stalling
- Ebay Parts (for us broke peeps w/ cheap cars)
- squeaking timing belt
- need help asap!!!! pllease
- obd2!?!?!?!
- my rebuild problems...
- Girlfriend's EF Sedan not starting...
- Aftermarket Steering Wheels
- this is my EF
- Rewiring car
- timing belt cover
- Headers Wat's a good Cleaner
- won't rev past 3300???
- CRX engine swap on Google Street View!!
- old noob question
- tranny compatibility...
- Control arm height/strut extension question.
- ECU to run with MPFI swap.
- Exposed Flywheel....
- MUGEN M7 and Wilwood Brakes on a EF?
- b16 axle question
- 91 crx si B16a1
- d15b1 mpfi running rich?
- NRG Floor mat Quality?
- SOHC ZC build and questions
- wont do anything with the key in the switch
- mishimoto half radiator fan? 1989 civic hatch
- are ef9 and ed hood hinges the same?
- Which walbro fuel pump
- help w/my brake problem car dies
- CRX cable to hydro swap Q's
- Wheel bearing size
- OEM Dual Switch holder......DiY?
- honda crx ecu help
- new problem car running slow
- ef n crx
- fuel pump not kicking on
- 1991 civic dx running issue
- 1990 Civic Help
- nurburSTIG
- Authentic JDM EF9 Help
- high pitched whining coming from my motor....need help!!!!!!!!!
- ef with B16a: code 20,31, and 41 need help :=(
- mpfi swap
- Need your guy's help.....fume problem
- 3 point bar fitment???
- Trouble Code 6 Coolant Temp Sensor Wont start
- car does not pass 3k rpms?
- EFRue57's CR-X build thread........56k beware
- Injectors and reverse wiring questions
- spark plug help
- JDM DOHC ZC Fuse Diagram
- Holes where seats should bolt in
- !!!1991 EF9 2 trade!!!!
- Brake Lights aren't working, Need Help ASAP
- have some extra hoses
- ANOTHER SEDAN QUESTION...
- ST sway bar endlink....
- Need help identifying this cluster.
- NOOB: All Honda Gods/Gurus. I need some help !!!
- 89 CRX randomly dying
- need help
- 89 civic hb seats?
- A Hans Nothen(hondahans) inspired CRX build
- door hinges
- 86 CRX 5 Speed Transmission Rebuild Problem
- coolant leak
- DOHC ZC dizzy help!
- 1989 Honda HF Starting Problem Please Help!!!
- CV Axles..?
- problems with 91 crx si
- b16 obd1 question
- Wont Fire?
