View Full Version : Honda CRX / EF Civic (1988 - 1991)
- FIRST SWAP: DPFI TO MPFI
- 91 crx b16 1/4 mile trap speed question
- ELECTRONIC VSS,WHERE SHOULD WIRE GO
- Are LS rods good for 9000 rpm's?
- 91 civic si
- JDM D16a OBD1 w/ cable clutch
- Civic dx zc swap wiring help PLz look Not regular SEARCHED
- crx k20a2 turbo clearance problem
- speedo not working
- More new pics!
- NEED HELP!! GSR DIZZY ON B-16.......
- PROJECT WHITE EF9:
- Post your exhaust set up here
- EF JRSC Question
- Where is the parking lights wire?
- You Talk About Pissed!!!!!!!!(Update.........)
- whats the average price?
- Rod knock?
- bought a crx and vtec isent workin???
- untuned ls vtec?
- KYB AGX shocks with E-Gay coilovers
- Auto To 5 Speed Conversion Wiring Help
- Jdm B20b(crv) into a 89 Civic hatch
- ZC head on d16a6?
- Heater lines
- eg struts in ef - ##searched## - still have question about rears
- WTB 88 CRX Si drivers door panel.
- San Jose Shops?
- Spark Plugs for 1st Gen B16A???
- Car Died lost power and the ecu wont turn on what do you think it is???
- My 1991 civic hatch.... project ef9!!!!
- Tranny/Clutch/Flywheel Question:
- 1986 civic chassis code?
- Mugen M7 16x7 5-lug
- tire pressure
- horn/tail light fuse under hood??
- any canadian EF owners? I need your assistance... (not a scam, ploy, etc...)
- Sohc ZC? 1.5 or 1.6
- would it be better not to get a b16a1, but get b16a2 which is from a 92-95 civic or get a civic engi
- Who makes bronze/polished lip wheels
- Ef9 shocks same as Ef7 shocks??????
- How to tell if u have an 88-91 si tranny.?
- replaced motor in dx hatch--throwing wierd code
- What size BOLT is this?..dimesions?
- crx glass top
- best 88-91 4 door you've seen!!
- 17x7 on EF
- someone gimme some sohc zc info please...
- How much timing can you add to a d16a6 without knock on 94??
- type r cam comparison
- After cleaning the motor car runs like crap, HELP PLZ!
- ek9 with with tranny problem need helpo
- sale value modded crx?
- i need some extended lug studs....which ones?
- everything needed to do d16z6 swap
- Not really tech... but, finally got a 13sec ET out of a track car.
- Suspension Swaps???
- d16a8 installed + today fly + HD clutch...there is a tapping noise at idle ?
- K20 Motor?
- hb no start.
- dpfi to mpfi
- S2k cluster swap INFO
- bad wiring in ef8, need help!!!!
- exhaust fitment question
- jdm b16 trany front torqur mount???
- 3rd gen itr suspension on an eg civic
- heater control
- when it says......? would fit on b16 from 92-00 would it fit a 89-91 b16a1?
- sohc..
- Bad Rack and Pinion??
- opinions on steering wheels
- good site for 4dr goodies????
- finally installed the exedy clutch & fidanza flywhl
- flywheel step
- For a b16a1 can i just put low com..... pistons or what other things should i look for and also what
- Quick ? for you EF fools--Will 195/60/15's rub on stock suspension?
- p28 on obd0 b16a crx
- Where To BUY?
- swapping parts from crx into civic...questions.
- Stage 2 d16 camshaft need to upgrade springs?
- why wont my car start?
- 2nd o2 ???
- The budgeted 6 month build off!
- can an a6 throttle body fit on my z6 manifold?
- where is a good place to sell parts for an...
- car starts to misfire past 1/4 throttle. black fouled plugs
- OBD0 to OBD1 Done, now ecu?!!!
- How complete is this swap?
- how hard to take apart the entire dash???
- New to this forum. Lexan window question VIDS
- tips to get my car faster
- fuel gauge
- REVS TO 5500rpm with closed throttle
- Clutch Linkage
- quick injector question
- B16 Going OBD0 to OBD1 W/Hondata
- what cap and roter for a OBD 0 b16
- thanks...
- help find pic
- To VTEC or To TORQUE?? (d16z6 vs. d16a8)
- Tranny weight- Buff bagwell
- Low top speed
- burning rich
- is this a z6 or y8 head
- lets see your gauge setup in your ef
- Mini-Me Swap.
- 4 door parts.
- Clutch Pedal (searched!!)
- newbe question
- timing help
- Getting Vtec to work with a cable speedo?
- Wondering about LSD
- Work equip
- Will 90-91 CRX doors bolt on and line up on a 89 CRX?
- ecu ??????
- B18c type R engine swap
- traction bar problem
- What to coat floor with?
- b16 hatch 1/8th mile times
- Mainshaft strength
- 1991 CRX HF $1900
- jdm p30
- 91 civic hatch 4 $ale
- Do You Guys Think Its Worth It...
- Car no run!!!
- Quick Question on dpfi to mpfi
- my 91 B16a1 crx SI Blown Head gasket
- tired of my suspension setup
- JDM CRX front end on 88-89 USDM CRX, trim?
- Failed Emmissions Today :(
- no spark...mpfi swap
- Need some PARTS and a few Ideas
- what do you think of these pistons??
- Good Place to buy exhaust?
- broken clutch pedal
- WHat to do next, negative compression test results???
- just got my first crx
- Return to the 88-91
- Spark plug torque specs (searched!)
- Wiring in an IACV. Jacked DPFI-MPFI wiring harness. Need to fix it.
- spark plugs
- Got bored....posting vids of my gsr crx..
- Need paint in Wisconsin (midwest - tristate area)
- eg spindle messed up camber
- Rebar bracket?
- Another charcoal canister, “how do I” thread
- OEM Fogllights on a 91 Civic HB
- I need a new bushing for the transmission Torque bar! Help..stranded!!
- rack end bushing replacement?
- My CRX, Unfinished.......Over Budget!
- ED7
- ac/ heat will not blow.
- got my first car couple days ago
- Which would be better: build engine harness from scratch or buy new one and modify?
- OK SEARCHED A TON!! WHATS BEST BUMPER FOR 89 CRX?
- new parts car:)
- anyone know about hyperutechtic pistons??? (for dohc zc)
- installing mud flaps on a crx ... got a question
- For people with swapped rear disc brakes...
- new si motor
- My distributor hell.....good for a laugh
- Crx HF motor question
- My CRX
- Anyone running Crespo Cams in their Dohc Zc.
- differance in a jdm support vs. usdm support
- Stock front Si lip?
- What's a CRX?
- thermoswitch?
- would a distrubitor for a d16 fit on a zc?
- another brake swap thread -sorry
- Crime Stopper Car alarm
- fuel injector problem on b18a swap
- tps question
- My CRX. Testing waters.
- cable clutch help
- bulb question
- where can i but donut gasket dc header?
- $50$ to borrow your CRX for a couple of hours
- Sway bar question
- What year has the electric VSS?
- My caster is off
- b16a ANNOYING LIFTER TICKING!!!! GRRRR........
- Neuspeed Race springs or Eibach Sportlines?
- Bitch Pin
- 15.392 @ 143.43Km/h
- CRX b16a2 swap info???
- Need Front Springs
- Turn Signals?
- mph tach
- sparks plugs
- Best ECU for LS swap?
- Seat Swap
- ecu help
- What do you guys think of this crx
- 99 civic Auto tranny on 90 Civic EX sedan?
- CRX CUSTOM SHOW CAR
- bumper support
- Something new!!!
- 88 CRX LOW Idle problem
- --CRX B16A Lean/Rich Problem--
- Do you like this color for a REX?
- Car has a touchy throttle any ideas?
- F1 racing clutch
- will a y1 lsd bolt into a s1 tranny?
- fenders?
- Can I put a hydro tranny in my 91 Civic hb dx?
- CRX hood on a HB?
- how high can i safely rev my Z6?
- soft brake pedle on 90 crx si
- CHARGE PIPING! How Did You Run Your Drivers Side? Kinda Stumped
- are b20 any good
- rmf header b-series
- HELP! walbro 190lph
- tunning question
- alternator question and help needed
- Tools for head work?
- HELP PLZ i need obd0 dx distributer wireing pinouts!!
- 91 CRX Si d15b swap problem CEL 43 and fuel in the eye
- shifter question
- testing if i can post
- ZC trans
- CRX Idleing problems! Help!
- Wiring Help PLZ!
- pm7 throwing a code!
- check engine light question
- 1990 HONDA CRX THEFT RECOVERY - $400 (EASTSIDE MILWAUKEE)
- leaky hatch
- removing rear quarter window's Unbolt,Screw, ect??
- how to "install eagle rods in a dohc zc??
- won't start flooding turbo b16 question
- missing my rear motor mount BRACET
- Any difference between 88-91 Crx Si-HF etc.. Headlights?
- where is the bolts to the dash???
- Hybrid CRX/Sedan dasbhoard How To....for all you sedan/wagon lovers out there.
- 1,6 header to 1,4
- needed B-16 head!!!
- My car is retarded
- sterring wheel problem
- Got code 19 with ps9 and code 1 and code 4 with pr4?? WTF? ls swapped civic
- Reasons WHY A/C should be kept in our cars.
- main relay clicks, rpm drops down and sometime dies
- CLUTCH HELP ASAP PLS
- Headgasket for JDM D15B?
- Speedo Cable Questions
- Cargo Cover
- d16a6 hg?
- D15 SOHC died
- EGR Value Issues
- B18C into DX?
- Whats all need for a Headgasket change
