View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ZC guys... help...
- vafc + pr3 ecu
- ZC into a DX question...
- Are all D series axles the same?
- Crx Clutch Help
- Whats that rattling Noise
- what to do to my d16a6
- d16z6 cam in a d16y8?
- anyone running without a front crossmember?
- What header goes on a DOHC ZC?????????????????
- b16 exhaust manifold o2 sensor question
- Whats a good ZC install price?????????????????
- Please help D16a6 gone bad
- gsr cluster in and working but some probs
- I traded my h22
- does anyone have insrtuctions on rewiring DX to SIR?
- Grains of sand in engine! Help!
- ZC auto?
- Which distributor cap nipples go to which cylinder?
- zc problem
- jdm center consol?
- today is a sad sad day...i'm selling my new swap
- Whats the fuel cutoff for a stock 91 civic dx
- HP difference between hi-flow cat or no cat?
- FS: 1991 CRX Shell
- Stereo and AC/Heater problem?
- what axel's do i use for b16 swap in 91 hf crx.
- i am puzzled.. no clue.Help
- close up pictures of 90-91 Si tranny???
- SOHC ZC Vtec..........
- Zc with dx tranny
- lca replacement camber kits
- Whats this thing on the transmission?
- 95 civic shifter cable problems
- Tire time Looking at 3 different sizes. Help?
- show me your vafc mounting in your ef
- 90-93 integra front swaybar on 88-91??
- Y8 Head gasket on an A6?
- ignition, key thing, is broke?
- Axle stuck in intermediate shaft!!!
- $150 for mpfi parts without ecu good?
- Tranny help?
- Car runs better without a/f gauge
- crx si wire harness on dx for b16a swap?
- help me decide on tires
- cluster questioin
- Anyone have these clips ?
- i hear a rattleling sound from under my engine... what is it??
- Mantaray Motorsports custom gauges
- damnit
- Niagra Meet Date Set!!!!!!!!
- best place to get b16a in northern pa???
- Went to the ref today. Now I need help!!!!! Stupid ass ref!!!!!!!!
- Wanted:H-Tunning turbo D15 article
- J1 tranny with ls 3rd, 4th, 5th gears? $600
- cam position sensor
- lose muffler...add cat and straight though muffler?
- which car has a zc
- how much should i sell my..
- I need a high flow cat..where to buy?
- zc exaust
- zc ecu
- 88-91 hatch JDM rear bumper lip..............where can i find?
- zc distributor
- Need any kind of help, all my lights pulse!!
- motor mount???
- 2005 CRX in the Making??? or a Kit?
- ac smell
- So my trailing arm is F**KED
- when I slam on the gas, it hesitates
- Broken thing on my Intake mani. what is it?
- Calling all A/C techs
- help, swaping steering colums.
- zc dist
- did compression test on my 91 si
- need a wire diagram 4 jdm folding mirrors
- My tires are singing.
- Junkyard turbos.....how to put together??????????????
- heater button lights stay on all the time
- body kits/ebay
- rear disks
- jdm front for ef civic
- Possible camber kit problems?
- WTB: CRX si/dx inner bumper
- Probably one of the oldest questions in the book.
- removing throttle position sensor
- for those of you that have adjusted ur tps yourself..
- what a difference a new shift knob makes!!!
- pg7 ecu on zc swap
- Caster Problems
- Fuel Pump and ECU
- body molding
- Civic Msd
- 84-87 crx questions
- offsets on tires
- Has anyone ever had a Fuel filter cloge to the point, that your car would not start?
- MPEG of my 1st ever track outing in the CRX
- Supercharger Questions For Civic 1998 CX
- Transmission Drain and Fill plug?
- Autometer tach, where to mount?
- Dropping a ZC into my car, I have some quick questions though...
- Metal Headgasket for d16a6? WHich one?
- stealth radar
- js racing lip for usdm crx?
- There is a fist sized hole in my engine block, where can I get a ZC ASAP!
- question about axles
- Who ships Rota wheels to europe ?
- Koni yellow's adjusting question....Please help if you can.
- does anybody know where...
- Flowmaster Exhaust
- Anyone order from bigexhaust.com
- Flowmaster b.s
- B16 Swap Question
- will mugen or spoon style lip fit on ef9
- b16a dizzy?
- Northstar
- peep w/ auto to manual conversions.
- WTB A/C compontnets
- Where can I get OEM Foglights?
- HELP! with jdm front lip.
- n00b needs helms manual for CRX beater, correct one ?
- bad camber on a STOCK height car??
- 89 civic si blew my trans axle and motor question need help fast
- Dohc ZC-CRX HF-swap-Q
- Need part #'s for 1990 Civic Si...
- Muffler problems, what do you guys think ?
- will a prelude alternator work on a 88 Si engine?
- wiring probs..
- violently shaking car, but only every now and then
- b16a1 swap questions, we're stuck in the middle of a swap, please help!
- Ecu Code 13 -already did search-
- How much does CF hood weigh?
- crx gauge need help
- Info / Pics / Links for 1'st gen CRX's and 3'rd gen Civics?
- y8 head > listen to what the mech said
- Please Help! (CRX w/B16) Car shuts off for split second then back on!!! NO codes?
- wiring questions
- Ac on Hybrid swap....Repost...
- 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!!
- sunroof fixed
- Non Vtec head from si crx..
- si ecu wiring harness
- Which header is better for B16....DC?????
- car doesnt wanna start...getting a code 16 on ecu
- would spark plug wires from an LS....
- 1990 dx hatch a/t weight
- does brand matter for alignment kit?
- Is this CRX repairable?
- Recomendation for an oil cooler kit
- HF dizzy same as Si??
- CRX fuel line(the one from the filter to the firewall)
- Please help! Oil in chambers
- D16 head on EF DX block
- zc wireing question
- 90-91 integra steering wheel in a crx
- Header Question?
- the tack,water temp and the fuel guage stopped working! help!!!!
- maint req light?
- Post pics of aftermarket motor mounts for B-series motor!
- PMFI ECU test harness.....
- Need Help Guys.. Possibly Starter.. ASAP
- ITR intake manifold?? Fitment issues.
- What tranny for B16 in CRX HF?
- koni yellow's on GC?
- ITR Seats
- New World Order!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Search Disabled! Rear disc brake conversion? on 1990 Civic Si.
- anyone install a moroso oil pan on there d16 motor?
- Last Call for 3rd Annual Civic/CRX Meet in Pa
- I just had a brand new engine swap and now...
- TB coolant bypass question...and coolant very hot!
- suspension pros please help me out ..
- S1 trans rebuild shops(orlando)
- ST swaybar on a Std... Too tight???
- Blown Headgasket? What else to look for..
- 91 Hatch DX B16a(Sacramento Ca)$$3,300
- Maple Grove
- Car sick... again... HELP Cold idle
- Disconnected IACV
- rear disc brakes?
- What control arms fit my 90 SI CRX?
- itr suspention on my 91 hatch?
- [FAQ] ECU Codes and trouble shooting
- Help!!!! DC header How do i wire up o2 sensor?
- transmission axle oil seal - good info
- Sohc ZC cam fit a D16a6????????????????
- DC 4-1 Header on D16A6 - Review
- help wiring a obd0-obd1 jumper harness
- Just got my first car today.
- d16a1 in a 91 gen crxsi
- jdm fog light instal
- Cost of installing AC, back onto a 89 Si...??
- (search is broken!!)90-93 integra gauge cluster wiring ?!?!...its for 91 hatch
- Can you put VSS in a stock si tranny?
- best rack and pinion for crx
- MPFI DX quicker than CRX SI??
- 0-60 b16
- Just picked up a 91 ef today!
- 88hfcrx/b18a car is bogging down alot
- i asked this in the civic eg forum but i guess they don't know, so to u! Can you take ZC internals a
- Where to get an electronic VSS?
- what should i do with this?
- ????????wiring question???????
- Good deal?
- Tuning Fuel Maps
- White Some At Idle
- Anyone running 225/50/15's in the front?
- will 17's fit??
- will a 00 b16a manifold and tbody work on my 91 jdm crx b16a
- Every CRX's owner desires to have this cluster..
- 89 crx si, does it have...........??
- whats need for mpfi swap?
- V-AFC Gurus LOOK!! Need help on a settings for a stock Z6
- B16 probs
- ratteling
- d16z6 swap???
- AC removal
- Rear Disc Swap process ?'s
- spc / srr
- Track day at Sebring
- Intake Manifold...
- how do u take these apart?
- d16 sleeves ?
- This Weather Blows !!!!!!
- 88 and 89-91 crx, are there any diff. in the front struts?
- What dist cap for my B series obd-0 dist?
- body differences for 88-89 and 90-91 (can they be switched)??
- WTB: intercooler piping or kit.
- Typical problems, some of them answered here
- 2nd time at the Drag strip...
- D16A6 Vs. D16Z6 bottom end
- CRX without back side windows
- vaccum hose diagram?dohc zc
- Cost of b16 swap
- rims w/tires and lugnuts for $50. (thats right $50.)
- Rear cross member
- Gumball3000?
- e-brake light never goes off
- brighter headlights?
- Would like to speed up SOHC motor.
- crx and radiar detectors
- 94 integra dash into 90 civic hatch
- bent unibody??
- question on brakes......differnce between 88-91 and then 86
- this is my civic
- Head Studs for ZC?
- 1991 Honda CRX 4 sale
- What should I pay for a b16 head??? Need to know ASAP!!!!!
- front lower ball joint installation and removal
- d16z6 swap, how do i find out what cel it's throwing?
