View Full Version : Honda CRX / EF Civic (1988 - 1991)
- LOOOK WHAT I GOT :p
- b16 swap into crx Si
- EF ! piece front end
- 1991 CRX HF with B16A Mount question
- AC Compressor/AC Lines for a 1990 Civic Si Hatchback, Help?
- 89 civic no start when hot
- I need OBD0 to OBD1 parts BAD!
- JDM Cluster wiring
- how much does a 91 hatch weigh??
- Need help locating a ground..... 88 hf
- b20 into 91 HATCH
- Dizzy problem, I swaped motors and wired up harness and ran into wire prob>>????
- air cylinder problem on ef-9. need help
- Your LHD USDM civic / CRX is NOT an EF!!!!! It's an ED! Check your VIN.
- ef gas tank ????crx tank
- My new car 1988 Honda CRX SI, Caution 56k unfriendly
- rear disk swap...do DC teg trailing arms fit?
- CRX backseat?
- Type R quesiton
- CEL's... runs like crap.
- question about weird noise
- password jdm front brace help
- Weight reduction
- HELP...wiring powerwindows in EF hatch?
- OH..........SHIT the worst has happened(timing belt)
- skunk2 header?
- turnsignal problem is molesting my brain!!!
- half size radiators in 92-95 civic, anything else?
- doublethink project log [interior restoration tips & more]
- elrandeeto's crx project log (turbo)
- No Power?... Need Help
- JDM gauge cluster wire harness
- How does refrigerant R134a contaminate a 1991 crx?
- can anyone help me find a diagram for a crx folding mirrior
- engine swap help deciding (h2b/b20)
- EF8 or EF9 ?
- what does crx stand for?
- I want to nab the CRX Sir brakes, what caliper does it use?
- ckp sensor wiring - read archives...
- from crx to civic
- B16B PISTONS INTO B18A1
- cut bumper support
- 88 hf rear disc conversion
- how to replace wheel bearing?
- D16Z6 into 89 HF CRX
- Problems with CRX Hatch leaking water...
- 88 crx idle question *flame suit on*
- clutch cable questions
- Taking Badges Off My Car, Help
- Need opinions on coilovers for my CRX!
- Radiator as oil cooler
- master cylinder question
- E brake Cable snapped. Help me out guys
- code 16 question i did a little search still have a question
- List of all Engines, and Styles for CRX and Civic
- (Looking For Info) D16y8 into Crx - Question about IM
- 90 climate control into 88 crx
- JDM Shift Fork
- popping and jerking steering wheel ever since swap
- intake air temperature sensor on a 91 crx dx
- I NEED HELP FAST.
- wire gurus please help out
- zc dohc or zc sohc
- Problem @ 3500 rpms. Need some help. VIDEO inside.
- I have seen the high milage thread but I want to know who has the lowest milage EF here!!
- Fact or Fiction ~ Radiator support AKA T-bar: The frontend conversion (56k warning)
- in need of some help... i think
- Anybody ever run a fuel cell?
- EX MC
- stock gsr dual bend shifter
- crx quetions
- smog and ZC question
- invidia exaust for crx. i did search. judt look
- 89 crx underdash wiring
- port and polish questions
- HARNESS ANYONE GOT ONE for dual point dx, EF 89 for b16a>>>??? WANT TO BUY
- 88-91 prelude fog lights on an EF .........(almost JDM)
- crx rear glass weight?
- 89 civic dx, b16a Harness problem, !!!!!!!!!!!! NEED HELP
- b18a1 swap a/c braket?
- painting blubs?
- I'd know if I was knocking, right?
- Car sputters for a little while
- Adjusting trunk springs? Anybody done it?
- v-tec head on a d15 block question
- Rich Running B16 Swap Please Help!
- Where does this hose go?
- B16a1 or Dohc ZC
- k series into sedan
- IS DRIVING ON A BAD AXLE HARFUL TO OTHER PARTS?
- Get another Trans or repair the old one
- severe ecu problems...please help!! pw0
- quick bumper question
- i'm lost on the axle topic....yes i searched
- CRX Si Rear Sway bar fitment
- My new CRX
- VSS Broken Need Help
- how much should sell zc tranny 4 its like new
- can you put b16 pistons in a ls motor??
- removing speed sensor..HELP!
- Half a qt burnt after 30 miles after rebuild on lsvtec.
- zc swap question
- 89 lx 4door auto, stalls when brakes are applied
- Car wont start
- 90 CRX si NO START, main relay/bad ecu symptoms but maybe not....need help!
- obd0 to obd1
- battery relocation, fire question
- NEED HELP FINDING HONDATA ECU FOR MY EF9
- CLEAN Ebay Si Tranny - Will it work with my motor? WANNA BUY
- Rattle sound from front...
- Rear end feels very loose
- MINI ME BUILD, WHAT PISTONS? NEED HELP?
- Audio Help
- obd1 dizzy
- looking for information on the b20 swap
- anyone interested in a 1989 rare y49 crx si? (nyc) clean title runs and drives
- harness info...
- Will d16y7 injectors work in a b18b motor?
- clutch ?
- Car won't start, throwing codes
- need help quick
- LOOKING FOR A DECENT EK PLEASE MESSAGE
- Brakelight warning buzzer crazynes
- help me with the confusion, i dont know hondas
- selling the daily driver
- '88 si trans on '91 std
- brake upgrade
- ZC to Z6 wiring involved?
- apexi world sport 2
- Need help bringing this EF back to normal condition!
- hydraulic tranny
- both rear hubs went out at once
- Back to the D?
- Blox Rear Lower Control Arm??
- thinking about to turbo out my 1991 civic with a d16 stock engine
- quest on skunk2
- B16A in a 90 civic hatch
- Honda Motors Guide
- Oak Harbor,Wa White boosted CRX
- Aluminim calipers?
- testing video 3rd gear 4k to around 7k EF hatch
- "Real JDM amber corners"???
- A few more pics, alittle progress :o
- 91 SI hatch eating frying coils??
- Turbo question??????
- anyone have pics of hardlines from integra booster and mc on crx
- 88 civic dx hatch converted with ls swap... wont start, did before... check it out
- fucked up wires in my 91 crx
- Rear Mount
- best throttle body for EF
- B16A1 O2 sensors question.
- best oil/fuel filter
- the new crx
- * 2009 Civic Turbo diesel
- EF SI Battery/Alt Problem after car sitting for 7 days!! Any input would help
- Aftermarket Carpet for 91hb
- no spark!!! HELP!
- Where can I find a detailed D16Z6 Swap Guide?
- how do i get Speedometer in a 88 CRX with a B16 Swap..
- crx tranny problems?
- bench bleeding mc
- Help needed again! little bit urgent.. Unknown connector on Z2 wire tree for my A9
- vtec pressure switch and code 9
- i got 6k need to pick a swap any options?
- how to remove and install crv auto tranny..
- AC presure switch, please help
- Y1 tranny...2 vacumm hoses...what do they go to?
- 3 seals to replace when replacing cam seal???
- need some help on a obd0 to 1 conv help plz
- Del Sol Seats into 90 EF Sedan.
- smog crx please read
- what do i torque d16a6 head to
- ROOF RACKS!!!
- d16y8 manifold in non vtec zc
- Another b16a wiring ?...this one I need help with IACV?
- bad knock and o2 sensor?
- any1 running only "upgraded" front brakes?
- what oil should i use for a D15b
- Civic just died
- just for shits and giggles
- !!!!HP HELP!!!!!!
- CAR SPUTTERS ALOT......
- D16Z6 and supercharger for $500!!!
- trying to track down hatch leak...are there seams on the roof?
- K series need list
- Removing/reinstalling front and rear windows.
- Weird ecu problem...story inside
- Distributor question!!
- Help with short shift selection
- Obd0 with obd1 Automatic ecu.
- suspension question
- NITROUS HELP!!!!
- DA rear disc swap, need ebrake cables.. Suggestions?
- Comfortable Suspension for EF civics and CRX's Dail Driver
- HOW TO: Charging your A/C air conditioner conditioning system at home. (crosslink)
- ecu code 1
- wtf is wrong with my car
- how to check timing?
- d15 vtec wont rev past 3k rpms!!!
- i would like to know
- Battery relcation problem
- D16...what throttle bodies fit?
- Coil problems 91 Si hatch
- Auto Civic Problem
- High idle on my zc and gears are grinding
- locking hood pins.
- LSVTEC parts HELP
- Looking at a 90 CRX SI
- My project! 91 Si
- My JDM Front End Didnt come with headlight wires....
- where to look to see what trannie i have ????
- Price of ef si motor
- need help with 1-4 wire o2 sensor.
- ef crx constantly cutting out!
- Automatic tranny fluid change.
- What to do Next
- Oil in spark plugs?
- dx Si interchangability.
- making my b18 into a vtec help!!
- Please Help!!! Broken headlight selector!
- Tachtometer showing 0 when I idle
- 84-87 crx????
- 86 crx block question
- passwordjdm lip on ef usdm bumper
- windsheild replacement
- motor mount question
- 89 Civic lx losing oil pressure after rebuild... HELP!
- Need to find a few CRX parts
- steering question
- Tie Rod end replacement question.
- full-race traction bar install problems
- A/C in my EF with b16 swap (help)
- rev limit kicking in at 3k!!!! please help
- wth is STD
- HOW do i check coolant level? (SEARCHED ALREADY)
- 88 crx help
- SWAP HELP
- problems
- d16z6 obd0-obd1 questions
- looking for trade?
- ground controls
- i don't know what body harness i have plz help
- CEL tripping out on me
- obd1 conversion help please
- Opinion on if this CRX is worth it?
- dremel huh?
- wiring
- Tach problems, not working. Wiring?
- How many miles does your EF/ED 88-91 civic/crx have?.
- I have two seperate problems... a/c and clutch (trans)
