View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ac in my rex
- code 4 after MPFI still giving me problems!!
- Projectors and real HID
- idle stuck at 3k. wtf?
- power brake booster gone bad?
- how do you find out ECU codes in a crx with DOHC 16
- eg radiator w/place racing x-member
- Exhaust
- mpfi help
- Nebody put prothane bush in rear lower of an 88?
- To anyone with a Y8 IM on there EF...
- ebay spoon mirrors
- cluster not working after swap???
- Painting the interior body of car?
- Help upper control arm hitting frame on crx
- difference between these ecu's?
- need a distributor BAD! ZC or 89 integra
- Tein
- Which coolant temp sensor for ZC?
- transmission inspection?
- CRX weight?
- Timing belt... broke.
- vafc question
- cluster problem
- Not passing CA SMOG due to Timing
- 200 HP CRX vs 300 HP Accord
- B17a 1 generation gsr, is there room for the hood to close w/ this swap?
- Speedometer Cable?
- Please help! My friends CRX w/ modded jdm b16a is slow!
- Gas Gauge malfunctioning?
- home depot lip crew, what do u do about the factory lip?
- Whast wrong with this CRX??
- Anyone going to The Battle of the Imports this weekend at MIR????
- Fake si rims?
- any group buys for cf hoods..crx..?
- bad miss in my zc?
- GSR wheels
- SiR Repair Manual/Guide
- need some input on rusting crx fenders...
- Someone Keyed my car!!!
- Strange, intermittent "stumble"
- zc whoas!!!!!!!!!
- UKDM?
- CRX sliced in half in crash
- Swapped CRX in limp mode... FROM WHAT?!?!
- crx si axles in 94 cx???
- RSX front clip conversion 89 CRX
- Props to Jeff @ Homemadeturbo.com>>>
- Roll bar in 88 crx... ( i did search)
- Finally got my tranny
- zeal b6 question
- a1 trans??
- code 4 DOHC 16 whats this??
- intake mani for b16 turbo?
- Apexi Vafc question
- std to si doors and seatbelts
- ? about installing CV in trans
- would u spend $750 on a si tranny??
- for fellow b16ers
- Went to the track tonight...tell me what you think!!!
- Who sells Erebuni??
- d15 to d16
- FAQ: How-to on removing steering rack(non-power steering)
- oil control jet?
- To those using WaterWetter....
- engine prices?
- Transmission question...?
- Relocating a/c?
- possibly selling my 90 civic si, just looking at my selling price options....
- code 6 ECT...
- MPFI confusion
- Rattling inside the door, possibly seatbelt related.
- Help with the Tach
- How much is my car worth?
- bumpstops
- vids of my b16a1
- distrubutor question
- Junkyard turbo kit from a CRX, going onto a 97 civic EX - Q about downpipe
- typical starting problems... help?
- built zc engine seized
- too many switches
- srr or spc lca's ?
- anyone know this civic? (interesting shifter)
- integra airbox into ef hatch w/b16??
- ?? for crx owners
- need help w/ o2 sensor
- Ricer Theme Song!
- mini me wont start.
- What do I need to drop in a h22a in my 89 rex.
- zdyne compatibility with 93 civic ex
- Would This make a difference??
- Mini me fuel injectors not injecting
- having trouble starting my car...
- EF Hatch. How do you remove the left vent on the dash?
- b16a arrived today
- Just got autopower bar for my CRX!
- Whats faster 95 automatic integ LS or a 89 stick crx hf with si 91 hatch back manifold
- what are hubcentric rings what purpose do they serve
- 88 integra into crx
- How much horse power would i have/gain if i put a Si manifold in my stick crx 89 hf
- people with y8 mani. where to place TA sensor???
- Quick question about apexi exhaust......... need answer fast!
- PROGRESSIVE bearings for front crossmember
- ITR caliper on GSr knuckles?
- 92' cai from accord fit in a 89 hatch
- Help me choose: BFG Comp TA's or keep saving for slicks
- pm6 rev limit
- Few questions about Ground Control Coilover install??
- turbo crx owners
- A/C Baby!!!!
- d15 / 16 rebuild info?
- ZC valetrain and internals?
- EF bumper lights
- Finished Mpfi swap, not starting!?!!?
- How did everyone fit a 92-95 rad. w/ the stock crossmember?
- gauge hybrid.
- pr4 in crx ok?
- bomz cam gears?? good/bad?
- b18b in crx
- Brake Redux: how much does it cost to replace entire system...
- ARP's for my ZC?? Use the VW's or did they come out with new ones???
- high idle and surging throttle
- boging problems
- oil control jet from what 92-95 block into Z6 with A6 head
- "40,000 mile tranny's"
- i need a cheap swap shop in So Cal (Long Beach/OC)!!!
- 00 civic rad into a 91 Si?
- integra LS 93 rear sway bar on 4th gen civic SI
- Hatch Doesn't Lock!
- 97 hatch steering wheel in my 89 hatch dx
- How would these look?
- Cluster in 1990-91 hatch...
- which suspension is better?
- What is the deepest water a CRX can tread through without damage?
- got in a wreck today :(
- any ef passangers side turn light fit on 90civicsi?
- Compatability DX and SI Front Brakes??
- How to change the wheel bearings in a CRX?
- Syncros hard to replace?
- How many ppl. would be interested in CF side mouldings??
- Anybody in the LA, OC area in So Cal willing to work on MPFI for some cash
- 89 hatch w/ 92 gsr front brakes, which axles to use?
- Castlenut wont tighten, bolt broke loose..
- what oil pans fit a d16a6?
- My Car on Ebay
- Tire Width Shoudl I go with 185/60/R14s or 195/60R14s?
- my turbo crx or 91-96 Turbo Toyo MR2????need help
- Trying to buy Rotors and Pads for my Civic Wheres best place to go?
- help me understand mufflers/exhaust systems more?...
- Running rough, no codes thrown
- fuel pressure?
- replacement motor mounts/inserts? and other questions
- Autometer gauges - sending unit adapters
- Which is better Cusco or Neuspeed?
- 93 civic hatch engine into 89 civic sedan
- Turbo Kit for JDM D15B NON-VTEC?
- crx bumper on a hatch.... anyone have pics?
- axels b series in 91 hb
- SI head on DX
- JRSC D16z6
- WIRING HARNESS
- idle bounces from 800-1600
- spark plug wire configuration on 1st gen b-16a
- 92-95 CIVIC Trailing Arms FIT CRX/CIVIC?
- Stupid Question
- Power Window Switch, what car has this?
- Part throttle misfire?!?!
- d15b1 auto
- Weird brake problem
- Lower intercooler piping...
- DOHC ZC eats dizzies?
- how hard to swap any vtec engine in crx?? plz help
- whats the best shocks for 89 crx? Tokico?
- cx engine questions?
- 89 crx si brakes
- i need some stuff
- Anyone done head work on ZC?
- code 10 IAT sensor
- I made a movie!
- 1990 CRX Si for sale .....one owner Columbia, SC.
- speedometer problems on my cluster
- obdo and obd 1 how to tell?
- Stock UK All Leather CRX Seats on eBay, nice find for someone a little less poor than me
- bumpstops
- Car Fax Please
- car
- pic of my crx, what you think?
- Anyone with an S1 tranny and upgraded clutch/flywheel? I have a question for you (Or if you might kn
- t/3 t/4 turbo on ZC in ef civic
- STOLEN 93 red hatch stolen from my Apt. LOUISIANA
- What seats into my 88 civic hatch?
- Easy Turbo Question
- how much is a YS1 worth
- question for sohc vtec
- coolant temp sensor in z6 swap...
- tranny ? pls hep......
- wiring headlights for JDM front end..
- How many teeth on 5th gear main and countershaft from 1990-91 USDM Integra
- D16A vs D16Z oil pan question
- wiring y8 dizzy to 91 dx harness??
- main relay help?
- High Idle!
- The rear of my CRX sits too high, and there's a bunch of dead coils, so I was thinking...
- B16a1 alternator belt
- Crower Stroker Kit Install?
- save stock fuel level gauge
- My Car Won't Start
- 89 crx si engine code light on ecu stays on???
- Whats the difference between the 91 hatchback dx and hatch back si?
- years for silver 2nd gen crx ?
- cf hatch on a crx?
- 1990 Honda Civic Wagon 2WD
- 13" stock steel wheels
- CRX cup holder
- Going mini-me but want more torque..
- I need help and opinions.
- D15B question
- Sparco Speed seat on my stock 88 crx rails / sliders?
- Exhaust Questions
- shorten your gear ratio by using smaller rims?
- Newbie saying hi
- Will 91 integra LS brakes fit on 90 crx si?
- Using OBD1 oxygen sensor on CRX?
- Whats my motor compression?
- differences in EX and Si 5spd tranys
- Nitrous on my DOHC ZC in my crx.
- 89 crx Si tranny into 89 HB DX????
- Y1 Top speed... is this right?
- Turbo My Hatch or My CRX??? READ
- Magnaflow..review
- why wont vss sensor fit... ....
- who knows how to....
- blew engine, have some engine swap ?s
- what size resonator to get?
- Thermostatic switch on EF w/ LS???
- need a distributor FAST!!
- h23 ?? crx??
- 90 gage cluster lights (schematics)
- stick a d15 or pay extra for a d16?
- white over red tail lamps
- Can a stock 89 crx hf beat a stock 96 ls integra?
- Bizarre possible clog in my brake line?
- urgent problem with friends car...need help
- newbie
- distributor connection
- HCP A/C BRACKET; how do you adjust belt tension on the idler pulley??
- Can a clutch go bad if it sits too long?
- Need a diagnosis (engine burning oil)
- adjusting cable clutch
- What do you think about this body kit for a CRX?
