View Full Version : Honda CRX / EF Civic (1988 - 1991)
- will it fit????
- lower tie bar hits stock rear sway bar
- anyone know where I can buy a Rhd Crx,hatch etc... Just wondering if you can find em
- does a 90-93 integra stock exhaust fit an ef 90 hatch?
- HELP!!! my EF bogs down then dies
- wut should i be runin?
- would a pr4
- Sway bar input needed
- Lightened flywheel for a B16?
- changing head
- Difference of 88 & 89-91 CRX
- Horrible rust problem
- Wiring d16y8 in CRX DX
- Wiring da6y8 into a 90 CRX DX
- ZC ECU
- b18b in crx, throws of balance?
- obd0 to obd1 swap..how hard
- How do i make this work???
- 92-95 vtec in a 89 sedan how to.
- trailing arms rear disk brake conversion?
- JDM CF hood
- Hi all. I may be joining your ranks.
- engine wont hold idle
- gearing question
- suspension goodies
- d16y8 intake mani on d16a6????
- need a desperate carfax!!
- Trunk mounted batteries?Do they require a external cutoff switch to pass tech inspection at the trac
- Complete ZC SWAP for sale
- Trannny problem... what u think it is?
- 91 Sedan Exhaust Question
- a6 head on z6 block....
- What should i pay for a 90 civic wagon.....
- stupid question, need quick answer
- civic/crx si seats
- 89 civic 4 door
- level of transmission fluid
- Bigger injectors for the A6 other then 450's *pref stock honda ones*
- Chip install???
- Look at my free new toy was in friends back yard :D
- shift linkage/short shifter problems...
- Just bought a 88 HF hatch What do i need to put B series in it..
- Distributor wooooohs..?
- Need Speedo Schematics
- 1994 civic DX motor in 91 EF standard ?????
- pics of the rex
- Vtec Cross over???
- retainer ?
- How do I change d15b2 tranny oil??
- What kinda Head fits on D15?
- Strange IACV/EACV problem
- IACV
- b16a Throttle Body
- cel 13 help
- that trans goes where
- help w/ fender removal
- Clutch engaugement problem in 89' hatch
- code 23??
- Headlight Removal Question (90 Civic Si)
- car out the shop for second time.
- I finally got him to lower the price!
- how hard to mod a TypeR non SRS
- AC Compressor Problems
- tick tick eeeaaach woosh swoosh sound when I turn to the left.
- I need to know what the MAP sensor voltage should be.
- civic dx wont start its been sitting...
- axels question on 91 hatch std
- coilover install guide? help
- dohc zc performance parts
- cleaner enigne bay and headers
- Rubbing sound
- dohc zc, high idle
- HF's don't have front bumper support right? somewhat ok to take off si's?
- L3 LSD in a ZC / throw out bearing not engaging pressure plate / WHY!!!!
- Anyone know anything bout this?
- flywheel ?
- need help on gauges
- DA front end on a EF?
- 90 to 88 Rear Lower Control Arm swap question
- My custom body kit ...
- Picture Request!!! I need to know what the stock Sohc Mounts look like 89 crx si!!!
- B-18 rod ?
- Fender rolling?
- Look what i got for $600!!
- Engine Questions CRX
- Weight Reduction...
- How do I get the speedo gear off the diff?
- SIR hood....does it add under hood clearance?...how much?
- Si Wire Harness into DX hatch...
- wiring diagram
- car bellows smoke when i stop?
- Arospeed 4-1 header
- DESCRACED CRX
- Removal of resistor box, anyone have a write up of the wiring?
- timing belt info needed techs advise
- Throttle body for Y8 Intake Manifold?
- b18c head on obd-0 b16a questions
- Wiper question on '91 Si
- mini-me queston help
- removing inside of mirror for painting..
- How difficult to replace hatch sunroof glass ?
- Dpfi-Mpfi w/ si harness, Plugs don't match??(yes, I searched)
- My car, believed tranny problem? am i right?
- buzzing from cluster, no left blinker!
- I need engine mounts, but which part #'s do I need??
- YS1 GSR tranny
- Any yellow CRX owner in here
- will my rims fit over EX brake caliper setup???
- I NEED HELP!!!! CLUSTER PROBLEM
- a6 head or z6 head?
- fuel cut-off problems
- quick question about a 1990 crx...
- fuel filter banjo bolt
- OUCH....the exploded tranny of bad luck fridays!
- Just swaped B16A into CRX HF and engine has knockings...?
- SOHC's.... how does ur oil pressure behave?
- what axles work wit zc tranny
- Installing a camber kit, didn't come with instructions..
- tany/axles
- Press Release: Hasport Hydro conversion mount kit for EF is released.
- maaco paint job/body work
- after market H4H bulbs
- 89 CRX Si wont start HELP!!!
- Exhaust path
- help - fiberglass fenders and corner lights
- Time for another round of "Name that Exhaust Part"
- Need help with DX to B16 distributor wiring
- OBD1 Conversion
- usdm obd0 ecus: pm6 vs. pg7 vs. pr4
- Rebuilt motor won't start !!! Have spark and fuel NEED HELP!!!!!
- Battery relocation plus starter kill
- euro style hood?
- (another)Mini-me question
- wired for b16 with pr3, now going to a b18b
- Power Lock Problems
- To those who have the CTR intake cam in your B16 rex....
- b18b with b16 tranny
- swap b18b into crx
- engine swap headaches need help
- how to get a locknut off w/o a key? help needed asap
- DC2 seats in EF?
- Difference Between Injectors
- ZC TRANNY- Will it bolt right up to a....
- seatbelt alarm problem
- Does the year of crx affect climate control installs?
- which pcv valve and fuel filter for b16?
- cel code 16
- B16a Swap Question?
- battery reloc. > move selinoid?
- OK What gas do you guys use?
- Few Questions about the CRX
- Anyone have the link to Y1/LS 5th gear and FD swap thread.
- I think I need to jump on this...
- CRX HF weight? i already search want some real world answers
- idle control valve on d15
- B16A into crx what clutch should i get?
- What year cap and rotor will work for b16a?
- stock shift light
- Carfax VIN and Suggestions
- How to make d16y8 manifold work??? just questions !
- 5 speed swap... can't find old thread..
- crooked headlight
- Mini Me Timing Belt/Other Questions
- B16 Swap Intake Wheeze at Shut Down
- compression test?
- price b18a ?
- B20 prelude motor
- can u clean a vtec solenoid
- does a 93 integra radiator fit 91 crx si?
- B18A1 into 89 CRX HF
- New Hatch!!!!!!!
- CRX Brake Help
- b-series swap + hydro tranny in an EF = what axles to use?
- Help crx wont shift
- I need an estimation!
- CRX Engine Swap???
- Anyone with a 89 crx si with Eibach Springs and KYB AGX struts.
- I'm starting to get ticked off... My engine is on crack.
- getting around wireing harness for d15 to d16!
- cap and rotor question
- JDM D15B w/ JDM SSO tranny and half shaft, what axles???????
- Headlights are Yellow, can you clean them and make em clear again??????????
- air fuel gauge
- OBD1 wiring
- idle is so frigen crazy
- Found oil filter is it for my CRX?
- Help!!! Car over heating after changed timming belt
- can a leaking headgasket cause......
- b16 a both o2 wires hooked up to one o2 sensor
- zc dohc question
- brake calipers
- shock/suspension questions
- ls question
- Apex N1 Exhaust
- starting a new project
- are jdm crx sir headlights the same as jdm civic sir headlights?
- CREAK!
- Ef9 front end conversion?
- finished d16z6 swap into crx si, but car wont start, HELP!!!!
- Pic Request and need info on Aftermarket Crossmembers and 92+ Rad. ?
- which turbo?
- DIY DPFI->MPFI conversions: did you build a quick-disconnect subharness?
- what motor?1111
- 91' civic hb. passenger window is off the regulator, help
- pics of ef with itb's
- shift linkage question b16
- AEM Pully's?
- 89 hatchback into offroad car
- Civic door help..
- Here is an interesting situation.....
- vafc question
- CRX DOOR!!!!
- rad... heater and coolant problem....
- EDM cluster?
- Will a ITR exhaust cam help out?
- Whats code 21?
- diff in interior
- Zc Parts on a D16?
- Talkin' about Exhaust..???
- need info on stock crx exhaust to beat ticket..please help!
- Help: Projector vs Cai or intercooler piping...
- crx rear wiper delete question????
- 88 crx electrical problems?
- How much Hp Gain from CTR CAMS in b16?!?!?!
- 88-91 civic/crx si radiator wanted!
- mods to keep or buy for future B16A install
- D15B2 VTEC turbo/D16Y8 sohc vtec Turbo VS B16 ?????????
- help with carberator
- what should i do with my 89 dx.....
- if i were to get a zc for my hatch........
- Thing I re-did on my MPFI wiring...
- HELP!
- d15 ditributer
- just blew my b16...
- You guys are missing out
- fuel and oil consumption
- good use for a switch
- How much would u pay for CRX OEM Fog Kit?
- getting complete sir change over, what else is needed please help.
- intermittent sputter on highway
- bumper fell off
- D series block
- Best swap
- Best street tires for tha rex
- CRX.... Good deal???
- if you live in the UK buy this car!
- zc cams
- suspension question
- Is this motor vtec???
