View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Surging idle after hitting VTEC
- obd1 swap, DIY harness, need help
- question about mini me
- Turn signal problems, gauge cluster problems.
- put a new door on and havin problems electrical
- Better times at night or in the day?
- ZC SWAP
- winter project anyone?
- Crx hf
- Tach dropping, bogging, ignitor???
- Slippin and cant get up
- are all b16 loud at 3100 rpms
- does my 89 dx have a mass airlfow sensor or not?
- B16B swap: What next?
- New axles
- 90 msi to 88 crx swap
- ecu compatibility
- The most disgusting thing I have ever seen
- b16a oil pan gasket problem
- D15B1 vs. D15B2
- Hydro transmission on an EF - Searched...
- EGR Valve.....
- need 88-89 crx si cluster wiring/theft problem
- civic motor trouble. any ideas?
- DOHC ZC question
- Pics of my car and it's dead engine
- VAFC fuel setttings SOHC VTec
- dohc zc + 50 shot?
- help with my car
- Sir front end
- how to save my car.
- jdm d15b swap on an EF/CRX
- DO I BUY OR NOT
- I love owning a 16yr old car, w/ 100k on it(Inner Tie-Rod Shot)
- mini me ecu question
- 99 Dx motor into 91 sedan
- one way valves?
- mpfi swap wont start (look over my wiring)
- 1990 Civic w/ D16z6 swap what cai fits
- wich turbokit fits in the ef8?
- WOW! NEED SUSPENSION HELP WITH THE CRX ITS ALL OVER THE ROAD
- Funny idle and O2 sensor question
- AEM cam gear question
- crx back seat
- Mystery LSD, can anyone ID? 56k fuhgettaboutit
- mini
- Gear shift lever on 1991 Civic DX
- YOU GUYS ALL LIED!!
- cheap oem parts
- eg cluster in a ef
- 89 si seats into 91 dx...
- yellow fogs
- How big is my 85 crx gas tank?
- WHERE TO BUY ZC MOTOR
- It's official...again.
- Tune Up questions, what to do
- grindin in 3rd and 5th gear help!
- Buzzer disconect?
- 1991 crx w/b18a
- vtec controller question
- JDM Front Clips
- h22 vs dsm injectors
- D16z6 swap Now wont start
- Quick seat bracket question
- Coilovers
- Y8 swap in EF, help a brotha out, obd1 swap questions
- jdm d15 greddy kit 90 civichb
- BIG CARBON PROBLEM
- RSR drift festivle CRX sighting
- question for people that have done a ZC swap
- aftermarket or oem dizzy??
- Backwords Mini-me ? ?
- Starter Hookup. Which of 2 studs gets the main power wire?
- dyed plexiglass? where to get it? spray on tint?
- having trouble roving rear wiper
- burnin rich and stallin out
- My 1/4 Mile.. Is it Decent?..
- what could casue a bad gas mileage
- pics of rex with k20
- b16 in 89 si wont start. HELP!!
- b16a obo-0 vtec not engaging and no codes are being thrown?
- map sensor
- Jackson Supercharger Or Skunk2 Motor???
- sneeky pete is it a waste?
- crx to hatch suspension
- suspension, anyone have adjustable coilovers, the kind that thread up or down??
- how to post up a car for sale???
- Need replacement parts for swap.
- Got crx shocks laying around you can measure??
- harness bar
- ecu question......
- Install: C-Pillar Bar on 90-91 CRX
- valve ?
- brake lines?
- B16a TDC code 8
- why doesnt my 89 honda civic start???
- Kiss my lipz
- custom heater question...
- 90-91 EX front brakes 10.3" under an HX wheel write-up
- Will EK shocks fit CRX's?
- HELP! crx won't start after swap
- crx hf axles ???
- Throwout Bearing Assembly Removal *ASAP WORKING ON IT* PIC!
- ls/vtec pr3 chipped ecu
- MUST SEE biger the better
- Just picked up new CRX, BIG TRANNY PROBLEM, help please, stuck in Orlando!!!!!
- Idle goes up and down when the engine is warm
- help with headlights!
- crx people send me pics
- fuel mangement question
- where do you guys buy your rims?
- What special tool for the fuel filter bolt?
- are all d-series distributors the same?
- whats the stikiest tires out there for the street??
- A few engine questions
- need o2 sense help
- Replace stock clutch
- ZC replacement parts : double check
- Need quick answer! Stock wheel / center caps
- VAFC settings for ls/vtec crx?
- Underdash Fuse diagram for 1990 Si, Please HELP!!!
- code 14 and 10
- SRS in an EF?
- Check CEL light, what codes are these
- d15b2 block + d16y7 head = d16y7 tbelt??? and what water pump?
- question about CRX accessory wiring
- couple of ?'s 91 crx hf -swap
- Starter troubles...need help asap!
- Alternator
- shift linkage
- b16 OBD0 o2 sensor single 02 conversion
- rear drum squeak question
- What do u guys think about tinting on hatchs?
- CRX SEAT BRAKETS INTO CIVICS???
- I need your Feedback
- Window tint
- speedometer just stop working
- wavering idle. changed some stuff, code 15. i'm stumped!
- Just bought Falken Azenis
- s2000 4 lug 17's?
- cumstom side exit exhaust?
- About the jdm d15b vtec motor
- 94+ Integra Cluster in EF (SEARCHED)
- Look at this Gay $200 dollar CAI AEM intake **CRAPPY POS**
- 89 DX Hatch, Blew ZC, Putting SOHC VTEC, What ECU? ? ? Will current PG7 work
- SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics
- fuse blowning up
- Will 87' integra distributor fit a ZC?
- general wheel question???????
- OEM/Helms Service Manuals
- How do you remove a torque converter from a d15b2????
- DAMN THIEVES BROKE MY WINDOW AND TOOK MY CD PLAYER...
- d15b vtec obd0 to obd1 with ghetto o2 sensor?
- so my motor mount breaks...
- Want Azenis but they dont have 195-50-15...
- QUick answer needed... already searched.. d16a6 firing order distributor
- What do u guys think about these rims...im planning on picking them up...also what tire choice shoul
- ECT Sensors...what do each of them do differently?
- Problem with install of rear lower tie bar
- HELP ME PLEASE!!! MY CAR WONT REV PAST 3K rpms
- Car shakes?
- speedo ?
- HELP WITH B-SERIES TRANNY IN CRX
- Lots of info on Mini-Me D15B2... what about B1?
- 1988 hatch with d16z6 Lights flicker and car jumps at night..
- solid one piece strut bar questions??
- Transmission fluid for a Y1
- hb
- shes up and running
- 90 rs seats in 90 si
- clutch problem
- Heavier of the two?
- Code 15 car won't rev past 6800????????
- throwing codes 7 & 10 help please!
- new buil-up ,poormans almost done!
- Tranny probs, HELP!!! please!
- d15b-pm6ecu and vtec controller or p08 ecu with obd-0 to obd-1 harness
- MPFI?
- my mechanic said "ACT 6 puck is too harsh"
- b series tranny help
- Tranny Help?
- honda song
- Any turbo 3rd gen hatches?
- im excited, maybe picking up 90 4d EX monday
- interior colors
- Calculated my CR...
- seat swap, gsr in crx
- steering problem?
- best company to buy crx lowering springs?
- Hole in gas tank problem :(
- H22 Swapped into CRX
- B18C1 with 91 A1 LS trans is it gonna suck?
- CRX Half Radiator? Where to buy?
- Anyone here from arizona ?
- Falken Azinas??????
- look at this camber kit im going to buy ..that way i dont get ripped off..dont know the brand :/
- California can you get any stupider.
- Alternative to JDM yellow fogs
- EF8 siR VTM wire
- Best place to buy 15x100 rota slipstream's?
- One Piece Front End for 84 CRX?
- cable clutch
- will these fit?
- obd2 to obd1
- GSR cam install into b16 day!!!
- danbury meet curse! my upper radiator pipe just broke... anyone ever fix this b4? look at pic!
- silver box right in fornt of fire wall
- Cam Gear(help!!!)
- a question for my EF peeps.
- Hopefully picking up'88 CRX next week. What are your thoughts on getting more power
- What would you do? Ripped outer tie rod boot, sloppy steering?
- Problem with 1990 civic DX
- Crx Exhaust Routing
- timing question
- B16A G1 vs B16A G2 intake manifold
- Installed New Front Bumper (Questions w/pics)
- zdyne pm6 ecu?????
- ohio e-check HELP!!!!!
- B16 HELP Car Runs Bad.. whats wrong
- I know what block I have now...
- cam timing
- Suspension Dilema....Help
- B18C1 ECT sensor wiring question
- ls/vtec kit?
- Hf crx.... change to si knuckles?
- egine codes and HP
- Exhaust dilemma........need help
- Safety issues
- ED Weigh Loss Plan
- Favorite SOHC - Z6 or A6
- ZC vs. Mini-me
- best for the $$$$
- AGX for 88 CRX?
- 88-91 prelude ecu
- Sohc ZC or Dohc ZC for going turbo?
- where to buy '89 CRX adjustable crossmember?
- CEL, Cant check it, whats wrong?
- Y7 Block, A6 Head -> Retain stock Si tranny/axles/mounts?
- Having problems with my car...
- dropping?
- ZC swap boging bad
- Aftermarket power sunroof. Found a GREAT price. Anybody installed one of these?
- CRX JDM thin moldings-where to get?
- climate control or heater core not working?
- 88 Honda Civic DX 1.5 NEED HELP!!
- *** DISTRIBUTOR went out on my 91 HB 4 seed anyone have any advice?***
- Gray CRX seat question.
- Strange Vtec problem
- Si and DX brake question
- Do you recognize these springs?
