View Full Version : Honda CRX / EF Civic (1988 - 1991)
- civic & crx
- manual to auto swap
- LS 5th gear mpg increase??
- making the engine bay cleaner
- my 91 civic hatch (build thread)
- Door Checker Compatability
- ***EF FOGLIGHTS***
- after market wing for hatch
- Wheel shakes at low speeds. What could it be?
- dohc zc built up
- Good deal ?
- Mysterious engine swap?
- New to the 1991 era
- dohc zc swap help
- Wheel bearing worn out
- Manual Steering rack install. *Help please*
- MPFI power numbers?
- Tie Rod Locking Nut
- motor/ trans
- Couple questions on the k swap in a crx
- just got introduced to this world of CRX and need of major help to start.
- Passenger side headlights not working
- Which ST Sway Bar set up do i buy???
- throttle cable help
- help with head of D16A6
- help with axle problem!!!
- passing smog in california question
- radiator help
- NEED SOME HELP GUYS!!!!
- Trunk lift schocks for sedan
- I passed my emmisions test today!
- turbocharging a b16a CRX
- anyone know of any honda clubs in the Indianapolis area
- What should I set my cam gears to on my gsr?
- b18 intermediate shaft and axles compatability
- Axle seal question
- having trouble with my swap plz help
- distributor plug dx to zc swap
- RS*R ex-mag GT2 or Invidia N1
- D16A6 rebuild
- sedan fron crossmember diff than the hatch and crx?
- B18C GSR into EF- What parts?
- CRX Electrical Quirks
- B18C GSR swap- Throttle Cable help
- my rex
- Headligts, Corner lights, Rear Brake lights flicker
- mini-me with jdm zc and d15b head anyone ever did it?
- b18 swap now speed sensor not working
- CEL code 20 twenty
- REX failed emission :( help?
- Mini Me Swap
- Turn signal problems
- @@@ Cooling system replace @@@
- Jdm visor install... what is butyl sealer?
- code 16
- Ef Suspension question...
- HELP WIRES B18 swap
- SOOOOO CONFUSED<----NOOOOOB
- Rear Left wheel locks up sometimes when hitting Potholes.
- Blower Motor Running slower on all 4 speeds after replacement.
- VTEC not engaging
- USDM bumper support on JDM bumper (88 hatch)
- High idle
- Code 4 Crankangle
- skunk2 front camber kit fitment... any modification needed?
- Cable B16a Tranny
- do i realy have to??
- spark plugs covered in oil
- D15b1 restrictor plate removal?
- i have no brakes try #2
- fuel filter problem. please help.
- Why the hell is my car so loud at speed?
- Help finding a front lip.
- i have no brakes
- 91 crx b16 swap help
- Battery light always on!!!
- Password jdm battery relocator
- what header can i use
- Timing question.
- jdm b16
- B18C1 Wiring Diagram
- have a question on side molding
- invidia N1
- ITR header on 1st gen B16 problem...
- Just did DPFI to MPFI. help.
- Problem starting my 88 CRX Si...
- Switching window tracks.. .easy or hard?
- 1990 DX Stock Exhaust 4dr
- My 88HF daily driver gas mileage project.
- ecu blinking
- Distributor for a jdm b16
- crx si with zc just intalled wont fire
- EF Hatch 90 LS Swap Out of nowhere starts running SUPER Rich
- crx b16a charging system problem...???...
- how do I tahe the hey ignition off the steering column
- I think I broke the timing belt in my B16...
- Best setup for performance and hight
- 90 CR si, DOHC ZC, clutch tranny problems
- What kind of mpgs do CRX HF's get in real driving situations?
- just got rear discs...
- rebuilding a ys1
- B series crx mount question
- cable tranny customizing?
- z6 swap help needed...
- suspension question
- CRX Dimensions
- Auto X Build ona budget (does anyone have 56k anymore?)
- D16a6 block + D16Y8 Head, what I need to complete this.
- new battery. new alternator. still only 12v when car is running
- Oil filter sandwich adapter can this be used for external oil filter relocator???
- MSD distributor cap and external coil 88 DX 1.5L DPFI
- looking for a low-miles D1.5
- 89 civic LX build thread
- 90 CRX DX Wheel Fitment
- Part # experts...
- vtec isnt working
- spark plug gap closed?
- where to buy
- 1990 honda crx si question
- Brand New Civic EF Floor mats ?
- civic/ 90 integra conversion question
- 88 crx hf no start need help kind asap
- Bad bump steer = EF8 Tie rods ends worn?
- really bad idle sometimes, and of course blue smoke
- Need Help
- no spark!!!!!!help
- 88 crx w/ b16 and ys1 tranny (short gears) setup?
- LCA question
- over heating no heat
- timing question
- Poly replacement for the upper shock bushing?
- Quick Hood question
- starter went out
- k sport coilovers
- Rywire obd-1 conversion harness? CEL Check?
- Fender question
- b16 just got here... but i have some problems..HELP PLZ
- i need help
- what harness is in my si
- shifter bushings
- just bought innovative mounts
- runs fine then bogs like hell
- Help TO Deciding !
- usdm ys1
- eristic gasket set
- DA mirrors on a ef
- d16z6 into 91 crx si...wiring help?
- Oil Filter
- mini me wont start
- help water at the donut wheel area
- Portland Oregon people. help!
- new to crx world
- Portland Oregon peple. help!!
- wiring vtec on my ef hatch????
- Clutch Interlock Switch
- 1989 crx dx dying on me
- question on a b20
- AC and Heat on 1 doesn't work
- NOOB RESTRICTIONS
- B16A, wiring Problem..
- replacing coolant hoses?
- Thermal R&D owners
- what fits in a ef 4 door?
- My Honda Beat Project - A technical deconstruction of a little known Honda.
- zc tune - obd0 or obd1?
- (pic) what gear set is the finel drive in thiss dx tranny
- Clutch Cables Breaking
- 1988 CRX SI...just got it today!!
- B20 Vtec Supercharged CRX
- Can i use a DA booster and master on my ef?
- I reat ihinkmy transision just craed out.
- how do u adjust a cable clutch
- Dizzy/ECU question for MPFI
- looking for a cheap exhaust.had some questions.
- WTF is up with this!
- h22 swap
- My white hf
- install help.
- 88 civic si cluster in2 a 90 civic dx
- Tranny interchanging(B into D)
- What to do with broken ZC block?
- Car has no electrical power
- ignition break up at low RPM
- Avid Racing shift linkage vs. Hasport shift linkage
- Suspension Techniques Sway Bars!!
- i will pay for help
- Need to weld new front radiator support pls help where to do it cheap, socal area.
- I need some help FAST!
- 88 model (crx) with 90-91 side moldings
- how can you put automatic door locks on a 91 si
- burnt looking coil and distro cap
- help is it posible to use a mpfi obd0 motor with a obd1 ecu
- 90 dx - mpfi question
- fast blinkers please help!!!!!
- Automatic To Manual Swap...
- crx noob question.
- coolant temp sensor
- 1989 honda civic foglight
- would p28 work on my ls motor
- 88-89 CRX -90-91 CRX DIFFERENCES (HF) MODEL
- tokico HP/ illumina?
- just bought a 91 si yeah boy
- 91 crx hf wont start.
- SOHC ZC cam gear same as A6?
- Another Rim/tire suggestion thread
- DA integra power steering rack into a CRX
- can i use a 12volt switch for a fuel kill??
- What mpg does your 88-91 CRX/Civic get?
- help with mpfi swap cel 4 for crank angle sensor
- gauge cluster swap help!!
- crx with b18 swap checklight cel 6 and 5 codes no thermostat HELP!!
- ecu/ motor swap question???
- Exhaust Question!! RS-R!!!
- b18b1 into an EF Si, searched, still have remaining questions
- motor swap
- 91 civic hb clutch problem
- BRAKE BOOSTER!
- blown alternator fuse again
- Anyone using EF9 knuckles? serious toe in after fitting. Shorter tie rods?
- code 9 problem
- crank part #'s
- Which master cylinder to use on a CRX ?
- Pistons
- H22 v.s B18
- options for mounting rear speakers
- No heat in the motor nor in the the car????
- 91 hatch .. problem plz help
- A plastic key???
- Ecu code 9
- brembo evo 8 calipers on a civic?
- bumpers?
- GSR ef motor sometimes stalling...
- @@@ Mystery Heat @@@
- integra seats vs del sols
- Couple of different questions and suggestions
- Need some help
- b20 ef back firing no start
- b20 in ef, firing order?
- difference between dx and si
- Emergency Handle
- IACV / EACV Help on CRX
- bogging under 2k rpms
- CRX suspension help!?
- CD Player Issue?
- my lights stay on, key wont come out
- my ef-8
- Car won't start after replacing valve
- no heat or ac on blower
- OBD1 injector question.
- vtec solonoid leaking oil please help!!!!!
