View Full Version : Honda CRX / EF Civic (1988 - 1991)
- D15b7 mini me project
- Ctr Ecu
- car is makin a weird sound
- B16 with dc 4-2-1 one-piece header bracket
- Help me out on this engine
- Crash pics
- some ole dumb questions.
- greddy sp pics????
- Look what I found for sale..
- Hf-Zc wiring problems!!!!!
- Need Advice !
- I think I got a pretty good deal!
- EF/ED rear brake swap INFO
- Wings West Door Cap question
- heres 8 pics. some help me please, and tell me that something looks wrong in the pics. thanks
- Things keep getting better
- ghetto d16a6 buildup question...
- how to get the molding off of the sunroof?
- when installing a b16 in a crx, do you still use that black canister
- Trany oil, what do you use?
- rear seats
- D16y7 for mini me?
- please help
- 88-89 Cluster into a 90-91
- Swapproggress... was "got board had some stuff delivered"
- Will Integra lowering springs fit a CRX?
- I need your opinion on Brakes
- Car problems... need help pretty quick.
- Resonator For new exhaust???
- Loud noise coming from shifter??
- my car idels at 3k rpm, how can this be fixed, need your help honda techs
- anyone have a b16 w/itr intake manifold. if so. how did you hook it up
- Mods
- need a part that will let me hook up my speedo cable
- Best Motor swap
- CRX/Civic Seats
- B16 problems stil!!! Help me guys comn..
- tranny gurus - how do you pull the bearings out of the case?
- EG vs EF weight differences...
- Pg7 ECU with ZC
- sunroof tracks
- Need help removing front bumper
- D16y7 vtec mini me swap
- Different ecu programs
- anyone heard of camp 3180 engine mounts......
- Diagnostic system check
- Abnormal Front End Noise?
- wanna make sure im not rippin off my friend. tell me what u think.......
- for those with adjustable struts...
- 87 prelude engine
- mandrel-bent exhaust for Civic Si?
- my car bubbles..
- crx exhaust
- What's the difference between...........?????
- Rear sway bar
- car won't idle right..
- best thing to cap axle holes on tranny with?
- why do i get alot of smoke when i start the car
- Miata wheels fit on a crx?
- jdm b16a1 linkage heeeeeeeeeeeelp
- Anyone Want to Sell me Their Rear Seats for HB??
- HELP!! Fitting 5th Gen Civic Front Seats Into 89 HB
- How often do you drive your CRX/Hatch?
- hondamotorsonline.
- b16 vuum leak
- Problems with SiR Headlights......
- pressure regulator or pump
- D16A6 Engine Troubles
- b16 header?
- flow rates for zc and si injectors
- clutch problem. please help
- Taking forever to start...what might be the problem?
- Teg interior...? And CV boot ripped!
- crx tranny on hatch?
- where to buy B16a CABLE TRANNY????
- compression tested today?
- Carfax
- Crossmember..can i ditch it?
- need pic/help with rear sway bar on a 91 dx
- ive asked this 3 times, still not a good awnser
- Need Parts
- Loud noise in motor
- some old lady hit me!!!
- Why do reverse lights come on sometimes when I brake on a 91 CRX SI?
- timing belt on ZC help
- who has a H22/23 in there EF or CRX?
- Midwest CRXers!!!
- ctr pistons in b16a1?
- dx to si swap?
- Still having b16 problems..the list goes on
- b16 intake...help
- b16 idle problem...help
- JDM clear corners? where to buy em?
- How to: Convert from a 1-wire to a 4-wire O2 sensor
- Left side sagging...Time for new shocks?
- Temp guage not working
- 90' dx fully gutted ......
- Pricing info on "mini-me" motor...
- Any SI's for sale? Northern va??
- b16 in 89hb shakes violently while accelerating?? please help???
- how do i tell if a ball/roller bearing is bad?
- 88 DX for sale in Cali
- What should I do for my poor sunroof?
- Gauge Cluster
- QUICK HELP PLEASE!!!! On computer code!!!
- Just got free CRX need advice....
- Quick ?....need torque specs of the flywheel bolts...
- 89 si hb, full interior trim 100% new looking, for sale, ef oriented.
- Klean engine bays post um.
- post your 91civic hb`s!!!!!
- carpet dying
- Need an a/c parts list and what to expect to pay..
- Quick Help Quick!
- Anyone go on CHB?
- Hood locks
- Car shaking WTF??
- Why can't I lower my car more?
- rear disk
- I did it!! Threw everything useless out the car!!
- CRX-Want to put in a gsr cluster!Need help!!
- D16A6 Swap wiring?
- will 91 integra motor mounts work for my car?
- light bulbs..
- intake pipe
- check this intake out guys ooo so nice
- JDM Stanley Clear Corners
- Need Advice ASAP...
- MIDWEST Chicago Honda-Tech Meet
- whats the best oil to put in your jdm ys1 trans w lsd
- Will b16a pistons fit into a b18a
- grinding when up and down shifting into 2nd.
- Brake Fade
- D series swap
- radiator question...
- ef9 suspension
- bouncing tach
- I'm A THEIF...so what?
- Spark plug wires popping out
- Anybody know how to wire a 4wire O2 sensor into my car???
- 88 Teg - ZC swap
- anyone in oklahoma city here?
- b16 linkage
- EF8 or EF9?????
- Cleaning Injectors.
- clutch with si trany and zc engine?
- Exospeed?
- Anyone done their own Interior work? Reccomendations.. pics?
- What should I do?
- b16 spark plugs are getting so black that spark won't go through the plug wires
- 1990 CRX Si, wring B16 ?'s
- Body Part Interchangibility
- SI dist. wiring
- To mini me or not to mini me, that is the question!
- neeed. imitation gun metal spoons.
- Integra '86 engine harness... will it work with a ZC swap?
- high performance brake pads
- how can i find out if a zc tranny has LSD?
- crx shell
- How to dpi-mpfi DX-Si
- Stopwatch Dyno-Long
- CRX vs Me vs Leman Course
- Hey guys, I'm....new to the C-REX world......how easy it is to get a D16Y8 in a 91 SI?
- i want to install these brake pads...........
- What does it mean?
- Introducing myself and a special introductory offer!
- Action Clutch From Exospeed? Any Good?
- Will 92-95 civic springs fit my 91 crx si
- Intake Manifold - What will fit???
- valve cover
- 95 M3 style sport mirrors on 89 hatch
- question on my springs
- need internals
- I am the new proud owner of a '91 CRX HF. :)
- d16a6 camshaft
- Zc timing belt?
- rear speaker brackets?
- jdm one peice headlight
- check this civic
- Info on sir 1 b16
- How do I make ____________ seats fit in my HB??
- Iac?
- MPFI swap... getting 5k idle and smoke out of the exhaust
- cam gear settings......B16's
- timing on b16
- Bolt pattern for 99 Civic?
- Downpipe to Catalytic Converter With B16
- Accel wires for a CRX?
- ZC cam gears (again) HELP!!!
- auto - maunal conversion info.
- need help with zc
- CRX front bumper problems
- 92 D16Z6 Driver side mount Question.
- 99 prelude seats into a 91 si rex?
- how do you seperate transmission halves? (i know about the clip)
- what camber kit to get?
- D16Z6 wiring question...
- I have a Question about My Recaro Srd's Seats?
- Weighed my sunroof.....
- VTEC solenoid
- high flow cat vs. test pipe
- Carsound cat?
- crx or 87 hb??
- 1990 Honda Civic Hatch
- Quick oil question....?
- poppng (not clicking or tapping)....engine really loud.
- How much is it worth?
- Anybody see the JDM style CRX in the new superstreet?
- Is this product good??
- Which would you suggest, 2 1/4 or 2 1/2 in exhaut piping on B16a CRX?
- Which Spring Compressor should I get?
- New Motor -> CRX Suggestion?
- will 89 teg guages work in a 2nd gen?
- question about swapping guage clusters??
- B2 block & A6 head...timing issues !!!
- Alternative to Rebuild?
- typer
- CRX Sir headlights?
- 87 CRX swap queastions...
- 1984 Civic HB..how close to 88 is it?
- ZC check engine light question
- JDM ITR shocks and springs on JDM CRX SiR?
- b16a top out?
- 98 civic ex knuckles?
- FS: Honda CRX Front/Rear Bumpers with foam inserts. (In Classifieds too, more CRX traffic Here)
- oil consumption
- b16 is in....cylinders #2 and #4 getting no spark
- FS: (yes i know this should be in classifieds but its for CRX's only)
- Question about shocks and springs.
- Sohc Zc?
- heres how much i can spend.
- Need help finding.....
- clutch replacement in 88-91 civic/crx with b16
- Adding Air Conditioning
- what kind of intake should i use?
- What shocks should I get?
- ZC backfire?
- B16 Time!
- whos the pre-OBD to OBD-1 GOD around here??? i have some questions
- what axle do i use???
- ATTN. People with HCP mount kits.
- electrical help pls.
- quick ? ordering now
- Timing Belt Broke
- DX flywheel same as crx Si flywheel
- tranny for zc swap...
- motor swap question......
- 4 point harness on del sol seats?
- Seats
- n e one using crane ignition?
- Hydro tranny
