View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Fuel filter install
- hondata ecu????
- FYI: Found a great deal on EF GC coilover kit (I'm not affiliated)
- accord ac control in crx
- EF_SEDAN HELP
- 255 fuek pump
- help with my integra console
- spark plug wires + mini me swap = plus is too short?!
- Need some diagram help...
- CRX mugen wing...
- hf dx or si
- 88 crx si distributor on a 91
- motor legit or not
- 1990 crx hf
- d15b1???
- need help with distributor...
- DA integra dash
- Whats the " ZC Front End " off of?
- Will Si suspension components fit an HF?
- im want to put a h22a into my 89 crx si?
- bad BOV??
- now this is differant
- Where do these sensors go??? - help me finish up my B16A2 swap please
- no hot air blowing out
- ls long block
- resistor box question
- *anyone rockin eg suspension in there ef's*
- What is this, random port with no hose, b16 ED
- wiring problem
- Car came without an antenna.....Need to install a new one, any opinions on how/which one??
- CRX Sand rail conversion?
- Window Problems!
- What Spark Plugs?
- Differences between front dx and si brake setup???
- need SUGGESTION on intake manifold and throttle body
- 91 dx (without tach) cluster problem
- Oil is dark not sludge
- crx corner light question??????????????????
- '90 CRX Talk - HF tranny in my DX? (The horror!)
- slamming my 84 rex???
- Wiring Help
- 91dx hatch lookin for lip options? pics plz!
- b20 pistons
- 89 or 88 Crx, DPFI?
- wagon
- S/T rear sway bar
- Syncros problems.
- wheel positioned to far foward
- dohc/sohc engine and gear box
- O2 Senser
- Shaved Fuel Door
- LS swap in CRX
- Rear Trailing Arm Bushing X-Tractor??????
- car surges really fast after mpfi swap
- ZC trans on D16z6 in an EF... DA inner joint issues
- '90 crx hf front brake ????
- need to buy an alarm any advice
- ENGINE SWAP IDEAS?
- Swapping Different Year CRX HF Transmissions & Clutch Kit Question
- B16a build up with out pulling out the hole engine. need some help???
- crx clutches all the same? 1988-1991
- vacuum hose routes, engine is stalling out.
- MAP sensor problems...need help
- Civic bumpers on 88 CRX
- D series turbo question again
- Where to find exterior moldings?
- Ship bumper
- b16a2.............car won't redline?????
- IAT sensor
- code 4
- Finally a worthy engine for the EF!
- INTAKE MANIFOL
- Crx wiring harness question.
- Im Civic-less
- Hve a swap problem/quest.....
- supercharger or turbo
- CRX for sale.. 4wheel disc brake.. ZC engine
- which sunroof visor?
- brake problems...pls. help
- What you think work equip 1's or 3's???
- New here.
- Nitrous Blew my head gasket!
- I Need Advice. Installed a New Header on my DOHC ZC. Hangs Way Too Low...AC Fan Won't Fit.
- y8/D15 Mini me and OBD1 conversion questions
- cant decide! either b16a or ur basic ls/vtec??
- d16z6/a6 mini me, what head bolts?
- b16 injectors vs d16 injectors
- ek half shaft
- Proper Bleeding Of Coolant System!
- help, upper control arms..
- B20 overheating?!
- code 14
- Shifter??????
- HELP! I need a new clutch pedal bracket
- What is this in my engine carpartment?
- need some serious help
- Need help on Vacuum hoses's/diagram b16a1stgen
- oil seeping out of block on #4 cylinder
- How much does a JDM front end weigh?
- How to get CEL code in OBD1 crx??
- Just to verify...
- help: need new cat
- Honda CRX ECU - Laptop Connection
- PM7 ecu pinout
- Just bought rex.Entering the ef comunity.Picsss.Couple of little problems thogh lil help please.OK M
- FAQ: Mugen CRX Pro Kit II Authentication Tips. Tell The Real Deal From Fakes
- h22 dizzy question will paypal $10.00 for answer
- b20,anything else needed?
- crx bumper on civic
- looking for a post of ef! help me out!
- d16a6 help
- b16a in crx... dizzy gone bad.. what do i replace it with ?
- any other rear bumper supports?
- Cluster Lights Flicker/on at wrong time
- hf questin
- D15B VTEC Question
- MY FUEL PUMP DIED!!!!!!! Please help!!!!
- B20 Linkgeage
- Omni power coilover problem
- short shifter
- drag gen3 manifold clearance questions
- honda civic si ecu info!!!
- B16 wont turn over at all!!!
- New guy here
- S1 tranny
- Look what i go this weekend
- code 13
- Back seat swap
- after the swap
- well went to the track and have some Q's
- megan springs
- will a d16y8 manifold work for an MPFI swap?
- prices for an alignment
- HELP NEEDED! 87 crx si. I GET SPARK BUT IT Won't TURN OVER!
- Click clack thump up front
- rhino camber kit hitting frame what can i do to fix this??
- Motors Mounts
- Out with the old in with the new
- Kinda bored, thought I'd ask.
- b-series engine mounts!!
- anyone from sweden (stockholm)
- LS swap into my 90 Si CRX
- 90-91 CRX Recalls?
- Built b16 vs Built LS??
- hi there
- have to love ebay
- Hidden wirings
- jdm d15 dual carbs
- d16a6 no compression at all
- How much do you think my CRX is worth.
- speaker ???
- knock sensor question
- Holy low mileage CRX!!
- Front traction bars . . . . . . Opinions?
- starting issues
- Ef Hatch Ls Swap Trouble
- problem with d15b2 motor
- throwing code 7
- VTEC ?
- Wire tuck
- Info on 1st Gen CRX
- tranny to motor help
- This is just crazy (chk out this ebay auction that ended)
- Need help asap
- dual point computer
- 90 hatch with obd1.. having problems..
- Need a column-mounted light switch / directionals switch
- d15 b head
- fuel pressure regulator install?
- d16a6 problems
- Subwoofer, backspeakers, and power
- EF swap probems
- sunroof problems
- DX pic request. intake mani wiring.
- crx in need of.....
- I WISH MY CRX WOULD BURN DOWN
- help a NC
- positive camber issue
- syncros for b series tranny
- New engine questions
- 4 door fo sho...
- what is the ricest CRX/HATCH u ever seen
- hello to all
- can the harness connectors be retensioned?
- everyone with a DC2 non srs wheel please read ::-
- I have a d15b will the stock front motor mount work with this motor?
- b16 tranny
- Rebuild motor or buy new?
- CRX brake upgrade
- need help on wiring dizzy
- Fuel Pump won't stop priming, HELP!
- Help a noob with high compression D16 project plans
- 5 bolt civic conversion
- ecu wiring
- ZC intake mani and zc cam?
- Stripped tranny fill bolt
- Tranny Code Info?
- accel pedal drags down rpms after decel
- Anyone ever had this happen before?
- what tranny??
- fuse box diagram
- 90-91 crx si cluster swap to my 89 crx si... need wiring pin out or diagram.
- Deceleration Jerk... Any Ideas
- Eliminating excess wiring on 89 CRX DX...
- help choosing engine, b16 b17 b18
- JHP OBD1 Harness problems!
- idle
- do i really need to change this?? and a sunroof question (stuck open)
- could i use si wiring
- got some problems with the o'l CRX
- head gasket help
- "XTR" clutches?
- Alternator or Battery?
- Where to mount 4pt. harness?
- car vibrates when i turn
- Dash Lights
- Rear lip on CRX ?
- need help asap
- look at this pr3
- oldschool
- WTF! arg
- GoFastTshirts Company car Build Log
- Can anyone tell if this PR3 is AUTO or 5 Spd?
- putting 90 rear bumper cover/ support on 88
- need help on how to install a new lower ball joint
- Is there any kits available to use a sohc hydro tranny???????
- problems with tdc/cyp/ckp sensors
- O2 sensor placement
- Tubular Control Arms?
- B16 cant rev past 3500 rpms, and almost bogs when I tap the gas.
- ek coup side skirts on an ef?????
- Location of oil pressure sender on obdi ZC DOHC
- anyone with b20 hatch
- i wanna out a/c in my car...
- zc engine vtec
- Where do i get fiberglass race parts now?
- HC and CO
- 89 CRX fuse box diagram
- b16 buy
- obd1 question
- Another car won't start thread... I'm not a noob.
- d16 swap question
- My 88 Turbo Wago Project!! (Lots of pics)
- Gauge Installs (Voltage, Oil Temp, Coolant Temp, Air/Fuel, etc) Walkthroughs - Where?
- Finished up the quarters on my CRX today
- which motor is it???
- B16a6 Block/Gearbox separation.. Need quick adive how to separate the two
- 1988 CRX HF - build in progress...
