View Full Version : Honda CRX / EF Civic (1988 - 1991)
- normal then at 3,000rpm starts to backfire
- Timing?
- aem adjustible cam gear
- these fit just as tight as pistons :)
- What now? All my brake lights in the back stay on when the car is off
- Removing boot from radiator fan switch
- 4x114 on to a ef9
- Replacing wheel studs
- ?? burning way rich??
- Ls Swap in my CRX Hf what harness to use
- speedometer problem
- be for i buy please help
- Trying to get parts for a tune-up, but what are these?
- Surging/Jerking Problem with B18A swap CRX
- water lines to the throttle body
- Head gasket???
- 88 CRX Electrical Problem [searched]
- Questions (climate controls)
- Help!! 89 Civic Si
- Could a dying battery...
- Anyway at all to tell between a YS1 GSR or LS tranny without disassembling?
- HELP! CAR SHUTS OFF FOR NO REASON!!!!
- I need help with the air conditioning
- Engine badge question
- CRX FUEL TANK question.
- How do i install a switch to Radiator fan ?
- Random Tranny Mount Question
- s2000 cluster and 90-91 crx interior
- b18 swap, shifter not sitting in the right spot??
- Timing Problem
- b16 ef Q's
- molded carpet?
- solid cel after swap
- OBD0 to OBD1 wiring gurus please chime in!!!
- is my civic rare?
- civic wagon bumer support question
- Difference Between zc cams and d16a9
- Weird electrical problem. ls/vtec obd1
- 88 dx 4door w/mini me not getting Fuel to injectors # 2 and 3 help?
- crx/gsr question
- Please ID this part
- Car won't start. Please help. Main relay??
- B16A OBD0 Tuning?! Trying to adjust for exhaust and cam changes w/o dyno and hondata
- What Axle to use for wagon 1990
- wheel bearing or new hubs
- help!!!flywheel
- do i have ex identical knuckles?
- 4 door seat rails same as hatch??
- b20 vtec head gasket question
- Read the FAQ but still have questions: Big Brake upgrade on CRX HF with DA knuckles
- Thermostat problem 88 civic
- firewall bar location for cage. already searched
- fuel injectoin conversion??
- what axel do i need?
- reviews
- 88 civic issues help!
- T-Brace (Intake)
- issue with water temp gauge after swap
- Timing question
- 5x8x24 magnaflow with a sohc ZC and 2.25 pipe
- crx ls
- 88 DX bottom end, 94 DX head= which timing belt?
- 02 sensors
- Anyone ever fail smog/emission due to high HC and NOX?
- No Spark help needed after DPFI to OBD1 conversion
- Side-mount seat rails?
- >>i need some help please<<
- Cluster troubles LSVTEC please help!!!!!!!!!!
- converting 90si to run on hondata s300. distributor issues. Need help, posting for a friend.
- 1988 hf crx trans si, dx, hf splines the same for the axles into the hub and trans, i know the 89+ c
- i need help on my minime swap PLz?
- 91 crx SiR gauge cluster light. What is this
- idle problems...
- qaurter panel replacement.
- Anyone know about this spoiler?
- OBX Twin Loop Exhaust
- just got a 89 crx si it has a b16a in it but i need help with my wiring!
- Fog light EF9 help
- JDM Gauge Cluster Install Help!
- torque specs on y8
- very bad shifting prob....
- crx LS drive axels HELP
- axle seal leak after trans rebuild
- B16A obd0 to obd1
- timing belt cover Q's....
- Differences in B series swap mounts.
- SEAT BRACKET HELP?
- HELP!! i cant figure out how to take this trim off
- A/c problems in a crx
- EF A/C questions... anyone out there good with auto AC ?
- Crx fender flares? HELP!
- dpfi to mpfi need help
- Cali Smog, failed NO test, will simple adjustment pass me?
- Help with B18 Trans
- zc tranny, b series axles?
- Disc brake conversion question
- Overheating problem on race track only
- BIG Brake upgrade for 1990 Si Hatch
- Clutch cable swapable?
- Performance Chips...
- dim headlights, no electrical power
- exhaust
- Just bought an EF
- Any issues running a different stock Fuel pressure regulator?
- Struts?
- Vacuum advance diaphragm location?
- CEL Code 9 :: Cylinder Position Sensor Issue
- stock hight bad neg camber
- 90 Crx Transplant Problems
- NEED HELP WITH INSTALLING NEW SEAT FOR EF9 ?
- Cam belt change tutorial
- Throttle cut out high rpms
- car keeps flooding
- Spark Plug Wire Order
- Grills...
- Clutch Help?
- Clutch relpacement question.
- need a picture or the pin outs for drive side shock tower engine harness connector
- ECU Code
- integra rear disc swap question
- EMRacing bars in Crx installation
- b16 swap ?'s
- Any one know which part replaces JDM...
- B16a rod big end spec. Also looking for y1 tranny pdf.
- crx to accord climate wiring
- Quick question - CRX/Civic door trim interchangability? I searched!!
- crx HF question
- Finishing Rear Brake Swap, ?s about Parking Brake
- removing decals
- Weird Overheating Problem
- 90-91 gauges fit inside 89 cluster?
- How the hell do you remove the main relay??
- d16 compression increase
- 91 civic noise when starting
- Quick question, is the cx and dx engine harness the same from a 90 hatch?
- limp mode,popping noise out of intake
- ef with b16a ignition timing
- help! swap help..
- jdm b16 build upp
- headlight/corner light question
- weird idle? up down up down
- Stock Steering Wheel Poll
- Hatchback owners, Cargo Cover fabrication
- Pic request. crx civic fiberglass hood
- Engine Torque Damper
- climate control
- Civic owners, CRX Dash?
- long crank before car starts???
- Looking for a Job in the P.A. delaware. area Swaps, Wire tucks, conversions, tech...
- Lowest offset??
- JDM ef2 front end conversion for ef sedan question...
- Help please! I need some minor help form you honda wizards. 88 CRX DX bogging on exceleration.
- where to straight pipe my car?please help
- gas problem, bad mpg
- b16 crx heater core
- Black rear center garnish
- Misfiring at low RPM?
- wiring a DX 89 CRX to B16???????
- AC not running cold. How to do a DIY recharge?
- B16 OR D16Y8... WITCH ONE?!?!?!?
- I messed up and need help please
- rpm seizure X_x
- nosing a b16
- b series questions...
- overheating problems?
- what is the name of this web site
- Electronic VSS pinout
- JDM Crx nose cut vs USDM Crx nose cut
- Looking for clutch interlock switch
- 91 civic dx with 92 teg in dash and motor harness work ?????
- NEw ProBlem...HELP
- IS ANYONE SELLING ANY EF SEDAN PARTS??
- Repair Shop Recommendations for the Dallas, TX Area
- brakes
- fuel problem with a si D16
- dpfi wiring schematic
- SUSPENSION QUESTION
- 88 CRX DX 4 speed bogging down when warm
- Are all crx taillights 88-91 interchangeable?
- power is shuting off when starting
- 1.5l DX wont pass smog any ideas?
- Converting to hydro tranny. VERY CONFUSED!
- DOHC ZC question
- Is this a decent deal? (1990 hf CRX)
- Where to buy a piezo buzzer?
- air conditioning problems
- upper control arms
- Where can i buy OEM front quarterpanels?
- lsvtec what to do to the head
- wtf is up w/my rpm gauge?
- Tranny/Clutch issues..plz help
- Re setting timing on 89 civic DX 1.5L
- crx not starting
- transmission help~ lsd
- Power steering in a crx?
- TPS sensor question
- Need help with running antenna wire
- Squeaky Suspension
- need some help with mini me swap
- mpg!
- CRX JDM trailing arm vs CRX USDM trailing arm: same?
- EDM Flush Mount CRX Spoiler
- searched and no answer that i liked: sunroof 89 crx.
- Will a 88-91 civic climate control fit into a CRX??
- car not starting after driving
- cluster
- dude...dude...look...look
- f to d threads?
- CRX JDM SiR headlights & corner lights
- Hi guys, new to the forum, I need help.
- heater core need it or not
- wire tuck help! i searched
- ZC hood on an 88 sedan????
- Should I Boost Her?
- B18A1 block question ????
- Question between USDM and JDM Transmission Gear Ratio's for a B16A
- Ripped off
- B16/B18 Transmission
- ZC intake manifold woes
- auto mpfi help. please
- EF Civic hatch grill...
- fuel pump?
- FRONT CAMBER ASAP
- c313 connector where wires go ?
- Mini-me ?
- B16 MOTOR WITH LS TRANNY
- pics of a b16 swap in a crx/civic
- need help installing coilovers on my crx
- 92-95 civic uca same as 88-91 civic
- going to state refiry , what catilac converter??
- wiring harness question please help
- What mounts are you guy's using?
- hey check this site out..
- Need help!! alternator,solenoid fuse 14 popped
- Crx dash in a civic hatch
- Hard Shifting 91 crx si
- Uh, this is bad right?
- 5-Lug using EX knuckles
- 90 si rev limiter
- walbro fuel pump problem
- not good gas mileage. maybe its because of a code im throwing or chipped ecu? fix it please
- Problem with car starting every once in a while.
- Problem with illumina shocks
- Aftermarket pump for GSR questions
- just a video of my swap experience..
- VTEC BOGS DOWN WHEN KICKS IN
- 91 Teggy LS Wheel Bearings...
- what the heck is going on with my car??? can someone helop me now?
- Eg seats in ef??
- finnaly getting rid of that single (help)
