View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what kind of oil for a lsd tranny?
- 1992 Civic DX Distributor and Wireing Harrness in 1990 DX with d16z6
- ECU HELP
- need help on conversion!!
- quik question...On wiring plz answer.
- quick qustion for a friend
- ls tranny?
- OBD0 to OBD1 conversion.
- hf problems
- 91 cx to SI 5th gear= the same?
- A question about DPFI to MPFI/OBD1 conversion. Injector powering question.
- Help please!
- no coolant?!?!?!?
- HOW MUCH FOR A EF/CRX SHELL ????
- Need help with reverse lights
- question
- Best Road/Track CRX Suspension Setup Full Coilover
- 16A6 Camshaft
- b16a 1st gen into 91 honda hatch
- speedometer/milage issues
- I cant get these JDM ef9 seats in my 1991 USDM hatchback Si. PLEASE HELP!!
- What axles b18
- Taking out the back seats
- Should i buy? 89 CRX B18C1 YS1 + many extras $5000
- taking apart the steering rack
- Picture time woo!!
- how much is a ys1 gsr tranny worth?????????????????????????????
- hub bearings bad, which do i get w/ b18 swap?
- Venom Vacuum Mani - Which Vac Hoses To Back of Manifold?
- wiring help needed.
- Steering wheel shaking with stopping.
- LS swap
- Need detailed pictures of ecu wiring for crx b18b
- H22 Into an EF?
- damn it the cold comes around so does my fogged up windows what do you do?
- getting rid of 4 door ef
- why would you lock the topic???
- What causes EXCESSIVE moisture in exhaust?
- ef squad logo
- anyone have a tranny diagram?
- I want in EF Squad
- About draining my gas tank...
- d15b7 vs d15b2
- how to remove fuel injectors from d15b2?
- Blitz turbo timer install
- Selling my project, what price would be reasonable?
- where can i find some rails/slider for my recaro srd's???
- 90-93 teg seats in a 91 crx - opinions
- Ball joint Removal...Bolt flared?
- putting a z6 into my ef. Got a fields boxer v-tec controller. anyone got any wire diagrams for me to
- oil filter
- will d15 axles fit on a d16a6 tranny
- Crx sunroof rust: Is there any way to slow its progress?
- *who has 45 series tires*
- CRX EXHAUST
- Car hesitates when accelerating...HELP
- need help
- jdm headlights Question/
- Removable Hub n Grant Wheel Install. WTF Am I Missing? Scammed?
- Tranny Problems! Engine makes ticking noises! help!
- Gas tank interchange
- a factory cd player from honda 1998 civic ex wire chart.....
- what is this sensor for?
- help me trouble shoot please: dpfi dilemma.
- car overheatin!!!
- DOHC ZC
- sparks arnt sparking
- Stereo Wire Colors
- wire harness help
- HP Racing Exhaust or Magnaflow?
- I've got A quick release question
- Newbie Question!! what kind of oil for my crx
- NEED PICS OF RED GT3'S ON A BLUE HATCH!!!!!!!!!
- NEED PICS OF BLUE HATCH WITH AMBER LIGHTS!!!!!!!!!!!!!!!!!!
- Pls help. Will an 88 CRX hf driver seat rail fit an 88 crx si?
- Alternator?
- need a basemap bin file for d16a6-T obd0 with 390s
- help on how to wire a 91 honda civic hd dx
- Quick EF Si question.
- JDM D15B WATER PUMP PROBLEM!!!!!!!!!!!!!!!!!!!!!!!! HELP!!!!PLEASE!!!!!!
- what does this plug do ?
- GSR SWAP HELP!
- NEED HELP!!!!!
- What's the blue plastic on the clutch pedal do?
- help
- Which Camber Kit
- Any one here care more about MPG than going fast?
- Best Place to Buy Replacement Springs
- ef squad????
- Apexi S-AFC 2 $225
- LS 5th gear?
- Roll Cages ?
- b16a motor sweep in a civic
- Whicht tranny to get?
- Bouncing Idle Problem, Pissin me off
- Can you Use a B series Tb on a D series Intake Manifold?
- Main relay
- Weres it at???
- Shifter has way too much play
- 88-89 OEM fenders
- Eibach Sportline Springs!!!
- Do I have a GSR or and LS transmission?
- how to : radiator?
- UKDM cluster/low gas question
- looking for member from past: Chrisonepointsix
- anyone with aftermarket fuel pump have starting problems?
- Exaust manifold B16A1
- Hello from across the pond!
- crx bumper fins?
- CRX SE Restoration - In progress pics.
- help car acts like it wants to die
- want to buy...!!!!!!!!!!!!!!!!
- converted to obd1...does it matter which b16 tb I get?
- Say I have a CRX HF and I want to make the engine an Si all I would have do is... ?
- crx sunroof top into a civic
- ZC tranny help...PLEASE!!
- Timing belt question
- Leaky 1990 Civic taillight Gaskets, I am making a batch of my own this weekend, do you want some??
- sedan owners #### have you removed your automatic belts?
- 2 yellow wires on drivers side harness...need help!
- electrical help, boggling!
- Cluster??
- pic of gunmetal itr 4 lug usdm rims on an ef
- ecu question
- some one please answer my question
- Engine Mounts
- Im new here Check out my GSR swap *pics*
- head gasket?
- 5th gear slips into neutral
- how to check spark plugs?
- splash guards off from a 4dr ?
- OEM shiftknob ?
- brake problem??
- right hand drive in the us how do u do it?
- LCA's. Will EG LCA's Swap Right In? (function 7 etc)
- HAHA sweet..thank you JDMSHIT.COM!!!
- j's fender flares
- flat paint.
- need wiring diagram for 90 hf
- Z6 vs Y8 block differences
- Could i paint and install my own bodykit
- fuel filter?
- need dohc aftermarket parts...whats zc equivelent???
- Fullsize radiator and turbo?
- Z10 traction bars, where to buy?
- could it be done?
- Block Guard Question
- Got me a Wagovan!
- got dynoed
- 91 crx
- Walbro fuel pump install?
- Which obd1 distributor do i need for Hondata on D16a6 motor?
- 1st Gen Tranny question
- Correct Spring rate
- Auto seatbelt wont go backwards!!
- What is this thing, why is it clicking and why won't my car start?
- ecu pinouts for tach after converting to obd1?
- Does the fast idle valve only affect cold starts?
- 88 STD with a 91 CRX Si dash/cluster
- d16 vs zc
- 1st Gen B16 Tranny
- OT: Trial user status?
- fuel pump
- HELP!!!! All lights work except driving lights and dashboard lights.....what could it be?
- 12" Willwoods clear Rota GT-3's?
- Code 43 and Code 1 LS Swapped Crx....searched
- is it a bad headgasket?
- Looking for help with Turboedit
- dyno or more fuel first
- HELP: crx with b16a1 doesn't start
- What Intake should I get??
- interchangeable speedo cable?
- D15B vtec engagment problem?
- FC injectors...
- Code Questions!!
- where can i get a TDC sensors for a zc motor
- learning somthing new 2
- noob help
- eg rad in a ef
- Help.. Car won't start
- learning something new
- Carbon hood for 4 door Civic's
- putting in b18a1 into 88 hb
- Brakes
- Type R valve lash
- CHECKIN CODES ON 89 CRX SI
- Does this sound like a good deal?
- da cluster in ef
- My EF Civic !!!!!!
- thinking about turbo...
- how do you know if its an si tranny
- IGNITION CUT
- Need Specs of Front Clip 90 CRX
- Help with CRX Quarter Window Seal!!!
- climate control doesn't work at all and winter is almost here!!!
- Best way to clean motor?
- fuel pump problems
- Mr_CRX's bodywork and paint project log (56k get a snack)
- need wiring help (90 crx)
- Very-low to no idle when cold outside
- My brakes suck, anyone using the 11" fastbrakes kit on their Si?
- Idle problem
- My second attempt at recovering my ECU
- quick question?
- what dashes go into ef hatches
- Recommend a header for a b16
- No heat and its cold oustide...HELP!
- "buildup" so far.....'89 hatch
- heater making annoying noise
- tailights, gauge cluster and radio not working
- How can I temporarily by pass the steering lock w/o damage?How can I temporarily by pass the steerin
- V-AFC question
- 88-89 and 90-91 gauge clusters
- Any good forums sites or threads to get CRX parts?
- stock 89 1.5 hatch has no spark
- What parts will i need?
- auto tranny help, serched
- 91 REX Tach issues
- will a b16 head fit on a b18 ls block
- Where for a wide body for EF?
- Rear Disc Brake Swap Question
- Looking at an 87 CRX....what's different/should I Know before hand?
- valvetrain noise
- 4sale 4dr EF JDM ZC
- si tranny question
- homemade nos...will this work?
- d16y8 obd2 to obd1?
- jus curious here
- d16a6 redline??
- my odometer guage!!... help!!!
- how much boost can u push on a stock ZC motor
- i have a 89 civic si i was think about b18a1 will a b16 head fit on
- CRX B20/Type R head ><><><<NEED HELP
- which radiator hoses
- need help!!!!
- Anyone have any experiences with Magnaflow mufflers?
- Part Numbers??
- HELP ASAP!
- electric problems what the hell is goin on?
- fuel pump quits when rpm's get to low
- Busted input shaft bearing
- which would be a better choice?
- Pics of my B16!
- why me?
- Brake Upgrade
- Can't Get the Line off on the Fuel Filter!
- VIDS FROM THE TRACK OF MY B18C crx THAT PUT DOWN 210
- crx cargo cover question.
- Wirring/Sensor help needed! ASAP!
