View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Some help please. Benen products info
- way too much fuel?? tried alot.
- Jdm crx automatic window install
- fuel pump problems
- whats the rex doing???
- How Do I Replace Water Pump & Timing Belt On 1995 VX Motor(D15Z1 VTEC)?
- Map Sensor voltage
- Wiring h-e-double hockey stick
- Please Help - No Start After Transmission Install
- Help! Burning oil
- lug sizes?
- wiring harness questions
- Which headers will give me more power and save me gas??
- crx wiring with a b16 in a dx do i need to swap in si wiring??
- What will happen if I use ABS booster on CRX
- i need help plz
- 88-91 filler pieces same?
- Idle issues....Cold air intake?
- Timing Belt Guides?
- my project b18a into a std ef hatch!!!
- The K&N Xtreme Filter?
- Looking for a 'Cushy' CRX Passenger Seat - Suggestions?
- EFB2 Cable to Hydro W/Twin Disc
- D15b2
- resistor box
- crx car cover
- 91 civic wont start, doesnt crank,dash lights are funky Need Help!!!!!!!!
- Best ways to prevent theft ???
- Need help!! Crx bumper question!!!
- 95 vtec head on d15b.Timing????
- Annoying beeping caused from chestbelt!!!! Ef sedan help!!!
- Difference between 88 and 90 engine harness
- Cam, Timing Belt and Dist. Question
- SRT vs ZC Si
- whats the meaning of seized?
- Tranny's
- zc tranny ?'s
- Axle Question - Y1/S1 axles w/ YS1 transmission?
- Throttle problem after DPFI to MPFI swap
- What front end is this?
- B16 sleeve Kit
- Starter Compatability??
- super new to honda's, timing question
- 91 crx, How do I install a headllight
- i did know which section to post this in but...
- Gas Tank Leaking
- sway bar clearance issue
- DPFI to MPFI & CA Smog
- How to Build B-series Book found
- I'm in the prosess of rebuilding my motor. I have a few Q?
- wiring fuel pump on switch?
- Location of Cat converter???
- 90 Civic Hatchback Turn Signals
- starter question
- need help on some prices
- need some feed back on clutches!!
- got a ????
- Opinions needed
- Another car won't start thread
- Turn Signals Not working, no brake lights
- What Headlight Bulbs do you use?
- Axle?
- JDM EF8-9 stock air filter...
- quick timing question
- 89 crx si way too much fuel help
- cooling fan switch connector bad???
- opening stock head lights
- check engine light/shift light
- are these CRX quarter panels
- need help please....
- S1 transmission JDM or USDM??
- '89 civic won't start
- MPFI help.....
- em racing
- Msd ignition
- 91 crx cluster swap ?'s
- tranny problem
- D15b vtec parts?
- stolen rex
- Prop Valve leak
- 91 civic sedan heater problem
- crx front end on 91 dx civic hb
- Transmission Questions
- Check out my new toy!!
- new guy checking in
- bogging down at higher rpms?
- AC fan only works at highest setting.
- Parts that can still be had brand new from Honda
- 88 dx crx, swap complete 90 DA integra harness?
- what trans axle to use?
- the streets arent safe !
- A noob needs help lol
- Test A Coil????
- Intake Manifold
- RS-R Exmag Exhaust for 88-91 CRX?
- Ok, I really broke something.
- need b16 swap
- Zc dohc
- wtFF?
- cutting shift linkage?
- B16 alternator removal.. please help.
- Oil Pan Gasket?
- What exhaust manifold/CAT to BAR a B18C5?
- auto trans
- 91 Civic won't start
- Wheels in the 90's
- b16a2 vacuum lines in an EF
- Fuel Pump
- CRX Fuel Tank
- 89 Civic Sedan-Which transmission do i have?
- 90 crx water pump problem
- d16y8
- Caster
- Battery relocating cable usage.
- reping obd1 to obd0
- One side lower than the other, wth?
- are es poly shifter bushings worth it
- Transmission hell!!!
- P0A 1 ecu with d15 vtec
- Electrical Woes
- EF Motor Build Help (turbo)
- Ported my coolant neck, estimated hp gain: 0
- D16A6 with DPFI?
- i need some guidance
- Crank Bolt Removal Help
- help code 20?
- Idle issue after cleaning manifold with mass air flow sensor a
- dual cam zc tranny on d15b
- Rear Hatch Leak
- do i need to BAR a sohc vtec in crx???
- will ZC tranny and half shaft work on a d15b?
- d16a6 looking for hp gain.
- Energy Suspension Hyper-Flex Experience
- changing gauges
- Shift linkage removal
- Cleanest CRX I ever saw.
- rear sway bar body mounts
- Zc
- Overheating in stop-n-go traffic.
- Aftermarket door molding?!?
- crank but no start
- B16A or B18A
- Hydro HAsport kit question
- ek seats in ef hatch.
- motor help
- How many quarts for the trans ?
- Intake Manifold
- Changing a Dx blue interior to Si Black, any problems with paint?
- '88-'89 Civic windshield glass fit '88-'89 CRX?
- fuel pump issue
- O2 Sensor Help 4 wire
- Help me plz main relay
- Oil selection
- seat pan swap 88/89 90/91
- gsr vs type r head.
- Piston removal
- transmission specs
- Civic exhaust on a CRX, how much to cut out?
- ZC block w/D157 head??
- Scary Brake Problem 90 EF sedan
- Need a pic of the interior fuse box.... to see what im missin
- woe is me !!! poor poor rex (PICS)
- Removing Dash 90 EF Sedan
- does a da cluster fit
- hatch sat for 1 week.. hard to start
- Road Trip!!!
- Dx to Si conversion!?
- 90 Crx B16A Swap running hot
- fuses has no power..please help.
- exhaust??
- b16 tranny grinds at high rpms?
- what wuold be the best ecu for a 2nd gen b16a?
- ls/vtec in ef
- need help on my dx 90 hatch wiring anyone from cinci ????
- QUESTION: How To Clean Motor Interior Parts???
- 91 civic sedan won't start?
- 90 crx b16a swap valve adjusting
- What is this engine/car?
- 1991 civic dx
- o2 sensor question
- CRX D1.5 DX turbo?
- obd1 b16a. dizzy blew 2nd coil today.
- Rear Top Hats
- d15 ecu for dohc zc?
- Lightweight Crank(Under Drive) Pully, Bad or Good?
- Roll cage
- camshafts?
- ps engine mount bracket?
- hack job suspension questions...
- I need interior wire diagram for my crx...
- Will this intake work?
- More Tranny Questions
- Stealing
- sedan starter
- d16z6 turbo build
- Can some help me? Crx electrical problems
- Civic street cam & cam gear? Help!
- Where there a lot less 4 door EFs built
- Short Shifter
- Starting Problem NEED immediate HELP
- exhaust help
- d15z7
- Side hatch window bolt ??
- 90 DA engine harness similar to EF Si?
- i need help 90 ef ls vtec idle
- 90 civic dx & 91 civic si (parts compatibility?)
- O2 sensor help!!!!!
- wanted to share my 10 second build
- SOHC zc question
- combination z6 head or y8 head on jdm zc block
- Idle Air Control Valve questions using a p2k manifold on a d15b
- Engine bay and cleaning
- BAR help
- How do I mount the oddysey pc380 battery
- Gearbox linkages
- valve cover???
- dart tall deck in a ef
- PICS!!! Electrical problem..GUESS WHAT IT IS, the car is going to the shop on tuesday
- D15B Tranny Questions
- Code 4 Crank Angle Sensor
- D15B1 to D16Y8
- NOx levels to high smog problem nething could help
- 1990 d15b2 civic piston questions
- andyone have good links for a RHD conversion
- obd0 obd1
- New OEM Front Mud Flaps for CRX on Ebay
- how to change b pillar
- DC2 strumentation in EE8
- Nology ProFire Ignition Module
- Rear bumper interchangeability
- LS vtec with arp head studs help
- steering rack compatible?
- noob...
- New car
- How to: LED Climate control and Brake Light
- Has anyone installed a larger than stock battery?
- Jdm cluster with usdm speedometer??? Possible?
- What year honda battery will fit an '88
- CRX Cat
- Cold slushbox issues
- d15b vtec VS. Sohc ZC, whitch one is better?
- which tail lights are there?
- Can any Spoon heads confirm this?
- Mugen Wing Help - CRX
- help!! ac/heater problem!!!
- sway bar?'s
- Another boring code 41 thread.
- need help with z6 head
- Squeeling sound from belt? Help!
- Mpfi swap
