View Full Version : Honda CRX / EF Civic (1988 - 1991)
- does the B16a2 Stock Intake box fit in an EF 91??
- bumper!!!
- I Need Help Hooking Up A Heater Control
- My CRX was broken into, stereo, electronics, etc, STOLEN!
- opinions on springs
- H22 in a crx....
- Where to get ZC parts?
- anyone switch from CABLE to HYDRAULIC transmission
- HCP Mounts?????????????
- PIAA Super-White's
- Installing A Spoiler?
- art assignment (hybrid ef2's car)
- Please Help with zero idle
- Jumping Tach
- How to add camber in front
- Removing Freon from AC
- Wanted-foto idea
- D15/VTEC new toy.... will have some numbers soon
- 91 CRX swap question
- 88 CRX - B20 Swap, Is it possible!
- Automatic "j-spec" b16???
- Problem...won't start...sounds like dead batt but...
- Quick Question for all with b-series swaps
- B18C5 EF"s?
- del sol seats in a crx
- engine clean up
- Port and polish worth it?
- ES Oval Exhaust on CRX Question
- is it still possible to get OEM carpet?
- One of those si tranny questions.
- ZC SOHC or ZC DOHC
- eg seats in a 89 hatch help?
- fs JRSC for d16a
- fs: JRSC for d16a
- 89 d16a6 into 88 HF
- No B10 pin in ECU.....B12 PROBLEMS too?? MPFI
- Hondatech members EF8 mods
- what alternator???
- Anyone with custom pipe+spoon n1?
- Difference between Hatch and CRX
- Ya know that white 400hp 91 Civic 4D from around 1999
- ZC turbo "Greddy" with Zdyne tune guy
- civic problem wont start *PLEASE HELP*
- civic seat question
- B16 power issues
- how did you tie up the engine for your engine pull? *pics*
- ZC swap running...FINALLY!!!
- Some open track videos (uneditted).
- ||HELP|| TDC sensor code 8 (i searched)
- D-Series Power!
- Recalls?
- b18a1 in ef civic
- burnt ignition coil
- ?header will it fit?
- long blocks
- Noobie here only cuz i have Q's about my bros CRX...Nitrous Good or bad?
- My cracked radiator!!!
- CRX with b18 ??
- Swapping Thorttle bodies??????
- Question about block with after market cams?
- Second Gear Doesn't Go In All the Time
- can't get flywheel off help
- 2000 GSR Rims .. what is the best tire for my rex with these rims ?
- 89 fenders of 91??
- GSR Seats in 89 CRX si .. will it work ?
- b16 starting troubles
- inform me on the civic dx
- Tires You Would Pick
- tein on crx w/susp, what tires?? size?
- Carbon fiber hood vs stock hood weight?
- Attn: LS/vtec guys
- no CEL when key is turned to accessory
- GM Syncromesh
- unusual motor problems...
- explain mpfi swap?
- FS and ?? getting my dx tonigth details..
- oil leak near the block stamp
- new EF owner 56K killer pics
- clutch problems
- d16z6 swap question in a 4dr
- Oil Cooler Kits... where do I buy one
- Doing some research on what CRX / Civic people want. NOT A FS THREAD!!!!!
- ecu/v-afc debate
- Searched for firing order....
- looking for crx hf lifters
- sohc rods?
- Looking for a CRX SI engine!!!!!
- civic radiator in crx
- auto tranny
- what shop in arizona or so.cali is good at body kit installs?
- what other Si plugs are needed aside from, injector plugs for DPFI to MPFI???
- CEL- How to read the code?
- EF/DA injector resistor box compatibility
- JDM CRX SiR front end
- Maybe getting a FREE!!!! CRX.
- Clutch disappointed me yesterday...
- is my tranny going?
- speedometer
- Finished my mini me.. couple snags..
- PL9000 tranny code?
- Brake booster/Master Cylinder pushrod gap?
- z6 clutch with 90 tranny?
- EF9
- HCP Engineering Motor Mounts
- 5 lug si?
- Upgraded rotors VS. Big Brakes.
- Difference between 90-91 DX, HF, Si crx doors?
- stripping/painting wheels
- Shift Light Install, searched already, HELP!!!!!
- SI intake on a HF
- in need of help bad!
- map sensor code on b16
- Solid Sports Coilovers Good? Bad?
- What's going on with my B16 CRX??? Help!!
- o2 problem??
- Solutions for a water pump situation?
- 88-91 Clutch question
- have you heard of them?
- D16A6 Help Tip
- b20vtec: what would you do?
- troubleshooting A ZC motor
- puttin b16 in crx
- is a 93 civic DX intake mani and TB as good as a 89 SI one?
- FAQ: MPFI swap information
- I need a SI radiator.
- SOHC ZC???
- b16a1 Vs. b18c1
- Apexi VAFC wiring help
- B16 help
- MD/VA people Take a look
- reliability ona 12.5 to 1
- Hasport Hydro to Cable Conversion?
- Stuck in fifth...
- saturday night car wreck
- Just got Si tranny. Should I swap throwout bearing for new?
- fast turn signals????
- What Could This Be!!!!!!
- aftermarket ticket?
- ill trade my y1 lsd tranny for a ys1 lsd tranny.
- Need help wiring JDM fender side-markers..
- code 7- Throttle sensor...replace? high idle problem
- Sunroof question...
- odbo odb1????
- Need a little help with adjusting clutch cable!
- MPFI swap done but F'ed up... need answers
- ZC built for boost or all motor non vtec B20
- Some info about the jrsc?
- Installing safc question
- hcp mounts vs hasport mounts...
- Is this a dizzy problem?
- Is steering angle (castor) adjustable?
- Im the dumbest motherfucker on EARTH!!!!!
- Where to get EF8 Lights cheap?
- GSR rear disc brakes
- Come And Get It!! CRX Shell Must Go!!
- B16A dizzy
- Transmission question: Hydro or Cable
- wb: need the truth..dpfi to mpfi ..please read
- hatch hub conversion
- mpfi swap....won't start
- PR4 ECU with VAFC
- safety Rules
- how do remove a dist.
- what is a dizzy?
- jdm sir cluster wiring into 91 hatch
- std's with aftermarket wheels-running out of wheelstud?
- CRX stuff @ Staples!! : )
- Throttle stuck on my b16!! very weird
- mini me????
- b series mounts
- ..my d16/a6 and its fish problem
- Can you do a mini-me with a D15b1???????
- idle fluxuating
- What distributor cap for my jdm b16a.
- Please post pictures of CRX SI bumpers on Hatches!
- gasket romoval
- what injectors?
- 85 civic center consle?
- Rear Disc set up.
- Ground control Question?
- JDM IN NORCAL CRX
- crx front end conversion
- 1/4mile time?
- h22a swap into a crx si... need info and lots of read up information and just help
- opionion on KYB GR2, Eibach prokit, Energy Suspensions
- Place to buy JDM in MD, DC, NOVA
- what's a good street turbo for my ZC
- 90- 91 Crx TAIL lights
- new 90 Si tranny won't go into 3rd, 4th
- What's the problem with OBO ditributors
- how low can u go on tein ss?
- What tie rod ends do I use for lowered CRX??????
- NOVA, MD looking for garage to rent
- dohc zc pics
- Need wiring help asap
- wiring harness
- How to tell diff. between 88 and 89-91 CRX Si tranny?
- b16 idles hi with MAP, idles normal with out MAP....
- need help?
- Help vibration on clutch pedal
- GSR Rotors? need to change out the hub and spindle?
- Autometer Tach? Going crazy
- fuel pump install on a b16a1 swap in an ef
- Gas smell in hard cornering and braking....
- how much HP gain is a DPFI TO MPFI on 89 std hb
- 89 hb dx tranny fit on a dohc zc?
- <--cant post//thread locked? what does that mean?
- Bseries swap into a DX???????????????hubs
- sell the car or go turbo?
- Will 89 Integra seats fit in my 89 CRX DX??
- camber kit problems in crx
- turbo, or swap??
- greedy sp too small for b16?
- quick fuel pressure regulator question
- Dizzy Timing
- ZC to VTEC
- what is needed for a b16 turbo and where can i get it?
- Please Help!
- JDM D16a6 motor--does anyone import these?
- steering column help?
- where can i find a JDM SiR EF Airbox/Intake tube??
- Maintenance at 180k miles......... what to do?
- Swap problems!!!!
- AEM V2, no VTEC?
- CRX obd0 ecu
- BAY AREA, I need someone to help me!
- Zc swaped, Ecu is wigin out, high idle... What the hell.
- Selling G-G-Greddy Turbo Timer Black w/ Harness for Honda Civic
- Selling A Pair of Used 96-98 Honda Civic Clear Corner Headlights
- d16a6 headers on a d16z6 fit?
- HELP!!!
- What air box Tube to use with B16?
- crx with type r motor
- wiring help
- having doubts about my jdm b16a.....
- Mystery of dead battery
- Valve cover torque specs?
- Easily Removed?
- hey i am getting the tornado!
- Fiberglass fenders: WHY Z3?!
- good Rod and Piston combo
- no more nitrious?
- help me find a pic of a specific crx
- antenna plugs
- Exhausts: Magnaflow, Tanabe, Greddy or HKS?
- Need HELP!!!!!
- Stalling
- Tanabe GF210
- Wheel bearing??
- What exhaust do you have on your CRX?
