View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Something is wrong
- Best 2.5" mid-pipe
- Need Help!!!!
- which axle on what side?
- Stock 94 4dr Civ Springs on 90 HB Civ?
- new sunroof switch?
- Extra plugs after swap?
- 90 Civ HB SI Green price?
- zc sohc
- Car still won't start, I am out of ideas
- Cheapest stainless steal brake lines?
- Aftermarket Exhaust Review Thread (PICs Please)
- Radiator Question???
- black tail paint?
- d16 speedo cable work on b16??
- another EF broken into
- camber kit install trouble
- CR-X Si moonroof
- Stupid Question, Need some Quick Help
- Which flywheel from fidanza is for the b16a.
- Crx lowering
- Dumb stuff.
- Found a Dx Trans-Read.
- Please VOICE your opinions ---- B18A ---- B20B ----
- Help quick please- Adjusting rear drums
- crx sir buy?????
- my gauge cluster doesent light up?
- NEED help
- J1 trans ???
- engine swap advice~
- the wiring woes continue...
- Could it be? A new CRX???
- look at the devostation robbers done to my car for a 30 dollar head-unit....
- URGENT Seat question!!!
- quick z6 distributor question
- 180hp on the dyno what would that be in the quarter ruffly.
- Rear Hatch Noise
- Fuel pump wires????
- the best b series motor mount kit
- help installing suspension
- removing rear bumpers..help please, i did a search but didn't find any thing...
- sparco springs
- sohc vtec ecu on a d16a6??
- need b16 downpipe, off of what??
- zc axles
- PR4 Ecu
- Weird tachometer/reving problem
- jdm crx power window install
- b18a1 swap
- Can I put A Acura Integra Lsvtech block onto a b16A1
- ???????? Hydro tranny in EF CRX ??? how do ?
- full coilovers
- guy with JDM front end civic 4 door, silver..
- ... 86 crx engine swap
- T-shirts.
- ECU loca?
- CRX Si gearing...
- B20B into 91 CRX SI
- looking for jdm rear spoiler
- Need help, car died while driving!
- tach trouble
- 89 crx/ what stock mounts can i use for ls swap?
- Hesitation getting worse, confused?
- New Site For Us
- How to improve Turn In?
- Does this exhaust look right to you??????
- iacv or eacv? for y8 manifold swap on a6.
- water leak. Any help?
- What's the difference between a SWAY bar and a TIE bar?
- Anybody running a auto motor in a manual car?
- Insurance question
- need help...QUICK!!!
- Can one of my EF brothers please run a Carfax for me?
- trans fluid check?!?!?
- D16A6 D15B2?
- Wierd Electrical Problems.
- winding noice
- ***tanabe racing medallion***
- buying a 88 civic hb
- any nitrous people please click here.. need some help on an install...
- b16 clutch cable bracket
- DIY Links
- take a look of this set up
- What happens when tranny "freezes"
- WTB: 89-91 civic HB Si floor mats
- I am suuuuch a dumb a$$
- anyone have tenzo springs??
- I messed up :-(
- 4 gen ECU and VAFC or 5gen ECU on Z6?
- someting wrong with my tranny
- Need help identifying engine
- b16 wont run right
- Loose seatbelts!
- Brand New tranny price? Expensive?
- JDM Ventshades...or USDM
- rear lower control arm problems
- Car won't start
- i need info and pics of crx rear seats!!!!! JDM or not!!
- Wiring harness questions, 89 crx dx
- I need a little help
- Front Brake Upgrades for 1988-1991 Civic/CR-X - Not Just Integra Stuff?
- B18C hatch w/drag turbo kit
- difference between DX and Si tranny?
- wiring a 90-91 gauge cluster in 88-89 civic?
- ?tire
- how to put coil overs on an 88 civic?
- Converted to OBD1; erratic starter "click" problem
- Where to buy Z10 Radius Arm Traction System other than Z10 Motorsports?
- prices for 90-91 front bumper and front lip insane$$$$$$$
- will 88 suspension fit on 89-91? vise versa
- Will 92-95 springs fit a crx/civic 88-91?
- Upgrading the Radiator, use what?
- how do you know if you have a bad oil pump?
- Civic Hatch DX
- anyone have a final drive case??
- Passed smog by 2 parts per million..
- B16a1 Fast Idle
- D16y8 motor swap
- What starter will fit the b16 ?
- Transmission problems after D16Y8 swap into CRX
- Anyone recommend Caliper to use on ef8 SiR?
- DSM turbo manifold
- is this a good deal?
- ot: let's all wish zcivic a good wedding day
- VSS...again i need moer help! whitch one?
- Q about B&M FPR gauge?
- Need some help
- axle set rings
- CA jmd motor guys....i had a talk with the ref. *LOOK*
- Quick ECU question....
- HELP HELP HELP Beater has no heat!!!
- Desparately seeking bush.....
- options auto salon, need opion on their website info....
- 225/50r15???
- Las Vegas Crx meet???
- ZC and the Search function
- Looking for S1 tranny
- **New Pics Of Civic Coupes** All Welcome Comments 94+
- dunno if this is tech or alright for here. tranny question and a torque question.
- anyone in the MD/WV/VA area?
- BOMZ Racing Header???
- idle problem
- what engine swap is a straight bolt in for the crx? no b-series only d.
- What rate injectors are ideal???
- Zc with factory lsd.
- CRX Si, del sol, and civic radiators the same?
- starting problem....please help
- LCA sizing in relation to handling?
- tps
- cc DSM Injectors on an 89 Si
- Super Dumb Question
- Post Pic of you RIDE!
- EX Tranny Specs?
- B-series CRX, possible to change water pump without pulling motor?
- Quick question..... hoping for quick and accurate answer (DA dash into EF DX hatch)
- ITR or Skunk2 IM
- EF8 front end
- i hate to ask, but i really really really really need a carfax
- F22 in crx
- Weight of sohc motor? anyone know how much a d16 weighs? members corner didnt help
- Tranny need to be flushed?
- Whats up with the starbucks gathering in pasadena!!
- Car running like shit, need help...
- climate control
- Need your opinions on exhaust
- does anyone have a pic of where they mount there harnesses in a CRX?
- Did search but could not find the thread on the SOHC Vtec Turbo Making 265HP and 245 TQ in Florida
- Could I use a auto y8 IM if I use it's IACV instead of my a6's?
- How much heavier is a B18C5 compared to stock CRX Si engine?
- ITR suspension, what's needed to make it work?
- Which Cheap Ebay Muffler sounds good and deep
- ZC axle question
- true power of a ZC.... 417 hp! on a 4G....
- odometer..
- Any one in San Diego...
- eibach road race???
- hmotorsonline.com vs import auto salvage vs osaka
- Which MAP sensor in EF with B16?
- prelude injectors in a Sir1...
- EF9 Cluster lights...
- how much interest in EF SQUAD shirts or something similar
- 1987 CRX swap
- CRX TypeR - which tranny to use?
- USDM vs European Domestic Market
- My car almost stalled.....
- Rev limit @ 4000 RPM............
- Damn hood!
- look what i got
- Zdyne?? Who is using it? What size injectors?
- my new TEIN springs!!!!!
- sir half cut question
- I give up, suspension woes - Please give your advice (long)
- axels
- Hid Kits 5000K and 6000K
- Any fellow EF's going to the Jan 25 so cal meet?
- Integra Front Brakes!!!
- o2 Sensor?
- Factory Honda Radio Plate????
- Carfax report needed... PLEASE
- CRX not starting
- pillar bar in EF, i hope i'm the first to do this....
- Wiring Genieses!!! help needed
- which motor mount kit to use? b18c + hydro tranny into an EF.....
- is it worth it i need somebody elses opinion
- are obx coilovers good?
- Honk Honk.....CRASH!!!
- HKS universal muffler...
- LOTS of EF problems :(
- need opinions/advice/possibly prices
- 90 crx w/b18a.....when temperature drops below 30 degrees; car won't stay on....any suggestions
- ice on inside of windshield....wtf?
- tensioner replacement
- what year b18?
- Wiring Harness question
- valve cover torque?
- injector resistance on a 91 dx
- d16y7 swap into 89 crx si?
- hell yes! no more electrical woes!!!!!!!!
- dx to si wiring diagram
- tein s tech springs
- lowering question
- d16y8 IM on an a6???
- DSM Turbo Injectors on ZC motor...
- I need a ZC, wheres the best place to get one
- 4th gen b16 swap
- My personal crx web page.
- ride height on 15's
- my 1.9 60 foot time.
- filter idea
- cable trans gear interchangability
- 1988-1991 b16a jdm engine vtec
- si and hf fuel injectors
- Apexi AVC-R help!
- Which alternator fits the b16 ?
- about the EF title?
- Will a AEM short ram fit a 1st gen CRX w/ a B16A?
- What needs to be done on DX harness to convert to 4 point injection
- anyone have their interior fully stirped ??
- Wheres all the EF's at?
- Code 17 (17flashes) Vehicle speed sensor
- 4 speed standard model final drive, what is it, and will it fit into a dx 5 speed?
- give me some comments bout my vtec controller setting
- 1991 dx 4 speed to 1992 cx 5 speed tranni swap?
- 1991 dx 4 speed to 1992 cx 5 speed swap?
- identifying this FMIC
- is the knuckle/ hub assembly the same on an si and a dx both 91s?
- quick coolant Q?
- so, how did you
- I'm looking for weight specs.........
