View Full Version : Honda CRX / EF Civic (1988 - 1991)
- cluster problem
- engine Stuck, Jamed
- NEED HELP, b16a swap with YS1 transmission
- engine wiring diagram for a 1989 honda civic dx hatch
- Block Guard to repair minor Head gasket leak??
- obd0 1 wire o2-4 wire o2 obd1
- 88-89 bumper with jdm foglights
- How to ? <v-tec head>
- tranny bracket screws?
- *UPDATES OF MY 1991 CR-X GSR PROJECT*
- S1 B16a Tranny question (searched some)
- upcoming project..
- balljoints
- the "shocks" that hold up the rear hatch on crx's and hatches...whats it called?
- cant find part # for exterior molding(searched)
- LS non-vtec build
- Is This Honda Dealer Not Telling the Truth?
- Wayyyy, too many threads and debates on DPFI to MPFI, need some harness help.
- d16a6 -- Supercharged or Turbo?
- weight questions?
- clutch disc question
- mild build n/a
- hey guys some safety help plz.
- Dead
- DA integra front brake issues after install. Please lend a hand...
- Short IN wiring harness? Help!!!
- taking off break hub?
- drivers door lock
- How to ? (v-tec head)
- Jhpusa.cm bushings question...
- quick ? about bumpers
- Warped Rotors?
- painted my rims on my ef, lemme know what you think.
- any good honda head in MD??
- where to get turboedit ecu's for a ef turbo setup?
- Pressure Plate Loose? What happens if it becomes really loose?
- release and pilot bearings
- fuel pump removal?
- dumb question: what else do i need to convert to a 90-91 front
- Who runs splashguards
- brakes
- another CRX project!
- a6 probs
- S-AFC help
- Boosting my d15
- clutch question
- Motor and tran swap questions I have a 91 CRX DX
- list of parts and what they weigh for crx?
- Tuning problem :s
- CRX si with B18A swap problem
- 00 gsr seat in 91 civic
- Cup holder prototype..
- Ignition Removal Question
- b16a w/type r cams/no vtec
- B16 swap what else do I need
- Would a 89 crx si odo will plug and play with 90-93 harness
- Password bar or Neuspeed? ...Recommendations?
- ugly grind noise then shut off
- Main relay replace in 91 SI
- megan racing, whatcha think?
- emssions sticker under hood
- CRX Power Steering QUESTION!!!!! please help
- help
- turbo d16a6
- My new gauge cluster.. which model is it from?
- need help with swap
- si transmission into dx
- i heard of people doing a wire tuck if so please post pics
- head ports
- to swap or not to swap?...that is the question
- i would like to know how to post pics (help)
- camber/toe for sports use
- My beater build up thread
- serious problem with my frekin corner lights.. plz HELP!!!!!!!
- question about distributor and ecu
- will a 94-01 integra shifter fit 91 crx
- 1990 Si Hatchback lips
- 89 si with b17?
- My new Project K20a type r crx (stage 2)
- what sohc head is this
- Whats a better steering wheel size big or small?
- JimFab bar with no radius rods! What are my options??
- spoon strut bars + skunk2 rear lower tie bar !!!
- making 92-00 struts fit a 88 CRX
- what rad hoses????
- timing?
- Help needed on civic si
- looking for opinions on ksport suspension
- Did Some Work Today
- my 1000.00 std
- 8000k hid install
- Y-49 Restoration, Project CLEAN.
- my car was stolen today in the daylight how fucked is that
- 2.0L Accord engine in 91 Civic Wagon?
- need to safety..wut should i buy?
- Tranny problem
- Jdm glasstop, ebay?
- How to make Hydro tranny work in CRX?
- Magnaflow Oval Muffler Setup, Offset or Centered???
- Fixed the speedo... still bogging, possibly detonating
- Anyone ever open up the main relay and fix it?
- Is it legal??
- fuel pump
- alternator help
- speed sensor
- ONE NICE CRX IS IT ANYONE ON HERE
- track times?
- I NEED advise on choosing a swap!
- mud flaps off a 91 hatch fit my CRX?
- throwing codes for crank angle sensor, electroniair control valve codes please help
- WOW! New problem! LOUD ASS SQUEAL!?!?!
- gsr swap and a/c
- CRX fuel filter
- Auto --> Manual Conversion: Clutch Switch Help
- Fuel Delivery Problem?
- which aem cold air intake?
- 96 ITR 4x114.3 disc swap on EF chasis?
- Weight Reduction yet again
- very simple question....
- which parts do i buy for my b16?
- i know i know difficult and old question but can you lsd tranny a crx?
- Sunroof question!!
- Leaking/Burning coolant from under dizzy (searched)
- CRX 88 w/ B16A for $3000
- TYC spoon style mirrors for the CRX; Anyone have them?
- Obd1 code 9 problem need help troubleshooting
- crx roof mount rack
- my engine
- Takata Harness with recaro SRD's
- GSR swap no start
- Do all crx door panels say crx on them?
- ZC DOHC TURBO PARTS !!!
- It's Done: The BALLS Challenge GSR Powered CRX... 217whp/144ft-lbs
- SiR Bumper w/ Wings West Bodykit?
- no start problem
- Hf to Si intake manifold?
- ws2 exhaust issue
- I have big overheating problems with my 1988 Wagovan
- Idle/RPM Problem PLEASE HELP!
- EF Sedan Window's compatible with Hatch Windows???
- Mini-Me hesitates
- Two Probs, One Thread...
- engine type
- Hey i need and answer
- Random Mis-Fire...or is it?
- Hood clearance problem
- Looking for si hybrid crx tranny? you got? i got $$$$ :)
- Ok PROBLEM!!! SOHC d16z6 fresh build with turbo???? Knocking???
- My holset powered ls/vtec hatch(56k warned)
- 90 Sedan Daily Build
- bodykit ?'s
- authentic mugen mid wing.. how much would you pay?
- Brake Pedal to the floor PICS
- Foam in Radiator and cooling system bad headgasket?
- Prelude rim Question
- B16a
- P08 ecu help.
- b16a 'jdm' wiring harness --> jdm/swap experts help!!!
- headliner removal?
- stock engine
- code 9 question
- re thread
- need some wireing help while my motor is out, pics
- ls vtec swap, no start
- how will removing rear seats affect balance and handling?
- Walbro Fuel Pump 'Whine' - Normal?
- Are 1.6-1.7 60' times feasable w/o wheelie bars and full drag setup?
- Engine Stutters / Wants To Die - When Re-Starting After Hard Drive. Why
- cant get code for obd0 to obd1 conversion. please help!!!
- Need a good write up on D16y8 motor into Crx. Anyone?
- amber bumper lights?
- cross member
- JDM Honda CR-X EF8 Bass Tubes
- SOHC Turbo kit advice(think I have everything)
- Searched: Window tab alignment 90 CRX
- head bolts stuck!!! How to remove?
- quick question about clutch cable removal
- know how to remove headlights??????
- convert dpfi to mpfi then odb0 to obd1
- Failed Horribly :(
- i need a parts list
- White smoke, help fresh swap
- I locked my keys in my car! help please
- Doing my timing belt, replace tensor?
- engine change, please help!!!
- wiring help
- Review: Fox-Stock.com - Kteller Products A+
- smokey as hell please someone help!!!!
- need help with some frontbumper for me EE8vtec..
- Rain gutter(s) question!
- obd0 dizzy in obd1?
- ls vtec swap in an ef hatch si no fuel or spark obd1 converted please help
- need help!!
- Ridiculous question about converting to OBD1 *I should be shot*
- HAHAHA !!!! $38,500 CRX !!!! w/ 900 HP .... YOU HAVE THE CHECK THIS SHIT OUT
- Little help with ecu code.. help!
- 90 CRX OBD0-OBD1 conversion on mini-me wont start!
- Car wouldn't turn over w/key only when push start...
- RIP Rex
- swapping crankshaft in b series
- this would be great in the CRX
- Finally, my new (to me) CRX! What do you guys think? LOTS OF PICS 56K BEWARE
- I Need Help, Removing Dashbard in a 96 civic ex
- tachometer help
- MY CRX MADE IT ONTO DIAL D! Street Battle, Shreveport
- rhd ef
- STOLEN Civic in NorCal (Bay Area) Please keep an eye out!
- heating up problem, I am on mah sidekik hlp plzzz
- Help with sway bar
- will the delsol b16 ac bracket work for 88-91 a/c comp
- suspension swap
- vacuum line help
- Some Nitrous Questions for my CRX.
- Checking CEL Code?
- ls swap question
- NEED HELP WIT HEAD
- 88-91 CRX Factory enhancement kit
- b16 hatch
- post your suspension setup.
- Igniter?
- little rock shops?
- TPS Sensor???????
- Engine Serial # aka has my engine been replaced?
- NEED HELP REMOVING STOCK SPRINGS
- Steering wheel shaking when accelerating?
- Tachmeter
- Maryland Inspection
- I got my EF sedan!
- import shop in little rock?
- suspension question
- Zc
- Sidemount IC question
- b16 running rich and getting 6mpg?????
- curious... can a wagon awd drivetrain be put in a hatch?
- d15b??????
- TO ALL Tahitian Green Pearl Clearcoat.........BG-28P COLOR CRX OWNERS
- How to tell if speedo cable is broken?
- 91 SI eating igniters?????
- ---Write Up: Rear Wiper Delete for Less Than $10---
- 93 civic radiator in 91(help plz)
- ugliest crx ever?
- 1990 Hatch w/ b16A si-R motor.
- B16 Hesitation Please Help
- rear b-swap bracket?
- 89 crx dx, fuel filter replacement?
- Auto PR3 to manual to run a mini-me?
- Side Skirt
- budget boosting my 88si. need ideas
- *SEARCHED* DA to EF Disc Swap Problem...
- turbo.
