View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Intro / projects of mine
- Broken Balljoints
- D series Transmission leak
- Axle dynamic damper necessary?
- DA exhaust
- crx bogs and acts like rev limiter at 3k rpm
- Manual transmission fluid question
- 89 dx hatch swap question
- removing the wiring harness
- should do a engine swap or rebuild?
- stiffest suspension for drag racing for the buck???
- b20 wiring harness
- If this car is an Si... what the hell...
- crx axles
- 89 CRX obd0 to obd1 swap help
- 1990 Civic Si Brakes/Suspension HELP
- 91 hatch side glass removal?
- oil catch can
- SOHC ZC swap questions
- new crx just bought last night
- My 1st Honda, 1991 Civic Si
- 4door ef dash
- quick o2 sensor question
- will not stay on...sometimes though.
- 180 psi ok compression for gsr head??
- Brake Proportioning Valve Question
- no power steering+camber
- any special trick to pulling the wire harness?
- RUNNING HOTT ISSUE!?!?!
- 96-00 civic lowering spring fit 88-91 civic?
- 88 hf SHELL
- Crx dash installed..now horn,cd player/radio dont work?
- B18 Swap Help
- crayola marker+cluster needle=jdm look! DIY
- wheel rub problem
- Car is shutting off when i stop?
- Crx b16 ..strange smell
- 90 si crx ls battery light goes off at high rpms
- gsr or gsr type-r swap? id like some advice
- any transmission DIY's?
- benefit to larger bore?
- rear brake issue...
- A little vtec dilemma! I think Video inside.
- DOHC ZC code 1
- Changed tranny.... now laggy?
- Code 8, And Maxed Adjustment Dizzy Problem
- hf to ls
- Trim Delete
- How to do cluster wiring from 88 HF cluster to 91 SI
- what intake manifold to use on my d16a6?
- Fuel Pump/Kill Switch Issues
- B16-CRX update ( '09 Si Seats, Solarwing, Sprint Springs...)
- Daily driver build
- EFsedan seat swap options
- Fuel Pump help...
- need more help mpfi swap ahhh lol
- stiff shifter
- my first build thread its lame i know.
- Need help figuring out what I should do , to bore or not to bore?
- Feels like tapping on my foot ( on the gas paddle) ??
- Lowered finally
- any new hampshire tech,s here
- sohc boosted or dohc vtec need some advice
- Will a d16a6 distributor fit on a d15b1?
- Need some help... new to the scene
- ZC headlights
- d15/d16 block fitment please help!!
- air conditioning problem!!
- headlights turn off??!!
- d15b complete rebuild suggestions
- head has dirty valves!
- ef brakes and suspension questions please look
- i need help with my ef everyone look i need help!!
- ecu for my si w/d16z6
- Need a DIY for jetta lip
- crack in tranny
- how can i run si exhaust on my std
- K20A EF Swap Questions..
- pistion to valve interferance question
- 99 integra LS cluster into my 90 civic dx help
- temp gauge inop searched)
- IAT sensor
- New introducing myself
- BALANCING WHEELS without the weights showing on the outside
- Fuel gauge VERY inaccurate?
- B20 EF Front end conversion questions???
- h22 ef swap
- Why is my car hesitating?
- 91STD ac system problem
- sharing my ED6
- CR-Z
- 1990 ef hatch auto to manual conversion
- 91 hatch sitting for 1 year
- Best exhaust for a 89 SI?
- ecu questions for 91 si demo derby car
- (ECU) Red blinking light..
- loud click noise when braking
- Can you repair striped out motor mount threads?
- EF members in VA
- 90 si gsr turbo wont start HELPPPPPPP
- doing a dpfi to a mpfi need a little clearifying
- when i turn the key on nothing happens???????
- what do you guys think of the dizzy jumper for obd0
- 88-89 CRX Fog Light Pictures
- y8 clickng noise.
- my car wont start
- 89 Civic Si front rotor
- a/c question
- broken trunk latch
- NEED DIY FOR FRONT COILOVER INSTALL
- Another car wont star thread
- Rebuilt Alternator?
- 1990 EF HATCH
- Interesting Electrical Issue
- 92 da center console in EF?
- crx pics
- Boot Latch warning light
- who are all the maker for the 3 point strut bars?
- gsr parts
- Electric Speedo Conversion help...
- help in the middle of swap and need info
- 89 CRX DX
- lower ball joint replacement question
- sidemarkers install?
- 90 ef with b18 problem
- tapping a bolt/battery moved to rear
- opinions/personal experience with suspension
- need help with this tranny!!!!
- b16 header question
- 90 hatch running rough after ls swap
- what to do to hatch??
- D16y8 header on D16a6
- Help, Stranded Civic Won't Start
- Need Help With MY EF
- how do i open my fuel sending unit?
- Any Kansas City EF Members?
- car over heating!!!
- Tranny specs list
- which obd1 ecu?
- motor wiring issue
- d15b2 rebuild
- A/C installation?
- CRX bumper on 91 ef hatch?
- doin a dpfi to mpfi swap
- engines
- welllll......
- password jdm intake question
- Screaching Noise, Maybe Speedo Cable?
- inital d
- Wiring Harness for a b18b swap
- Hub won't spin
- New to the "ef" section here my hatch
- crx headlight
- Adjusting lifters on B16
- crx cable to hydro hasport kit
- Are any strut bars that will fit on a crx with a d16y8 manifold?
- My 91 4 Door LX
- what stock catalytic converters work with stock si piping?
- Transmission. Cable.
- looking for a tranny..!!!
- battery-starter/fuse wire guage question
- When vtec hits there's a loud click
- Ebay replacement quaters
- ek sideskirts on ef
- Bull Bar
- Ignition cuts out at high temp
- '91 Civic won't key or roll start - pls help!
- the meaning of words...... b16a honda
- ignition problem?
- d16z6 and d16y7 pistons?
- Need help installing aftermarket seats.
- '88 Civic - Engine rattle upon loaded acceleration
- Saving this EF Sedan
- foglights
- CRX Seat covers Ebay
- Crx Glass sunroof (pics)
- crx carbon wiper cowl..
- Should I Install 89 prelude fogs on my 88 crx?
- My new honda civic EF
- Car overheats! help
- speed senson..need help???
- Wagovan Trans?
- 89dx with 90si wiring
- obd0 to obd1
- CRX wiring problem!!!
- Keep blowing the alternator solenoid valve fuse??
- My GSR swap IS SLOWER THEN BEFORE?? Car sputters at start after letting sit
- Rear Speakers
- Problem with Fuel. its not turning on?
- B18a Hard start when engine cold... help?
- Help With Camber Kits
- body parts?
- my new 1988 ef hatch, HELP
- Need help!! 1990 crx
- Code 8, No Start
- A/c questions
- 4 door moulding removal (SEARCHED)
- LET'S SEE HOW MY CRX BUILD GOES....
- 1990 ef help
- si seats
- How many miles do you have?
- B18 swap
- prevent long term damage by engine modifications?
- Momo Steering Wheel Installation Help
- Can 90-91 crx amber corner lights be retrofitted to a 88-89 crx?
- AWD EF
- A/C Drier location?
- Crx spindle help
- wheel rebalance?
- Skunk2 D series Intake Manifold help - pics etc labeled..need help
- crx si motor options
- Tech Question: Alternator Voltage Regulator...
- help me
- saving and then selling this 89 si crx ::build.:thread
- snowboard roof rack for my rex
- CRX bushing
- my civic si
- 4 speeds vs 5
- Ignition switch melting wires
- slight issue when changing upper arms
- ► ► for sale / would like to buy 88-91 crx/civic parts only ► ►
- help...idleling when cold!!!!
- 90/91 CRX side moldings on 89 CRX
- Bumper lights needed and also wiring clip?
- B16 Swap burning to much gas?
- 91 crx si (zc)
- Doors squeaking/grinding??
- HELP! MINI-ME OBD0 OBD1 questions!
- Radio/Climate control does not work 89 Sedan
- 92-95 ex seats in 90 dx question
- Key switch go boom
- battery relocation question
- seats
- Roll cage question!
- stripped headlight bolt help
- 1991 Civic Si stolen and found
- D16y8 vs D16z6 swap questions
- crx timing issue?
- O2 sensor question
- noisietraction bar!!
- Mini-Me swap in 88 crx dx
- altenator power question?
- B18C5 Crank Pulley Clearance
- A/C in my dx hatch
- 91 DX cluster needs to go
- Putting D15B7 in a '89 CRX Si questions.
- oh crap. blue smoke!
- D15 no start
- tire size question
- NEED HELP FAST Wheel base
