View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Help with price and info on an 89' civic dx
- ****GRILL area space of WW front bumper?
- Anyone in the Richmond area ever put on a camber kit?
- Whats wrong with my motor..
- hasport or any company mount kit
- 91 civic dx hb auto
- whats the cheapest ugrade i can do on a stock zc
- my signals don't blink!
- Car just died? WHAT THE FU*&!!
- I am new so I figured I would intorduce myself to the board :-)
- need 89-91 si tranny...
- help b16
- Dumb question: where is the ignitor on a CRX?
- Dizzy Probs
- JDM glass moon roof
- After Market Tach Installation (any help a be good) and another quesiton
- 3" Thermal cat-back on NA CRX *vid*
- Hf distributor on SI motor?
- Clutch cable engagement/adjustment questions..........
- BUYING D16Z6
- cable tranny rebuild kits ?
- Help this fool with his side mirrors
- F.S crx HF'88 "clean"no piCs
- tires on 91 Si hatch?
- Hatch got backed into today =(
- Watch out for ebay (read)
- Swap help
- civic or integra seats
- Rechipping pr3 ecu
- 89 Si B16 swap
- How do I search...
- Which motor for my new project???
- Any info on Crx Euro bumper with Dual exhaust cut out?
- front and rear disc conversion
- CRX/Civic underdash compatibility
- roll bars for your ef's
- autopower rollbars
- Help me settle a bet...
- b16 vacuum lines
- One Plug left, where does it go?
- Pic Request please: D16Y8 and Z6 intake manifolds and fuel rails THANKS!
- VIN troubles
- Need help with choice - a ls/vtec civic or a b16 crx
- what bearings (did search)
- f_cking vandals =0
- fuel problem any idea
- Oil pan removal...
- Looking to buy 89 hatch need advice
- TRANNY PROBLEM!!!!! PLEASE HELP ASAP
- 1 peice jdm civic sedan headlights fit crx?
- What can I realistically expect?
- How Do you Tell an Si Tranny From a DX/STD Tranny?
- Civic Si Bodykit question?
- I want to put a 94 LS in my 4 door EF civic. NEED HELP!!!!
- right hand drive question
- D16A6 gives up the ghost (finally)
- HID on EF?
- 91 Civic hb dx Gauge Cluster?
- What distributor to use?
- cel codes 14 and 20 at the same time
- just throwing this out...
- front bumper question, (real bumper, not cover)
- overheating - what could it be?
- What color more rare?
- Tach wire on 89 CRX Si...?
- D15A2 (Carbed) questions; small crack in head from overheating..
- Anybody using lowering springs from a dc2?
- Anyone in the sd area got a 1990 si stock manifold
- Go pick up an EF/CRX for under a $1000 what should I do
- Why did i get owned
- tps question.
- IM NEW And i wanna welcome parade :)
- p29 pistons and boost
- Buddy Club Race SpecII or RSR* GT II Exhaust?
- put my si cluster in.... now it goes all wack after 5100rpms
- HELP it just starting running really bad all of sudden!
- check engine light...no codes...wtf???
- Valve guide seals
- OBD0 - OBD1 conversion Mini-me Z6 on 88 CRX Si - - help!
- what did I do...?
- best header for a b16?
- 91 Civic HB, installing an H22 will AC fit
- Brake Compatibility DX and Si caliper
- couple of questions
- CRX in the new Tony Hawks Underground (video)
- for those who watch
- Will the Dist. fit???
- How many hours for first time e-swap?
- 88 civic mount question
- Vtec solenoid leak?
- d15b dizzy on z6??
- D16A6 intake manifold vs. D16Z6 IM
- b16..!!
- Low-Cost Lotus killer
- swap shift linkage help
- engine swap for CRX 90
- How good is the zc? (d16a9) please reply!
- GSR turbo ideas
- CRX with power locks?
- What is this sensor?
- Are all TPS the same?
- Do 2 door DA integra seats fit in my EF civic hatch?
- differences in wiring between 88-89 and 90-91 Si's.....
- Which Throttle Body
- easy way to remove tranny and motor?
- possible clogged cat?
- Pg7 ecu ? and interior CRX/Civic ?
- how much am i looking at to swap my crx 88 hf?
- USDM teg tranny and ZC tranny????
- How many ZC guys having serious traction issues?
- I don't understand some things about OBD
- JDM Civic question.....
- J's Racing intake fit EF
- Might buy D16Z6, need suggestions
- 2002 SI Calipers on 91 EX Spindles
- Loose Steering
- whats easier for a mpfi swap?
- 88 and 89-91 Front shocks Different or the same?
- Question on shipping a car?????
- Anyone know what the flow of the dpfi injectors are?
- Code number, how do I tell?
- CRX Cluster
- old skool dc sports header ?
- crx STRUTS???
- best Plug Wires for a 1st gen JDM B16A...?
- 92-95 civic si rear disk setup?
- tell me if you think this is a good price
- 89 si civic & 90 ls integra ecu diagrams
- ys1 tranny? lsd or not?
- crx si 88-89 brake pads different from 90-91 brake pads
- enigine cutting out???
- Pic request for Autopower roll bar installed with interior in a CRX
- y8 swap need coolant help
- torque specs (searched)
- SiR rad. support for SiR hood?Shortcuts?
- help! check engine!
- 91 Right Hand Drive CRX
- Turbo kit for new EP3 Civic Si
- CRX crossmembers
- How do you Recharge A/C on CRX? please help!!
- couple questions about dpfi to mpfi
- need these parts for my crx, cant post in classifieds yet.
- is their anyway i can fix my A/C beside buying a new ac system? is for me crx
- Shift Light hook-up...standard ignition...? where!
- toda products
- Brembo rotors not available for EF Civic SI's?????
- 88+ crx (si, hf, dx...) only si FI, others carbed?
- question about sunroof repair...
- pre OBD b16 head with OB2 gsr block?????
- somthins wrong with my brakes!!
- help: irregular/dead idle
- you know anything about a stock ignition coil on a CRX?
- What kind of hood is this?
- help! part out, sell whole, or fix?????
- ecu diagram
- Which Engine Management for a Boosted B16
- Older magazine scans, Turbo 4D EF
- Need ? on Linkage
- My car keeps overheating, and I don't know why.
- Compression testing a b16
- Hessitating Acceleration???
- new hatch owner
- HARD clutch pedal after swap
- Looking for OBDO Injectors
- tranny identification
- 88' STD hatch, 88' Si gauge cluster
- driving any other car then an EF feels wierd!
- Cheap Ass Ebay Short-Rams
- Which camber kit?
- CV boot maintenance?
- Engine light comes on in reverse?
- Replacing Wheel Bearings?????
- really hard to start really rough idle
- Quick Question on Skunk2 coils
- ef owners
- 92-92 mud flaps on a EF?
- Dyno time?? Expensive? Where?
- A/F w/fuel computer. should i run lean?`
- cat ?
- JDM headlights
- cable vs hydro tranny
- an Estimate for my CrX~~
- Ferrari Gated Shifter?
- fs ww kit
- Will EP3 calipers fit on EF/DA knuckles?
- water pump question
- Honda Aftermarket Parts Websites???
- sorry wrong forum but i cant post in General cuz im only a trial
- b16 into 90STD
- 88-91 civic si hatch
- Anyone defrauded by Ted Holt AKA dohc_notec (in LA) on Ebay please contact me.
- Do all '88 trannys have no markings???
- ayone have tips or pics of a DIY crx wheel well rust fix? Maybe just some tips
- Starting a motor that has been sitting for a year...
- 89 CRX Si Sunroof Leaking...!!!!!
- 90-93 accord intermediate shaft
- non resistor injectors wired to a resistor box
- circuit breaker on Battery relocation *!help asap!*
- Newbie to Honda Tech
- Yellow Crx Si OEM Hood. Atlanta Area and Beyond. GC
- cam seal replacement b16a1
- What will this setup run. Please help.
- Variable Speed Sensor for EF9
- d16a6 cam
- *hurry!* 92 shift boot on a crx...
- code 20 Electrical load detector
- dX dUAL point to SOHC VTEC crx? Can I use a 92-95 si hatch harness? what harnes?
- I Think Im Comming Back
- best suspension for 90 hatch SI
- camber kit issues
- Idle problem- swapped obd1 d15 in a crx
- ECU question
- y1?
- Radius bars with integra suspension
- HELP!!!!! car won't start..
- b16 o2 sensor, (look inside)
- where to get a b16 complete swap kit
- Information on TPS
- Need a solution for B16 w/ A/C AND Fluidyne Radiator!
- jumpin plug wires :)
- b16a1 with type r manifold throwing cel 3?
- Climate Control Installation?
- 1995 civic seats in 1988 civic?
- what header for b16 (i searched)
- Mini Me Write Up
- Will a 91 CRX si dash, fit correctly in an 88 CRX si?
- what ACT clutch for Y1 cable gearbox ??
- D16Z6 with D16y8 manifold?
- Turn signal stays on..help
- Built LS or B18c5
- 88-89 D16A1.. P29/PM7 pistons WTF
- can any one give me an idea of how quick my car is?
- Engine options for my EF
- alternator terminal glowing
- Tire question...should I try and squeeze these on?
- 90-91 crx si interior into a 90 hf?
- d15b problem on my 89 hatch
- Stock tailights -4-SALE-((Mke an offer))!!Crx-Si 1989!!!
- Va Beach Swap
- 90-91 si
- Which Tails?
- Just pulled my zc..............????
- Best mounts? Mine vibrate way too much!
- Some things I learned from the B18A swap I just did in my CRX
- What to use to flush motor oil after blown headgasket?
- anyone mix-n-match harnesses?
- swap questions, B-series + brakes
- 4wd wagon axles the same as ZC axles?
- whos Red ef hatch, Ericks racing sticker on the side???
- This look legit for a swap?
