View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Canadian EX equivalent for big brake swap?
- zc piston qustion
- Minor Mods
- What are the fastest street d-series times
- Need Help!! Bolt broke off inside engine block..
- DESPERATE help needed in passing emissions
- Gsr tranny
- To trade or not to trade?
- Not the starter!!???
- look what i got :)
- Integra console in Crx
- rear cross member cracked?
- z10 traction/crossmember
- wheels
- could someone help??
- type r suspension on cr-x
- ZC in 4wd Civic wagon???
- vision corners?
- hey wasssup new here!!!!
- Just Joined this Forum
- OK wtf happend to my car...
- Anyone have Rota Slipstreams or Circuit 8s on your crx?
- Who makes a cat back exhaust for an ED9?
- Brake boosters for the ef/ed???
- swap pics
- PWO???????
- Swapping motors price
- Attn: Vinceg99
- gude head?
- Quiet Exhaust for 88 CRX ?
- LCA's are they all the same???
- OBD0 - OBD1 - Do i need OBD1 distributor?
- Is there a way to center the steering wheel?
- San Diego Stadium Races.
- ITR head and cams.....HELP!
- Hasport or place racing?
- Doesn't say vtec on my d16z6 valve cover
- looking to raise compression in my b16
- will a type r guage cluster fit?
- 1989 civic
- 4gen wheels - help
- anyone here know where or who to get JDM sidemarkers from (EF8)
- CRX b16 sir 1 wiring...
- what motor mounts??
- just bought a hybrid
- my car is in 500 pices !
- Should i keep this or sell/trade for a Honda CRX
- jdm SiR cluster
- stock b16a pwo ecu for sale
- Building a ZC????
- read all IDLE PROBLEMS in search still nothing like this...
- O2 Sensor Wiring Flipping
- 90-93 LS ecu on a d16??
- Wanted - Your old OBD 0 Ecu plugs.....
- 91 HF Brake Conversion
- code 6
- 92-93 GSR brake comparison
- humor me........
- My CRX is for you!
- Instrument Cluster Question???
- Would you trade? look
- 1 piece crx headlights
- Rio red spray paint?
- Car jumps then dies...
- check it
- Code 9
- oxyacetylene welder preferences
- updates on my 500$ beater- cheap mods
- need crush washers for fuel rail
- pleasepleaseplease help ls wiring
- throttle angle sensor
- finally hooked up vtec!!!!
- crx spoiler
- Cheap insurance search...
- just a little info for ya
- quick help about si motor
- GSR breaks
- spring help.
- !!!!can someone with CARFAX plz help!!!!!
- I think my engine is messed up
- Sparco seat rails for si
- My night at the track
- alternator, battery, or battery cable problem??
- parts list for ZC, trying to get it all together... little help
- where to get these for b16 Sir 1?
- Need Help!!!!
- Starter?? ARGGGG!
- Exhaust manifold pictures - How many pieces?
- looking for 1.0 to 1.5 drop springs for 91 std
- any of you stock CRX's pull on LS's
- any way to identify year of tranny?
- what i need to do with a itr short block?
- H&R sport springs on a 89 Hatch.
- SPC control arms
- ok just wondering but need help!!
- Hybrid 4 doors??
- ??B16 swap /will a monster style carbon fiber hood fit without hitting the motor?
- O2 sensors...
- ZC Drivability Problem!
- Axles for ZC swap
- can a zc motor handle a 50 shot of nitrous?
- JB Weld as body filler?
- Need Tranny For Ls Motor Swap
- quick...... will a clutch from a 98 dx work on my 90civic si?
- diff. b/t CRX and Civic bumpers?
- z6 piston
- fuel problem?
- Exact speaker size for rear in CRX with opt. kit?
- itr rear tranny bracket for b16 swap. Will it work.
- motor running bad
- hood pins, where do they go??
- B16a Parts???
- Whats wrong, tranny or clutch?
- right hand side axle back/catback.
- code 4
- Do 90-91 CRX bumpers fit 88-89 Crx's?
- thermoswitch, fan on, cold redline.... any help its good
- Just bought a d16y8 head, I think??? HELP!
- this sh*t is pissing me off!!!
- New Mounts
- G-Force Suspension ?
- o2 sensors
- WTB: Honda
- 6'6"... would I fit in CRX comfortably?
- front lower strut bar
- Is this true, or BS?
- B-Series Cable Final Drive swap??
- ecu for LS in a 91 hatch...
- Jacnife Wheels
- si cluster
- Anyone have pic of J's Racing catback for EF-8.
- What's the differnece on ESS and VSS?
- Need some help
- ZC Guys
- Pictures of my Car!
- Identify this cluster
- How many holes does your car have?
- Si shafts in 4g STD
- ATTN: blown90hatch, or anyone else who has done a obd1 conversion
- BAD ls vacuum leak
- spent three hours today, studying XSI harness, looks like it will work in my CRX.
- Pic request! clutch cable!
- Cusco Roll Bar/Cage
- seatbelt chime driving me crazy , will not stop (did search)
- Strut and Spring Install
- How to post pictures on HT?
- I think I'm having withdrawls...
- off topic but how u guys get those wierd titles
- $2300 for '91 CRX Si 150K, worth it?
- roll cage
- RHD front clip
- A few question on a n/a b16a build up
- Skunk2 D-series intake manifold?
- Should I do my own brake work?
- Does anyone have a pic of the SKunk2 exhaust?
- what tools do i need for swap?
- Did a compression check on my b16 awhile back, I want your thoughts ?
- b20 in 88-91 crx
- which cluster should I go with?
- ef/gsr wngine harness ?
- EF almost finshed!!!
- Steering wheel swap-help
- question about engine not starting???
- let this be a lesson....
- taking fenders off?
- b18a Axle question
- Anyone have exp. with JIC Magic FLT-A2's?
- ITR suspension vs. bilstein/eibach-prokit - better for daily driver?
- Installed indiglow gauges, now Temp. reads HOTTT!?!?!
- to gude or not to gude???
- Skunk2 Coilovers
- integra exhaust
- MPFI swap, getting code
- A/C in 91 HF with B16
- tranny still grinds
- Many thanks to Blown90hatch!!
- my compression test results
- I Need Help!
- Went to the junk yard
- how to remove upper dashboard?
- Need advice on suspension.
- zc distributer problems, i think. igniter? HELP
- Clutch cable- OEM or aftermarket?
- Anyone have pictures of an Autopower Rollbar installed in a Hatch?
- CRX or Del Sol: My decision
- Where to get OEM fogs for crx?
- clutch cable and throttle cable ???'s
- b16a spark plug thread stripped!!!
- fuse on the battery.
- clutch problem
- which electronic vss?
- gounding a wire for +10hp???
- How much did you pay for your springs
- How long can an engine sit?
- New Lightweight wheel offering. Pics Inside---->
- ok here it is 4th gen car, 5th gen struts, 4th gen springs what will it result?
- 32-40 offset yeah or ney on my CRX?
- Is this possible?
- 88 hatch seatbelts vs. 91 seatbelts
- GSR cluster into CRX
- grease for tranny
- civic and crx window ?
- PM6 ECU chip - how many pins?
- wiper arm on my 86 hatch
- Question about crank??
- looking for average cost on swapping a b16a1 into a 91 std...help?
- Performance brake disk and pad suggestions!!!!
- Spots for 3 harnesses in GSR cluster?
- is this possible? HELP
- Gas Gauge broken I think.....
- front tranny mount
- b16 or d16z6turbo
- repost obd0 to obd1 harness questions Wiring Guru's OBD0 to OBD1 conversion alternator woes
- Old schoolers - ID this header
- How2 wire ef8DX 2 SIR???????
- B16A Cable Tranny and ECU.
- b16 build up questions
- gas needle floating?
- Hard Idle... help please ne1
- what brakes for 91 crx
- Rota Slipstreams with 215 45 16 tires fit in our wells?
- need pics Of CRX BLACK with either Black rotas Slipstreams or spoon 4 spoke
- D15b
- what rex's match up with EF 7, 8, 9
- New to CRX'es....
- Injector Resistor Box......
- ANyone need a brand new STR adjustable cam gear in the box for a d16?
- Ligth bulbs on the cluster gauges???
- fuse prob
- Buying a new oil pump tomorrow...will a VTEC one be better?
- 88 crx si options?
- leather interior
- probably gonna get a different rex or hatch
- jdm gauges in CRX
- built d16a6 head or mini me??
- hood weight?
- Camshafts
- will these tires be ok on a 91 civic?
- lexan windows?
- 84-87 crx body kits?
- 87 crx si sunroof filler piece?
- Question
- 88-91 si seats in a 84-87 crx?
- brake rotors
- Inake swap: 88 CRX DX
- cable to hydro tranny conversion?
- interior post
- tranny prices
- integra stuff in a crx?
- 90-91 integra fuel pump, calipers, & master cylinder on 90-91 Si
