View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what brand camber kit do you have
- b16 turbo in a 88 crx
- EF Radiator
- does most of the cat back exhaust come out on the drivers side?
- quick suspension ?
- hatch
- wtb. got a 91 civic hatch for sale wit a jdm b18b and a b16 trany
- Doing rings in car?
- jdm fronts???
- o2 sensor
- service manual download
- ebay radiator!!! need help within the next 10 min!!!! HELPP!!!!!!!!!!!!!
- Someone stole my Crx
- D16 SWAP 88 CRX DX
- Know where i can find spoiler?
- Q on fuse size for rear battery conv.
- Quick Brake questions
- Letting go of the B20 CRX :-(
- JDM radiator support?
- 90-91 civic hatch doors and 90-91 crx doors, are they the same ?
- FS in Minnesota: D16 and kit
- vaccum lines std to eg6 si ( i searched)
- how to install 2.5 bar map sensor
- how many miles r u getting on a full tank of gas with ur b16crx
- need some ideas on what is causing my 3rd gear grind
- Think I got a electrical problem with 89 crx!
- Mugen Sway Bars
- Help Tire Size alignment
- JDM front end
- cable tranny fluid
- where does the radiator fan plug into?
- Bolts for Rear Cargo Holders
- b18a hose on back side of tranny? help
- does any body run zdyne???
- Wago-van Prices??
- b16 stroke??
- pre 88 rex
- quick Cam question...
- Can I replace my crx SI sunroof for a civic moonroof ?
- soon to buy coilovers but need info
- installing a a/c in the crx si
- Electrical Issue Please Look...searched!
- Hi all im new 2 this forum / Drive CRX turbo d16a (ZC) from downunder
- i need a good place to buy a motor
- b16 swap stuttering
- sohc cam
- splines of gear box L3-1565707, 20 or 21 ??
- 91 LS HATCH ECU QUESTIONS
- wheel size
- No power to my crx
- Transmission/Clutch problems...Help
- Name that part!
- sohc d series head gaskets, all the same?
- obd0-obd1 o2 conversion
- Engine likes to bog...
- HELP... what kind of mounts?
- 91 ls teg cluster swap into a dx ef hatch?
- auto crx 2nd gen???????????
- 87 crz having cutting out prblems
- Repaired Ignition switch = New Car
- What size tires?
- Whats the benefit of changing from DPFI TO MPFI????
- progress of the CRX
- Attn. CRX Pros.........Newbies, Need help.........
- What shift linkage for B18A into EF Sedan??
- b18 into a 91 hf HELP
- CRX 3" Thermal blues ...
- swap help!!!!
- 88-89/90-91 Cluster Question
- Noise Behind Gauages
- what is this???
- throttle responce sucks
- Searched for days..... Kill Switch Question.
- s2000 cluster PINOUT
- tranny stamp
- Stroked D16.... Whats so wrong with it?? (Newbee, sorry...)
- Water in hatch: how to remove tailights?
- slammed ef pics------> I ♥ My EF
- I need to vent!!
- DA seat install
- Rear Sway Bar: Is ST worth the $
- stock internals for boost
- NEW TO SWAPS BUT NOT THE GARAGE
- Will D16y7 tranny bolt on any........
- Where did you buy your swap?
- can this fit a da?
- usdm hood on a jdm front? the fitment?
- about door moulding ?
- Axle question
- headlight question (i did search)
- tranny woes
- Might be buying a beater (Honda crx hf) Swap help please...
- phearable.net chippin Q
- overcharging alt?
- crx tie rod
- b16 throw out bearing
- 91 hatch radiator hose question
- daily driver crx won't start!!!!need help asap!!!!!
- Turbo question on a 1st gen b16
- What is the name of this hose???? help
- hybrid brake setups?
- vtec not kicking in
- steering wheels
- Can i put teins off an EK coupe on my 89 hatch si?
- Can you find the "Needle" in the crx-stack?
- Newbie Question:Looking to do a b16a1 swap and was wondering???
- How Much Would You Pay?
- crx vs. civic hatch
- Zc 1/4 times
- cbr929rr itbs with ZC
- Ticking Relay, and no clue where it goes.
- 1990 honda crx d16z6 block timing probloms>? ???
- how do i fix this?
- idea about clutch pedal breakings
- wheres my AVATARRRRRRRRRRRR
- timing belt?
- Lowering springs on a crx
- CRX SI trailing arms on EK hatch
- data
- Civic/integra Arm rest in a '90 Civic Sedan
- 88'civic DX..........won't START!
- HOW TO: Interchangeable Mufflers
- b16 block how much power before the block falls apart or cracks
- D16a1 Swap!! Engine Mount Help!!!
- What to look for when buying this EF?
- Ignition power lose, take a look i need help on this!
- what club is the best one to use
- I ♥ My EF
- Who makes a CF SIR style hood for a 4dr
- ROOKIE PLEASE HELP MY CRX!! CRANK BUT NO START, WONT FIRE
- '90 CRX?
- Wont go in 3rd Gear
- CRX Si nstrument cluster
- zc gears and 88-91 final drive
- h4 / h4h bulb pinouts
- jdm ef9 side moldings
- CLIMATE CONTROL COVERS!!! Who Sells Them Here?
- alarm light wiring to door panels
- 1988 - 1991 CRX Quick Alternator Removal Guide
- integra type R 4 lug conversion
- bashpot makes car idle at 3000
- axle bolt....Help
- rim fitment
- shortened knuckle
- Idle air control Valve
- Si knukles/integra brakes
- Cylinder sensor help
- GSR in EF - Tranny Troubles
- safc installation questions
- ZC Axle\CV Joint qustion (searched)
- Cam plate bolts...are they all the same? need help quick
- Need opinions and some help based on looks.
- need opinions, what is the best exhaust for crx?
- which water pump? mini me (kind of)
- boring out sleeved z6
- code 9 from hell please help
- Diffrence in 91 Civic DX and Si front bumper?
- were to buy cluctch for a b16
- Sunroof wont close...
- TOE problem?
- lost my brakes, WTF?
- Crx Exhaust
- b16 brake system shaking like a mofo
- ? for those who have recovered door panels
- Dash Rattle 89' crx?
- b16a
- swap help
- About this bumper
- parting out or selling crx!
- wtb ef harness dx or si
- OEM rims ASAP
- Trouble starting in the rain
- Carbon Fiber hood quaility
- grandpa car 91 civic wagon
- Engine choice's for a new swap
- B16A cam caps......
- Will any d-series starter work on 88 Civic Dx?
- Which axels for 88 crx with B16A2/Y2 hydro tranny
- obd question......
- somebody please help,,, car stalling out, b16 motor 91 civic hatch
- car cuts off while running????WTF
- Rear wiper wiring on a CRX DX. Help please
- wiring problem
- DOHC ZC help
- tps sensor for b18 swap into my dx rex
- ecu for sohc zc
- NEW PROJECT: Trying to save another EF ON A BUDGET!!!
- d series parts interchange question
- kicking a farting motor
- help::91 ef bumper removal
- What alternator can i use for jdm b16a Obd 0
- pic request
- heater core hose firewall to engine
- what could be causing this?? HELP!!!
- Should i do lz/vtec or boost my d16
- 87 hatch
- would a map sensor make my car bogg?????
- Brake trouble
- is this okay to use? throttle cable bracket (ebay)
- My new project - 1989 CRX DX
- Type R seats in a 1991 civic hatch?
- HardSaltydogg's illegitimate child**56k go have a kid of your own**
- block off plates
- Hatch Struts Question - Bolt size that bolts to chassis?
- 1990 honda crx wont start but cranks
- Stroker kit for a b16a
- so what do you guys think?
- So i picked up a CRX to wrench on.......
- wooo!
- Just thinking about the quickest shift possible
- Fiberglass CRX Parts?
- Rear 97 gsr disc and front disc swap help?
- quick main relay question
- Idiots or wut
- quick question using obd-1 dizzy
- Lights flickering at night...
- VTEC problem in LS/VTEC 90 CRX
- distributor ??
- hf swap help
- strut tower sway bar question
- Anyone have a OEM foglight switch diagram?
- 90 integra guage cluster into a 88 crx hf
- Can someone help with ef8 cluster install...
- about EBC GREEN STUFF
- Honda crx
- What's The Best Way To Lower A '02-'05 Civic SI- EP3??
- Custom Exhaust Options
- 91 crx hf disc conversion
- Help me decide.......Mild K or Complete built 84x89mm B? in '89 CRX Si
- jdm ef cluster
- pros/cons of an crx Si
- 2 much smoke out my xhaust
- another main relay blown!!
- Momo Hub ?
- Main Relay Trouble
- lower tq mounts
- !! I need Transmission !!
- wich cable tranny came with LSD?
- Are sedan LCA's the same as crxs?
- can this be done
- Checkout this EF9 SiR
- Is there a difference?
- wtb: 88-91 si distributor
- GSR dash swap in EF
- crx and civic ef suspension questions
- zc swap oil problem
- B16a CRX boggin out
- i have a jdm b-16, i'am ready to build need info on best way to go...turbo?charge it?allmotor?
- Remove Engine While Keeping Tranny in
- SIR Wing Installation and hardware Questions
