View Full Version : Honda CRX / EF Civic (1988 - 1991)
- B16A1 Del Sol?
- tranny help wont go in
- will EF hatch exterior parts fit on an EF sedan??
- civic ex brake switch over
- JDM EF9 Sir Guage Cluster Plugs
- jdm crx bass tubes
- WHY DOES MY CAR REV BY ITSELF?
- Does the 92-96 crx exist?
- 1986 CRX performance help
- DC sports Header O2 Sensor.
- How do I pop my hood if the cable has been tampered with?
- Can I run a 4-1 header w/ factory Xmember in '90 REX w/SiR II B16
- exhaust question
- Plug wire pops at dizzy...searched but want to know cause
- oil cooler
- Anyone on here using this b-series motor mount kit?
- What the hell brakes did I have!??!
- Cam Seal question
- Help me read my plugs. 100 miles on a fresh bottom end. Low compression...
- need pics of factory blue on crx's
- how do you wire a crx clock into dx hatch?
- problems
- Why go for a Type R intake?
- Removing the crank pulley
- ECU Tuning????
- Size of speakers?
- ZC Axel Question?????
- d15z1 and d16z6 compatibility
- First time honda owner
- b16 intake manifold diagram? someone help pleaz!
- brakes is going insane!
- spark plug wiring order
- main realy question NEED HELP!
- HELP another alternator question!
- disassembling '90 Si seats
- Took some pics of the little CRX I'm working on.
- D16A6 help motor not cranking up!!!!
- LIGHT COMES ON AND OFF
- code problems? help
- D16Y8 head weight
- looking for the true mugen hatch kit
- dpfi to mpfi to obd1
- JRSC install, now motor BOGs after 100 miles..... PLEASE HELP.
- Red stock JDM crx?
- FAQ: Where To Buy Mugen Kit For 1st Gen CRX
- 88 civic suspension
- Six short flashes - CEL Code?
- 91 climate control
- crx dash in STD
- Car makes a squeaking sound.
- ebay intake vs. cobbled together b16/d16 stock intakes
- bolt problem
- filters for throttle bodies...
- Rear cargo holder bolts
- BRAKE LIGHTS WONT WORK PLEASE HELP
- ALTERNATOR HELP !!!
- ck
- Steering quikiner Question
- new suspenstion 89 crx si
- JDM Engine Importer in the Toronto, Ontario area?
- Transmission Qustion
- Question about using 450 dsms
- How hot does your EF's heat get?
- 1991 JDM EF8 CONVERSION CRX GSR TURBO PROJECT...
- EF9 CF Hood.(JDM). What do you think?
- What kit is this??
- Quick Tranny Qustion for you B series experts
- Which is better: Kaaz or oem LSD?
- Where to buy carbureted jdm d15/d16 engines? Can't find but one!
- 88 civic dx with z6 head
- How many miles on your Civic/CRX?
- Headers: Stay w/ Jap Headers or go After Market?
- PISTON WRIST PIN LOCKS
- Integra Dash conversion into CRX
- hf manifold and ac compressor
- turbo pistons
- b18 into a 91 4d civic dx....will it mount up?
- custom h.i.d.
- couple of questions about removing b16 tranny will engine is still in
- Car slams!
- HELP!! noob question
- removing carpet on crx
- who has the most OEM JDM parts......
- Anyone tried the "TYpe R" mirrors on a CRX?
- need to now about exhaust
- Which suspension should I get?
- aftermarket fuel pump bracket (upgrading fuel system)
- STAGE 3 XTD RACING CLUTCH w 8lb FLYWHEEL
- Running a little rough dizzy off a bit? PICS
- B16a Swap hesitation
- It happened to me again!!
- disconnected hood release cable!!! how to reattach?
- Draft: ebay intake install questions...b16/ef....with pics
- 91 ef hatch bumper lights
- Looking for 1991 CRX SI Seat Replacement/Parts
- SOHC users what intake manifold do you use?
- should the for sale thread be unlocked?
- do you think the for sale thread should be un-locked?
- shoud the (ef) for sale thread be unlocked?
- unlock the for sale tread!!!!!!!!!!!!
- would suspension for a 92-00 work on my 1990?
- Integra big brake upgrade for CRX
- what size mm for spark plug wires??
- D16A6 distributor cap the same as D16Y8?
- I know, I know, Check the archives....... I must be retarded or something.....
- CRX Si/CRX/HF pedal assembly
- OBD 0 ignition coil?
- sup fellas noob to the forum here
- transmission
- crank angle and tdc sensors
- CRX Axle Question
- Banging Sound From Rear Sus?
- what harness do i have?
- Drivers side seat
- Problem with removing axle from half shaft
- knock off mugen steering wheel
- Which tranny is better???/
- fuel pump help
- Speedo doesn't work under 20mph
- ZC SWAP AXEL PROBLEM
- Original Clutch Lasted 90k!!!
- New addition to the family
- b16 harness installation
- Does Anyone have a 91 crx HF engine harness???
- obd-o resistor box vs. obd-1 resistor box?
- wiring harness help
- Stereo Wiring Diagram
- put new tranny in...won't start!!!!
- how much would it be usually for a bseries swap? ls, b16, ect....in a DX REX
- Polyurethane Suspension Bushings?
- where can i find this??
- lightened flywheel
- Need Pics of JDM manual for cam gear setting
- Value of a built head?
- clock & cd player problems!! Need help!!
- jdm engines
- will a jdm bumper fit on a usdm front?
- H22 into CRX wiring question(s)
- Climate Control Help!!
- 89 STD question
- dsm injector compatability
- mpfi conversion ecu question
- WTB: crx ef8 edm gauge cluster
- my heater dont work
- Has anyone put a 99Civic Si dash in a 88Crx HF
- quick question!
- Best D-series motor?
- Looking for an EF in jersey let me know
- 1990 dx hatchback
- B series question
- 87 CRX SI turbo project afc?
- which distibutor??
- so much smoke
- civic cvcc radiator in ef
- I have searched(no luck), Timing belt replacement
- Climate control plate
- Having problems with code 4:
- EF Sedan. I Am Interested in Buying One. Which Year and Sub-Model to Get?
- Oil Pressure = HP?
- need timing belt info
- Is the '86 CRX Si worth the trouble of rebuilding.
- b18a1
- hey ignition ?
- Car won't start when left out in the cold for two+ hours
- dx to si wiring
- 90 Civic STD...SOHC VTEC problems
- will gsr brakes fit in 89 crx?
- *ebay coilovers and koni yellows*
- Need help with my 90 dx hatch
- *thinking of new suspension setup*
- Another CRX Project...
- can i use a crv timing belt on my lsvtec swap
- need to know where all vacuum areas are on a b18a1
- please dont kill me (dpfi to mpfi) help.
- glove box help
- look what i just got(jdm tight)
- STOLEN CRX - Northridge Area - I hate thieves, Pics in the post
- Which cluster (what car) is the one that goes up to 9K???
- turbo + ecu codes = ???
- White Smoke out of Breather, What?!
- pg7 w/ what cars?
- heater doesnt work...
- tranny problem/ question
- Bought new Heater Controls: What year is this for?
- Honda Wiring
- Steering wheel shakes at idle and high speed
- Wow...didnt think that was gonna happen...
- 0 to 60
- were is your battery?
- ed civic pis wanted
- Problems with Hasport EFAC bracket
- OBD-1 DOHC ZC
- 91 civic dual port to multiport wiring harness conversion.......
- bypass igniton key to close sunroof?
- RHD conversion firewall comparison (searched)
- Orlando - read this
- need reviews: Tanabe Sustec Pro S-s
- photoshop
- Info on P70 ECU please
- curious swap question??
- Bought a CRX, now general questions...
- b20 valve size vs a b18 valve size
- 91 crx wiper and rear defrost problems
- Y8 Mini-me Questions
- Cold Fuel??
- FS 88 crx
- need help!!!!!!!!
- heater core remove help
- JDM front end.....
- at and mt
- Not all hatchies had door side moldings....
- 1989 Honda Crx Hf engines need help swap maybe si, or zc?
- best N\A engine management system
- fuel pump prob ?
- noise/vibration levels of EF's with B series?
- Changing alternator, question about master cylinder
- dizzy problems
- valve cover stud is stripped
- Problem with '86 CRX Si sunroof
- 89 crx si electical problems help!!!!!
- starter for b16a1
- Civic HB climate control, only 2 bulbs?
- B16A/Y1 AXLE problem
- LS and b16 oil pan
- Stripped lugnut
- d15b2???
- help me with my crx
- Wire Harness
- FOR SALE! Mugen cf-48 wheels on CRX!! mint 15"
- rear garnish
- Installing the SiR Spoiler
- Turbo D16 Rods?
- dx vs si cable throw out fork, same?
- Motor Swap Difficulties
- Name This Part, plz.
- any body hav hx wheels
- Shift light?
- quick dizzy question
- license plate bolts
- Fuel pressure problem
- Gauge cluster removal
- p08 IM vs p32 IM
- are 96-98 side mirrors same as 99-00?
- '88 1.6l 16V VS '89 1.6l 16V CRX
- i know this is messed up, but what do i need ?
- need help!!!!!
- mid throttle sputter b16
- washer trick for chamber??
- Hinges on my cargo cover
- Need Parts or Help on your ef we can help
