View Full Version : Honda CRX / EF Civic (1988 - 1991)
- crx need a little help here throwing a o2 code
- Blue valve cover
- bogging problem HELP!!
- Still havning an issue starting.....uugh!!!!
- help 16V turbo
- are Obd1/2 injector kits the same???
- Ls CRX Motor Mount Help
- Help with plan for a6 cylinder head
- Honda B Series Starter In North Carolina
- 88-91 vtec stickers not jdm
- Accord & Civic window visors question?
- z6 or zc?
- Honda CRX A/C dryer problem
- Proportion valve
- Hasport hydro cable conv..
- how to take out air conditioner out of stock 91
- JDM H22 dizzy question?
- Huge wiring mess! HELP
- Resistor box/RX-7 injector cock-up
- questions about d16a1
- EF hatch positive camber issue.
- does anyone know what this kit is called?
- i had no idea wats wrong wit my crx....
- front end question
- LS swap into CRX
- Skunk 2 sport shock + coil sleves
- skunk 2 catback exhaust system
- b16a obd 0, vss problem!
- hybrid steering wheel & cluster ideas
- 91 ED Hatch passenger side mirror =/
- AC question for B-Series Canadian Wagovan.
- El Paso EF project shop Car
- SOME SEDAN QUESTIONS.
- ok got a serious problem this time guys
- Mini Me coolant tube
- CHECK ENGINE LIGHT HELP
- obd1 converted; Code 14 mystery, Help!
- fuel injectors arent getting power
- Back after a while, new engine build!
- 88 crx hf b20 swap. fuel injectors not squirting searched and stumped
- Converting from OBD0 B16 to OBD1, need help
- PS bracket for zc civic
- need help swapping h22 in a 91 hatch
- awful rattling noise.
- ceased pilot bearing
- First Car 1991 civic hatch
- missfire,sputteringD16A6
- crx disc brakes
- scan tool connector location
- 1990 crx ef8 build
- 91 EF HATCH WITH JDM16A NEED INFO ASAP..
- 91 EF STD Build
- dropping the EF
- Just Recently.
- Twm itb's
- 91 won't start or come out of park
- CRX with b18a1 swap Axle/ Driveshaft Problem
- cna i do this ???
- Can someone ID this traction bar??
- Bad Cluster?
- Lookin for Directionf or B Series swap into 90 CRX
- 90 crx help!!
- ok ok guys i need to find out somethin
- Question?
- Complete Wiring Diagrams For 88-91 Civic
- I am looking for interior parts for CRX
- enkie rpf1
- need help with tack
- Guide Me Thru This Please (SOHC CRX)
- check engine light code check
- B swapped 1991 ED First Long Trip Prep!
- anyone replaced rod bearings withought polish crank
- ExtraBlackRex's 88 CRX Build..
- Civic EF '89 from Spain
- 1988 civic exhaust studs?!?!
- DPFI to MPFI troubles
- CV axle fitment problem
- my 91 hatch build
- 91 EF hatchback with d15a1 stumbles on takeoff
- sputtering 1990 si hatchback D16A6
- For Sale: Immaculate CRX WoW
- Shorter than stock front suspension forks
- 90 Crx Si No High and Low wipers
- Lowering my drivers seat.
- EF Hatch Si w/ JDM B16-Help!
- Zc DOHC PG7 or PM7 or PM6.....?????? HELP!!
- Rear disc barke confusion 90 crx
- Alternator Killing Battery ??
- retreive codes on 90 crx obd1 conv.
- 91 EF HATCH WITH B16.."SPUTTERS ON HIGH RMP"
- Ef opinions
- swap/suspension problems
- 89 CRX HF stalls--need advice please
- Hatchback bumper compatibility
- PhrequenC's 89 CRX HF Build
- obd0 to obd1 eveyr thing!!! crx help plz
- What is the best way to clean out the sunroof drain tubes?
- B16 IACV Question!!! Please help...
- will a 89 hatch grill and filler fit a 89 4dr?
- JDM B16 EF/ Help!
- 91 civic rear Disc Conversion
- Cooling issues
- Bad week...Bent rod? b16 ef help please no oil
- Crx bumper on ef hatch
- Will crx parts fit eg hatch
- What engine and tran should i put in?
- EF LS VTEC
- Weapon-R coolant overflow tank..suggestions?
- Question about the B16B
- EF wont start
- head gasket
- OBD0 Wire ID!
- Check engine light stays on when keys out.
- fan wont kick on
- now its a hesitation issue.....
- fuel fressure and AF ratios question.
- z6 head on my d15b2 block???
- Is this a lost cause????
- dohc zc swap help please ....
- crx clutch question
- Will CRX hub assembly fit 1990 civic hatch?
- Electrical issue dealing with cluster.
- Crx shell with full interior and clean body without motor but NO KEY?
- dpfi to mpfi dizzy problems. someone please help???
- turbo rex not starting
- 90 hatch front jdm bumper?
- 2 QUESTIONS 1MOUNT AND A SWAP QUESTION
- D16a6 Dead
- EF CIVIC Hatch FOR Sale(socal)
- Fixing GHETTO MPFI swap HELP!!!
- ac system
- need help gsr!
- all lights flickering
- Harness question
- Spoiler help
- b16 ef vibrates too much need help
- D16Y7 problem with 89 Si trans
- GAB Polished Strut Tower Bars
- Ball joint/Tie rod nut madness!!!
- Some pics of LS/VTEC build
- Gps Help...
- Tranny question
- leak between mc and booster
- Ok guys, tell me, what is something you hate about your car??
- CRX Floor Mats
- is there a difference in ef8 corners and 90-91?
- Alarm for 89 CRX
- b16a sputtering?? HELP!!
- sohc zc question
- Problem with my headlight turnsignal switch
- first time attempting timing
- a6 Piston Rings, Valve Seal help
- vibration or wobble issue
- d16y8 distributer
- D16 zc twincam dohc
- rear seats?
- CRX b series swap question
- thermostat location
- ? about 89 crx si
- CRX lowering springs.... HELP
- over heating problem
- walbro fuel pump
- Crx Body kit help.
- Rear caliper sticks on when E-brake released. Solution?
- obd0 to obd1 conversion
- injector help
- megan racing coilovers?
- for anyone who cares, i got the d-series running now
- The recession si's 90 ed6
- CRX OEM Springs on Civic Wagon?
- CRX won't turn over! tried everything!
- projectors?
- window visors
- CRX fog lights
- d15 to d16z6 swap
- d15 to d16z6
- d series cable tranny
- No 02 sensor wire on engine harness, 91 civic si
- hondas
- P73/1st gen skunk2 vacuum lines on LSV CRX
- 91 ef with b16 misfire
- Quick questione?
- Stolen CRX outside my complex in visitor parking
- dc axles in B series ef?
- Speedo Cable Broke , Need Advice
- Sunroof Drains & MPG questions
- lowering springs
- will a 1990-91 civic corner lights work for a 90 crx?
- Mystery suspension...
- What Clutch?
- ek axles in ef??
- 89 std hatch turn signlas dont work
- fuel filter - banjo bolts are frozen
- Finally finished my rear seats...
- ok guys i got another problem please i need to figure out whats rong with my car
- MPFI Conversion car in limp mode
- Quick Question?
- Finished my Y7 swap, started and now code 7
- crx ls swap
- ZC aftermarket parts help
- Y8 swap help
- where can i find this part?
- Tail Light Problem (Weird?)
- Project: eREXion
- 91 si manual transmission gear issues
- need lots of HELP TRANNY SUX
- 89 CRX Si B18C1 GSR Swap Project!
- sunroof switch fix *how to*
- 91dpfi injectors not firing
- crx 4/t
- 1991 Honda Crx Wont Start!
- crx sunroof!!
- crx door question...
- Gear Swapping
- help with this question..
- Fuel pump problem
- Help with 91 si electrical problem
- need some help with d16 swap in 91 ef
- Front Bumper Attachment?
- Codes 1 and 10?
- RHD wagovan----Are they real?
- pilot bearing help
- ef help
- D16Y8 Intake manifold onto ZC Head HELP
- Adjusting wipers
- CARBON FIBER HOOD
- D series transmissions?
- where does my O2 sensor plug into??
- ground help
- B16 obd-0 dizzy o-ring???
- Y7 swap question.
- b16 problems
- 89 crx si seats in a 90 crx??
- CRX Dx - Hf dash harness differences?
- Jorsher's LS-VTEC CRX (videos too!)
- building an a6 mini-me have a few questions
- VAFC install on ef
- DA roof rack fits CRX?
- Civic/Crx sunroof really weak motor & Power Windows
- which way does the dizzy go?
- pwjdm vtec solenoid cover
- 90 crx ready to go
- Ef help.
- Help alternator removal 91 civic, d15b1 engine
- h2b questions
- Timing connector queston with B series swap and Rywire harness.
- 89 CRX Clutch clevis pin.
- converted ef hatch..
- repair crx door panels?
