View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Wiring Question: putting a D16A6 into an STD model.
- 88 crx si tranny in 89 std
- 99-00 Civic Si seats in CRX.... fitment question. TIA
- any one know what yr 1987 1988 civic crx use the same struct as the 97-01 type r???
- quick Drivetrain question
- need help in battery fuse problem
- ?'s on LS TURBO
- plug gap with msd ignition
- OIL FILTER BLOCK ADAPTER
- Sh*t uh I mean shoot
- cold air intakes +water
- problem with steering
- h22 swap?
- HELP!! questions about half shaft and axles for b18a
- headlight indicator?
- SoCAL: flat black 17" ADR DV-8 rims fs
- !!!!!!!!!!!!!!!!!!! Help pleaseeeeeee !!!!!!!!!!!!!!
- Front big brake upgrade!
- ef7 engine block with d16y8 head good combo?
- J's Racing Carbon Fiber Intake on B16A
- altinators hitting fire wall help?
- What other year axles fit on stock 89crxSi?
- "Silt" in coolant reservior...
- crx automatic trans.
- need help with mpfi distributor
- JDM D15B-VTEC into a CRX
- Climate Control Question:
- HELP!!!!! Injectors not getting fuel!!!! SEARCHED!!!!!!!!!!!!!
- what went wrong??
- Table of codes, PLease help or look.
- a couple of cheap d16a6 parts
- Front wirng for turn signals and corner lamps.
- engine swap on a 88 civic wagen
- b16a1 wiring
- NEED HELP with 91 dx
- Ok Im doing a swap just need a little help and advice.
- oil jet.
- stereo wiring color codes-- searched
- MA to GA
- Anyone got skunk2 springs? They didn't lower my car for shit!
- Weird Code 4 problem
- 96-00 civic suspension on 89 4 door?
- this sux stripped bolt
- 1991 CRX HF Check engine light and other questions
- A/C Question
- **NEW** DPFI-MPFI CONVERVION QUESTION???
- Replacement carpet options
- crx transmission removal
- engine bay relocation question
- antenna on ef hatch
- What Would You Ask For This?
- what size FMIC
- obd 0-1-2 conversion?
- d16z6 coversion in 90 si
- b16 lsd cable tranny ??????
- WTB: 1990-1991 civic EX sedan (4dr) front knuckles.....!
- '89 Honda Civic Interior
- si bottom /zc head
- sohc zc same as 88-91 si motor?
- Tieing up some loose ends with my jdm d15b swap
- where can i get sleeves for a honda crx ZC
- help miss firing!?!?!?!
- CRX Axles Auto vs 5spd
- i crx is runing funny help
- Flooded Interior!!!
- 1990 Honda Civic GL 1.4 ( UK )
- UK EF Civic.. chosing.
- transmision fluid
- mini me
- front lip USDM....must speak dutch
- ZC hood+ef9 front....does it work?
- DSM vs Honda
- EG front end on EF hatch?
- Razo rs13 shift light any body familiar with it?
- help please!!!! i need to know the problems can cause a code 13 on a pr4 ecu. help please?
- V-AFC install on OBD0
- 89 STD hatch back
- Replacing waterpump on LS in the rex....
- Glowing rotors
- Front Strut Bars
- iat mpfiswap
- blower doesnt work at all? could motor be out
- Downforce?
- suspension
- What gauge cluster into 89 Std?
- calling out to all ef 's in the eastern part of pa
- rear disc brakes ??
- ef/ed model cars (searched)
- 1990 tach on automatic
- What injectors/fuel rail?
- Weird problems with Drivetrain
- d15b2 /d16z6 mini me timeing belt
- pr3 wiring and ecu
- CRX starts but will not stay running. Ideas?
- Hasport mount rear bracket?
- removing rear sway bar
- CRX HF with fuel injection
- code 13 on a PR4 ecu?
- help with speed sensor
- Do you?
- Anyone using Totem mounts?
- Valve adjustment ; Richmond va
- Hoodlatch on JDM front conversion for EF sedan????
- Lets talk about wagons......
- just got my CRX, free. couldn't believe no rust.
- Help Me open my hood! Theives cut cable at the latch and then shut hood!
- no ac wut to do?
- D16Z6 into a CRX/EF
- Found a genius way on hooking up fog lights
- Transmission Guys HELP! what bearing size?
- cooling problems prob an easy fix but i'm stuck please help
- Finished my L3 thans-reabuild-to limited Slip Diff.
- Increased pressure pressure plate clutch set up CRX si
- si head
- Quickly declining fuel economy... any ideas?
- Advanced clutch problem
- Autometer Gauge Install (56K warning)
- where the fuck did these come off of?
- B16 wire harness diagram?
- front integra brake swap???
- 96 B18c gsr - Complete list.
- mpfi finally runs! but a little rough...
- how to build a mini me motor
- quick engine question
- rear trailing arms
- Have joined the EF side
- Need advice with b20 vtec
- Charcoal Canister question
- Concerns about Mugen Racing II steering wheel
- Camber Question
- 86 si hatch.. some questions about the motor
- What problems have you been riding on for a while?!?!?!
- calling stereo experts!
- stock stereo wiring
- stupid question page
- engine swap for my civic
- cluster help! need pictures
- million dallor question! please help!
- JDM SiR hatchback wing question
- Transmision Trouble please help
- Finishing up my swap
- HOW MUCH DID YOU PAY FOR YOUR B16 SIR1 SWAP?
- Valves and stage 3 cams
- Damn oil pressure guage!
- Dx to Si tranny swap
- Anyone have restoration pics of there crx's?
- need wheel brearing help fast, please!
- help!!!
- still jerky
- Rear wing ideas
- EF turbo clearance issues and others.
- To anyone with a Full-Race Traction bar
- rota circuit 8'ss
- Noobie. Need help with Engine decision.
- Tire Tech
- What o2 sensor to use for JDM d15b in 90 Dx hatch??
- crx door trim
- **Problems installing a INTEGRA CENTER CONSOLE in my HATCH**
- crx rear trunk cover?
- how many people have you....
- Brakes
- HAPPY NEWYEARS
- tire opinion
- ****intermediate shaft bracket bolt size???????*********
- 90-93 Integra LS parts car...what can I use?
- new mini-me
- Trans
- Camber kit Question
- I found a beautiful little CRX but I have a problem
- SOHC 1.6 VTEC in a 90 4DR LX
- I thought these things were light weight
- optional center console
- front end
- Integra seats. Will they bolt right on to the stock CRX brackets?
- Anyone know where you can get some jdm Oem Parts?
- Difference between 88-89 and 90-91 pm6?
- FYI TSB 97-047 Update Head gasket install & Torque sequence D Series (56K Beware
- ATT: Those Who've Swapped EK Skirts onto EG; I'm Looking for EG Skirts
- Crack in Windshield
- Another Boosted Dseries
- What tranny fluid?
- How much $$ for a mechanic to look at your car?
- temp gauge not working
- YAY finally something is going right....
- simple question.....
- How sturdy would the chassis be without the front/rear bumper supports and bracing?
- Need help with torque specs.
- Damn Distributor!
- Which do you prefer? obd0 or obd1?
- 1st G b16 dizzy same as LS dizzy? Both obd0??? NEED QUICK!
- Teins basic for 90 crx hf installment.
- Can i swap axles, tranny, ecu, everything from a civic ex?
- D16 Intake Manifold
- **New Years "EF Resolutions"**
- look for CRX
- Integra non-Vtech B18a swap for CRX??
- best oem pistons for turbo app
- koni sport ef rear shocks vs koni sport eg, dc rear shocks
- Steering wheel Ques-t-ions???
- My 1990 civic si Stolen in AZ!!! pictures, link, reward!!!
- Does anyone have the crx window visors?
- lean problems
- d-series itb gains???
- driving with a loose tie rod what can happen?
- lookin!!!
- headers
- Problem with my sunroof....
- greddy evolution exhaust in a 1990 civic hatch?
- 88 DX dash harness same as 88 HF harness
- hood release weird
- question about a possible track car
- WW Mugen flared ricey??
- Need Help !! cant find axels to fit my tranny.
- Looking for Rex...which one is best?
- dx to si problems
- Shocks...yes i searched....but the answers given werent very helpful
- What would you do if you found a mint crx si???
- need help
- CRX help
- crx jdm front conversion and usdm hood?
- Anyone from Idaho? moving from cali, need smog info? Swaps??
- blue interior - what paint matches?
- new wheels
- OMG look at this!!!
- what's up with RPR???
- some cheap seats?
- d15b6 vs d15b1
- seat covers?
- Door clicky noise
- do you think this would work?
- Chassis codes clarification
- EF7 C/F Hood
- Who knows this EF9
- Grinding Noise when Stopping?
- JDM D15B Header, which to use....
- ALL 4 FUEL INJECTOR LOCATIONS?
- Resistor Box help
- What does this jdm crx door say?
- Weird Knock
- EF hatch jdm fogs?
- 14 or 15 inch Mugen MR5's.
- Fastest crx in the uk coming soon"
- 15's or 16's
- NOx readings twice as much as standard
- One Quick Question.
- code 17?? :crook:
- Me and Hatchy get New Shoes for Christmas!
- dx ignitor same as b16?
- GSR cluster with 88-89 cluster hood...done
- Shocks from SI
