View Full Version : Honda CRX / EF Civic (1988 - 1991)
- jdm cr-x tail light logo
- need help with tranny question
- 90' Si moonroof cracked -replacement found on other hondas/acuras?
- tranny choices
- ba18a1
- Just Bought A Rust Bucket.
- Another Project Finished...H22A Crx...
- b18b crx turbo
- accord obd1?
- Timing belt tensioner
- sohc zc into 89 hf, cel codes.
- idle problems
- Oil Leak
- zc dohc head gasket???
- looking to pick up a 89 and 90 crx
- failed CA smog for the 3rd time with my stock 88 crx si
- Electronic VSS issue
- turbo timer
- iv had a zc for quite some time now
- rpm gauge is turning off randomly?
- Need help locating side molding for my EF hatch
- Skunk2 mega power exhaust
- malfunctioning fuel guage
- I need help!!!
- dpfi to mpfi problems plz help
- How much would a authentic used mugen wing for a crx go for?
- easy dpfi to mpfi conversion question
- Radiator
- hood fitment question
- EF lights...
- 1988-1989 Civic Question
- Fiberglass
- Quick question?
- identifying heads.
- in a bind...
- would this fit?
- OBX intake manifold
- axle swap ????
- whats the difference between ZC and Si
- Totalled Crx, Worth straightening for racecar, or parts car???????????
- replacement cat?
- After swap question. Please help.
- Timing belt
- how much transmission oil
- hoods
- loss of words
- whats wrong?!?
- engine harness quick question
- 1988 civic hatch heater core?????????????????????????
- Oil filter for noob's tired D1.5 in winter
- Low idle
- is an hf an si engine harnees the same.........
- Intermitent front wiper option on CRX ???
- 89 EF SEdan Front Lip
- how much r HX wheels worth?
- Thirteen20/Autoworks EF build...
- intera seats in a 91 dean
- what is tdc?
- HELP!! I cant advance my timing more than 12 degrees btdc!
- d15b turbo
- lights dimming with a new alternator
- brake lights...searched!
- 2000si tranny or ys1 w/ limited slip
- NEED input on planned swap
- gsr and type r EF's
- injector h20 question????
- All I want for christmas is my gauge lights and climate control lights
- jdm tail lights...
- parts compatible?
- 1989 Honda Civic sedan
- 89-91 CRX Si JDM Front Bumper
- dx model crx
- a whole bunch of electrical (?) issues with my honda 1990 civic
- 8atman's supercharger install.... also posted in the F/I, but nobody has input.
- How To Wire An Auto DX After Auto To Manual Conversion
- to the smog man! I have high NOx emissions
- Ef8 Power folding mirrors?
- ITR seats? Which rails?
- Could you help me out i want to connect a gsr cluster in my crx is it possible?
- a question
- i just sold my CRX
- Inner Tie Rod ends
- Question on crx si roof drain tubes
- need help for a friend quick! 1991 si harness into 1988 awd wagovan
- could a stock dx barburator hold boost from a turbo?
- D15B2 DPFI Intake Restrictions
- I need a turbo
- pr3 vs. pw0
- what do the numbers on the rocker arms mean??
- whats wrong withmy car?
- D16y8 wiring harness question
- Clutch cable question.
- Just bout a rex have a question???
- Are these ABS axles?
- Weird starting problem in d16a6 crx
- Need Help with Brake Lights with 99 Civic EX
- will a6 alternator work for a z6? searched!
- Please Read need more help
- How to unlock the steering wheel?!
- Wirring Loom? :S
- Is there a way or write up on how to use 90-91 cluster w/rpm in a 89 hatch?
- best way to remove the crankshaft seal on D16
- does a d16 sohc vtec bolt right on a d15b2 block?
- Crx hatch installation?
- obd-0 to obd-1 harness's what kind
- need help tranny problem
- Anyone know where i can get this Dash Cluster Cover?
- finally a video of my car
- a quick rear disk conversion q
- Rough idle on cold start...
- Problems!!
- rotors for a si on a dx.
- Turboedit, Mini me, 1 wire vtec not working
- Wire harness
- Rear fluid sprayer leak
- coolant bleeding on d16a1
- 97 C-5 Corvette exhaust ON A 91 CIVIC EX.?
- brake lights wont work, dash lights come on! plz help fast
- 1991 Honda Civic Sedan (I got questions)
- post your street legal crx wieght and info of weight reduction and pics out to find the lightest st
- Coolant not circulating
- EF8: b16a1 pcv removal help!
- quik question
- steering rack
- wiring speakers
- stolen, plz look
- Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles??
- how much wieght can you take of a crx HF
- Humming/Vibration From left Front Wheel
- shift linkage ? please help!!!!!!!
- my e-brake. dosen't brake at all
- Tranny and Clutch?? D16y8 into a 89 hatch DX.
- throttle body
- My car photos Honda civic 1990 hatchback
- fuel filter bolts? stores?
- axles for my swap?
- Block comparison
- B16 swap questions?
- ex ecu plug and play with hx harness?
- b20 b18 B16 crAP
- Need some help with aftermarket tach.
- pulsating idle
- Do you prefer the CRX or the Civic hatch...?
- si cluster for a 91 crx
- Stopping wheel hop?
- crx disc brakes
- B16A Swap Into 87 Crx SI
- bypass tube / valve on upper radiator hose
- Honda civic 1990 and crx taillights
- D16a6/y8 (minime) Into 87 CRX
- quick question
- b16 swap????????
- 2 question plz help!!!
- B16 CRANK GEAR ????
- help with headers
- SUPERCHARGED A6 OR ZC SOHC NO-TEC......fans..post here!
- Mugen Wing for CRX. How Do You Install It?
- To all the guys who have dizzy's that dont line up with the bolt holes
- car won't start? Urgent help need!!!!!!
- Battery or Alternator?
- why does the IACV...
- 90 si transmission question
- Code 17, tried searching... need help asap!!!!!
- wrecked hatch with crx front end..
- 91 s1 b16 ecu code 21
- 91 crx dx. eacv problem?
- radiator question
- jdm bumper
- Neuspeed or ASR sub frame
- got a really good deal on a prelude!!! h22
- plz help me find a topic
- car alarm issues
- will this remove my valve springs??
- Code 41--any tips on how to fix?
- new to the d-series and i have some questions
- Steering knuckle question.
- inline transmission filter?
- Glass Top for crx
- 90 Civic Sedan Clutch Replacement Destructions Available????
- Y1 and YS1 differences
- Crx Lip Kit
- CRX Hatch rattle from struts
- Replacement Seat skins for CRX
- weird temp readings =-(
- can someone with a d16z6 help me?
- is it just me?
- Upper Arm assembly (pass, drive interchangalbe?)
- wireharness conversion?
- Axles...some1 plz help asap!!!
- cooling fan
- How to change inner and outter CV joints? 88 crx
- How to distinguish between trims - si dx std hf?
- shift linkage "?"
- will this help me??
- Help ASAP/ Fireing order and spark plug wires.
- zc headers !!!!!searched!!!!
- 1979-1983 Honda Civic B-series swap. Possible????
- mini me
- JDM B16 OVERHEARING.....s l o w l y
- my boosted sohc ef project
- HELP center console question
- Can i use 90-91 civic hatch doors on my 89 hatch????
- rotors/brake pads from ebay?
- center console question
- Question about a sir gauge cluster
- 91 dx windshield wiper bushings
- My friend has . . .
- Hey Guys need some help
- wire tuck
- crx exhaust question
- throttle cable ?
- Master Cylinder question ?
- timing belt?
- SiR Question
- What size wheels will fit over DA Brakes on a CRX?
- MSD Ignition Install
- Suspension Bushings
- code help
- anyone have a wiring diagram
- Dont worry, I searched! What denotes a short ecu flash??
- EX knuckle on CRX
- Headlights....same across the board?
- Tach wire @ ecu
- DOHC ZC TURBO HELP
- k24 swap in 91 si!
- clutches
- Limited Edition crx any one ever seen this ... look at the pics on this ebay auction
- crx ls harness ?
- fuse problems
- preventative measures
- harsh shifts Automatic Transmission
- crx ls swap ?
- WHAT CAUSE LIMP MODE in obd0
- 91 Si DOHC ZC SWAP.....CODE 9...LIMP MODE...3100rev limit...SEARCHED
- CRX Bumper On Civic Hatch?
- Reducing weigth
- HELP my civic acting like a mustang 30 mpgs to 20
- has anybody acheived 140-150ish HP on a D16a6 all motor
- Newbie--OEM repair question
- Swaps for 86 wagovan?
- Will this pass as J.D.M. Style?????
- crx - civic q's.....
- b16 question
- battery problem
- JDM B16- Which Water Outlet Housing?
- b2 and a6!
- All aluminum radiator that fits like OEM unit?
- b16 swap alternator clearnace issues
- What aftermarket high end header will fit with stock crossmember?
