View Full Version : Honda CRX / EF Civic (1988 - 1991)
- looking for pic's of 00 Si rim's on black ef's
- crx break switch
- Interior Grounds?
- the car wont start
- Having issues diagnosing my problem
- somone help??? knuckly/axle problem
- 450hp Civic Wagon sleeper
- obd0 obd1 dizzy conversion
- CODE 16 FUEL INJECTORS HELP!!
- what would cause the timing belt to come off?
- Easy B16 retainers question?? Help.
- B16 Idles real high
- sell as shell or part out
- Suspension suggestions
- D16z6 into an EF help
- crank no start
- trannsmission question.
- I need to know if this is a good site.
- DOHC ZC header fitment questions...
- im at a loss
- EF Hatch
- b16 part suggestions
- 90 Civic Hatch
- ef,dx,ed?
- Thinking about getting an EF
- RT4wd crx conversion
- Removed a/c with a problem?
- Need some help with an Idle problem
- What's the easiest swap into a CRX
- Eg seats on Ef?
- 90 civic si wont start!
- b series in ef
- ef sedan 5spd swap?
- This cannot be for real
- need help!!! evap canister and CA smog
- Changing Color of Seats
- Help with 90 civic dx
- kyb???
- crx si with check engine light need help
- How to take off my valve cover?
- is this fixable ??
- b16 crx high idle...HELP PLZ!!!!!
- Transmission Guru's!
- Honda Integra Xsi motor/tranny swap into '91 Civic DX DPFI Auto
- Timing different than factory setting?
- to vtec or not?
- LS swap in 90 Sedan
- S2k seats in EF?
- '89 CRX si Build so far...
- Can I use a a/c system from a Del sol?
- Having trouble with my Rex help please!!!
- msd sport compact
- I need your input on crx upgraded sway bars!?
- Am I having a leak?
- civic lights black!
- sohc zc problem!/?/!
- Ek seats in EF?
- Engine options for '90 Civic Std.
- Forgot what its called. mirror.
- My Crx, Stomp'n Snow
- sohc help
- Brake Problem..
- Ac for 50 bucks =DD
- wtb sir ef9oref8 front bumper jdm or usdm 90-91
- need some help with code 4
- crx wont start...fuel issue.
- d16z6 head?
- Hello everyone!
- GSR SWAP just dies after driving ?!?
- just want u to know.
- CRX exhaust opinions
- crx 88-89 to 90-91 front bumper swap
- My new 89 Civic Sedan.. just purchased...
- 91' CRX HF Headgasket Replacement HELP! Overheated
- nooby needs help
- EF steering wheel removal...
- I finally got my first car
- Crx weight
- No tachometer!?! WTF
- ek axles fit
- D15B7 head?
- Restrictor Box
- Removing sohc motor 89 si
- D16Y7 S0HC - non vtec
- clutch problems, Plesae help??
- 91 Ef Si swap help.
- OBD1 Distributor help.
- overheating diagnosing
- Quick Drivers seat question!
- Mpfi snafu
- Si axle vs STD one???
- Cheapest 4 door jdm front end????
- Revving? ECU maybe?
- 91 crx b16a problems
- Help me fix my power locks, win money.
- RLCA question.
- It's not an ef but nothing wrong with a EE2
- LS/VTEC running horrible and shooting smoke!
- help in corona riverside area .
- hydro kit
- New here & new to hondas
- squealing from trans
- D Series Axle Question.
- JDM civic hatch front end on to EF Sedan??
- Swap help!! B18c into HF
- ef spring length
- ready for a clutch...
- My 91 CRX, just bought today
- Code 14 crx hf
- I need 88 89 honda civic ef side moldings. prefer them new
- awd wagovan auto to 5 speed?
- LCA compatibility?
- obd0 ls dizzy on single cam?
- da mirrors
- CR-X Windshield
- A Different DPFI to MPFI Conversion Question.
- main relay cliking when on contact
- need help with B16A misfire, no codes
- b16a 1st gen
- Are all D series intake manifold gaskets the same?
- what kind of head can i put?
- Water and vacum hose sizes
- GSR Swapped CRX - CEL 9, 17, 20 - Suggestions?
- chargespeed wing dimensions?
- my Build Thread =) good times
- 5-second question: hub/knuckle
- New to cars and car tech, just bought 1991 honda civic hatchback what to do?
- civic wagon doors/windows fitment
- Hey! I have a CRX!
- No Power...
- Why I love ef Honda's
- connecting rod ?
- riced out rex...can it be saved...
- Inner Fenders - Will hatch inner fenders fit CRX?
- need help
- stupid newbie questions bout the dpfi swap.
- My EF typeR build
- need help!!
- 1988 Hazard Light Issue
- what to do with this Si
- engine harness and interior harness: crx and ef hatch interchangeable?
- Key has to be held to keep engine running?
- PLEASE HELP!!!!!!
- G-man's rear lower tie bar for 88-91 civic
- help with code 12
- 1989 Honda Civic Hatchback Project
- 87 CRX Si
- Squeak from timing belt question
- quick question on headgaskets and timing belts
- squealing noise from transmission
- need help installing visors..
- car only blows warm air
- JDMkid413 ef hatch/ ls vtec build thread
- $4k to spend on engine help!
- b20 block with ls internals?
- Need a Fuse Panel Diagram Picture please
- Wicked vibration in front end
- What shift linkage can i use for hydro clutch for my Ef?
- DPFI to MPFI ?'s
- b20vtec build question
- Ef Swap Help?
- Miguey310's build / 91 civic
- ef8 sir bumper canard/splitter setup?
- bad knock and grind - dies when push clutch
- Just bought a CRX, tell me what you think
- Alternator solenoid fuse popping, what causes this?
- 91 CRX ZC
- Ride Height
- b16a o2 sensors
- Weird Battery Problem (no constant Volts reading)
- Removing factory sound mats
- HELP! EF B-Series trouble
- front lower control arms
- Need rear seat brackets
- >>>Baby Blue 90 Ef<<< MTL LOVE
- ef side skirts
- Fuel problem i guess? 90 Crx si
- transmission fluid and 5th gear whine
- Seat belt harness bars
- ZC CRX
- Did I blow my clutch?
- Crx Si axle back
- ZC Thermostat?
- ZC problem!!!!!
- DX axles on a STD?
- Fuel tank swap?
- please sir just little off the top!!!!
- want to swap a sohc vtec but dont know what i need
- civic doors question
- Continuous blinks from ECU
- Engine timing question!
- Low Compression on all cylinders whats wrong?
- B16A Alternator Question. Your opinions needed
- engine won't rev passed 6k???
- Anyone have experience with racing_guys catback?
- 91' crx - rear wiring diagram
- driver side water leak
- sunroof help
- Intake manifold help!
- Installed new SEAT LOCKS today.
- EF Fog Lights / Retrofitting
- Bergenholtz CRX Inducted in NHRA Museum
- Different timing belts
- stolen 91 civic hatchback
- Car starts then dies
- Eg fog light on ef?
- b18 ef swap cluth question
- car dies at idle with cams
- Rear disc w/o swapping suspension?
- 90 crx si 2 step install?
- New clutch problems...
- EDM/JDM cluster
- Crx D16a6 Engine Harness
- Spark,fuel,and compression wont start after MPFI Con.
- D15B7 Swap Issues, I would really appreciate it if someone could help out.
- EF with b swap intentions questions
- Auto to 5speed swap ???
- si cluster into dx
- timing my rex
- will ek front shocks fit in any way on my 88 hatch?
- D15b cam profile vs D15X
- how many of ya got ac??
- heater ??
- Mini Cams
- Sohc zc dohc zc axles the same?
- what is an a1 transmission
- auto crx tranny issues
- 89 D16A Help
- H&R sports-Need camber kits?
- D16Z6 swap ECU question Help
- d15 build or b16/h22 swap
- EF Tail Light
- shift linkage on a cable tranny?
- What shift linkage for a b16a2 into a crx?
- Smog fail high nox
- 89 EF hatch NO start D16Z6 sWAP ....IDEAS???
- Which distributor???
- B18b backdating to obd1
- no fuel power
- Website for cheap fenders and stuff
- replacing tranny need help
- Jake's ED Hatch Build
- Poor Crx :(
- Civic hb door panels on crx
- 1991 Honda Civic CX HB Auto Center Console Swap?
- oil leak out intermediate shaft any ideas?
- new crx
- 90 Civic LX GSR Swapped - Charging Issues
- Pr3 pistons?
- OBD conversion in a dx hatch
